No packages found in aur and flatpak package sources in fresh manjaro installation
Hi, I just installed a fresh manjaro with the 5.15 kernel.
Everything works perfectly except for the package management:
Neither flatpak nor AUR finds any packages: Searching them for any keyword (firefox for example) returns no results (and no error either).
Running pamac search Google Chrome returns
Failed to query https://aur.archlinux.org/rpc/?v=5&type=search&arg=google from AUR: error 429
I already refreshed to mirrors.
What’s going wrong here?
This means the AUR is rejecting you.
And it isnt client-based because I can still access it through pamac.
But somehow you have been making too many requests. Were you doing anything before this?
I believe this may be relevant:
https://bbs.archlinux.org/viewtopic.php?id=268996
make sure you have enabled the aur in pamac gui
You mean make sure BOTH AUR and Flatpak are enabled in Pamac.
@ishaan2479 @Locutus
I have done that
This is strange since this is a fresh installation! I have not done anything with the aur!
try with yay:
sudo pacman -S base-devel
sudo pacman -S yay
yay -S google-chrome
AUR is unsupported - completely unsupported - and unless you have very compelling reasons - you shouldn’t need AUR.
Installing AUR packaged immediately makes your system unsupported.
Thanks, from a different network it works :slight_smile:
For flatpak I had to remove and readd the flathub package source.
