I got a new HP 15s Laptop and dual booted Manjaro KDE on it. I’ve done it before on a Lenovo Ideapad (Intel) and an ASUS TUF (AMD) with no issues, but on this HP I’m getting a No output or input devices found error for audio. The audio output on Windows isn’t working either. I have sof-firmware
and alsa-ucm-conf
installed. I also created the file /etc/modprobe.d/soundfix.conf
and included
options snd-intel-dspcfg dsp_driver=1
but it didn’t work, so I assume that works only for HP Intel devices. I’d like a solution for this please.
pactl list sources
Source #0
State: SUSPENDED
Description: Monitor of Dummy Output
Driver: module-null-sink.c
Sample Specification: s16le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 16
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor of Sink: auto_null
Latency: 0 usec, configured 0 usec
Flags: DECIBEL_VOLUME LATENCY
Properties:
device.description = "Monitor of Dummy Output"
device.class = "monitor"
Formats:
pcm
inxi -Fxxxx
Host: lotus-manjaro Kernel: 6.1.25-1-MANJARO arch: x86_64 bits: 64
compiler: gcc v: 12.2.1 Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HP product: HP Laptop 15s-eq2xxx v: N/A
Mobo: HP model: 887A v: 59.21 serial: <superuser required> UEFI: AMI
v: F.27 date: 10/20/2022
ID-1: BAT0 charge: 40.7 Wh (100.0%) condition: 40.7/40.7 Wh (100.0%)
volts: 12.5 min: 11.3 model: HP Primary type: Li-ion serial: SerialNumber
status: discharging
Info: 6-core model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64
type: MT MCP smt: enabled arch: Zen 2 rev: 1 cache: L1: 384 KiB L2: 3 MiB
L3: 8 MiB
Speed (MHz): avg: 2421 high: 4033 min/max: 1400/4056 boost: enabled cores:
1: 1796 2: 1684 3: 3942 4: 1981 5: 4033 6: 1400 7: 1784 8: 1769 9: 3947
10: 3798 11: 1473 12: 1455 bogomips: 50322
Device-1: AMD Lucienne vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN-5 pcie: speed: 8 GT/s lanes: 16 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c class-ID: 0300
temp: 53.0 C
Device-2: Chicony HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 04f2:b6f1 class-ID: 0e02 serial: 0001
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: AU Optronics 0x499f res: 1920x1080 dpi: 142
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") modes: max: 1920x1080
min: 640x480
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.49 6.1.25-1-MANJARO) direct-render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: snd_rn_pci_acp3x v: kernel pcie: speed: 8 GT/s lanes: 16
bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.1.25-1-MANJARO status: kernel-api with: aoss
type: oss-emulator
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: off
Server-3: PulseAudio v: 16.1 status: active
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A pcie: speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 01:00.0 chip-ID: 10ec:c822 class-ID: 0280
IF: wlo1 state: up mac: 14:d4:24:ea:b9:49
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 0bda:b00c class-ID: e001 serial: 00e04c000001
Local Storage: total: 476.94 GiB used: 7.63 GiB (1.6%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WD PC SN740
SDDPNQD-512G-1006 size: 476.94 GiB speed: 63.2 Gb/s lanes: 4 type: SSD
serial: 224130806097 rev: HPS3 temp: 35.9 C scheme: GPT
ID-1: / size: 67.7 GiB used: 7.55 GiB (11.2%) fs: ext4 dev: /dev/nvme0n1p6
ID-2: /boot/efi size: 256 MiB used: 86.6 MiB (33.8%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 59.4 C mobo: N/A gpu: amdgpu temp: 53.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 0
Processes: 249 Uptime: 13m wakeups: 2328 Memory: 14.95 GiB
used: 2.02 GiB (13.5%) Init: systemd v: 252 default: graphical Compilers:
gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman pkgs: 1056 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.26
