Thank you so much for the reply. Please check the requested info.
!!ALSA Information Script v 0.5.1
!!Script ran on: Fri Sep 30 01:16:40 UTC 2022
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: Dell Inc.
Product Name: XPS 17 9720
Product Version:
Firmware Version: 1.9.0
System SKU: 0AFF
Board Vendor: Dell Inc.
Board Name: 0W7GHH
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI0003:00/status 15
/sys/bus/acpi/devices/ACPI000C:00/status 15
/sys/bus/acpi/devices/ACPI000E:00/status 15
/sys/bus/acpi/devices/DLLK0AFF:00/status 15
/sys/bus/acpi/devices/INT33A1:00/status 15
/sys/bus/acpi/devices/INT340E:00/status 15
/sys/bus/acpi/devices/INTC1041:00/status 15
/sys/bus/acpi/devices/INTC1046:00/status 15
/sys/bus/acpi/devices/INTC1046:01/status 15
/sys/bus/acpi/devices/INTC1046:02/status 15
/sys/bus/acpi/devices/INTC1046:03/status 15
/sys/bus/acpi/devices/INTC1046:04/status 15
/sys/bus/acpi/devices/INTC1046:05/status 15
/sys/bus/acpi/devices/INTC1055:00/status 15
/sys/bus/acpi/devices/INTC1070:00/status 15
/sys/bus/acpi/devices/INTC1099:00/status 15
/sys/bus/acpi/devices/LNXPOWER:00/status 1
/sys/bus/acpi/devices/LNXPOWER:01/status 1
/sys/bus/acpi/devices/LNXPOWER:02/status 1
/sys/bus/acpi/devices/LNXPOWER:03/status 1
/sys/bus/acpi/devices/LNXPOWER:04/status 1
/sys/bus/acpi/devices/LNXVIDEO:00/status 15
/sys/bus/acpi/devices/NVDA0820:00/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0C02:02/status 8
/sys/bus/acpi/devices/PNP0C02:04/status 3
/sys/bus/acpi/devices/PNP0C02:05/status 3
/sys/bus/acpi/devices/PNP0C09:00/status 15
/sys/bus/acpi/devices/PNP0C0A:00/status 31
/sys/bus/acpi/devices/PRP00001:00/status 11
/sys/bus/acpi/devices/PRP00001:01/status 11
/sys/bus/acpi/devices/STM0125:00/status 15
/sys/bus/acpi/devices/USBC000:00/status 15
/sys/bus/acpi/devices/VEN_04F3:00/status 15
/sys/bus/acpi/devices/device:01/status 15
/sys/bus/acpi/devices/device:03/status 15
/sys/bus/acpi/devices/device:04/status 15
/sys/bus/acpi/devices/device:0e/status 15
/sys/bus/acpi/devices/device:a1/status 15
/sys/bus/acpi/devices/device:a9/status 15
/sys/bus/acpi/devices/device:aa/status 15
/sys/bus/acpi/devices/device:ab/status 15
/sys/bus/acpi/devices/device:ad/status 15
/sys/bus/acpi/devices/device:ae/status 15
/sys/bus/acpi/devices/device:af/status 15
!!Kernel Information
Kernel release: 5.15.65-1-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.15.65-1-MANJARO
Library version: 1.2.7.2
Utilities version: 1.2.7
!!Loaded ALSA modules
snd_hda_intel (card 0)
snd_hda_intel (card 1)
!!Sound Servers on this system
PipeWire:
Installed - Yes (/usr/bin/pipewire)
Running - Yes
No sound servers found.
!!Soundcards recognised by ALSA
0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0x6291240000 irq 231
1 [NVidia ]: HDA-Intel - HDA NVidia
HDA NVidia at 0xad000000 irq 17
!!PCI Soundcards installed in the system
0000:00:1f.3 Multimedia audio controller [0401]: Intel Corporation Alder Lake PCH-P High Definition Audio Controller [8086:51c8] (rev 01)
Subsystem: Dell Device [1028:0aff]
0000:01:00.1 Audio device [0403]: NVIDIA Corporation GA106 High Definition Audio Controller [10de:228e] (rev a1)
!!Modprobe options (Sound related)
snd_intel_dspcfg: dsp_driver=1
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 1
power_save_controller : Y
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
dmic_detect : Y
enable_msi : -1
pm_blacklist : Y
power_save : 1
single_cmd : -1
snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
!!Card: /sys/class/sound/card1
Tree:
!!HDA-Intel Codec information
--startcollapse--
Codec: Intel Alderlake-P HDMI
Address: 2
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x8086281c
Subsystem Id: 0x80860101
Revision Id: 0x100000
No Modem Function Group found
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
Converter: stream=0, channel=0
Digital: Enabled GenLevel
Digital category: 0x2
IEC Coding Type: 0x0
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
bits [0x1a]: 16 24 32
formats [0x5]: PCM AC3
Power states: D0 D3 EPSS
Node 0x04 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x00 0x00]
Pincap 0x09000094: OUT Detect HBR HDMI DP
Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
DefAssociation = 0x1, Sequence = 0x0
Pin-ctls: 0x00:
Unsolicited: tag=00, enabled=0
Devices: 0
Connection: 0
Node 0x05 [Audio Output] wcaps 0x6611: 8-Channels Digital
Digital: Enabled
Digital category: 0x0
PCM:
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x07 [Audio Output] wcaps 0x6611: 8-Channels Digital
Digital: Enabled
PCM:
Node 0x08 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x09 [Audio Output] wcaps 0x6611: 8-Channels Digital
Digital: Enabled
PCM:
Node 0x0a [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0b [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0c [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0d [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0e [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x0f [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Codec: Nvidia GPU 9f HDMI/DP
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10de009f
Subsystem Id: 0x10280aff
Revision Id: 0x100100
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Power states: D0 D1 D2 D3 CLKSTOP EPSS
Node 0x04 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin Default 0x185600f0: [Jack] Digital Out at Int HDMI
DefAssociation = 0xf, Sequence = 0x0
Pin-ctls: 0x00:
Devices: 4
Dev 00: PD = 0, ELDV = 0, IA = 0, Connections [ 0x08* 0x09 0x0a 0x0b ]
Dev 01: PD = 0, ELDV = 0, IA = 0, Connections [ 0x08* 0x09 0x0a 0x0b ]
Dev 02: PD = 0, ELDV = 0, IA = 0, Connections [ 0x08* 0x09 0x0a 0x0b ]
*Dev 03: PD = 0, ELDV = 0, IA = 0, Connections [ 0x08* 0x09 0x0a 0x0b ]
Connection: 4
Node 0x05 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Devices: 4
Connection: 4
Node 0x06 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Devices: 4
Connection: 4
Node 0x07 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Devices: 4
Connection: 4
Node 0x08 [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
bits [0xe]: 16 20 24
Node 0x09 [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x0a [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x0b [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
--endcollapse--
!!ALSA Device nodes
crw-rw---- 1 root audio 116, 24 Sep 26 13:17 /dev/snd/controlC0
crw-rw---- 1 root audio 116, 10 Sep 26 13:17 /dev/snd/controlC1
crw-rw---- 1 root audio 116, 23 Sep 26 13:17 /dev/snd/hwC0D2
crw-rw---- 1 root audio 116, 9 Sep 26 13:17 /dev/snd/hwC1D0
crw-rw---- 1 root audio 116, 15 Sep 26 13:18 /dev/snd/pcmC0D10p
crw-rw---- 1 root audio 116, 16 Sep 26 13:18 /dev/snd/pcmC0D11p
crw-rw---- 1 root audio 116, 17 Sep 26 13:18 /dev/snd/pcmC0D12p
crw-rw---- 1 root audio 116, 18 Sep 26 13:18 /dev/snd/pcmC0D13p
crw-rw---- 1 root audio 116, 19 Sep 26 13:18 /dev/snd/pcmC0D14p
crw-rw---- 1 root audio 116, 20 Sep 26 13:18 /dev/snd/pcmC0D15p
crw-rw---- 1 root audio 116, 21 Sep 26 13:18 /dev/snd/pcmC0D16p
crw-rw---- 1 root audio 116, 22 Sep 26 13:18 /dev/snd/pcmC0D17p
crw-rw---- 1 root audio 116, 11 Sep 26 17:41 /dev/snd/pcmC0D3p
crw-rw---- 1 root audio 116, 12 Sep 26 16:34 /dev/snd/pcmC0D7p
crw-rw---- 1 root audio 116, 13 Sep 26 13:18 /dev/snd/pcmC0D8p
crw-rw---- 1 root audio 116, 14 Sep 26 13:18 /dev/snd/pcmC0D9p
crw-rw---- 1 root audio 116, 6 Sep 26 13:18 /dev/snd/pcmC1D10p
crw-rw---- 1 root audio 116, 7 Sep 26 13:18 /dev/snd/pcmC1D11p
crw-rw---- 1 root audio 116, 8 Sep 26 13:18 /dev/snd/pcmC1D12p
crw-rw---- 1 root audio 116, 2 Sep 26 13:18 /dev/snd/pcmC1D3p
crw-rw---- 1 root audio 116, 3 Sep 26 13:18 /dev/snd/pcmC1D7p
crw-rw---- 1 root audio 116, 4 Sep 26 13:18 /dev/snd/pcmC1D8p
crw-rw---- 1 root audio 116, 5 Sep 26 13:18 /dev/snd/pcmC1D9p
crw-rw---- 1 root audio 116, 1 Sep 26 13:17 /dev/snd/seq
crw-rw---- 1 root audio 116, 33 Sep 26 13:17 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 80 Sep 26 13:17 .
drwxr-xr-x 3 root root 560 Sep 26 13:17 ..
lrwxrwxrwx 1 root root 12 Sep 26 13:17 pci-0000:00:1f.3 -> ../controlC0
lrwxrwxrwx 1 root root 12 Sep 26 13:17 pci-0000:01:00.1 -> ../controlC1
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 12: HDMI 6 [HDMI 6]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 13: HDMI 7 [HDMI 7]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 14: HDMI 8 [HDMI 8]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 15: HDMI 9 [HDMI 9]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 16: HDMI 10 [HDMI 10]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 17: HDMI 11 [HDMI 11]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 12: HDMI 6 [HDMI 6]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
!!Amixer output
!!-------Mixer controls for card PCH
Card sysdefault:0 'PCH'/'HDA Intel PCH at 0x6291240000 irq 231'
Mixer name : 'Intel Alderlake-P HDMI'
Components : 'HDA:8086281c,80860101,00100000'
Controls : 84
Simple ctrls : 12
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
Simple mixer control 'IEC958',4
Mono: Playback [on]
Simple mixer control 'IEC958',5
Mono: Playback [on]
Simple mixer control 'IEC958',6
Mono: Playback [on]
Simple mixer control 'IEC958',7
Mono: Playback [on]
Simple mixer control 'IEC958',8
Mono: Playback [on]
Simple mixer control 'IEC958',9
Mono: Playback [on]
Simple mixer control 'IEC958',10
Mono: Playback [on]
Simple mixer control 'IEC958',11
Mono: Playback [on]
!!-------Mixer controls for card NVidia
Card sysdefault:1 'NVidia'/'HDA NVidia at 0xad000000 irq 17'
Mixer name : 'Nvidia GPU 9f HDMI/DP'
Components : 'HDA:10de009f,10280aff,00100100'
Controls : 49
Simple ctrls : 7
Mono: Playback [on]
Mono: Playback [on]
Mono: Playback [on]
Mono: Playback [on]
Mono: Playback [on]
Mono: Playback [on]
Mono: Playback [on]
!!Alsactl output
--startcollapse--
state.PCH {
control.1 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
name 'IEC958 Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
value ''
comment {
access 'read volatile'
type BYTES
count 0
control.7 {
iface CARD
name 'HDMI/DP,pcm=7 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.8 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.9 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.11 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.13 {
iface CARD
name 'HDMI/DP,pcm=8 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.14 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.15 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.16 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.17 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.18 {
iface PCM
device 8
name ELD
value ''
comment {
type BYTES
count 0
control.19 {
iface CARD
name 'HDMI/DP,pcm=9 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.20 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.21 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.22 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.23 {
iface MIXER
index 3
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.24 {
iface PCM
device 9
name ELD
value ''
comment {
type BYTES
count 0
control.25 {
iface CARD
name 'HDMI/DP,pcm=10 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.26 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.27 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.28 {
iface MIXER
index 4
comment {
access 'read write'
type IEC958
count 1
control.29 {
iface MIXER
index 4
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.30 {
iface PCM
device 10
name ELD
value ''
comment {
type BYTES
count 0
control.31 {
iface CARD
name 'HDMI/DP,pcm=11 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.32 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.33 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.34 {
iface MIXER
index 5
comment {
access 'read write'
type IEC958
count 1
control.35 {
iface MIXER
index 5
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.36 {
iface PCM
device 11
name ELD
value ''
comment {
type BYTES
count 0
control.37 {
iface CARD
name 'HDMI/DP,pcm=12 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.38 {
iface MIXER
index 6
comment {
access read
type IEC958
count 1
control.39 {
iface MIXER
index 6
comment {
access read
type IEC958
count 1
control.40 {
iface MIXER
index 6
comment {
access 'read write'
type IEC958
count 1
control.41 {
iface MIXER
index 6
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.42 {
iface PCM
device 12
name ELD
value ''
comment {
type BYTES
count 0
control.43 {
iface CARD
name 'HDMI/DP,pcm=13 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.44 {
iface MIXER
index 7
comment {
access read
type IEC958
count 1
control.45 {
iface MIXER
index 7
comment {
access read
type IEC958
count 1
control.46 {
iface MIXER
index 7
comment {
access 'read write'
type IEC958
count 1
control.47 {
iface MIXER
index 7
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.48 {
iface PCM
device 13
name ELD
value ''
comment {
type BYTES
count 0
control.49 {
iface CARD
name 'HDMI/DP,pcm=14 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.50 {
iface MIXER
index 8
comment {
access read
type IEC958
count 1
control.51 {
iface MIXER
index 8
comment {
access read
type IEC958
count 1
control.52 {
iface MIXER
index 8
comment {
access 'read write'
type IEC958
count 1
control.53 {
iface MIXER
index 8
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.54 {
iface PCM
device 14
name ELD
value ''
comment {
type BYTES
count 0
control.55 {
iface CARD
name 'HDMI/DP,pcm=15 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.56 {
iface MIXER
index 9
comment {
access read
type IEC958
count 1
control.57 {
iface MIXER
index 9
comment {
access read
type IEC958
count 1
control.58 {
iface MIXER
index 9
comment {
access 'read write'
type IEC958
count 1
control.59 {
iface MIXER
index 9
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.60 {
iface PCM
device 15
name ELD
value ''
comment {
type BYTES
count 0
control.61 {
iface CARD
name 'HDMI/DP,pcm=16 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.62 {
iface MIXER
index 10
comment {
access read
type IEC958
count 1
control.63 {
iface MIXER
index 10
comment {
access read
type IEC958
count 1
control.64 {
iface MIXER
index 10
comment {
access 'read write'
type IEC958
count 1
control.65 {
iface MIXER
index 10
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.66 {
iface PCM
device 16
name ELD
value ''
comment {
type BYTES
count 0
control.67 {
iface CARD
name 'HDMI/DP,pcm=17 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.68 {
iface MIXER
index 11
comment {
access read
type IEC958
count 1
control.69 {
iface MIXER
index 11
comment {
access read
type IEC958
count 1
control.70 {
iface MIXER
index 11
comment {
access 'read write'
type IEC958
count 1
control.71 {
iface MIXER
index 11
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.72 {
iface PCM
device 17
name ELD
value ''
comment {
type BYTES
count 0
control.73 {
iface PCM
device 3
name 'Playback Channel Map'
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.74 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.75 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.76 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.77 {
iface PCM
device 10
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.78 {
iface PCM
device 11
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.79 {
iface PCM
device 12
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.80 {
iface PCM
device 13
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.81 {
iface PCM
device 14
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.82 {
iface PCM
device 15
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.83 {
iface PCM
device 16
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.84 {
iface PCM
device 17
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
state.NVidia {
control.1 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
value ''
comment {
type BYTES
count 0
control.7 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.8 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.9 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.11 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.13 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.14 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.15 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.16 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.17 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.18 {
iface PCM
device 8
name ELD
value ''
comment {
type BYTES
count 0
control.19 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.20 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.21 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.22 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.23 {
iface MIXER
index 3
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.24 {
iface PCM
device 9
name ELD
value ''
comment {
type BYTES
count 0
control.25 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.26 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.27 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.28 {
iface MIXER
index 4
comment {
access 'read write'
type IEC958
count 1
control.29 {
iface MIXER
index 4
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.30 {
iface PCM
device 10
name ELD
value ''
comment {
type BYTES
count 0
control.31 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.32 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.33 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.34 {
iface MIXER
index 5
comment {
access 'read write'
type IEC958
count 1
control.35 {
iface MIXER
index 5
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.36 {
iface PCM
device 11
name ELD
value ''
comment {
type BYTES
count 0
control.37 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.38 {
iface MIXER
index 6
comment {
access read
type IEC958
count 1
control.39 {
iface MIXER
index 6
comment {
access read
type IEC958
count 1
control.40 {
iface MIXER
index 6
comment {
access 'read write'
type IEC958
count 1
control.41 {
iface MIXER
index 6
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.42 {
iface PCM
device 12
name ELD
value ''
comment {
type BYTES
count 0
control.43 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.44 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.45 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.46 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.47 {
iface PCM
device 10
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.48 {
iface PCM
device 11
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.49 {
iface PCM
device 12
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
--endcollapse--
!!All Loaded Modules
ac97_bus
acpi_pad
acpi_tad
acpi_thermal_rel
aesni_intel
af_alg
algif_hash
algif_skcipher
atkbd
bluetooth
bnep
btbcm
btintel
btrtl
btusb
ccm
cfg80211
cmac
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cros_ec
cros_ec_ishtp
cryptd
crypto_simd
crypto_user
dcdbas
dell_laptop
dell_smbios
dell_wmi
dell_wmi_descriptor
dell_wmi_sysman
drm_ttm_helper
ecdh_generic
ext4
fat
firmware_attributes_class
fuse
ghash_clmulni_intel
hid_multitouch
hid_sensor_als
hid_sensor_custom
hid_sensor_hub
hid_sensor_iio_common
hid_sensor_trigger
i2c_hid
i2c_hid_acpi
i2c_i801
i2c_smbus
i8042
i915
iTCO_vendor_support
iTCO_wdt
idma64
igen6_edac
industrialio
industrialio_triggered_buffer
int3400_thermal
int3403_thermal
int340x_thermal_zone
intel_cstate
intel_gtt
intel_hid
intel_ish_ipc
intel_ishtp
intel_ishtp_hid
intel_ishtp_loader
intel_lpss
intel_lpss_pci
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_spi
intel_spi_pci
intel_tcc_cooling
intel_uncore
ip_tables
irqbypass
iwlmvm
iwlwifi
jbd2
joydev
kfifo_buf
kvm
kvm_intel
ledtrig_audio
libarc4
libps2
loop
mac80211
mac_hid
mbcache
mc
mei
mei_hdcp
mei_me
mmc_core
mousedev
mtd
mxm_wmi
nouveau
ns
pcspkr
processor_thermal_device
processor_thermal_device_pci
processor_thermal_mbox
processor_thermal_rapl
processor_thermal_rfim
qrtr
rapl
rfcomm
rfkill
rng_core
roles
rtsx_pci
rtsx_pci_sdmmc
serio
serio_raw
sg
snd
snd_compress
snd_hda_codec
snd_hda_codec_hdmi
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hrtimer
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_pcm_dmaengine
snd_seq
snd_seq_device
snd_seq_dummy
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_hdac_hda
snd_sof
snd_sof_intel_hda
snd_sof_intel_hda_common
snd_sof_pci
snd_sof_pci_intel_tgl
snd_sof_xtensa_dsp
snd_timer
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
sparse_keymap
spi_nor
squashfs
thunderbolt
tpm
tpm_crb
tpm_tis
tpm_tis_core
ttm
typec
typec_ucsi
ucsi_acpi
uhid
uinput
usbhid
uvcvideo
vfat
video
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
vmd
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xhci_pci
!!Sysfs Files
/sys/class/sound/hwC0D2/init_pin_configs:
0x04 0x18560010
0x06 0x18560010
0x08 0x18560010
0x0a 0x18560010
0x0b 0x18560010
0x0c 0x18560010
0x0d 0x18560010
0x0e 0x18560010
0x0f 0x18560010
/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC0D2/hints:
/sys/class/sound/hwC1D0/init_pin_configs:
0x04 0x185600f0
0x05 0x185600f0
0x06 0x185600f0
0x07 0x185600f0
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
!!ALSA/HDA dmesg
[209185.610770] WARNING: CPU: 9 PID: 46292 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush 0xf6/0x100 [nouveau]
[209185.610834] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[209185.610866] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[209185.610902] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[209185.668027] WARNING: CPU: 9 PID: 46292 at drivers/gpu/drm/nouveau/nvkm/subdev/mmu/vmmtu102.c:43 tu102_vmm_flush 0x161/0x170 [nouveau]
[209185.668081] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[209185.668106] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[209185.668132] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[209185.724914] WARNING: CPU: 9 PID: 46292 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush 0xf6/0x100 [nouveau]
[209185.724964] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[209185.724987] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[209185.725012] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[209185.783598] WARNING: CPU: 9 PID: 46292 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush 0xf6/0x100 [nouveau]
[209185.783683] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[209185.783729] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[209185.783778] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[209185.841217] WARNING: CPU: 9 PID: 46292 at drivers/gpu/drm/nouveau/nvkm/subdev/mmu/vmmtu102.c:43 tu102_vmm_flush 0x161/0x170 [nouveau]
[209185.841305] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[209185.841353] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[209185.841407] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[209185.898520] WARNING: CPU: 9 PID: 46292 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush 0xf6/0x100 [nouveau]
[209185.898571] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[209185.898598] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[209185.898629] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[209185.955601] WARNING: CPU: 9 PID: 46292 at drivers/gpu/drm/nouveau/nvkm/subdev/mmu/vmmtu102.c:43 tu102_vmm_flush 0x161/0x170 [nouveau]
[209185.955658] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[209185.955678] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[209185.955701] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[209186.012478] WARNING: CPU: 9 PID: 46292 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush 0xf6/0x100 [nouveau]
[209186.012527] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[209186.012549] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[209186.012573] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[209186.070260] WARNING: CPU: 9 PID: 46292 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush 0xf6/0x100 [nouveau]
[209186.070312] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[209186.070336] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[209186.070361] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[209186.127052] WARNING: CPU: 9 PID: 46292 at drivers/gpu/drm/nouveau/nvkm/subdev/mmu/vmmtu102.c:43 tu102_vmm_flush 0x161/0x170 [nouveau]
[209186.127104] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[209186.127122] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[209186.127141] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[267564.886660] WARNING: CPU: 8 PID: 61375 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush 0xf6/0x100 [nouveau]
[267564.886713] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[267564.886742] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[267564.886772] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[267564.943957] WARNING: CPU: 2 PID: 61375 at drivers/gpu/drm/nouveau/nvkm/subdev/mmu/vmmtu102.c:43 tu102_vmm_flush 0x161/0x170 [nouveau]
[267564.944029] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[267564.944054] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[267564.944080] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[267565.000952] WARNING: CPU: 2 PID: 61375 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush 0xf6/0x100 [nouveau]
[267565.001024] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[267565.001055] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[267565.001085] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[267565.059305] WARNING: CPU: 2 PID: 61375 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush 0xf6/0x100 [nouveau]
[267565.059376] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[267565.059408] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[267565.059443] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[267565.116205] WARNING: CPU: 2 PID: 61375 at drivers/gpu/drm/nouveau/nvkm/subdev/mmu/vmmtu102.c:43 tu102_vmm_flush 0x161/0x170 [nouveau]
[267565.116269] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[267565.116288] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[267565.116307] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[267565.172902] WARNING: CPU: 2 PID: 61375 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush 0xf6/0x100 [nouveau]
[267565.172954] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[267565.172977] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[267565.173002] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[267565.229934] WARNING: CPU: 2 PID: 61375 at drivers/gpu/drm/nouveau/nvkm/subdev/mmu/vmmtu102.c:43 tu102_vmm_flush 0x161/0x170 [nouveau]
[267565.229991] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[267565.230010] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[267565.230029] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[267565.286777] WARNING: CPU: 2 PID: 61375 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush 0xf6/0x100 [nouveau]
[267565.286836] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[267565.286862] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[267565.286890] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[267565.344732] WARNING: CPU: 2 PID: 61375 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush 0xf6/0x100 [nouveau]
[267565.344796] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[267565.344827] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[267565.344854] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[267565.401598] WARNING: CPU: 2 PID: 61375 at drivers/gpu/drm/nouveau/nvkm/subdev/mmu/vmmtu102.c:43 tu102_vmm_flush 0x161/0x170 [nouveau]
[267565.401669] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[267565.401698] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[267565.401731] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[280444.389727] WARNING: CPU: 4 PID: 64213 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush 0xf6/0x100 [nouveau]
[280444.389780] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[280444.389809] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[280444.389841] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[280444.446831] WARNING: CPU: 4 PID: 64213 at drivers/gpu/drm/nouveau/nvkm/subdev/mmu/vmmtu102.c:43 tu102_vmm_flush 0x161/0x170 [nouveau]
[280444.446884] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[280444.446907] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[280444.446930] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[280444.503697] WARNING: CPU: 4 PID: 64213 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush 0xf6/0x100 [nouveau]
[280444.503750] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[280444.503772] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[280444.503796] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[280444.561890] WARNING: CPU: 4 PID: 64213 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush 0xf6/0x100 [nouveau]
[280444.561941] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[280444.561968] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[280444.561998] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[280444.618709] WARNING: CPU: 4 PID: 64213 at drivers/gpu/drm/nouveau/nvkm/subdev/mmu/vmmtu102.c:43 tu102_vmm_flush 0x161/0x170 [nouveau]
[280444.618781] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[280444.618804] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[280444.618832] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[280444.675404] WARNING: CPU: 4 PID: 64213 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush 0xf6/0x100 [nouveau]
[280444.675480] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[280444.675517] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[280444.675556] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[280444.732660] WARNING: CPU: 4 PID: 64213 at drivers/gpu/drm/nouveau/nvkm/subdev/mmu/vmmtu102.c:43 tu102_vmm_flush 0x161/0x170 [nouveau]
[280444.732723] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[280444.732746] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[280444.732770] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[280444.789533] WARNING: CPU: 4 PID: 64213 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush 0xf6/0x100 [nouveau]
[280444.789585] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[280444.789607] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[280444.789630] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[280444.847330] WARNING: CPU: 4 PID: 64213 at drivers/gpu/drm/nouveau/nvkm/subdev/bar/g84.c:35 g84_bar_flush 0xf6/0x100 [nouveau]
[280444.847383] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[280444.847408] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[280444.847435] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
[280444.904129] WARNING: CPU: 4 PID: 64213 at drivers/gpu/drm/nouveau/nvkm/subdev/mmu/vmmtu102.c:43 tu102_vmm_flush 0x161/0x170 [nouveau]
[280444.904181] Modules linked in: ccm usbhid snd_seq_dummy snd_hrtimer snd_seq snd_seq_device rfcomm uhid cmac algif_hash algif_skcipher af_alg hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio hid_sensor_custom bnep hid_sensor_hub cros_ec_ishtp cros_ec intel_ishtp_loader iTCO_wdt intel_pmc_bxt iTCO_vendor_support intel_ishtp_hid joydev mousedev hid_multitouch mei_hdcp intel_rapl_msr dell_wmi_sysman firmware_attributes_class btusb btrtl btbcm wmi_bmof btintel bluetooth ecdh_generic dell_laptop dell_wmi dell_smbios dell_wmi_descriptor dcdbas intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl intel_cstate intel_uncore pcspkr snd_sof_pci_intel_tgl snd_sof_intel_hda_common iwlmvm soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp mac80211 snd_sof
[280444.904199] snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus ledtrig_audio libarc4 snd_soc_core intel_spi_pci iwlwifi intel_spi spi_nor snd_compress ac97_bus mtd i2c_i801 snd_pcm_dmaengine i2c_smbus uvcvideo mei_me thunderbolt videobuf2_vmalloc mei videobuf2_memops cfg80211 snd_hda_codec_hdmi videobuf2_v4l2 intel_lpss_pci videobuf2_common snd_hda_intel intel_lpss snd_intel_dspcfg i915 idma64 videodev snd_intel_sdw_acpi snd_hda_codec processor_thermal_device_pci processor_thermal_device mc snd_hda_core processor_thermal_rfim processor_thermal_mbox snd_hwdep intel_ish_ipc processor_thermal_rapl intel_ishtp snd_pcm tpm_crb intel_rapl_common nouveau intel_gtt snd_timer tpm_tis ucsi_acpi snd tpm_tis_core typec_ucsi mxm_wmi tpm typec soundcore drm_ttm_helper ttm igen6_edac rng_core roles wmi mac_hid i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone video squashfs intel_hid sparse_keymap loop qrtr int3400_thermal rfkill ns acpi_thermal_rel acpi_tad
[280444.904218] acpi_pad vfat fat uinput sg fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 i8042 crc32c_intel vmd rtsx_pci xhci_pci serio
