No networking and sudden system instability
Hi.
My computer suddenly got pretty effed. I have noticed the following problems:
  • Services (including NetworkManager) fail to start during boot. Currently no network connection on the device.
  • Constant stopjobs during shutdown leading to computer not shutting down normally (requiring hard reset). Cycling between multiple services (see image at the bottom of the post).
  • Intermittent login to black screen in GUI session.
Here is some system information I managed to extract by USB:
Manjaro: Version
ManjaroLinux 23.1.3 Vulcan
Inxi:
CPU: quad core Intel Core i5-7500 (-MCP-) speed/min/max: 3600/800/3800 MHz
Kernel: 6.6.10-1-MANJARO x86_64 Up: 4m Mem: 1.4/39.12 GiB (3.6%)
Storage: 1.26 TiB (85.8% used) Procs: 219 Shell: Bash 5.2.21 inxi: 3.3.31
systemctl status:
● DEVICE-NAME
    State: starting
    Units: 408 loaded (incl. loaded aliases)
     Jobs: 7 queued
   Failed: 1 units
    Since: Wed 2024-02-14 19:49:33 CET; 2min 30s ago
  systemd: 255.2-2-manjaro
   CGroup: /
           β”œβ”€init.scope
           β”‚ └─1 /sbin/init splash
           β”œβ”€system.slice
           β”‚ β”œβ”€ModemManager.service
           β”‚ β”‚ └─811 /usr/bin/ModemManager
           β”‚ β”œβ”€NetworkManager.service
           β”‚ β”‚ └─748 /usr/bin/NetworkManager --no-daemon
           β”‚ β”œβ”€accounts-daemon.service
           β”‚ β”‚ └─864 /usr/lib/accounts-daemon
           β”‚ β”œβ”€avahi-daemon.service
           β”‚ β”‚ β”œβ”€750 "avahi-daemon: running [************-desktop.local]"
           β”‚ β”‚ └─776 "avahi-daemon: chroot helper"
           β”‚ β”œβ”€colord.service
           β”‚ β”‚ └─1197 /usr/lib/colord
           β”‚ β”œβ”€containerd.service
           β”‚ β”‚ └─843 /usr/bin/containerd
           β”‚ β”œβ”€cronie.service
           β”‚ β”‚ └─845 /usr/sbin/crond -n
           β”‚ β”œβ”€dbus-broker.service
           β”‚ β”‚ β”œβ”€746 /usr/bin/dbus-broker-launch --scope system --audit
           β”‚ β”‚ └─747 dbus-broker --log 4 --controller 9 --machine-id 18e6f089491e4f28b8675d1f4f1184bf --max-bytes 536870912 --max-fds 4096 --max-matches 131072 --audit
           β”‚ β”œβ”€dhcpcd.service
           β”‚ β”‚ β”œβ”€751 "dhcpcd: [manager] [ip4] [ip6]"
           β”‚ β”‚ β”œβ”€754 "dhcpcd: [privileged proxy]"
           β”‚ β”‚ β”œβ”€755 "dhcpcd: [network proxy]"
           β”‚ β”‚ └─756 "dhcpcd: [control proxy]"
           β”‚ β”œβ”€docker.service
           β”‚ β”‚ └─1468 /usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock
           β”‚ β”œβ”€lightdm.service
           β”‚ β”‚ β”œβ”€850 /usr/bin/lightdm
           β”‚ β”‚ └─863 /usr/lib/Xorg :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
           β”‚ β”œβ”€polkit.service
           β”‚ β”‚ └─752 /usr/lib/polkit-1/polkitd --no-debug
           β”‚ β”œβ”€rtkit-daemon.service
           β”‚ β”‚ └─1165 "(t-daemon)"
           β”‚ β”œβ”€sshd.service
           β”‚ β”‚ └─834 "sshd: /usr/bin/sshd -D [listener] 0 of 10-100 startups"
           β”‚ β”œβ”€sysstat-collect.service
           β”‚ β”‚ └─1007 /usr/lib/sa/sadc -F -L 1 1 /var/log/sa
           β”‚ β”œβ”€systemd-journald.service
           β”‚ β”‚ └─233 /usr/lib/systemd/systemd-journald
           β”‚ β”œβ”€systemd-logind.service
           β”‚ β”‚ └─757 /usr/lib/systemd/systemd-logind
           β”‚ β”œβ”€systemd-resolved.service
           β”‚ β”‚ └─741 /usr/lib/systemd/systemd-resolved
           β”‚ β”œβ”€systemd-udevd.service
           β”‚ β”‚ └─udev
           β”‚ β”‚   └─234 /usr/lib/systemd/systemd-udevd
           β”‚ β”œβ”€tailscaled.service
           β”‚ β”‚ └─900 /usr/sbin/tailscaled --state=/var/lib/tailscale/tailscaled.state --socket=/run/tailscale/tailscaled.sock --port=41641
           β”‚ β”œβ”€udisks2.service
           β”‚ β”‚ └─1270 /usr/lib/udisks2/udisksd
           β”‚ β”œβ”€upower.service
           β”‚ β”‚ └─1235 /usr/lib/upowerd
           β”‚ β”œβ”€vnstat.service
           β”‚ β”‚ └─841 /usr/sbin/vnstatd -n
           β”‚ └─wpa_supplicant.service
           β”‚   └─824 /usr/bin/wpa_supplicant -u -s -O /run/wpa_supplicant
           └─user.slice
             └─user-1000.slice
               β”œβ”€session-2.scope
               β”‚ β”œβ”€ 997 lightdm --session-child 13 20
               β”‚ β”œβ”€1036 xfce4-session
               β”‚ β”œβ”€1091 /usr/bin/ssh-agent -s
               β”‚ β”œβ”€1101 xfwm4 --display :0.0 --sm-client-id 2a4a85514-5e48-4abd-9298-0adcdf7df090
               β”‚ β”œβ”€1112 xfce4-panel --display :0.0 --sm-client-id 2bbf4e444-1a6e-42d6-acf3-fb3906471423
               β”‚ β”œβ”€1117 Thunar --sm-client-id 204ef1443-1a31-48ca-b9ce-ef75786e7182 --daemon
               β”‚ β”œβ”€1123 xfdesktop --display :0.0 --sm-client-id 27e0f4719-b044-401a-a501-54e3f1aba1fa
               β”‚ β”œβ”€1127 /usr/lib/xfce4/panel/wrapper-2.0 /usr/lib/xfce4/panel/plugins/libwhiskermenu.so 8 16777223 whiskermenu "Whisker Menu" "Show a menu to easily access installed applications"
               β”‚ β”œβ”€1128 /usr/lib/xfce4/panel/wrapper-2.0 /usr/lib/xfce4/panel/plugins/libsystray.so 6 16777225 systray "Status Tray Plugin" "Provides status notifier items (application indicators) and legacy systray items"
               β”‚ β”œβ”€1131 /usr/lib/xfce4/panel/wrapper-2.0 /usr/lib/xfce4/panel/plugins/libpulseaudio-plugin.so 9 16777226 pulseaudio "PulseAudio Plugin" "Adjust the audio volume of the PulseAudio sound system"
               β”‚ β”œβ”€1134 msm_notifier -session 279216d5f-3ca9-4943-a2ac-27daae3c1aa2_1703606285_141122
               β”‚ β”œβ”€1137 xfce4-power-manager --restart --sm-client-id 2de8a3f3d-9e54-4fcf-b643-d3c9555b962f
               β”‚ β”œβ”€1174 xcape -e Super_L Alt_L F1
               β”‚ β”œβ”€1177 /usr/lib/geoclue-2.0/demos/agent
               β”‚ β”œβ”€1181 light-locker
               β”‚ β”œβ”€1183 xiccd
               β”‚ β”œβ”€1185 nm-applet
               β”‚ β”œβ”€1186 /usr/lib/evolution-data-server/evolution-alarm-notify
               β”‚ β”œβ”€1194 /usr/bin/python3 /usr/lib/python3/dist-packages/timekpr/client/timekprc.py /usr/bin/timekprc
               β”‚ β”œβ”€1198 /usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1
               β”‚ β”œβ”€1221 /usr/bin/python /usr/bin/blueman-applet
               β”‚ β”œβ”€1282 recollindex -w 60 -m
               β”‚ β”œβ”€1401 /usr/bin/python /usr/bin/terminator
               β”‚ β”œβ”€1428 /bin/bash
               β”‚ β”œβ”€1434 ssh-agent
               β”‚ β”œβ”€1611 /bin/bash
               β”‚ β”œβ”€1615 ssh-agent
               β”‚ β”œβ”€1620 xfsettingsd --replace
               β”‚ └─1655 systemctl status
               └─user@1000.service
                 β”œβ”€app.slice
                 β”‚ β”œβ”€app-dbus\x2d:1.11\x2dorg.a11y.atspi.Registry.slice
                 β”‚ β”‚ └─dbus-:1.11-org.a11y.atspi.Registry@0.service
                 β”‚ β”‚   └─1085 /usr/lib/at-spi2-registryd --use-gnome-session
                 β”‚ β”œβ”€app-dbus\x2d:1.2\x2dorg.xfce.Xfconf.slice
                 β”‚ β”‚ └─dbus-:1.2-org.xfce.Xfconf@0.service
                 β”‚ β”‚   └─1079 /usr/lib/xfce4/xfconf/xfconfd
                 β”‚ β”œβ”€dconf.service
                 β”‚ β”‚ └─1211 /usr/lib/dconf-service
                 β”‚ β”œβ”€evolution-calendar-factory.service
                 β”‚ β”‚ └─1377 /usr/lib/evolution-calendar-factory
                 β”‚ β”œβ”€evolution-source-registry.service
                 β”‚ β”‚ └─1309 /usr/lib/evolution-source-registry
                 β”‚ β”œβ”€gnome-keyring-daemon.service
                 β”‚ β”‚ └─1028 /usr/bin/gnome-keyring-daemon --foreground --components=pkcs11,secrets --control-directory=/run/user/1000/keyring
                 β”‚ β”œβ”€gpg-agent.service
                 β”‚ β”‚ └─1099 /usr/bin/gpg-agent --supervised
                 β”‚ β”œβ”€obex.service
                 β”‚ β”‚ └─1370 /usr/lib/bluetooth/obexd
                 β”‚ β”œβ”€tumblerd.service
                 β”‚ β”‚ └─1141 /usr/lib/tumbler-1/tumblerd
                 β”‚ β”œβ”€xdg-desktop-portal-gtk.service
                 β”‚ β”‚ └─1264 /usr/lib/xdg-desktop-portal-gtk
                 β”‚ └─xfce4-notifyd.service
                 β”‚   └─1163 /usr/lib/xfce4/notifyd/xfce4-notifyd
                 β”œβ”€init.scope
                 β”‚ β”œβ”€1018 /usr/lib/systemd/systemd --user
                 β”‚ └─1019 "(sd-pam)"
                 └─session.slice
                   β”œβ”€at-spi-dbus-bus.service
                   β”‚ β”œβ”€1071 /usr/lib/at-spi-bus-launcher
                   β”‚ β”œβ”€1077 /usr/bin/dbus-broker-launch --config-file=/usr/share/defaults/at-spi2/accessibility.conf --scope user
                   β”‚ └─1078 dbus-broker --log 4 --controller 9 --machine-id 18e6f089491e4f28b8675d1f4f1184bf --max-bytes 100000000000000 --max-fds 6400000 --max-matches 5000000000
                   β”‚ β”œβ”€1033 /usr/bin/dbus-broker-launch --scope user
                   β”‚ └─1034 dbus-broker --log 4 --controller 10 --machine-id 18e6f089491e4f28b8675d1f4f1184bf --max-bytes 100000000000000 --max-fds 25000000000000 --max-matches 5000000000
                   β”œβ”€gvfs-afc-volume-monitor.service
                   β”‚ └─1310 /usr/lib/gvfs-afc-volume-monitor
                   β”œβ”€gvfs-daemon.service
                   β”‚ β”œβ”€1055 /usr/lib/gvfsd
                   β”‚ β”œβ”€1061 /usr/lib/gvfsd-fuse /run/user/1000/gvfs -f
                   β”‚ └─1353 /usr/lib/gvfsd-trash --spawner :1.7 /org/gtk/gvfs/exec_spaw/0
                   β”œβ”€gvfs-gphoto2-volume-monitor.service
                   β”‚ └─1325 /usr/lib/gvfs-gphoto2-volume-monitor
                   β”œβ”€gvfs-metadata.service
                   β”‚ └─1385 /usr/lib/gvfsd-metadata
                   β”œβ”€gvfs-mtp-volume-monitor.service
                   β”‚ └─1320 /usr/lib/gvfs-mtp-volume-monitor
                   β”œβ”€gvfs-udisks2-volume-monitor.service
                   β”‚ └─1255 /usr/lib/gvfs-udisks2-volume-monitor
                   β”œβ”€pulseaudio.service
                   β”‚ └─1158 /usr/bin/pulseaudio --daemonize=no --log-target=journal
                   β”œβ”€xdg-desktop-portal.service
                   β”‚ └─1162 /usr/lib/xdg-desktop-portal
                   β”œβ”€xdg-document-portal.service
                   β”‚ β”œβ”€1222 /usr/lib/xdg-document-portal
                   β”‚ └─1245 fusermount3 -o rw,nosuid,nodev,fsname=portal,auto_unmount,subtype=portal -- /run/user/1000/doc
                   └─xdg-permission-store.service
                     └─1231 /usr/lib/xdg-permission-store
I can’t say that these problems appear tied directly to any obvious system changes on my end. I didn’t update the system or install any new software before this started occurring.
(Sorry for image, but I don’t know how to access this information easily) - Image taken during shutdown, illustrating stopjob problems. This occured roughly ~15 minutes after initiating shutdown and multiple incrementing β€œstopjob” messages.
Does anyone have any ideas what the problem could be? I’ll try to provide any additional information to the best of my ability.
Can you still boot via your install media, usb stick? the odd nature of the degrading boot suggests a possible hardware failure or corrupted install …
You can test via the install media or a repair disk.
Can you boot into an terminal based admin session?
I will that as soon as I have a chunk of time to spend looking into this in more detail (probably not before tomorrow). Does the installer include any tools for testing the hardware? I’ve performed a memtest which passed, and will run a fsck as well. Anything else I should do?
Hi @singofy,
This whole thing smells like some kind of hardware failure. Probably a disk drive or something.
At the moment I can’t think of anything other than SMART tests…I don’t know how many disks you’ve got in there, but:
I’m presuming two. So boot into a live environment, and run a smart test on each of your disks:
sudo smartctl --all </path/to/disk>
Where, and this is important, </path/to/disk> is the path to the disk (e.g.: /dev/sda) and not the partition (e.g.: /dev/sda2).
It is also possible to get system logs from a chroot environment if that doesn’t reveal anything.
How to chroot
  1. Ensure you’ve got a relatively new ISO or at least one with a still supported LTS kernel.
  2. Write/copy/dd the ISO to a USB thumb drive.
  3. When done, boot with the above mentioned USB thumb drive into the live environment.
  4. Once booted, open a terminal and enter the following command to enter the chroot encironment:
manjaro-chroot -a
  1. If you have more than one Linux installation, select the correct one to use from the list provided.
When done, you should now be in the chroot environment.
But, be careful, as you’re now in an actual root environment on your computer, so any changes you make will persist after a restart.
To get the logs, run the following there, in the chroot environment:
journalctl --priority=warning..err --no-pager --boot=-1
Where:
  • The --priority=warning..err argument limits the output to warnings and errors only;
  • and the --no-pager formats the output nicely for use here, on the forum;
  • the --boot=-1 argument limits the output to log messages from the previous boot. This can be adjusted to -2 for the boot before that, -3 to the boot before that, and so on and so forth. I’m guessing for you it’d be -1.
Provide the output here if you wish for us to have a look.
Finally got around to it. Booting from USB went fine.
Smart CTL output
/dev/sda (Boot drive, SSD)
 sudo smartctl --all /dev/sda
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.6.10-1-MANJARO] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Phison Driven SSDs
Device Model:     KINGSTON SM2280S3G2120G
Serial Number:    50026B7277014519
LU WWN Device Id: 5 0026b7 277014519
Firmware Version: SAFM01.W
User Capacity:    120,034,123,776 bytes [120 GB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
Form Factor:      < 1.8 inches
TRIM Command:     Available, deterministic, zeroed
Device is:        In smartctl database 7.3/5528
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Thu Feb 15 20:18:04 2024 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00)	Offline data collection activity
					was never started.
					Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					without error or no self-test has ever
					been run.
Total time to complete Offline
data collection: 		(   30) seconds.
capabilities: 			 (0x79) SMART execute Offline immediate.
					No Auto Offline data collection support.
					Suspend Offline collection upon new
					command.
					Offline surface scan supported.
					Self-test supported.
					Conveyance Self-test supported.
					Selective Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
					Supports SMART auto save timer.
Error logging capability:        (0x01)	Error logging supported.
					General Purpose Logging supported.
Short self-test routine
recommended polling time: 	 (   1) minutes.
Extended self-test routine
recommended polling time: 	 (   2) minutes.
Conveyance self-test routine
recommended polling time: 	 (   3) minutes.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000b   100   100   050    Pre-fail  Always       -       0
  2 Not_In_Use              0x0005   100   100   050    Pre-fail  Offline      -       0
  3 Not_In_Use              0x0007   100   100   050    Pre-fail  Always       -       0
  5 Retired_Block_Count     0x0013   100   100   050    Pre-fail  Always       -       0
  7 Not_In_Use              0x000b   100   100   050    Pre-fail  Always       -       0
  8 Not_In_Use              0x0005   100   100   050    Pre-fail  Offline      -       0
  9 Power_On_Hours          0x0012   100   100   000    Old_age   Always       -       23206
 12 Power_Cycle_Count       0x0012   100   100   000    Old_age   Always       -       3397
168 SATA_Phy_Error_Count    0x0012   100   100   000    Old_age   Always       -       0
170 Bad_Blk_Ct_Lat/Erl      0x0003   100   100   010    Pre-fail  Always       -       0/141
173 MaxAvgErase_Ct          0x0012   100   100   000    Old_age   Always       -       142 (Average 81)
175 Not_In_Use              0x0013   100   100   050    Pre-fail  Always       -       0
187 Reported_Uncorrect      0x0012   100   100   000    Old_age   Always       -       0
192 Unsafe_Shutdown_Count   0x0012   100   100   000    Old_age   Always       -       265
194 Temperature_Celsius     0x0023   075   050   030    Pre-fail  Always       -       25 (Min/Max 13/50)
196 Reallocated_Event_Count 0x0002   100   100   010    Old_age   Always       -       0
197 Not_In_Use              0x0032   100   100   000    Old_age   Always       -       0
199 SATA_CRC_Error_Count    0x000b   100   100   050    Pre-fail  Always       -       0
218 CRC_Error_Count         0x000b   100   100   050    Pre-fail  Always       -       0
231 SSD_Life_Left           0x0013   100   100   000    Pre-fail  Always       -       98
233 Flash_Writes_GiB        0x000b   100   100   000    Pre-fail  Always       -       4658
240 Not_In_Use              0x0013   100   100   000    Pre-fail  Always       -       0
241 Lifetime_Writes_GiB     0x0012   100   100   000    Old_age   Always       -       8080
242 Lifetime_Reads_GiB      0x0012   100   100   000    Old_age   Always       -       11661
244 Average_Erase_Count     0x0002   100   100   000    Old_age   Always       -       81
245 Max_Erase_Count         0x0002   100   100   000    Old_age   Always       -       142
246 Total_Erase_Count       0x0012   100   100   000    Old_age   Always       -       2734800
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed without error       00%     23206         -
# 2  Short offline       Completed without error       00%      6769         -
# 3  Conveyance offline  Completed without error       00%      6765         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
The above only provides legacy SMART information - try 'smartctl -x' for more
/dev/sdb (/home drive, HDD)
sudo smartctl --all /dev/sdb
Model Family:     Seagate BarraCuda 3.5 (CMR)
Device Model:     ST1000DM010-2EP102
Serial Number:    Z9AFFWPF
LU WWN Device Id: 5 000c50 0a3aa2da4
Firmware Version: CC43
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Thu Feb 15 23:35:33 2024 UTC
					was never started.
					been run.
data collection: 		(    0) seconds.
capabilities: 			 (0x73) SMART execute Offline immediate.
					Auto Offline data collection on/off support.
					command.
					No Offline surface scan supported.
					power-saving mode.
recommended polling time: 	 ( 103) minutes.
SCT capabilities: 	       (0x1085)	SCT Status supported.
SMART Attributes Data Structure revision number: 10
  1 Raw_Read_Error_Rate     0x000f   082   063   006    Pre-fail  Always       -       198248413
  3 Spin_Up_Time            0x0003   097   097   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   096   096   020    Old_age   Always       -       5034
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   086   060   045    Pre-fail  Always       -       420261122
  9 Power_On_Hours          0x0032   074   074   000    Old_age   Always       -       22948
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   097   097   020    Old_age   Always       -       3369
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0 0 0
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   066   049   040    Old_age   Always       -       34 (Min/Max 18/38)
193 Load_Cycle_Count        0x0032   098   098   000    Old_age   Always       -       5492
194 Temperature_Celsius     0x0022   034   009   000    Old_age   Always       -       34 (0 9 0 0 0)
195 Hardware_ECC_Recovered  0x001a   001   001   000    Old_age   Always       -       198248413
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       20393h+14m+21.546s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       58873753054
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       65678023065
No Errors Logged
# 1  Extended offline    Completed without error       00%     22946         -
# 2  Short offline       Completed without error       00%     18023         -
# 3  Short offline       Completed without error       00%      2101         -
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
There is a third disk (SSD) mounted, but it is the newest drive and only holds my steam lib so I have excluded it here.
Logs
Slighly older log which includes an attempt at a normal shutdown.
journalctl --priority=warning..err --no-pager --boot=-5
Feb 14 19:59:30 thorbjoernl-desktop kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Feb 14 19:59:30 thorbjoernl-desktop kernel: x86/cpu: SGX disabled by BIOS.
Feb 14 19:59:30 thorbjoernl-desktop kernel: pci 0000:04:00.0: can't disable ASPM; OS doesn't have ASPM control
Feb 14 19:59:30 thorbjoernl-desktop kernel: resource: resource sanity check: requesting [mem 0x00000000fdffe800-0x00000000fe0007ff], which spans more than pnp 00:07 [mem 0xfdb00000-0xfdffffff]
Feb 14 19:59:30 thorbjoernl-desktop kernel: caller get_primary_reg_base+0x4f/0xb0 mapping multiple BARs
Feb 14 19:59:30 thorbjoernl-desktop kernel: ata5.00: supports DRM functions and may not be fully accessible
Feb 14 19:59:30 thorbjoernl-desktop kernel: usb: port power management may be unreliable
Feb 14 19:59:30 thorbjoernl-desktop systemd[1]: Configuration file /usr/lib/systemd/system/timekpr.service is marked executable. Please remove executable permission bits. Proceeding anyway.
Feb 14 19:59:30 thorbjoernl-desktop systemd-vconsole-setup[216]: KD_FONT_OP_GET failed while trying to get the font metadata: Invalid argument
Feb 14 19:59:30 thorbjoernl-desktop systemd-vconsole-setup[216]: Fonts will not be copied to remaining consoles
Feb 14 19:59:30 thorbjoernl-desktop systemd-journald[230]: File /var/log/journal/18e6f089491e4f28b8675d1f4f1184bf/system.journal corrupted or uncleanly shut down, renaming and replacing.
Feb 14 19:59:30 thorbjoernl-desktop kernel: r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
Feb 14 19:59:30 thorbjoernl-desktop systemd-vconsole-setup[362]: KD_FONT_OP_GET failed while trying to get the font metadata: Invalid argument
Feb 14 19:59:30 thorbjoernl-desktop systemd-vconsole-setup[362]: Fonts will not be copied to remaining consoles
Feb 14 19:59:31 thorbjoernl-desktop kernel: nvidia: loading out-of-tree module taints kernel.
Feb 14 19:59:31 thorbjoernl-desktop kernel: nvidia: module license 'NVIDIA' taints kernel.
Feb 14 19:59:31 thorbjoernl-desktop kernel: Disabling lock debugging due to kernel taint
Feb 14 19:59:31 thorbjoernl-desktop kernel: nvidia: module license taints kernel.
Feb 14 19:59:31 thorbjoernl-desktop kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  545.29.06  Thu Nov 16 01:59:08 UTC 2023
Feb 14 19:59:32 thorbjoernl-desktop kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Feb 14 19:59:48 thorbjoernl-desktop avahi-daemon[665]: *** WARNING: Detected another IPv4 mDNS stack running on this host. This makes mDNS unreliable and is thus not recommended. ***
Feb 14 19:59:48 thorbjoernl-desktop avahi-daemon[665]: *** WARNING: Detected another IPv6 mDNS stack running on this host. This makes mDNS unreliable and is thus not recommended. ***
Feb 14 19:59:48 thorbjoernl-desktop dhcpcd[670]: no interfaces have a carrier
Feb 14 19:59:54 thorbjoernl-desktop kernel: Xorg[834]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
Feb 14 19:59:54 thorbjoernl-desktop dbus-broker-launch[661]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Feb 14 19:59:54 thorbjoernl-desktop systemd-xdg-autostart-generator[869]: Configuration file /etc/xdg/autostart/timekpr-client.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Feb 14 19:59:55 thorbjoernl-desktop dbus-broker-launch[876]: Service file '/usr/share/dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Feb 14 19:59:55 thorbjoernl-desktop dbus-broker-launch[876]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
Feb 14 19:59:55 thorbjoernl-desktop dbus-broker-launch[876]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
Feb 14 19:59:55 thorbjoernl-desktop dbus-broker-launch[876]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
Feb 14 19:59:55 thorbjoernl-desktop dbus-broker-launch[876]: Service file '/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Feb 14 19:59:55 thorbjoernl-desktop dbus-broker-launch[876]: Service file '/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
Feb 14 20:00:07 thorbjoernl-desktop kernel: Oops: 0000 [#1] PREEMPT SMP PTI
Feb 14 20:00:07 thorbjoernl-desktop kernel: CPU: 1 PID: 81 Comm: kworker/u8:6 Tainted: P           OE      6.6.10-1-MANJARO #1 09058216a4151ef643ec08e7c2fc4e2938993be0
Feb 14 20:00:07 thorbjoernl-desktop kernel: Hardware name: System manufacturer System Product Name/PRIME B250-PLUS, BIOS 0608 03/24/2017
Feb 14 20:00:07 thorbjoernl-desktop kernel: Workqueue: cfg80211 cfg80211_event_work [cfg80211]
Feb 14 20:00:07 thorbjoernl-desktop kernel: RIP: 0010:__cfg80211_connect_result+0x325/0x920 [cfg80211]
Feb 14 20:00:07 thorbjoernl-desktop kernel: Code: f6 74 1e 83 f9 0e 0f b7 d0 8d 79 01 40 0f 95 c6 48 0f a3 ca 0f 82 af 01 00 00 89 f9 66 85 c0 75 dd 41 80 8c 24 cc 00 00 00 01 <41> 8b 06 4c 89 e9 31 d2 41 89 84 24 c0 03 00 00 41 0f b7 46 04 66
Feb 14 20:00:07 thorbjoernl-desktop kernel: RSP: 0018:ffffc9000076bd90 EFLAGS: 00010202
Feb 14 20:00:07 thorbjoernl-desktop kernel: RAX: 0000000000000000 RBX: ffff888102bed818 RCX: 0000000000000001
Feb 14 20:00:07 thorbjoernl-desktop kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff888111c67f00
Feb 14 20:00:07 thorbjoernl-desktop kernel: RBP: ffffc9000076bde0 R08: 0000000000000038 R09: 0000000000000000
Feb 14 20:00:07 thorbjoernl-desktop kernel: R10: 0000000000000002 R11: 0000000000000000 R12: ffff888111c67800
Feb 14 20:00:07 thorbjoernl-desktop kernel: R13: ffff888111c67c30 R14: 0000000000000000 R15: 0000000000000001
Feb 14 20:00:07 thorbjoernl-desktop kernel: FS:  0000000000000000(0000) GS:ffff888a0ec80000(0000) knlGS:0000000000000000
Feb 14 20:00:07 thorbjoernl-desktop kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Feb 14 20:00:07 thorbjoernl-desktop kernel: CR2: 0000000000000000 CR3: 0000000518820002 CR4: 00000000003706e0
Feb 14 20:00:07 thorbjoernl-desktop kernel: DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
Feb 14 20:00:07 thorbjoernl-desktop kernel: DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Feb 14 20:00:07 thorbjoernl-desktop kernel: Call Trace:
Feb 14 20:00:07 thorbjoernl-desktop kernel:  <TASK>
Feb 14 20:00:07 thorbjoernl-desktop kernel:  ? __die+0x23/0x70
Feb 14 20:00:07 thorbjoernl-desktop kernel:  ? page_fault_oops+0x171/0x4e0
Feb 14 20:00:07 thorbjoernl-desktop kernel:  ? try_to_wake_up+0x20a/0x640
Feb 14 20:00:07 thorbjoernl-desktop kernel:  ? exc_page_fault+0x7f/0x180
Feb 14 20:00:07 thorbjoernl-desktop kernel:  ? asm_exc_page_fault+0x26/0x30
Feb 14 20:00:07 thorbjoernl-desktop kernel:  ? __cfg80211_connect_result+0x325/0x920 [cfg80211 2a612b830d3c9c5961b0330802770d4097d1b0f7]
Feb 14 20:00:07 thorbjoernl-desktop kernel:  ? finish_task_switch.isra.0+0x94/0x2f0
Feb 14 20:00:07 thorbjoernl-desktop kernel:  ? cfg80211_process_wdev_events+0x84/0x1c0 [cfg80211 2a612b830d3c9c5961b0330802770d4097d1b0f7]
Feb 14 20:00:07 thorbjoernl-desktop kernel:  cfg80211_process_wdev_events+0x84/0x1c0 [cfg80211 2a612b830d3c9c5961b0330802770d4097d1b0f7]
Feb 14 20:00:07 thorbjoernl-desktop kernel:  cfg80211_process_rdev_events+0x2a/0x40 [cfg80211 2a612b830d3c9c5961b0330802770d4097d1b0f7]
Feb 14 20:00:07 thorbjoernl-desktop kernel:  cfg80211_event_work+0x29/0x40 [cfg80211 2a612b830d3c9c5961b0330802770d4097d1b0f7]
Feb 14 20:00:07 thorbjoernl-desktop kernel:  process_one_work+0x171/0x340
Feb 14 20:00:07 thorbjoernl-desktop kernel:  worker_thread+0x27b/0x3a0
Feb 14 20:00:07 thorbjoernl-desktop kernel:  ? __pfx_worker_thread+0x10/0x10
Feb 14 20:00:07 thorbjoernl-desktop kernel:  kthread+0xe5/0x120
Feb 14 20:00:07 thorbjoernl-desktop kernel:  ? __pfx_kthread+0x10/0x10
Feb 14 20:00:07 thorbjoernl-desktop kernel:  ret_from_fork+0x31/0x50
Feb 14 20:00:07 thorbjoernl-desktop kernel:  ret_from_fork_asm+0x1b/0x30
Feb 14 20:00:07 thorbjoernl-desktop kernel:  </TASK>
Feb 14 20:00:07 thorbjoernl-desktop kernel: Modules linked in: tun nf_tables ip6table_nat iptable_nat nf_nat overlay qrtr 8021q garp mrp stp llc ip6t_REJECT nf_reject_ipv6 xt_hl ip6t_rt ipt_REJECT nf_reject_ipv4 xt_LOG nf_log_syslog xt_recent xt_limit xt_addrtype xt_tcpudp xt_conntrack nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c ip6table_filter ip6_tables iptable_filter nvidia_uvm(POE) nvidia_drm(POE) nvidia_modeset(POE) 88XXau(OE) xpad ff_memless cfg80211 mousedev nvidia(POE) snd_soc_avs snd_soc_hda_codec snd_hda_ext_core snd_soc_core snd_compress intel_rapl_msr ac97_bus intel_rapl_common snd_hda_codec_realtek intel_tcc_cooling snd_hda_codec_generic snd_hda_codec_hdmi snd_pcm_dmaengine x86_pkg_temp_thermal intel_powerclamp snd_hda_intel coretemp eeepc_wmi crct10dif_pclmul psmouse crc32_pclmul serio_raw polyval_clmulni snd_intel_dspcfg polyval_generic asus_wmi atkbd gf128mul libps2 ledtrig_audio vivaldi_fmap ghash_clmulni_intel snd_intel_sdw_acpi sparse_keymap sha512_ssse3 platform_profile sha256_ssse3 sha1_ssse3 i8042 aesni_intel serio
Feb 14 20:00:07 thorbjoernl-desktop kernel:  mei_hdcp snd_hda_codec iTCO_wdt mei_pxp intel_pmc_bxt crypto_simd ee1004 iTCO_vendor_support mxm_wmi rfkill snd_hda_core wmi_bmof cryptd snd_hwdep rapl snd_pcm r8169 intel_cstate i2c_i801 intel_uncore snd_timer realtek vfat snd i2c_smbus fat pcspkr mdio_devres mei_me libphy soundcore mei video wmi acpi_pad mac_hid crypto_user fuse loop dm_mod nfnetlink zram bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 usbhid crc32c_intel xhci_pci xhci_pci_renesas
Feb 14 20:00:07 thorbjoernl-desktop kernel: ---[ end trace 0000000000000000 ]---
Feb 14 20:00:21 thorbjoernl-desktop NetworkManager[663]: <warn>  [1707937221.0361] device (wlp0s20f0u8): Activation: (wifi) association took too long
Feb 14 20:00:21 thorbjoernl-desktop NetworkManager[663]: <warn>  [1707937221.0364] device (wlp0s20f0u8): Activation: (wifi) asking for new secrets
Feb 14 20:00:46 thorbjoernl-desktop lightdm[912]: gkr-pam: unable to locate daemon control file
Feb 14 20:00:46 thorbjoernl-desktop systemd-xdg-autostart-generator[938]: Configuration file /home/thorbjoernl/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
Feb 14 20:00:46 thorbjoernl-desktop systemd-journald[230]: File /var/log/journal/18e6f089491e4f28b8675d1f4f1184bf/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Feb 14 20:00:46 thorbjoernl-desktop systemd-xdg-autostart-generator[938]: Configuration file /home/thorbjoernl/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Feb 14 20:00:46 thorbjoernl-desktop systemd-xdg-autostart-generator[938]: Configuration file /etc/xdg/autostart/timekpr-client.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Feb 14 20:00:46 thorbjoernl-desktop dbus-broker-launch[948]: Service file '/usr/share/dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Feb 14 20:00:46 thorbjoernl-desktop dbus-broker-launch[948]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
Feb 14 20:00:46 thorbjoernl-desktop dbus-broker-launch[948]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
Feb 14 20:00:46 thorbjoernl-desktop dbus-broker-launch[948]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
Feb 14 20:00:46 thorbjoernl-desktop dbus-broker-launch[948]: Service file '/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Feb 14 20:00:46 thorbjoernl-desktop dbus-broker-launch[948]: Service file '/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
Feb 14 20:00:48 thorbjoernl-desktop systemd[1]: NetworkManager-wait-online.service: Failed with result 'exit-code'.
Feb 14 20:00:48 thorbjoernl-desktop systemd[1]: Failed to start Network Manager Wait Online.
Feb 14 20:00:49 thorbjoernl-desktop tumblerd[1068]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: cannot open shared object file: No such file or directory
Feb 14 20:00:49 thorbjoernl-desktop xdg-desktop-por[1091]: Choosing gtk.portal for org.freedesktop.impl.portal.Lockdown as a last-resort fallback
Feb 14 20:00:49 thorbjoernl-desktop xdg-desktop-por[1091]: The preferred method to match portal implementations to desktop environments is to use the portals.conf(5) configuration file
Feb 14 20:00:49 thorbjoernl-desktop gvfsd-trash[1277]: GFileInfo created without standard::name
Feb 14 20:00:49 thorbjoernl-desktop gvfsd-trash[1277]: file ../glib/gio/gfileinfo.c: line 1699 (g_file_info_get_name): should not be reached
Feb 14 20:00:50 thorbjoernl-desktop gvfsd-trash[1277]: GFileInfo created without standard::name
Feb 14 20:00:50 thorbjoernl-desktop gvfsd-trash[1277]: file ../glib/gio/gfileinfo.c: line 1699 (g_file_info_get_name): should not be reached
Feb 14 20:01:00 thorbjoernl-desktop kernel: exFAT-fs (sdd): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Feb 14 20:01:00 thorbjoernl-desktop gvfsd-trash[1277]: GFileInfo created without standard::name
Feb 14 20:01:00 thorbjoernl-desktop gvfsd-trash[1277]: file ../glib/gio/gfileinfo.c: line 1699 (g_file_info_get_name): should not be reached
Feb 14 20:02:19 thorbjoernl-desktop systemd[933]: pulseaudio.service: start operation timed out. Terminating.
Feb 14 20:02:19 thorbjoernl-desktop systemd[1]: rtkit-daemon.service: start operation timed out. Terminating.
Feb 14 20:02:19 thorbjoernl-desktop systemd[933]: xdg-desktop-portal.service: start operation timed out. Terminating.
Feb 14 20:02:19 thorbjoernl-desktop systemd[933]: pulseaudio.service: Failed with result 'timeout'.
Feb 14 20:02:19 thorbjoernl-desktop systemd[933]: Failed to start Sound Service.
Feb 14 20:03:49 thorbjoernl-desktop systemd[1]: rtkit-daemon.service: State 'stop-sigterm' timed out. Killing.
Feb 14 20:03:49 thorbjoernl-desktop systemd[933]: xdg-desktop-portal.service: State 'stop-sigterm' timed out. Killing.
Feb 14 20:03:49 thorbjoernl-desktop systemd[933]: pulseaudio.service: start operation timed out. Terminating.
Feb 14 20:03:49 thorbjoernl-desktop systemd[933]: pulseaudio.service: Failed with result 'timeout'.
Feb 14 20:03:49 thorbjoernl-desktop systemd[933]: Failed to start Sound Service.
Feb 14 20:05:19 thorbjoernl-desktop systemd[1]: rtkit-daemon.service: Processes still around after SIGKILL. Ignoring.
Feb 14 20:05:19 thorbjoernl-desktop systemd[933]: xdg-desktop-portal.service: Processes still around after SIGKILL. Ignoring.
Feb 14 20:05:20 thorbjoernl-desktop systemd[933]: pulseaudio.service: start operation timed out. Terminating.
Feb 14 20:05:20 thorbjoernl-desktop systemd[933]: pulseaudio.service: Failed with result 'timeout'.
Feb 14 20:05:20 thorbjoernl-desktop systemd[933]: Failed to start Sound Service.
Feb 14 20:06:10 thorbjoernl-desktop systemd[933]: dbus-:1.11-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
Feb 14 20:06:10 thorbjoernl-desktop systemd[933]: xfce4-notifyd.service: Failed with result 'exit-code'.
Feb 14 20:06:10 thorbjoernl-desktop systemd[933]: xdg-desktop-portal-gtk.service: Failed with result 'exit-code'.
Feb 14 20:06:10 thorbjoernl-desktop systemd[1]: sysstat-collect.service: Main process exited, code=killed, status=15/TERM
Feb 14 20:06:10 thorbjoernl-desktop systemd[1]: sysstat-collect.service: Failed with result 'signal'.
Feb 14 20:06:10 thorbjoernl-desktop dbus-broker-launch[661]: Activation request for 'org.freedesktop.RealtimeKit1' failed.
Feb 14 20:06:10 thorbjoernl-desktop pulseaudio[1686]: Mapping hdmi-stereo: snd_pcm_info() failed Permission denied:
Feb 14 20:06:11 thorbjoernl-desktop dbus-broker-launch[661]: Activation request for 'org.bluez' failed.
Feb 14 20:06:11 thorbjoernl-desktop dbus-broker-launch[661]: Activation request for 'org.freedesktop.RealtimeKit1' failed.
Feb 14 20:06:11 thorbjoernl-desktop pulseaudio[1686]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NameHasNoOwner: Could not activate remote peer: activation request failed: unit is invalid.
Feb 14 20:06:49 thorbjoernl-desktop systemd[1]: rtkit-daemon.service: State 'final-sigterm' timed out. Killing.
Feb 14 20:06:49 thorbjoernl-desktop systemd[933]: xdg-desktop-portal.service: State 'final-sigterm' timed out. Killing.
Feb 14 20:07:40 thorbjoernl-desktop systemd[1]: avahi-daemon.service: State 'stop-sigterm' timed out. Killing.
Feb 14 20:07:40 thorbjoernl-desktop systemd[1]: docker.service: State 'stop-sigterm' timed out. Killing.
Feb 14 20:07:40 thorbjoernl-desktop systemd[1]: tailscaled.service: State 'stop-sigterm' timed out. Killing.
Feb 14 20:07:40 thorbjoernl-desktop systemd[1]: tailscaled.service: Failed to kill control group /system.slice/tailscaled.service, ignoring: Invalid argument
Feb 14 20:07:40 thorbjoernl-desktop systemd[1]: session-2.scope: Stopping timed out. Killing.
Feb 14 20:07:40 thorbjoernl-desktop systemd[1]: session-2.scope: Failed to kill control group /user.slice/user-1000.slice/session-2.scope, ignoring: Invalid argument
Feb 14 20:07:40 thorbjoernl-desktop systemd[1]: session-2.scope: Failed with result 'timeout'.
Feb 14 20:07:40 thorbjoernl-desktop systemd[933]: gvfs-daemon.service: Failed to kill control group /user.slice/user-1000.slice/user@1000.service/session.slice/gvfs-daemon.service, ignoring: Invalid argument
Feb 14 20:07:45 thorbjoernl-desktop systemd[933]: at-spi-dbus-bus.service: State 'stop-sigterm' timed out. Killing.
Feb 14 20:07:50 thorbjoernl-desktop systemd[933]: at-spi-dbus-bus.service: Processes still around after SIGKILL. Ignoring.
Feb 14 20:07:56 thorbjoernl-desktop systemd[933]: at-spi-dbus-bus.service: State 'final-sigterm' timed out. Killing.
Feb 14 20:08:01 thorbjoernl-desktop systemd[933]: at-spi-dbus-bus.service: Processes still around after final SIGKILL. Entering failed mode.
Feb 14 20:08:01 thorbjoernl-desktop systemd[933]: at-spi-dbus-bus.service: Failed with result 'timeout'.
Feb 14 20:08:19 thorbjoernl-desktop systemd[1]: rtkit-daemon.service: Processes still around after final SIGKILL. Entering failed mode.
Feb 14 20:08:19 thorbjoernl-desktop systemd[933]: xdg-desktop-portal.service: Processes still around after final SIGKILL. Entering failed mode.
Feb 14 20:08:19 thorbjoernl-desktop systemd[1]: rtkit-daemon.service: Failed with result 'timeout'.
Feb 14 20:08:19 thorbjoernl-desktop systemd[933]: xdg-desktop-portal.service: Failed with result 'timeout'.
Feb 14 20:09:10 thorbjoernl-desktop systemd[1]: avahi-daemon.service: Processes still around after SIGKILL. Ignoring.
Feb 14 20:09:10 thorbjoernl-desktop systemd[1]: docker.service: Processes still around after SIGKILL. Ignoring.
Feb 14 20:09:10 thorbjoernl-desktop systemd[933]: evolution-calendar-factory.service: State 'stop-sigterm' timed out. Killing.
Feb 14 20:09:10 thorbjoernl-desktop systemd[1]: tailscaled.service: Processes still around after SIGKILL. Ignoring.
Feb 14 20:09:10 thorbjoernl-desktop systemd[933]: evolution-calendar-factory.service: Failed to kill control group /user.slice/user-1000.slice/user@1000.service/app.slice/evolution-calendar-factory.service, ignoring: Invalid argument
Feb 14 20:09:40 thorbjoernl-desktop systemd[1]: user@1000.service: State 'stop-sigterm' timed out. Killing.
Feb 14 20:09:40 thorbjoernl-desktop systemd[1]: user@1000.service: Failed to kill control group /user.slice/user-1000.slice/user@1000.service, ignoring: Invalid argument
Feb 14 20:09:40 thorbjoernl-desktop systemd[1]: user@1000.service: Main process exited, code=killed, status=9/KILL
Feb 14 20:09:40 thorbjoernl-desktop systemd[1]: user@1000.service: Failed with result 'timeout'.
Feb 14 20:10:40 thorbjoernl-desktop systemd[1]: avahi-daemon.service: State 'final-sigterm' timed out. Killing.
Feb 14 20:10:40 thorbjoernl-desktop systemd[1]: docker.service: State 'final-sigterm' timed out. Killing.
Feb 14 20:10:40 thorbjoernl-desktop systemd[1]: tailscaled.service: State 'stop-post' timed out. Terminating.
Feb 14 20:12:10 thorbjoernl-desktop systemd[1]: avahi-daemon.service: Processes still around after final SIGKILL. Entering failed mode.
Feb 14 20:12:10 thorbjoernl-desktop systemd[1]: avahi-daemon.service: Failed with result 'timeout'.
Feb 14 20:12:10 thorbjoernl-desktop systemd[1]: docker.service: Processes still around after final SIGKILL. Entering failed mode.
Feb 14 20:12:10 thorbjoernl-desktop systemd[1]: docker.service: Failed with result 'timeout'.
Well, with both disks reporting:
I see nothing there. And this:
Shows many errors. Unfortunately, they tell me somewhere between nothing and squat. So I’m thinking we’ll have to wait for someone else that might be able to see something. Sorry.
:sob:
Edit:
Know what? Just thought of this, seeing as NetworkManager-wait-online also has problems, from within the chroot environment, please provide the output to the following:
journalctl -xeu NetworkManager-wait-online.service
and
systemctl status NetworkManager-wait-online.service
The logs provided indicates file inconsistencies.
Which is hard to say - but as your devices appear OK - at least known to smartctl - but file system errors can occur nonetheless.
If I were to troubleshoot my system - I would boot a live ISO and check the file systems on the unmounted root partition.
fsck /dev/sdXy -y
Then I would use the tools provided by pacman-contrib and pacutils to verify the files match the original package files. This will likely throw some false positives - so be sure to examine the output.
If I found inconsistencies - I would reinstall the package(s) …
Running paccheck --list-broken --files, only materialx shows up.
For this package it says /usr/share/mime/model/materialx.xml missing file.
This error disappeared after reinstalling the package.
Booting into the system now I still have issues with the internet, but I have noticed that I am able to ping an IP directly, but DNS seems broken (But at least NetworkManager is running so it’s going somewhere!)
Feb 16 14:55:54 thorbjoernl-desktop kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Feb 16 14:55:54 thorbjoernl-desktop kernel: x86/cpu: SGX disabled by BIOS.
Feb 16 14:55:54 thorbjoernl-desktop kernel: pci 0000:04:00.0: can't disable ASPM; OS doesn't have ASPM control
Feb 16 14:55:54 thorbjoernl-desktop kernel: resource: resource sanity check: requesting [mem 0x00000000fdffe800-0x00000000fe0007ff], which spans more than pnp 00:07 [mem 0xfdb00000-0xfdffffff]
Feb 16 14:55:54 thorbjoernl-desktop kernel: caller get_primary_reg_base+0x4f/0xb0 mapping multiple BARs
Feb 16 14:55:54 thorbjoernl-desktop kernel: ata5.00: supports DRM functions and may not be fully accessible
Feb 16 14:55:54 thorbjoernl-desktop kernel: usb: port power management may be unreliable
Feb 16 14:55:54 thorbjoernl-desktop systemd[1]: Configuration file /usr/lib/systemd/system/timekpr.service is marked executable. Please remove executable permission bits. Proceeding anyway.
Feb 16 14:55:53 thorbjoernl-desktop systemd-vconsole-setup[213]: KD_FONT_OP_GET failed while trying to get the font metadata: Invalid argument
Feb 16 14:55:53 thorbjoernl-desktop systemd-vconsole-setup[213]: Fonts will not be copied to remaining consoles
Feb 16 14:55:54 thorbjoernl-desktop kernel: r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
Feb 16 14:55:54 thorbjoernl-desktop systemd-vconsole-setup[371]: KD_FONT_OP_GET failed while trying to get the font metadata: Invalid argument
Feb 16 14:55:54 thorbjoernl-desktop systemd-vconsole-setup[371]: Fonts will not be copied to remaining consoles
Feb 16 14:55:55 thorbjoernl-desktop kernel: nvidia: loading out-of-tree module taints kernel.
Feb 16 14:55:55 thorbjoernl-desktop kernel: nvidia: module license 'NVIDIA' taints kernel.
Feb 16 14:55:55 thorbjoernl-desktop kernel: Disabling lock debugging due to kernel taint
Feb 16 14:55:55 thorbjoernl-desktop kernel: nvidia: module license taints kernel.
Feb 16 14:55:55 thorbjoernl-desktop kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  545.29.06  Thu Nov 16 01:59:08 UTC 2023
Feb 16 14:55:56 thorbjoernl-desktop kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Feb 16 14:55:57 thorbjoernl-desktop avahi-daemon[643]: *** WARNING: Detected another IPv4 mDNS stack running on this host. This makes mDNS unreliable and is thus not recommended. ***
Feb 16 14:55:57 thorbjoernl-desktop avahi-daemon[643]: *** WARNING: Detected another IPv6 mDNS stack running on this host. This makes mDNS unreliable and is thus not recommended. ***
Feb 16 14:55:57 thorbjoernl-desktop dhcpcd[648]: no interfaces have a carrier
Feb 16 14:56:01 thorbjoernl-desktop kernel: Xorg[839]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
Feb 16 14:56:01 thorbjoernl-desktop dbus-broker-launch[638]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Feb 16 14:56:01 thorbjoernl-desktop systemd-xdg-autostart-generator[902]: Configuration file /etc/xdg/autostart/timekpr-client.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Feb 16 14:56:02 thorbjoernl-desktop dbus-broker-launch[909]: Service file '/usr/share/dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Feb 16 14:56:02 thorbjoernl-desktop dbus-broker-launch[909]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
Feb 16 14:56:02 thorbjoernl-desktop dbus-broker-launch[909]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
Feb 16 14:56:02 thorbjoernl-desktop dbus-broker-launch[909]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
Feb 16 14:56:02 thorbjoernl-desktop dbus-broker-launch[909]: Service file '/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Feb 16 14:56:02 thorbjoernl-desktop dbus-broker-launch[909]: Service file '/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
Feb 16 14:56:06 thorbjoernl-desktop kernel: [UFW BLOCK] IN=br-b44f8ca0946b OUT= MAC= SRC=172.20.0.1 DST=224.0.0.252 LEN=65 TOS=0x00 PREC=0x00 TTL=255 ID=36143 PROTO=UDP SPT=5355 DPT=5355 LEN=45
Feb 16 14:56:06 thorbjoernl-desktop kernel: [UFW BLOCK] IN=br-b44f8ca0946b OUT= MAC= SRC=172.20.0.1 DST=224.0.0.252 LEN=65 TOS=0x00 PREC=0x00 TTL=255 ID=36202 PROTO=UDP SPT=5355 DPT=5355 LEN=45
Feb 16 14:56:06 thorbjoernl-desktop kernel: [UFW BLOCK] IN=br-b44f8ca0946b OUT= MAC= SRC=172.20.0.1 DST=224.0.0.252 LEN=65 TOS=0x00 PREC=0x00 TTL=255 ID=36252 PROTO=UDP SPT=5355 DPT=5355 LEN=45
Feb 16 14:56:07 thorbjoernl-desktop kernel: [UFW BLOCK] IN=br-b44f8ca0946b OUT= MAC= SRC=fe80:0000:0000:0000:0042:8eff:fee4:14a6 DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=85 TC=0 HOPLIMIT=255 FLOWLBL=745053 PROTO=UDP SPT=5355 DPT=5355 LEN=45
Feb 16 14:56:07 thorbjoernl-desktop kernel: [UFW BLOCK] IN=veth04765a2 OUT= MAC= SRC=fe80:0000:0000:0000:50d0:f7ff:feb5:db38 DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=85 TC=0 HOPLIMIT=255 FLOWLBL=839243 PROTO=UDP SPT=5355 DPT=5355 LEN=45
Feb 16 14:56:08 thorbjoernl-desktop kernel: [UFW BLOCK] IN=veth04765a2 OUT= MAC= SRC=fe80:0000:0000:0000:50d0:f7ff:feb5:db38 DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=85 TC=0 HOPLIMIT=255 FLOWLBL=839243 PROTO=UDP SPT=5355 DPT=5355 LEN=45
Feb 16 14:56:08 thorbjoernl-desktop kernel: [UFW BLOCK] IN=veth04765a2 OUT= MAC= SRC=fe80:0000:0000:0000:4c3c:cd74:8a94:52ce DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=85 TC=0 HOPLIMIT=255 FLOWLBL=213516 PROTO=UDP SPT=5355 DPT=5355 LEN=45
Feb 16 14:56:09 thorbjoernl-desktop lightdm[1302]: gkr-pam: unable to locate daemon control file
Feb 16 14:56:10 thorbjoernl-desktop systemd-xdg-autostart-generator[1567]: Configuration file /home/guest/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
Feb 16 14:56:10 thorbjoernl-desktop dbus-broker-launch[1580]: Service file '/usr/share/dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Feb 16 14:56:10 thorbjoernl-desktop dbus-broker-launch[1580]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
Feb 16 14:56:10 thorbjoernl-desktop dbus-broker-launch[1580]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
Feb 16 14:56:10 thorbjoernl-desktop dbus-broker-launch[1580]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
Feb 16 14:56:10 thorbjoernl-desktop dbus-broker-launch[1580]: Service file '/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Feb 16 14:56:10 thorbjoernl-desktop dbus-broker-launch[1580]: Service file '/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
Feb 16 14:56:12 thorbjoernl-desktop pulseaudio[1660]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NameHasNoOwner: Could not activate remote peer: unit failed.
Feb 16 14:56:12 thorbjoernl-desktop tumblerd[1733]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: cannot open shared object file: No such file or directory
Feb 16 14:56:12 thorbjoernl-desktop xdg-desktop-por[1779]: Choosing gtk.portal for org.freedesktop.impl.portal.Lockdown as a last-resort fallback
Feb 16 14:56:12 thorbjoernl-desktop xdg-desktop-por[1779]: The preferred method to match portal implementations to desktop environments is to use the portals.conf(5) configuration file
Feb 16 14:56:12 thorbjoernl-desktop xdg-desktop-por[1779]: No skeleton to export
Feb 16 14:56:12 thorbjoernl-desktop xdg-desktop-por[1779]: Choosing gtk.portal for org.freedesktop.impl.portal.FileChooser as a last-resort fallback
Feb 16 14:56:12 thorbjoernl-desktop xdg-desktop-por[1779]: Choosing gtk.portal for org.freedesktop.impl.portal.AppChooser as a last-resort fallback
Feb 16 14:56:12 thorbjoernl-desktop xdg-desktop-por[1779]: Choosing gtk.portal for org.freedesktop.impl.portal.Print as a last-resort fallback
Feb 16 14:56:12 thorbjoernl-desktop xdg-desktop-por[1779]: Choosing gtk.portal for org.freedesktop.impl.portal.Notification as a last-resort fallback
Feb 16 14:56:12 thorbjoernl-desktop xdg-desktop-por[1779]: Choosing gtk.portal for org.freedesktop.impl.portal.Inhibit as a last-resort fallback
Feb 16 14:56:12 thorbjoernl-desktop xdg-desktop-por[1779]: Choosing gtk.portal for org.freedesktop.impl.portal.Access as a last-resort fallback
Feb 16 14:56:12 thorbjoernl-desktop xdg-desktop-por[1779]: Choosing gtk.portal for org.freedesktop.impl.portal.Account as a last-resort fallback
Feb 16 14:56:12 thorbjoernl-desktop xdg-desktop-por[1779]: Choosing gtk.portal for org.freedesktop.impl.portal.Email as a last-resort fallback
Feb 16 14:56:12 thorbjoernl-desktop xdg-desktop-por[1779]: Choosing gtk.portal for org.freedesktop.impl.portal.DynamicLauncher as a last-resort fallback
Feb 16 14:56:13 thorbjoernl-desktop evolution-calen[1950]: e_source_unset_last_credentials_required_arguments: assertion 'E_IS_SOURCE (source)' failed
Feb 16 14:56:16 thorbjoernl-desktop systemd[1562]: dbus-:1.11-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
Feb 16 14:56:16 thorbjoernl-desktop systemd[1562]: xfce4-notifyd.service: Failed with result 'exit-code'.
Feb 16 14:56:16 thorbjoernl-desktop systemd[1562]: xdg-desktop-portal-gtk.service: Failed with result 'exit-code'.
Feb 16 14:56:16 thorbjoernl-desktop wpa_supplicant[767]: bgscan simple: Failed to enable signal strength monitoring
Feb 16 14:56:18 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC= SRC=fe80:0000:0000:0000:e39c:8e96:7aec:0d6b DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=85 TC=0 HOPLIMIT=255 FLOWLBL=941411 PROTO=UDP SPT=5355 DPT=5355 LEN=45
Feb 16 14:56:18 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-2
Feb 16 14:56:18 thorbjoernl-desktop NetworkManager[641]: <warn>  [1708091778.4796] dns-sd-resolved[050d6e609acb9b85]: send-updates SetLinkDNS@3 failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: Invalid DNS server address
Feb 16 14:56:19 thorbjoernl-desktop dhcpcd[648]: veth04765a2: no IPv6 Routers available
Feb 16 14:56:20 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-3
Feb 16 14:56:21 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-4
Feb 16 14:56:21 thorbjoernl-desktop NetworkManager[641]: <warn>  [1708091781.3298] dns-sd-resolved[050d6e609acb9b85]: send-updates SetLinkDNS@3 failed: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: Invalid DNS server address
Feb 16 14:56:21 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC= SRC=192.168.0.193 DST=224.0.0.252 LEN=65 TOS=0x00 PREC=0x00 TTL=255 ID=41126 PROTO=UDP SPT=5355 DPT=5355 LEN=45
Feb 16 14:56:21 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC= SRC=192.168.0.193 DST=224.0.0.252 LEN=65 TOS=0x00 PREC=0x00 TTL=255 ID=41142 PROTO=UDP SPT=5355 DPT=5355 LEN=45
Feb 16 14:56:21 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC= SRC=192.168.0.193 DST=224.0.0.252 LEN=65 TOS=0x00 PREC=0x00 TTL=255 ID=41196 PROTO=UDP SPT=5355 DPT=5355 LEN=45
Feb 16 14:56:22 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-5
Feb 16 14:56:22 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.193 LEN=394 TOS=0x00 PREC=0x00 TTL=64 ID=15641 DF PROTO=UDP SPT=49087 DPT=38111 LEN=374
Feb 16 14:56:22 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.193 LEN=403 TOS=0x00 PREC=0x00 TTL=64 ID=15642 DF PROTO=UDP SPT=49087 DPT=38111 LEN=383
Feb 16 14:56:22 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.193 LEN=466 TOS=0x00 PREC=0x00 TTL=64 ID=15643 DF PROTO=UDP SPT=49087 DPT=38111 LEN=446
Feb 16 14:56:22 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.193 LEN=403 TOS=0x00 PREC=0x00 TTL=64 ID=15644 DF PROTO=UDP SPT=55840 DPT=38111 LEN=383
Feb 16 14:56:22 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.193 LEN=442 TOS=0x00 PREC=0x00 TTL=64 ID=15645 DF PROTO=UDP SPT=55840 DPT=38111 LEN=422
Feb 16 14:56:22 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.193 LEN=474 TOS=0x00 PREC=0x00 TTL=64 ID=15646 DF PROTO=UDP SPT=35467 DPT=38111 LEN=454
Feb 16 14:56:22 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.193 LEN=403 TOS=0x00 PREC=0x00 TTL=64 ID=15647 DF PROTO=UDP SPT=36435 DPT=38111 LEN=383
Feb 16 14:56:22 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.193 LEN=462 TOS=0x00 PREC=0x00 TTL=64 ID=15648 DF PROTO=UDP SPT=36435 DPT=38111 LEN=442
Feb 16 14:56:22 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.193 LEN=456 TOS=0x00 PREC=0x00 TTL=64 ID=15649 DF PROTO=UDP SPT=43854 DPT=38111 LEN=436
Feb 16 14:56:23 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.193 LEN=466 TOS=0x00 PREC=0x00 TTL=64 ID=15710 DF PROTO=UDP SPT=52045 DPT=38111 LEN=446
Feb 16 14:56:23 thorbjoernl-desktop dhcpcd[648]: wlp0s20f0u8: DHCP lease expired
Feb 16 14:56:24 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT=wlp0s20f0u8 MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=328 TOS=0x10 PREC=0x00 TTL=127 ID=0 PROTO=UDP SPT=67 DPT=68 LEN=308
Feb 16 14:56:25 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-6
Feb 16 14:56:25 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-7
Feb 16 14:56:26 thorbjoernl-desktop lightdm[2134]: gkr-pam: unable to locate daemon control file
Feb 16 14:56:27 thorbjoernl-desktop systemd-xdg-autostart-generator[2278]: Configuration file /home/thorbjoernl/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
Feb 16 14:56:27 thorbjoernl-desktop systemd-xdg-autostart-generator[2278]: Configuration file /home/thorbjoernl/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Feb 16 14:56:27 thorbjoernl-desktop systemd-xdg-autostart-generator[2278]: Configuration file /etc/xdg/autostart/timekpr-client.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Feb 16 14:56:27 thorbjoernl-desktop dbus-broker-launch[2288]: Service file '/usr/share/dbus-1/services/org.xfce.Thunar.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Feb 16 14:56:27 thorbjoernl-desktop dbus-broker-launch[2288]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Cache1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Cache1'.
Feb 16 14:56:27 thorbjoernl-desktop dbus-broker-launch[2288]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Manager1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Manager1'.
Feb 16 14:56:27 thorbjoernl-desktop dbus-broker-launch[2288]: Service file '/usr/share/dbus-1/services/org.xfce.Tumbler.Thumbnailer1.service' is not named after the D-Bus name 'org.freedesktop.thumbnails.Thumbnailer1'.
Feb 16 14:56:27 thorbjoernl-desktop dbus-broker-launch[2288]: Service file '/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Feb 16 14:56:27 thorbjoernl-desktop dbus-broker-launch[2288]: Service file '/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
Feb 16 14:56:27 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-8
Feb 16 14:56:28 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-9
Feb 16 14:56:29 thorbjoernl-desktop tumblerd[2440]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: cannot open shared object file: No such file or directory
Feb 16 14:56:30 thorbjoernl-desktop xdg-desktop-por[2418]: Choosing gtk.portal for org.freedesktop.impl.portal.Lockdown as a last-resort fallback
Feb 16 14:56:30 thorbjoernl-desktop xdg-desktop-por[2418]: The preferred method to match portal implementations to desktop environments is to use the portals.conf(5) configuration file
Feb 16 14:56:30 thorbjoernl-desktop xdg-desktop-por[2418]: No skeleton to export
Feb 16 14:56:30 thorbjoernl-desktop xdg-desktop-por[2418]: Choosing gtk.portal for org.freedesktop.impl.portal.FileChooser as a last-resort fallback
Feb 16 14:56:30 thorbjoernl-desktop xdg-desktop-por[2418]: Choosing gtk.portal for org.freedesktop.impl.portal.AppChooser as a last-resort fallback
Feb 16 14:56:30 thorbjoernl-desktop xdg-desktop-por[2418]: Choosing gtk.portal for org.freedesktop.impl.portal.Print as a last-resort fallback
Feb 16 14:56:30 thorbjoernl-desktop xdg-desktop-por[2418]: Choosing gtk.portal for org.freedesktop.impl.portal.Notification as a last-resort fallback
Feb 16 14:56:30 thorbjoernl-desktop xdg-desktop-por[2418]: Choosing gtk.portal for org.freedesktop.impl.portal.Inhibit as a last-resort fallback
Feb 16 14:56:30 thorbjoernl-desktop xdg-desktop-por[2418]: Choosing gtk.portal for org.freedesktop.impl.portal.Access as a last-resort fallback
Feb 16 14:56:30 thorbjoernl-desktop xdg-desktop-por[2418]: Choosing gtk.portal for org.freedesktop.impl.portal.Account as a last-resort fallback
Feb 16 14:56:30 thorbjoernl-desktop xdg-desktop-por[2418]: Choosing gtk.portal for org.freedesktop.impl.portal.Email as a last-resort fallback
Feb 16 14:56:30 thorbjoernl-desktop xdg-desktop-por[2418]: Choosing gtk.portal for org.freedesktop.impl.portal.DynamicLauncher as a last-resort fallback
Feb 16 14:56:30 thorbjoernl-desktop pulseaudio[2407]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NameHasNoOwner: Could not activate remote peer: unit failed.
Feb 16 14:56:30 thorbjoernl-desktop gvfsd-trash[2637]: GFileInfo created without standard::name
Feb 16 14:56:30 thorbjoernl-desktop gvfsd-trash[2637]: file ../glib/gio/gfileinfo.c: line 1699 (g_file_info_get_name): should not be reached
Feb 16 14:56:32 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-10
Feb 16 14:56:32 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-11
Feb 16 14:56:35 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-12
Feb 16 14:56:55 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=466 TOS=0x00 PREC=0x00 TTL=64 ID=18347 DF PROTO=UDP SPT=37683 DPT=42323 LEN=446
Feb 16 14:56:55 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-13
Feb 16 14:57:18 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=466 TOS=0x00 PREC=0x00 TTL=64 ID=31070 DF PROTO=UDP SPT=44910 DPT=48617 LEN=446
Feb 16 14:57:36 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-14
Feb 16 14:57:42 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=466 TOS=0x00 PREC=0x00 TTL=64 ID=46085 DF PROTO=UDP SPT=59823 DPT=44079 LEN=446
Feb 16 14:57:55 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-15
Feb 16 14:58:06 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=466 TOS=0x00 PREC=0x00 TTL=64 ID=56300 DF PROTO=UDP SPT=46873 DPT=46684 LEN=446
Feb 16 14:58:06 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=394 TOS=0x00 PREC=0x00 TTL=64 ID=56301 DF PROTO=UDP SPT=60322 DPT=46684 LEN=374
Feb 16 14:58:30 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=466 TOS=0x00 PREC=0x00 TTL=64 ID=4934 DF PROTO=UDP SPT=56443 DPT=49627 LEN=446
Feb 16 14:58:36 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-16
Feb 16 14:58:55 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-17
Feb 16 14:58:56 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=466 TOS=0x00 PREC=0x00 TTL=64 ID=30387 DF PROTO=UDP SPT=37796 DPT=42659 LEN=446
Feb 16 14:59:17 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=394 TOS=0x00 PREC=0x00 TTL=64 ID=37584 DF PROTO=UDP SPT=40249 DPT=44899 LEN=374
Feb 16 14:59:36 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-18
Feb 16 14:59:40 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=466 TOS=0x00 PREC=0x00 TTL=64 ID=48022 DF PROTO=UDP SPT=37303 DPT=55137 LEN=446
Feb 16 14:59:45 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=01:00:5e:00:00:01:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=4390 DF PROTO=2
Feb 16 14:59:55 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-19
Feb 16 15:00:24 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=466 TOS=0x00 PREC=0x00 TTL=64 ID=12584 DF PROTO=UDP SPT=60461 DPT=43711 LEN=446
Feb 16 15:00:24 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=394 TOS=0x00 PREC=0x00 TTL=64 ID=12585 DF PROTO=UDP SPT=39568 DPT=43711 LEN=374
Feb 16 15:00:35 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-20
Feb 16 15:00:49 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=394 TOS=0x00 PREC=0x00 TTL=64 ID=32366 DF PROTO=UDP SPT=55670 DPT=33441 LEN=374
Feb 16 15:00:55 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-21
Feb 16 15:01:12 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=394 TOS=0x00 PREC=0x00 TTL=64 ID=38381 DF PROTO=UDP SPT=50978 DPT=49886 LEN=374
Feb 16 15:01:34 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=466 TOS=0x00 PREC=0x00 TTL=64 ID=43890 DF PROTO=UDP SPT=38189 DPT=55917 LEN=446
Feb 16 15:01:35 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-22
Feb 16 15:01:43 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC= SRC=fe80:0000:0000:0000:e39c:8e96:7aec:0d6b DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=75 TC=0 HOPLIMIT=255 FLOWLBL=941411 PROTO=UDP SPT=5355 DPT=5355 LEN=35
Feb 16 15:01:43 thorbjoernl-desktop kernel: [UFW BLOCK] IN=br-b44f8ca0946b OUT= MAC= SRC=fe80:0000:0000:0000:0042:8eff:fee4:14a6 DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=75 TC=0 HOPLIMIT=255 FLOWLBL=745053 PROTO=UDP SPT=5355 DPT=5355 LEN=35
Feb 16 15:01:43 thorbjoernl-desktop kernel: [UFW BLOCK] IN=veth04765a2 OUT= MAC= SRC=fe80:0000:0000:0000:4c3c:cd74:8a94:52ce DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=75 TC=0 HOPLIMIT=255 FLOWLBL=213516 PROTO=UDP SPT=5355 DPT=5355 LEN=35
Feb 16 15:01:43 thorbjoernl-desktop kernel: [UFW BLOCK] IN=br-b44f8ca0946b OUT= MAC= SRC=172.20.0.1 DST=224.0.0.252 LEN=55 TOS=0x00 PREC=0x00 TTL=255 ID=4889 PROTO=UDP SPT=5355 DPT=5355 LEN=35
Feb 16 15:01:44 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC= SRC=fe80:0000:0000:0000:e39c:8e96:7aec:0d6b DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=75 TC=0 HOPLIMIT=255 FLOWLBL=941411 PROTO=UDP SPT=5355 DPT=5355 LEN=35
Feb 16 15:01:44 thorbjoernl-desktop kernel: [UFW BLOCK] IN=veth04765a2 OUT= MAC= SRC=fe80:0000:0000:0000:4c3c:cd74:8a94:52ce DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=75 TC=0 HOPLIMIT=255 FLOWLBL=213516 PROTO=UDP SPT=5355 DPT=5355 LEN=35
Feb 16 15:01:44 thorbjoernl-desktop kernel: [UFW BLOCK] IN=br-b44f8ca0946b OUT= MAC= SRC=fe80:0000:0000:0000:0042:8eff:fee4:14a6 DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=75 TC=0 HOPLIMIT=255 FLOWLBL=745053 PROTO=UDP SPT=5355 DPT=5355 LEN=35
Feb 16 15:01:45 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC= SRC=fe80:0000:0000:0000:e39c:8e96:7aec:0d6b DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=75 TC=0 HOPLIMIT=255 FLOWLBL=941411 PROTO=UDP SPT=5355 DPT=5355 LEN=35
Feb 16 15:01:45 thorbjoernl-desktop kernel: [UFW BLOCK] IN=br-b44f8ca0946b OUT= MAC= SRC=fe80:0000:0000:0000:0042:8eff:fee4:14a6 DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=75 TC=0 HOPLIMIT=255 FLOWLBL=745053 PROTO=UDP SPT=5355 DPT=5355 LEN=35
Feb 16 15:01:45 thorbjoernl-desktop kernel: [UFW BLOCK] IN=veth04765a2 OUT= MAC= SRC=fe80:0000:0000:0000:4c3c:cd74:8a94:52ce DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=75 TC=0 HOPLIMIT=255 FLOWLBL=213516 PROTO=UDP SPT=5355 DPT=5355 LEN=35
Feb 16 15:01:47 thorbjoernl-desktop kernel: [UFW BLOCK] IN=veth04765a2 OUT= MAC= SRC=fe80:0000:0000:0000:4c3c:cd74:8a94:52ce DST=ff02:0000:0000:0000:0000:0000:0001:0003 LEN=75 TC=0 HOPLIMIT=255 FLOWLBL=213516 PROTO=UDP SPT=5355 DPT=5355 LEN=35
Feb 16 15:01:55 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-23
Feb 16 15:02:23 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=466 TOS=0x00 PREC=0x00 TTL=64 ID=4668 DF PROTO=UDP SPT=60450 DPT=36445 LEN=446
Feb 16 15:02:23 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=394 TOS=0x00 PREC=0x00 TTL=64 ID=4669 DF PROTO=UDP SPT=34042 DPT=36445 LEN=374
Feb 16 15:02:35 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-24
Feb 16 15:02:46 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=394 TOS=0x00 PREC=0x00 TTL=64 ID=9786 DF PROTO=UDP SPT=34014 DPT=57334 LEN=374
Feb 16 15:02:55 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-25
Feb 16 15:03:08 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=394 TOS=0x00 PREC=0x00 TTL=64 ID=29322 DF PROTO=UDP SPT=37928 DPT=38863 LEN=374
Feb 16 15:03:34 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=466 TOS=0x00 PREC=0x00 TTL=64 ID=29754 DF PROTO=UDP SPT=52485 DPT=50519 LEN=446
Feb 16 15:03:36 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-26
Feb 16 15:03:55 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=01:00:5e:00:00:01:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=60349 DF PROTO=2
Feb 16 15:03:56 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-27
Feb 16 15:04:24 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=466 TOS=0x00 PREC=0x00 TTL=64 ID=58860 DF PROTO=UDP SPT=48412 DPT=42641 LEN=446
Feb 16 15:04:24 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=394 TOS=0x00 PREC=0x00 TTL=64 ID=58861 DF PROTO=UDP SPT=36114 DPT=42641 LEN=374
Feb 16 15:04:24 thorbjoernl-desktop tumblerd[3423]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: cannot open shared object file: No such file or directory
Feb 16 15:04:36 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-28
Feb 16 15:04:49 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=466 TOS=0x00 PREC=0x00 TTL=64 ID=8369 DF PROTO=UDP SPT=53280 DPT=48486 LEN=446
Feb 16 15:04:56 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-29
Feb 16 15:05:09 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=466 TOS=0x00 PREC=0x00 TTL=64 ID=12510 DF PROTO=UDP SPT=49777 DPT=43073 LEN=446
Feb 16 15:05:36 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=466 TOS=0x00 PREC=0x00 TTL=64 ID=21073 DF PROTO=UDP SPT=55812 DPT=33896 LEN=446
Feb 16 15:05:36 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-30
Feb 16 15:05:55 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-31
Feb 16 15:06:00 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=01:00:5e:00:00:01:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=626 DF PROTO=2
Feb 16 15:06:26 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=466 TOS=0x00 PREC=0x00 TTL=64 ID=47424 DF PROTO=UDP SPT=42511 DPT=36718 LEN=446
Feb 16 15:06:26 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=394 TOS=0x00 PREC=0x00 TTL=64 ID=47425 DF PROTO=UDP SPT=38661 DPT=36718 LEN=374
Feb 16 15:06:34 thorbjoernl-desktop dhcpcd[648]: wlp0s20f0u8: DHCPv6 lease expired
Feb 16 15:06:36 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-32
Feb 16 15:06:55 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-33
Feb 16 15:06:59 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=466 TOS=0x00 PREC=0x00 TTL=64 ID=4136 DF PROTO=UDP SPT=35971 DPT=40633 LEN=446
Feb 16 15:07:20 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=466 TOS=0x00 PREC=0x00 TTL=64 ID=10002 DF PROTO=UDP SPT=60877 DPT=49399 LEN=446
Feb 16 15:07:36 thorbjoernl-desktop avahi-daemon[643]: Host name conflict, retrying with thorbjoernl-desktop-34
Feb 16 15:07:46 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=394 TOS=0x00 PREC=0x00 TTL=64 ID=14155 DF PROTO=UDP SPT=40272 DPT=44580 LEN=374
Feb 16 15:07:46 thorbjoernl-desktop kernel: [UFW BLOCK] IN=wlp0s20f0u8 OUT= MAC=9c:53:22:34:f0:93:84:1e:a3:93:88:6c:08:00 SRC=192.168.0.1 DST=192.168.0.76 LEN=403 TOS=0x00 PREC=0x00 TTL=64 ID=14156 DF PROTO=UDP SPT=40272 DPT=44580 LEN=383
I assume it has something to do with Avahi-daemon:
So, how is your DNS configured? Check the output of:
cat /etc/resolv.conf
you could be using a VPN which - possibly - do not restore system DNS upon disconnect.
You can find soem basic help with [root tip] [How To] Basic network know-how and troubleshooting
If you issue is VPN related you may need to look at your resolver - switching from openresolv to systemd-resolved work for NordVPN.
/etc/resolv.conf
# This is /run/systemd/resolve/stub-resolv.conf managed by man:systemd-resolved(8).
# Do not edit.
# This file might be symlinked as /etc/resolv.conf. If you're looking at
# /etc/resolv.conf and seeing this text, you have followed the symlink.
# This is a dynamic resolv.conf file for connecting local clients to the
# internal DNS stub resolver of systemd-resolved. This file lists all
# configured search domains.
# Run "resolvectl status" to see details about the uplink DNS servers
# currently in use.
# Third party programs should typically not access this file directly, but only
# through the symlink at /etc/resolv.conf. To manage man:resolv.conf(5) in a
# different way, replace this symlink by a static file or a different symlink.
# See man:systemd-resolved.service(8) for details about the supported modes of
# operation for /etc/resolv.conf.
nameserver 127.0.0.53
options edns0 trust-ad
search .
The only VPN I have running is Tailscale. I’ll try disabling it, and work my way through that debugging thread.
Hmmm…
Please provide the output of:
stat /etc/resolv.conf
Are you using systemd-resolved?
While trying to get that info the system ended up completely freezing, requiring a hard reset. It looks like I can’t get it via a chroot from my USB either (it shows very different values so I assume it accesses the file of the USB, not the actual system).
I think I will just try to reinstall the system and see if that improves things (I have backups). At this point there are so many weird intermittent issues that show up, that I think it will be quicker. And if it doesn’t, at least I’ll have some more confidence that it is in fact a hardware issue.
I appreciate everyone taking the time to help though.
Sound reasonable.
