Hi everyone, I recently installed Manjaro (stable) on my new laptop (Inspiron 14 5420) and the speakers/audio jack devices are not detected under sound settings (just dummy device). Bluetooth audio is working fine. I also apologize if the solution is obvious, I’m pretty new to linux. TIA
inxi -Fazy:
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=36ffddd6-8d4b-4e49-88e1-f1c7100bd499 rw quiet
resume=UUID=4460ea1d-42b2-4229-bbdc-8423fd2e9dc6 udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Inspiron 14 5420 v: N/A
Mobo: Dell model: 0KTFJN v: A00 serial: <superuser required> UEFI: Dell
v: 1.4.1 date: 06/06/2022
ID-1: BAT0 charge: 54.0 Wh (100.0%) condition: 54.0/54.0 Wh (100.0%)
volts: 17.5 min: 15.0 model: COM DELL MVK1126 type: Li-poly serial: <filter>
status: full
Info: model: 12th Gen Intel Core i7-1255U bits: 64 type: MST AMCP
arch: Alder Lake built: 2021 process: Intel 7 (10nm ESF) family: 6
model-id: 0x9A (154) stepping: 4 microcode: 0x421
Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 902 high: 1647 min/max: 400/4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 904 2: 904 3: 703 4: 529
5: 675 6: 1236 7: 1647 8: 830 9: 970 10: 810 11: 924 12: 695
bogomips: 62688
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel vendor: Dell driver: i915 v: kernel arch: Gen-12.2
process: Intel 10nm built: 2021-22+ ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0000:00:02.0 chip-ID: 8086:46a8
class-ID: 0300
Device-2: Microdia Integrated_Webcam_FHD type: USB driver: uvcvideo
bus-ID: 3-6:3 chip-ID: 0c45:6739 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
s-diag: 599mm (23.57")
Monitor-1: eDP-1 model: BOE Display 0x0a2a built: 2021 res: 1920x1200
hz: 60 dpi: 161 gamma: 1.2 size: 302x188mm (11.89x7.4") diag: 356mm (14")
ratio: 16:10 modes: 1920x1200
OpenGL: renderer: Mesa Intel Graphics (ADL GT2) v: 4.6 Mesa 22.1.6
direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:4
chip-ID: 8087:0033 class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 27.26 GiB (5.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KDI model: OM3PDP3-AD NVMe 512GB
lanes: 4 type: SSD serial: <filter> rev: 10100002 temp: 42.9 C scheme: GPT
ID-1: / raw-size: 459.79 GiB size: 451.5 GiB (98.20%) used: 27.26 GiB (6.0%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 16.85 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 43.0 C mobo: N/A
Processes: 276 Uptime: 3m wakeups: 591 Memory: 15.32 GiB used: 2.19 GiB
(14.3%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.1.1 clang: 14.0.6 Packages: pacman: 1184 lib: 320 flatpak: 0
Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.20
