I have recently come over from Windows, so still accustoming myself to the switch.
I have been unable to get audio from my onboard audio. I’ve been searching the forums, and looking through my audio devices in terminal, but still unsure as to how I can get it working, or what the root of the issue is.
My motherboard (B450M) uses Realtek ALC892.
I’m using the rear line-out with headphones.
In the audio mixer configuration, it only has two options which are not listed as “(unplugged) (unavailable)”, both of which are Digital Stereo, and only let me select the S/PDIF port in the output devices tab. I’m currently just running a bluetooth speaker until I can get the outputs working.
Here’s my pacmd list-cards output.
3 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 6
properties:
alsa.card = "0"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0xfc080000 irq 76"
device.bus_path = "pci-0000:26:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:03.1/0000:26:00.1/sound/card0"
device.bus = "pci"
device.vendor.id = "10de"
device.vendor.name = "NVIDIA Corporation"
device.product.id = "10f0"
device.product.name = "GP104 High Definition Audio Controller"
device.string = "0"
device.description = "GP104 High Definition Audio Controller"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 38668, available: unknown)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (priority 5700, available: no)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-stereo-extra5: Digital Stereo (HDMI 6) Output (priority 5700, available: no)
output:hdmi-surround-extra5: Digital Surround 5.1 (HDMI 6) Output (priority 600, available: no)
output:hdmi-surround71-extra5: Digital Surround 7.1 (HDMI 6) Output (priority 600, available: no)
output:hdmi-stereo-extra6: Digital Stereo (HDMI 7) Output (priority 5700, available: no)
output:hdmi-surround-extra6: Digital Surround 5.1 (HDMI 7) Output (priority 600, available: no)
output:hdmi-surround71-extra6: Digital Surround 7.1 (HDMI 7) Output (priority 600, available: no)
off: Off (priority 0, available: unknown)
active profile: <output:hdmi-stereo>
sinks:
alsa_output.pci-0000_26_00.1.hdmi-stereo/#0: GP104 High Definition Audio Controller Digital Stereo (HDMI)
sources:
alsa_output.pci-0000_26_00.1.hdmi-stereo.monitor/#0: Monitor of GP104 High Definition Audio Controller Digital Stereo (HDMI)
ports:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: yes)
properties:
device.product.name = "PHL 246E7"
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
properties:
hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: no)
properties:
hdmi-output-5: HDMI / DisplayPort 6 (priority 5400, latency offset 0 usec, available: no)
properties:
hdmi-output-6: HDMI / DisplayPort 7 (priority 5300, latency offset 0 usec, available: no)
properties:
index: 2
owner module: 8
properties:
alsa.card = "1"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xfc700000 irq 78"
device.bus_path = "pci-0000:28:00.3"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:28:00.3/sound/card1"
device.bus = "pci"
device.vendor.id = "1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "1457"
device.product.name = "Family 17h (Models 00h-0fh) HD Audio Controller"
device.string = "1"
device.description = "Family 17h (Models 00h-0fh) HD Audio Controller"
profiles:
input:analog-stereo: Analog Stereo Input (priority 65, available: no)
output:analog-stereo: Analog Stereo Output (priority 6500, available: no)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 6565, available: no)
output:analog-surround-21: Analog Surround 2.1 Output (priority 1300, available: no)
output:analog-surround-21+input:analog-stereo: Analog Surround 2.1 Output + Analog Stereo Input (priority 1365, available: no)
output:analog-surround-40: Analog Surround 4.0 Output (priority 1200, available: no)
output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (priority 1265, available: no)
output:analog-surround-41: Analog Surround 4.1 Output (priority 1300, available: no)
output:analog-surround-41+input:analog-stereo: Analog Surround 4.1 Output + Analog Stereo Input (priority 1365, available: no)
output:analog-surround-50: Analog Surround 5.0 Output (priority 1200, available: no)
output:analog-surround-50+input:analog-stereo: Analog Surround 5.0 Output + Analog Stereo Input (priority 1265, available: no)
output:analog-surround-51: Analog Surround 5.1 Output (priority 1300, available: no)
output:analog-surround-51+input:analog-stereo: Analog Surround 5.1 Output + Analog Stereo Input (priority 1365, available: no)
output:iec958-stereo: Digital Stereo (IEC958) Output (priority 38268, available: unknown)
output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958) Output + Analog Stereo Input (priority 5565, available: unknown)
active profile: <output:iec958-stereo+input:analog-stereo>
sinks:
alsa_output.pci-0000_28_00.3.iec958-stereo/#16: Family 17h (Models 00h-0fh) HD Audio Controller Digital Stereo (IEC958)
sources:
alsa_output.pci-0000_28_00.3.iec958-stereo.monitor/#23: Monitor of Family 17h (Models 00h-0fh) HD Audio Controller Digital Stereo (IEC958)
alsa_input.pci-0000_28_00.3.analog-stereo/#24: Family 17h (Models 00h-0fh) HD Audio Controller Analog Stereo
ports:
analog-input-front-mic: Front Microphone (priority 8500, latency offset 0 usec, available: no)
properties:
analog-input-rear-mic: Rear Microphone (priority 8200, latency offset 0 usec, available: no)
properties:
analog-input-linein: Line In (priority 8100, latency offset 0 usec, available: no)
properties:
analog-output-lineout: Line Out (priority 9000, latency offset 0 usec, available: no)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
iec958-stereo-output: Digital Output (S/PDIF) (priority 0, latency offset 0 usec, available: unknown)
properties:
index: 3
driver: <module-bluez5-device.c>
owner module: 30
properties:
device.description = "Karl's Speaker"
device.string = "08:EB:ED:30:B4:7C"
device.api = "bluez"
device.class = "sound"
device.bus = "bluetooth"
device.form_factor = "headset"
bluez.path = "/org/bluez/hci0/dev_08_EB_ED_30_B4_7C"
bluez.class = "0x240404"
bluez.alias = "Karl's Speaker"
device.icon_name = "audio-headset-bluetooth"
device.intended_roles = "phone"
bluetooth.codec = "sbc"
profiles:
a2dp_sink: High Fidelity Playback (A2DP Sink) (priority 40, available: yes)
handsfree_head_unit: Handsfree Head Unit (HFP) (priority 30, available: unknown)
off: Off (priority 0, available: yes)
active profile: <a2dp_sink>
sinks:
bluez_sink.08_EB_ED_30_B4_7C.a2dp_sink/#17: Karl's Speaker
sources:
bluez_sink.08_EB_ED_30_B4_7C.a2dp_sink.monitor/#25: Monitor of Karl's Speaker
ports:
headset-output: Headset (priority 0, latency offset 0 usec, available: yes)
properties:
headset-input: Headset (priority 0, latency offset 0 usec, available: unknown)
properties:
From what I can fathom from above, is that it has everything there, but it’s just not using the ports, or recognising that anything is plugged in. I also tried the front headphone jack with no change.
I have looked through a few topics, and tried to adapt the steps here [AMD] Family 17h (Models 00h-0fh) HD Audio Controller is disabled on LM20, but working on LM19.3 - Linux Mint Forums but to no avail.
Edit: I installed linux515 in the hope it may help, but it’s still the same.
