cannot delete my own post
must be 40 characters
Welcome to the Manjaro community.
As an infrequent forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements should be checked frequently for important update related information.
These announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
Output of the following command formatted according to forum requirements (see links above) may be useful for those wishing to help:
inxi --admin --verbosity=8 --filter --no-host --width
Be prepared to provide more information and outputs from other commands when asked.
this is probably a bit too restrictive
can you please translate what that sed command does to the output of journalctl into human language? ![]()
… I think I get it, but I’m not sure
I think sudo isn’t needed for journalctl.
I agree, sudo is not needed.
I agree.
Please provide the output of;
journalctl --boot=-1 --priority=3 --catalog --no-pager
and post system information as previously requested.
You might see if System freeze on suspend in the Known Issues and Solutions section of the 2024-10-01 Update announcement to see itf that’s related.
Otherwise, and now with your system information I see you’re using Sway; I’ll defer to others who might have specific information on that Manjaro edition.
Aside:- If you had opted to use the specific inxi command I gave, you might have avoided including serial numbers and other personally identifiable information from the command output.
@Thijxx I’m closing and unlisting this thread as this seems to be what you desire.
PM me if not. ![]()
I need to fix or replace this keyboard.
