Hello everyone! I am new to Linux & Manjaro
So I was using Windows 11 and replaced it with Manjaro now everything works fine besides that I have no sound? It seems like my headphones doesnt get detected I had the same issue on Windows BUT on Windows I found a workaround inRealtek Audio Console disabling the “Disable Front Detection” and then everything was working fine. Any idea how to fix this here on Plasma? Ty
Note: When plugging in the Headphones at the back of my PC everything works fine
Welcome to Manjaro forum @RaphaelDeck
To disable headphone jack detection:
Find the audio card number for the onboard audio analog output from:
aplay -l
(most likely to be either card=0 or card=1)
Then install alsa-tools package
pamac install alsa-tools
Run jack-detection tool with headphones plugged in and unplugged
sudo hdajacksensetest --card=0
If responses show: (Green Headphone, Front side): present = No
even when headphones are plugged-in, run the jack re-tasking tool:
sudo hdajackretask --card=0
Enable Advanced override and Override for the Green Headphone, Front side jack
Change Jack Detection to Not Present and click on Install boot override
Reboot system to load jack override
This show in my console “Command not available” even after installing the alsa-tools
typo error, should be:
Worked perfectly thank you so much! Now I can begin exploring Linux for the first time Ty for the fast help!
