Last night I updated my machine and turned it off. This morning when I booted up I had no network via LAN. after hooking up a Wi-Fi dongle. I got this inxi
#################### inxi -Fxzc0 ########################
System: Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: KDE Plasma 5.20.2 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASUSTeK model: H110M-C v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 0310 date: 09/02/2015
CPU: Info: Quad Core model: Intel Core i5-6600K bits: 64 type: MCP arch: Skylake-S rev: 3
L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28009
Speed: 2800 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 2800 2: 2800 3: 2800
4: 2800
Graphics: Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: Micro-Star MSI driver: nvidia
v: 450.80.02 bus ID: 01:00.0
Display: x11 server: X.Org 1.20.9 driver: nvidia s-res: 3840x1080
OpenGL: renderer: GeForce GTX 960/PCIe/SSE2 v: 4.6.0 NVIDIA 450.80.02
direct render: Yes
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1f.3
Device-2: NVIDIA GM206 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 01:00.1
Sound Server: ALSA v: k5.8.18-1-MANJARO
Network: Message: No Device data found.
Device-1: Qualcomm Atheros AR9271 802.11n type: USB driver: ath9k_htc bus ID: 1-2:7
IF: wlp0s20f0u2 state: up mac: <filter>
Device-2: ATHEROS USB2.0 WLAN type: USB driver: hid-generic,usbhid bus ID: 1-8.2:6
Drives: Local Storage: total: 2.87 TiB used: 125.72 GiB (4.3%)
ID-1: /dev/sda vendor: Western Digital model: WD20EZRX-00D8PB0 size: 1.82 TiB
ID-2: /dev/sdb vendor: Western Digital model: WD10EZRX-00L4HB0 size: 931.51 GiB
ID-3: /dev/sdc vendor: SanDisk model: SD8SBAT128G1002 size: 119.24 GiB
ID-4: /dev/sdd type: USB model: SMI USB size: 7.50 GiB
ID-5: /dev/sde type: USB vendor: Philips model: USB Flash Drive size: 14.44 GiB
Partition: ID-1: / size: 1.79 TiB used: 39.81 GiB (2.2%) fs: ext4 dev: /dev/sda2
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 46 C
Info: Processes: 198 Uptime: 44m Memory: 15.57 GiB used: 3.13 GiB (20.1%) Init: systemd
Compilers: gcc: 10.2.0 clang: 10.0.1 Packages: 1255 Client: KDE Plasma v: 5.20.2
inxi: 3.1.08
looking at my PCI buses I couldn’t find my network device either
#################### lspci -vnn ########################
00:00.0 Host bridge [0600]: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Host Bridge/DRAM Registers [8086:191f] (rev 07)
Subsystem: ASUSTeK Computer Inc. Device [1043:8694]
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
Kernel driver in use: skl_uncore
00:01.0 PCI bridge [0604]: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) [8086:1901] (rev 07) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 120
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff [size=4K]
Memory behind bridge: de000000-df0fffff [size=17M]
Prefetchable memory behind bridge: 00000000c0000000-00000000d1ffffff [size=288M]
Kernel driver in use: pcieport
00:14.0 USB controller [0c03]: Intel Corporation 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller [8086:a12f] (rev 31) (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 124
Memory at df110000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:16.0 Communication controller [0780]: Intel Corporation 100 Series/C230 Series Chipset Family MEI Controller #1 [8086:a13a] (rev 31)
Flags: bus master, fast devsel, latency 0, IRQ 125
Memory at df12d000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:17.0 SATA controller [0106]: Intel Corporation Q170/Q150/B150/H170/H110/Z170/CM236 Chipset SATA Controller [AHCI Mode] [8086:a102] (rev 31) (prog-if 01 [AHCI 1.0])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 123
Memory at df128000 (32-bit, non-prefetchable) [size=8K]
Memory at df12c000 (32-bit, non-prefetchable) [size=256]
I/O ports at f050 [size=8]
I/O ports at f040 [size=4]
I/O ports at f020 [size=32]
Memory at df12b000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:1c.0 PCI bridge [0604]: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #5 [8086:a114] (rev f1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 121
Bus: primary=00, secondary=02, subordinate=03, sec-latency=0
I/O behind bridge: [disabled]
Memory behind bridge: [disabled]
Prefetchable memory behind bridge: [disabled]
00:1d.0 PCI bridge [0604]: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #9 [8086:a118] (rev f1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 122
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
I/O behind bridge: 00002000-00002fff [size=4K]
Memory behind bridge: a8800000-a89fffff [size=2M]
Prefetchable memory behind bridge: 00000000a8a00000-00000000a8bfffff [size=2M]
00:1f.0 ISA bridge [0601]: Intel Corporation H110 Chipset LPC/eSPI Controller [8086:a143] (rev 31)
00:1f.2 Memory controller [0580]: Intel Corporation 100 Series/C230 Series Chipset Family Power Management Controller [8086:a121] (rev 31)
Flags: fast devsel
Memory at df124000 (32-bit, non-prefetchable) [disabled] [size=16K]
00:1f.3 Audio device [0403]: Intel Corporation 100 Series/C230 Series Chipset Family HD Audio Controller [8086:a170] (rev 31)
Subsystem: ASUSTeK Computer Inc. Device [1043:86c7]
Flags: bus master, fast devsel, latency 32, IRQ 126
Memory at df120000 (64-bit, non-prefetchable) [size=16K]
Memory at df100000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1f.4 SMBus [0c05]: Intel Corporation 100 Series/C230 Series Chipset Family SMBus [8086:a123] (rev 31)
Flags: medium devsel, IRQ 16
Memory at df12a000 (64-bit, non-prefetchable) [size=256]
I/O ports at f000 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GM206 [GeForce GTX 960] [10de:1401] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Micro-Star International Co., Ltd. [MSI] Device [1462:3202]
Flags: bus master, fast devsel, latency 0, IRQ 127
Memory at de000000 (32-bit, non-prefetchable) [size=16M]
Memory at c0000000 (64-bit, prefetchable) [size=256M]
Memory at d0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
01:00.1 Audio device [0403]: NVIDIA Corporation GM206 High Definition Audio Controller [10de:0fba] (rev a1)
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at df080000 (32-bit, non-prefetchable) [size=16K]
02:00.0 PCI bridge [0604]: ASMedia Technology Inc. ASM1083/1085 PCIe to PCI Bridge [1b21:1080] (rev 04) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 11
Bus: primary=02, secondary=03, subordinate=03, sec-latency=32
can anyone help?
