No notification sound for login since last big update
All other notification-sounds seem to work.
  Device-1: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    driver: snd_hda_intel
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor driver: snd_pci_ps
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio driver: snd_hda_intel
  API: ALSA v: k6.18.18-1-MANJARO status: kernel-api
  Server-1: PipeWire v: 1.6.2 status: active
Waiting for someone to blindly ask questions is also counter-productive – typically, nobody has a :crystal_ball: at their disposal – Instead, please help others to ask informed questions, based on information you provide.
Update Announcements
System Information
inxi --filter --verbosity=8
inxi -zv8
Highly Recommended
Technical Resources
Required Reading
Any solution for this issue?
Am i the only one with this issue?
What infos are you missing?
Here my full inxi:
inxi -zv8        ξ‚² βœ”
  Kernel: 6.18.18-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=3ef53767-c519-469b-a72e-b11b38900b68 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.5.6 tk: Qt v: N/A info: frameworks v: 6.24.0
  Type: Desktop System: LENOVO product: 12X9001AGE v: ThinkCentre M75t Gen 5
    serial: <superuser required> Chassis: type: 3 serial: <superuser required>
  Mobo: LENOVO model: 3317 v: NOK serial: <superuser required>
    part-nu: LENOVO_MT_12X9_BU_Think_FM_ThinkCentre M75t Gen 5
    uuid: <superuser required> Firmware: UEFI vendor: LENOVO v: M4RKT31A
    date: 07/22/2025
  System RAM: total: 32 GiB available: 30.5 GiB used: 6.38 GiB (20.9%)
  Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: spec: 5600 MT/s actual: 5200 MT/s
    volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Samsung part-no: M323R2GA3PB0-CWMOL serial: <filter>
  Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 8700G w/ Radeon 780M Graphics bits: 64 type: MT MCP
    arch: Zen 4 gen: 4 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
    family: 0x19 (25) model-id: 0x75 (117) stepping: 2 microcode: 0xA705208
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 2404 min/max: 423/5177 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 2404 2: 2404 3: 2404
    4: 2404 5: 2404 6: 2404 7: 2404 8: 2404 9: 2404 10: 2404 11: 2404 12: 2404
    13: 2404 14: 2404 15: 2404 16: 2404 bogomips: 134400
  Flags: 3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avic avx
    avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
    avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
    constant_tsc cpb cppc cpuid cpuid_fault cqm cqm_llc cqm_mbm_local
    cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms
    extapic extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae
    perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
    rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
    sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean
    vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves xtopology
    conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Phoenix1 vendor: Lenovo
    driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
    built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1
    empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, Writeback-1
    bus-ID: 0c:00.0 chip-ID: 1002:15bf class-ID: 0300 temp: 29.0 C
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
  Monitor-1: HDMI-A-1 model: Dell S2721QS serial: <filter> built: 2021 res:
    mode: 3840x2160 hz: 60 scale: 100% (1) dpi: 163 gamma: 1.2 chroma: red:
    x: 0.659 y: 0.329 green: x: 0.306 y: 0.647 blue: x: 0.149 y: 0.059 white:
    x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23") diag: 685mm (27")
    ratio: 16:9 modes: 3840x2160, 2560x1440, 2048x1280, 1920x1080, 1600x1200,
    1600x900, 1280x1024, 1152x864, 1280x720, 1024x768, 800x600, 720x576,
    720x480, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
    unhandled CEA mode 93 3: parse_edid: unhandled CEA mode 94 4: parse_edid:
    unhandled CEA mode 95
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 26.0.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M Graphics (radeonsi
    phoenix ACO DRM 3.64 6.18.18-1-MANJARO) device-ID: 1002:15bf
    memory: 500 MiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.341 layers: 2 device: 0 type: integrated-gpu name: AMD
    Radeon 780M Graphics (RADV PHOENIX) driver: mesa radv v: 26.0.2-arch1.1
    device-ID: 1002:15bf surfaces: N/A
    vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
    driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 0c:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Lenovo
    bus-ID: 0c:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.18.18-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.2 status: active with: 1: pipewire-pulse
  Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 07:00.0 chip-ID: 14c3:0616 class-ID: 0280
  IF: wlp7s0 state: down mac: <filter>
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    link-max: gen: 2 speed: 5 GT/s port: f000 bus-ID: 0b:00.1
  IF: enp11s0f1 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:5 chip-ID: 0e8d:e0d8
  Local Storage: total: 3.66 TiB used: 1.35 TiB (36.9%)
    model: MZVL81T0HFLB-00BLL size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 2L2QKXF7 temp: 33.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS541010A9E680
    tech: HDD rpm: 5400 serial: <filter> fw-rev: A560 scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SDSSDH3 2T00
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 20RL scheme: MBR
  ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%)
    used: 304.57 GiB (32.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 3ef53767-c519-469b-a72e-b11b38900b68
    used: 328 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: C8F4-05BD
  ID-3: /mnt/08f0f704-cc7d-448f-8ec8-ee1097c1f324 raw-size: 931.51 GiB
    size: 916.7 GiB (98.41%) used: 697.91 GiB (76.1%) fs: ext4 dev: /dev/sda1
    maj-min: 8:1 label: /data uuid: 08f0f704-cc7d-448f-8ec8-ee1097c1f324
  ID-4: /mnt/8c94e0e8-48b4-4528-9003-47c8ec0c9e59 raw-size: 1.82 TiB
    size: 1.79 TiB (98.37%) used: 382.18 GiB (20.9%) fs: ext4 dev: /dev/sdb1
    maj-min: 8:17 label: SanDisk2TB uuid: 8c94e0e8-48b4-4528-9003-47c8ec0c9e59
  ID-1: swap-1 type: file size: 512 MiB used: 12 KiB (0.0%) priority: -2
    file: /swapfile
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-7:2 info: Alcor Micro Multi Flash Reader type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 100mA chip-ID: 058f:6366 class-ID: 0806
    serial: <filter>
  Device-2: 1-9:3 info: USB OPTICAL MOUSE type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    chip-ID: 275d:0ba6 class-ID: 0301
  Device-3: 1-10:4 info: SiGma Micro USB Keyboard type: keyboard,HID
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
    chip-ID: 1c4f:0043 class-ID: 0300
  Device-4: 1-12:5 info: MediaTek Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0e8d:e0d8 class-ID: e001 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
  Hub-4: 3-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  System Temperatures: cpu: 35.5 C mobo: 31.0 C gpu: amdgpu temp: 29.0 C
  Fan Speeds (rpm): N/A
  Packages: 1561 pm: pacman pkgs: 1537 libs: 414 tools: pamac pm: flatpak
    pkgs: 24
    1: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    4: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    5: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    7: https://linorg.usp.br/manjaro/stable/$repo/$arch
    8: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 416
  1: cpu: 1.5% command: konsole pid: 7123 mem: 228.7 MiB (0.7%)
  2: cpu: 1.3% command: kwin_wayland pid: 1053 mem: 469.1 MiB (1.5%)
  3: cpu: 1.3% command: plasmashell pid: 1275 mem: 580.7 MiB (1.8%)
  4: cpu: 0.9% command: vivaldi-bin pid: 3347 mem: 301.4 MiB (0.9%)
  5: cpu: 0.9% command: zsh pid: 7145 mem: 10.4 MiB (0.0%)
  Memory top: 5 of 416
  1: mem: 580.7 MiB (1.8%) command: plasmashell pid: 1275 cpu: 1.3%
  2: mem: 469.1 MiB (1.5%) command: kwin_wayland pid: 1053 cpu: 1.3%
  3: mem: 459.3 MiB (1.4%) command: opera pid: 1968 cpu: 0.4%
  4: mem: 446.2 MiB (1.4%) command: thunderbird pid: 1783 cpu: 0.1%
  5: mem: 442.9 MiB (1.4%) command: vivaldi-bin pid: 2080 cpu: 0.7%
  Processes: 416 Power: uptime: 58m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.11 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 259 default: graphical
    tool: systemctl
  Compilers: N/A Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.40
 οŒ’ ξ‚°  ~ ξ‚°
