After some recent updates I lost the ability to play sound through my laptop’s default speakers, the headphone output doesn’t work either. Only thanks to the external usb DAC am I able to hear anything, external usb microphone also works just fine.
With no DAC plugged there are no controls for the output at all. The default input is there, but it works much worse than before, it’s like the sensitivity was turned all the way up, so the noise is unbearable.
I tried reinstalling pipewire and pulseaudio, but to no avail.
inxi -Aa:
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
Sound Server-1: ALSA v: k5.15.59-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.56 running: yes
alsa-info.sh --upload:
http://alsa-project.org/db/?f=e2527c43b6c8083976fce9fe78a28710b50686e0
