So I decided to replace the partition with an already installed Manjaro KDE, which when I still had it, GRUB was working fine. But now after replacing it with Manjaro GNOME (Dual-boot with Windows 10) I get this:
BootDevice Not Found
Please install an operating system on your hard disk
Hard Disk - (3F0)
F2 System Diagnostics
Hi @smileBrandon
How did you “replace” it?
When installing GNOME, one of the options was to replace an existing partition - what I did.
replace ?
Can you share the screenshot by running the calamares installer again?
Also when you run the os from USB drive can you share the output of the following command
Would be nice to have more information, since it could be true, that you deleted the whole HDD:
sudo parted -l
This message:
comes from the UEFI, so i guess it it did not find the EFI Partition or the MBR. Otherwise, there would be a grub emergency shell.
Model: ATA ST1000LM048-2E71 (scsi)
Disk /dev/sda: 1000GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 106MB 105MB primary ntfs
2 106MB 525GB 525GB primary ntfs
3 525GB 999GB 474GB extended
6 525GB 542GB 17.2GB logical ext4
7 542GB 965GB 423GB logical ext4 boot
5 965GB 999GB 34.0GB logical linux-swap(v1)
4 999GB 1000GB 841MB primary ntfs
Model: Lexar USB Flash Drive (scsi)
Disk /dev/sdb: 16.0GB
Disk Flags:
2 2778MB 2782MB 4194kB primary esp
3 2783MB 16.0GB 13.2GB primary ext4
What’s interesting is that it says my storage device is a BIOS with an MBR
I guess then this the root / partition:
and this the /home partition:
Since /boot is on the root partition, you need to deflag the /home partition and flag the root partition with “boot”.
I don’t know how to do this. Do I do this in konsole/Terminal?
No, that can be done in a live session with gparted. I guess you have to reinstall grub also, maybe i am wrong.
I did what you said so let’s see!
Could you post the content of the partitions?
sudo su
mkdir -p /mnt/sda6 && mount /dev/sda6 /mnt/sda6 && ls /mnt/sda6
mkdir -p /mnt/sda7 && mount /dev/sda7 /mnt/sda6 && ls /mnt/sda7
I guess you have to reinstall grub.
Chroot first:
https://wiki.manjaro.org/index.php/GRUB/Restore_the_GRUB_Bootloader#Chroot_environment
Then install grub:
https://wiki.manjaro.org/index.php/GRUB/Restore_the_GRUB_Bootloader#BIOS_System
megavolt:
sudo su
So do this on the live USB installation?
Also, I did manual partitioning and deleted that partion, here is what I’m left with:
Disk Flags:
6 525GB 965GB 440GB logical ext4
Then better formating /dev/sda6 and install Manjaro Gnome again. Keep sure the boot flag is set. Use manual partitioning… and set /dev/sda6 as root.
There are two options for installing the bootloader: 1st is the Master Boot Record (/dev/sda) or System Partion (/). Which do I do?
First one… it should write to the MBR > Master Boot Record.
Ok, I’ve already done it with the boot flag set to sda6 while also installing boot loader to MBR. Still says no operating system when I boot my hard drive.
6 525GB 965GB 440GB logical ext4 boot
