Is there any way, to be like on xfce?
I tried to install xfce4-notifyd, but that’s not really working.
I’m currently using i3 with xfce4 panel.
I tried to enable via the panel’s pulseaudio plugin, but no change.
inxi --admin --verbosity=7 --filter --no-host --width:
[i3hunor@HunorT480 ~]$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.15.21-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=cc7be21e-d9d4-4881-841a-b047d2a1253a rw quiet
udev.log_priority=3
Desktop: i3 4.20.1 info: xfce4-panel vt: 7 dm: LightDM 1.30.0
Type: Laptop System: LENOVO product: 20L6S1LV2F v: ThinkPad T480
Mobo: LENOVO model: 20L6S1LV2F v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N24ET67W (1.42 )
date: 11/17/2021
ID-1: BAT0 charge: 14.4 Wh (77.4%) condition: 18.6/23.9 Wh (77.6%)
volts: 12.3 min: 11.4 model: LGC 01AV489 type: Li-poly serial: <filter>
status: Not charging cycles: 77
ID-2: BAT1 charge: 11.9 Wh (59.2%) condition: 20.1/24.0 Wh (83.8%)
volts: 11.4 min: 11.5 model: SMP 01AV452 type: Li-poly serial: <filter>
status: Discharging cycles: 199
RAM: total: 7.51 GiB used: 2.46 GiB (32.8%)
RAM Report:
Info: model: Intel Core i5-8350U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEC
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 790 high: 800 min/max: 400/3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 720 bogomips: 30409
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep sgx
smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Chicony Integrated Camera (1280x720@30) type: USB
driver: uvcvideo bus-ID: 1-8:3 chip-ID: 04f2:b604 class-ID: 0e02
serial: <filter>
Display: x11 server: X.Org 1.21.1.3 driver: loaded: modesetting
alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: eDP-1 res: 1920x1080 dpi: 158 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo ThinkPad T480
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.15.21-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: no
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
bus-ID: 03:00.0 chip-ID: 8086:24fd class-ID: 0280
bus-ID: 1-7:2 chip-ID: 8087:0a2b class-ID: e001
Report: rfkill ID: hci0 rfk-id: 10 state: down bt-service: disabled
rfk-block: hardware: no software: no address: see --recommends
Local Storage: total: 238.47 GiB used: 141.47 GiB (59.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKKF256G8L
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: L15P temp: 31.9 C scheme: GPT
ID-1: / raw-size: 118.93 GiB size: 116.5 GiB (97.96%)
used: 54.66 GiB (46.9%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: cc7be21e-d9d4-4881-841a-b047d2a1253a
used: 25.3 MiB (26.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 2EAD-1B08
ID-3: /run/timeshift/backup raw-size: N/A size: 686.67 GiB
used: 86.79 GiB (12.6%) fs: ext4 dev: /dev/sdb label: N/A uuid: N/A
ID-1: swap-1 type: file size: 8 GiB used: 159.1 MiB (1.9%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 118.93 GiB fs: ntfs label: N/A
uuid: 3648B0CC48B08C5D
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 509 MiB fs: ntfs label: N/A
uuid: 1804C52004C5022C
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-7:2 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 1-8:3 info: Chicony Integrated Camera (1280x720@30) type: Video
chip-ID: 04f2:b604 class-ID: 0e02 serial: <filter>
Device-3: 1-9:14 info: Synaptics Metallica MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 06cb:009a class-ID: ff00 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 37.0 C pch: 34.5 C mobo: N/A
Fan Speeds (RPM): fan-1: 0
Processes: 228 Uptime: 1d 18h 4m wakeups: 72 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.1 Packages: pacman: 1217
lib: 328 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.12
EDIT:
i3 config:
[i3hunor@HunorT480 ~]$ cat .config/i3/config
# This file has been auto-generated by i3-config-wizard(1).
# It will not be overwritten, so edit it as you like.
# Should you change your keyboard layout some time, delete
# this file and re-run i3-config-wizard(1).
set $mod Mod1
# Font for window titles. Will also be used by the bar unless a different font
# is used in the bar {} block below.
font pango:monospace 12
# This font is widely installed, provides lots of unicode glyphs, right-to-left
# text rendering and scalability on retina/hidpi displays (thanks to pango).
#font pango:DejaVu Sans Mono 8
# Start XDG autostart .desktop files using dex. See also
# https://wiki.archlinux.org/index.php/XDG_Autostart
exec --no-startup-id dex --autostart --environment i3
# The combination of xss-lock, nm-applet and pactl is a popular choice, so
# they are included here as an example. Modify as you see fit.
# xss-lock grabs a logind suspend inhibit lock and will use i3lock to lock the
# screen before suspend. Use loginctl lock-session to lock your screen.
#exec --no-startup-id xss-lock --transfer-sleep-lock -- i3lock --nofork
# NetworkManager is the most popular way to manage wireless networks on Linux,
# and nm-applet is a desktop environment-independent system tray GUI for it.
exec --no-startup-id nm-applet
# Use pactl to adjust volume in PulseAudio.
set $refresh_i3status killall -SIGUSR1 i3status
bindsym XF86AudioRaiseVolume exec --no-startup-id pactl set-sink-volume @DEFAULT_SINK@ +5% && $refresh_i3status
bindsym XF86AudioLowerVolume exec --no-startup-id pactl set-sink-volume @DEFAULT_SINK@ -5% && $refresh_i3status
bindsym XF86AudioMute exec --no-startup-id pactl set-sink-mute @DEFAULT_SINK@ toggle && $refresh_i3status
bindsym XF86AudioMicMute exec --no-startup-id pactl set-source-mute @DEFAULT_SOURCE@ toggle && $refresh_i3status
# Use Mouse+$mod to drag floating windows to their wanted position
floating_modifier $mod
# kill focused window
bindsym $mod+Shift+q kill
# start dmenu (a program launcher)
# A more modern dmenu replacement is rofi:
# bindcode $mod+40 exec "rofi -modi drun,run -show drun"
# There also is i3-dmenu-desktop which only displays applications shipping a
# .desktop file. It is a wrapper around dmenu, so you need that installed.
# bindcode $mod+40 exec --no-startup-id i3-dmenu-desktop
# //Window manager\\
# change focus
bindsym $mod+j focus left
bindsym $mod+k focus down
bindsym $mod+i focus up
bindsym $mod+l focus right
# alternatively, you can use the cursor keys:
bindsym $mod+Left focus left
bindsym $mod+Down focus down
bindsym $mod+Up focus up
bindsym $mod+Right focus right
# move focused window
bindsym $mod+Shift+j move left
bindsym $mod+Shift+k move down
bindsym $mod+Shift+l move up
bindsym $mod+Shift+eacute move right
bindsym $mod+Shift+Left move left
bindsym $mod+Shift+Down move down
bindsym $mod+Shift+Up move up
bindsym $mod+Shift+Right move right
# split in horizontal orientation
bindsym $mod+h split h
# split in vertical orientation
bindsym $mod+v split v
# enter fullscreen mode for the focused container
bindsym $mod+f fullscreen toggle
# change container layout (stacked, tabbed, toggle split)
bindsym $mod+s layout stacking
bindsym $mod+w layout tabbed
bindsym $mod+e layout toggle split
# toggle tiling / floating
bindsym $mod+Shift+space floating toggle
# change focus between tiling / floating windows
bindsym $mod+space focus mode_toggle
# focus the parent container
bindsym $mod+a focus parent
# focus the child container
#bindsym $mod+d focus child
### move focused window between monitors
bindsym $mod+Shift+x move container to output right
bindsym $mod+Shift+y move container to output left
# //Worspaces\\
# Define names for default workspaces for which we configure key bindings later on.
# We use variables to avoid repeating the names in multiple places.
set $ws1 "1"
set $ws2 "2"
set $ws3 "3"
set $ws4 "4"
set $ws5 "5"
set $ws6 "6"
set $ws7 "7"
set $ws8 "8:S1"
set $ws9 "9:S2"
set $ws10 "10:S3"
## switch to near workspace
bindsym $mod+Tab workspace next
# switch to workspace
bindsym $mod+1 workspace number $ws1
bindsym $mod+2 workspace number $ws2
bindsym $mod+3 workspace number $ws3
bindsym $mod+4 workspace number $ws4
bindsym $mod+5 workspace number $ws5
bindsym $mod+6 workspace number $ws6
bindsym $mod+7 workspace number $ws7
bindsym $mod+8 workspace number $ws8
bindsym $mod+9 workspace number $ws9
bindsym $mod+odiaeresis workspace number $ws10
# move focused container to workspace
bindsym $mod+Shift+1 move container to workspace number $ws1
bindsym $mod+Shift+2 move container to workspace number $ws2
bindsym $mod+Shift+3 move container to workspace number $ws3
bindsym $mod+Shift+4 move container to workspace number $ws4
bindsym $mod+Shift+5 move container to workspace number $ws5
bindsym $mod+Shift+6 move container to workspace number $ws6
bindsym $mod+Shift+7 move container to workspace number $ws7
bindsym $mod+Shift+8 move container to workspace number $ws8
bindsym $mod+Shift+9 move container to workspace number $ws9
bindsym $mod+Shift+odiaeresis move container to workspace number $ws10
## ASIGN APP TO WORKSPACE
for_window [class="Firefox"] move to workspace $ws1
for_window [class="Caprine"] move to workspace $ws2
for_window [class="Discord"] move to workspace $ws2
for_window [class="Spotify"] move to workspace $ws3
for_window [class="Zoom"] move to workspace $ws8
## ASIGN WORKSPACE TO MONITOR
workspace 8 output HDMI-2
workspace 9 output HDMI-2
workspace 10 output HDMI-2
# //Manage i3\\
# reload the configuration file
bindsym $mod+Shift+c reload
# restart i3 inplace (preserves your layout/session, can be used to upgrade i3)
bindsym $mod+Shift+r restart
# exit i3 (logs you out of your X session)
bindsym $mod+Shift+e exec "i3-nagbar -t warning -m 'You pressed the exit shortcut. Do you really want to exit i3? This will end your X session.' -B 'Yes, exit i3' 'i3-msg exit'"
# //resize\\
mode "resize" {
# These bindings trigger as soon as you enter the resize mode
# Pressing left will shrink the window’s width.
# Pressing right will grow the window’s width.
# Pressing up will shrink the window’s height.
# Pressing down will grow the window’s height.
bindsym j resize shrink width 10 px or 10 ppt
bindsym i resize grow height 10 px or 10 ppt
bindsym k resize shrink height 10 px or 10 ppt
bindsym l resize grow width 10 px or 10 ppt
# same bindings, but for the arrow keys
bindsym Left resize shrink width 10 px or 10 ppt
bindsym Down resize grow height 10 px or 10 ppt
bindsym Up resize shrink height 10 px or 10 ppt
bindsym Right resize grow width 10 px or 10 ppt
# back to normal: Enter or Escape or $mod+r
bindsym Return mode "default"
bindsym Escape mode "default"
bindsym $mod+r mode "default"
bindsym $mod+r mode "resize"
######################################### Saját
## COLOR
# class border backgr. text indicator child_border
client.focused #FF7800 #FF7800 #FF7800 #FF7800 #FF7800
## GAPS
for_window [class="^.*"] border pixel 2
gaps inner 10
gaps outer 10
## EXEC SZOLG
exec_always --no-startup-id xfce4-power-manager
exec_always --no-startup-id killall /usr/lib/x86_64-linux-gnu/xfce4/panel/wrapper-1.0
exec_always --no-startup-id xfsettingsd
exec_always --no-startup-id killall sudo powertop --auto-tune exit 0
exec_always --no-startup-id xfce4-panel
## APPLICATIONS
#FIREFOX
bindsym $mod+Shift+w exec firefox
#TUNAR
bindsym $mod+Shift+f exec --no-startup-id thunar
#ROFI
bindsym $mod+Shift+d exec --no-startup-id rofi -show drun
#FLAMESHOT
bindsym Print exec flameshot gui
#TERMINAL(xfce)
bindsym $mod+Return exec i3-sensible-terminal
