I have a three-monitor display which used to behave as expected when waking from sleep. I built a new system (using same monitors and GPU but reinstalling Manjaro fresh), and hibernation disabled via Fabby’s tutorial on these forums; however, the monitors now get no signal when waking from sleep.
To get the monitors to output again I need to either unplug them and reconnect the DisplayPort cable, or reboot the system. The former causes weird issues like items disappearing from my desktop (notes, etc.), and the latter causes the system to disable the two side monitors in settings on restart.
Additionally, when the system wakes, if I ctrl + alt + F2/3/4/5/6 all three monitors will then wake and display the tty terminal; however, pressing ctrl + alt + F1 shows a frozen image of my desktop on just a single monitor, of which I can blindly interact with (image never updates, but clicking items will execute them).
I was on the 5.13 kernel, but I updated to the 5.15. No change in behavior. I’m using NVIDIA 470.86 drivers. Fairly new to linux, so don’t know what log files exist, or are useful for certain things. Just ask and I’ll supply.
Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=81864a47-ff36-46cf-9fb6-d0417118e994 rw quiet apparmor=1
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-I GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4005
date: 07/13/2021
RAM: total: 62.78 GiB used: 4.52 GiB (7.2%)
RAM Report:
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2879 high: 3441 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2914 2: 2864
3: 2809 4: 2617 5: 3088 6: 2659 7: 2846 8: 2848 9: 3067 10: 2670 11: 2712
12: 2707 13: 3441 14: 2820 15: 2884 16: 3132 bogomips: 121422
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA TU104 [GeForce RTX 2060] vendor: Gigabyte driver: nvidia
v: 470.86 alternate: nouveau,nvidia_drm bus-ID: 0a:00.0 chip-ID: 10de:1e89
class-ID: 0300
Device-2: Logitech HD Webcam C510 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-1:2 chip-ID: 046d:081d class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 2560x1440 s-dpi: 110 s-size: 592x333mm (23.3x13.1")
s-diag: 679mm (26.7")
Monitor-1: DP-4 res: 2560x1440 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
Device-1: NVIDIA TU104 HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 0a:00.1 chip-ID: 10de:10f8 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0c:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Logitech HD Webcam C510 type: USB driver: snd-usb-audio,uvcvideo
Device-4: Plantronics Plantronics GameCom 780 type: USB
driver: plantronics,snd-usb-audio,usbhid bus-ID: 3-2:3 chip-ID: 047f:c010
class-ID: 0300
Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 05:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: f000 bus-ID: 06:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp6s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-6:5
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Supported mdraid levels: raid1
Device-1: md127 maj-min: 9:127 type: mdraid level: mirror status: active
Info: report: 2/2 UU blocks: 1953381376 chunk-size: N/A super-blocks: 1.2
Components: Online:
0: sda1 maj-min: 8:1 size: 1.82 TiB
1: sdb1 maj-min: 8:17 size: 1.82 TiB
Local Storage: total: raw: 9.21 TiB usable: 7.39 TiB used: 160.94 GiB (2.1%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 type: SSD serial: <filter> rev: 3B2QGXA7 temp: 38.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 type: SSD serial: <filter> rev: 3B2QGXA7 temp: 52.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Crucial model: CT2000MX500SSD1
type: SSD serial: <filter> rev: 043 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT2000MX500SSD1
ID-5: /dev/sdc maj-min: 8:32 vendor: PNY model: CS900 120GB SSD
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0615 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 type: USB vendor: Western Digital
model: WD40EZRX-00SPEB0 size: 3.64 TiB block-size: physical: 4096 B
logical: 4096 B type: HDD rpm: 5400 serial: <filter> rev: 1065 scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 76.78 GiB (8.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:4
label: N/A uuid: 81864a47-ff36-46cf-9fb6-d0417118e994
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
label: NO_LABEL uuid: D750-671D
ID-3: /run/timeshift/backup raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 84.15 GiB (4.6%) fs: ext4 dev: /dev/md127 maj-min: 9:127
label: backups-raid uuid: 873508d2-1ece-40c2-a5bb-02233a5854ec
ID-1: swap-1 type: partition size: 111.79 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdc1 maj-min: 8:33 label: N/A
uuid: a977bcd9-c308-499c-87a9-3a0bf8f15f25
ID-1: /dev/nvme1n1p1 maj-min: 259:2 size: 931.51 GiB
fs: <superuser required> label: N/A uuid: N/A
ID-2: /dev/sdd1 maj-min: 8:49 size: 1024 GiB fs: ext4 label: N/A
uuid: b34283de-97d7-4dc5-8c4a-fe5bb01238ed
ID-3: /dev/sdd2 maj-min: 8:50 size: 1.64 TiB fs: ntfs label: N/A
uuid: 41BEF7F16C756141
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-1:2 info: Logitech HD Webcam C510 type: Audio,Video
power: 500mA chip-ID: 046d:081d class-ID: 0e02 serial: <filter>
Device-2: 3-2:3 info: Plantronics Plantronics GameCom 780 type: Audio,HID
driver: plantronics,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 500mA chip-ID: 047f:c010 class-ID: 0300
Device-3: 3-5:4 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
Device-4: 3-6:5 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-7: 7-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 7-3:2 info: Logitech M-BJ58/M-BJ69 Optical Wheel Mouse
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 1.5 Mb/s power: 98mA chip-ID: 046d:c00e class-ID: 0301
Device-2: 7-4:3 info: Dell Keyboard SK-8115 type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 70mA chip-ID: 413c:2003 class-ID: 0301
Hub-8: 8-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 8-2:2 info: Western Digital My Book (WDBFJK) type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 8mA
chip-ID: 1058:1230 class-ID: 0806 serial: <filter>
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 48 C
Processes: 394 Uptime: 38m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1386 lib: 426 flatpak: 0 Shell: Zsh
v: 5.8 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
