Hello,
I just install a new computer, with majaro KDE, but I have no sound. First I was able to see sound icon on dashboard and I was able to see the line output with the sound bar moving, but no sound at all.
I specify, with the same jack cable, same speakers, it’s working perfectly on other computer.
So I decide to install pipewire, to see if it works (I followed this). Unfortunately, the sound still not working and I have no more sound icon on my dashboard. With pavucontrol, I’m able to see my line output : https://i.imgur.com/lO9jtAX.png
inxi -Fazy:
Kernel: 5.10.49-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=bff5c670-64b2-439d-b7fe-a7b1ecede129 rw quiet apparmor=1
security=apparmor udev.log_priority=3 snd_hda_intel.dmic_detect=0
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Micro-Star model: X470 GAMING PLUS MAX (MS-7B79) v: 3.0
serial: <filter> UEFI: American Megatrends v: H.A0 date: 12/15/2020
Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D cache: L2: 3 MiB
bogomips: 81615
Speed: 1509 MHz min/max: 1550/3400 MHz boost: enabled Core speeds (MHz):
1: 1509 2: 3640 3: 1375 4: 1376 5: 1411 6: 1375 7: 1377 8: 1376 9: 1526
10: 2759 11: 1441 12: 1377
disabled, RSB filling
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: Micro-Star MSI
driver: nvidia v: 470.42.01 alternate: nouveau,nvidia_drm bus-ID: 27:00.0
chip-ID: 10de:13c2 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 4920x1920 s-dpi: 101 s-size: 1239x483mm (48.8x19.0")
s-diag: 1330mm (52.4")
Monitor-1: DVI-I-1 res: 1080x1920 hz: 60
Monitor-2: HDMI-0 res: 1920x1080 hz: 60 dpi: 94 size: 521x293mm (20.5x11.5")
diag: 598mm (23.5")
Monitor-3: DP-0 res: 1920x1080 hz: 60 dpi: 92 size: 531x299mm (20.9x11.8")
diag: 609mm (24")
OpenGL: renderer: NVIDIA GeForce GTX 970/PCIe/SSE2 v: 4.6.0 NVIDIA 470.42.01
direct render: Yes
Device-1: NVIDIA GM204 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 27:00.1 chip-ID: 10de:0fbb
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 29:00.3 chip-ID: 1022:1457
class-ID: 0403
Sound Server-1: ALSA v: k5.10.49-1-MANJARO running: yes
Sound Server-2: JACK v: N/A running: no
Sound Server-3: PulseAudio v: 14.2 running: no
Sound Server-4: PipeWire v: 0.3.31 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 22:00.0
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 5 TiB used: 12.37 GiB (0.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: PNY model: CS3030 500GB SSD
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: CS303226 temp: 39.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST31000528AS
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: HP35 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
model: WD Elements 25A3 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B serial: <filter> rev: 1029 scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
used: 12.37 GiB (2.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 50.4 C mobo: N/A gpu: nvidia temp: 58 C
Processes: 321 Uptime: 2m wakeups: 0 Memory: 15.64 GiB
used: 2.72 GiB (17.4%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1261 lib: 359 flatpak: 0 Shell: Bash v: 5.1.8
running-in: yakuake inxi: 3.3.05
