After installation try running:
manjaro-chroot -a
update-grub
Does it find the Installation?
manjaro-chroot -a
update-grub
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
==> Detected systems:
--> 0) Windows
--> 1) Windows1
--> 2) ManjaroLinux
==> Select system to mount [0-2] :
I think /dev/sdb1 is the install drive
Type 2 and enter.
Correct
[manjaro-gnome /]# update-grub
Found linux image: /boot/vmlinuz-5.8-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.8-x86_64.img
Found initrd fallback image: /boot/initramfs-5.8-x86_64-fallback.img
Found Windows 10 on /dev/sda1
Found Windows 10 on /dev/sda2
done
I didn’t reinstall it again.
So here is everything correct.
It has to do with your BIOS then.
Do I have to go into my BIOS setup?
Yes, guess it is the boot order then… idk.
Welp, I reset my BIOS settings to default and that did nothing AFAIK since the issue is still there.
Just a thought, but maybe your BIOS need a primary boot partition? Your root partition is a logical one now, which contains /boot…
Also please post your system:
inxi -Fazy
Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
misobasedir=manjaro misolabel=MANJARO_GNOME_2012 quiet systemd.show_status=1
apparmor=1 security=apparmor
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Type: Laptop System: Hewlett-Packard product: HP ProBook 450 G2
v: A3009DD10203 serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Hewlett-Packard model: 2248 v: KBC Version 67.22 serial: <filter>
BIOS: Hewlett-Packard v: M74 Ver. 01.04 date: 08/16/2014
ID-1: BAT0 charge: 24.4 Wh condition: 25.3/25.3 Wh (100%) volts: 17.0/14.8
model: Hewlett-Packard Primary type: Li-ion serial: <filter> status: Unknown
Topology: Dual Core model: Intel Core i5-4210U bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 45 (69) stepping: 1 microcode: 26
L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 19166
Speed: 1786 MHz min/max: 800/2700 MHz Core speeds (MHz): 1: 1746 2: 1707
3: 1892 4: 1939
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Hewlett-Packard
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0a16
Device-2: Cheng Uei Precision Industry (Foxlink) HP HD Webcam type: USB
driver: uvcvideo bus ID: 1-7:4 chip ID: 05c8:0359
Display: wayland server: X.org 1.20.9 compositor: gnome-shell driver: i915
note: display driver n/a - try sudo/root display ID: 0
resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2)
v: 4.5 Mesa 20.1.8 compat-v: 3.0 direct render: Yes
Device-1: Intel Haswell-ULT HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 00:03.0 chip ID: 8086:0a0c
Device-2: Intel 8 Series HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:9c20
Sound Server: ALSA v: k5.8.16-2-MANJARO
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus ID: 08:00.0
chip ID: 10ec:8168
IF: enp8s0 state: down mac: <filter>
Device-2: Intel Wireless 3160 driver: iwlwifi v: kernel port: 3000
bus ID: 09:00.0 chip ID: 8086:08b3
Local Storage: total: 946.43 GiB used: 11.33 GiB (1.2%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM048-2E7172 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: SDM1 scheme: MBR
ID-2: /dev/sdb type: USB vendor: Lexar model: USB Flash Drive
size: 14.92 GiB block size: physical: 512 B logical: 512 B serial: <filter>
rev: 1100 scheme: MBR
ID-1: / raw size: N/A size: 5.74 GiB used: 145.3 MiB (2.5%) fs: overlay
source: ERR-102
System Temperatures: cpu: 49.0 C mobo: 0.0 C
Processes: 223 Uptime: 7m Memory: 7.65 GiB used: 1.57 GiB (20.5%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1202 lib: 303
flatpak: 0 Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.1.05
