my secondary ssd, external hdds and pendrives are not showing up in nautilus
Summary
Kernel: 5.17.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=4f59b2e5-f30a-47a1-9a6c-703575900c84 rw quiet
cryptdevice=UUID=ec4147cc-607a-4361-9830-9da8566b2fe5:luks-ec4147cc-607a-4361-9830-9da8566b2fe5
root=/dev/mapper/luks-ec4147cc-607a-4361-9830-9da8566b2fe5 splash
Desktop: i3 v: 4.20.1 info: i3bar vt: 7 dm: 1: GDM v: 42.0 note: stopped
2: SLiM v: 1.3.6 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Gigabyte product: Z390 AORUS PRO v: N/A
serial: <superuser required>
Mobo: Gigabyte model: Z390 AORUS PRO-CF v: x.x
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: F5
date: 09/05/2018
Info: model: Intel Core i7-8700 bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/4600 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 76831
Type: l1tf
Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: Micro-Star MSI
driver: nvidia v: 510.73.05 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Turing pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1f08 class-ID: 0300
Display: x11 server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1 driver:
X: loaded: nvidia gpu: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 102
size: 476x268mm (18.74x10.55") diag: 546mm (21.51") modes: N/A
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f9
class-ID: 0403
Sound Server-1: ALSA v: k5.17.9-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: no
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Local Storage: total: 1.56 TiB used: 160.02 GiB (10.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS240G2G0B-00EPW0 size: 223.58 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0000
scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Gigabyte model: GP-GSTFS31480GNTD
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 61.3 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate model: BUP Slim
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 1707 scheme: GPT
ID-1: / raw-size: 223.57 GiB size: 219.01 GiB (97.96%)
used: 20.51 GiB (9.4%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-ec4147cc-607a-4361-9830-9da8566b2fe5
System Temperatures: cpu: 27.8 C pch: 43.0 C mobo: N/A gpu: nvidia
temp: 37 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 31%
Processes: 252 Uptime: 1h 14m wakeups: 0 Memory: 31.28 GiB
used: 2.28 GiB (7.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1294 lib: 337 flatpak: 0
Shell: Zsh v: 5.9 running-in: alacritty inxi: 3.3.16
