This is my first post here so please forgive any mistakes.
My installation has been working just fine for a couple of months now, but this week for some reason, the sound just stopped working, after some tweaking I think i found the problem.
The main issue here is the motherboard model, my motherboard is a asus a320m -k/br, and for some reason both here and in the audio panel it says prime b450m-a.
Is there a way to fix this without having to do a fresh install of the os?
I’ve tried updating the bios, booting from a flash drive with a different os, using pavucontrol-qt doesn’t show any output available.
typing “inxi -Aa” this comes out
Audio: Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: ASUSTeK PRIME B450M-A
driver: snd_hda_intel v: kernel bus-ID: 07:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK PRIME B450M-A driver: snd_hda_intel
v: kernel bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.14.18-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
Edit. I’m trying to use the analog front audio ports, I use the vga out, so hdmi audio is not an option.
