No network after update
Hello together,
I have a big problem: NO Network after the update.
Since the update 20230918 I have no network. I use kernel 6.1 LTS and Kernel 6.5.
With both kernels I don´t have network after this update.
Here is my system after the update without networking:
  Host: manjaro64 Kernel: 6.5.3-1-MANJARO arch: x86_64 bits: 64
    Desktop: KDE Plasma v: 5.27.7 Distro: Manjaro Linux
  Type: Desktop Mobo: MEDIONPC model: MS-7728 v: 2.0
    serial: <superuser required> BIOS: American Megatrends v: E7728MLN.208
    date: 08/15/2011
  Info: quad core model: Intel Core i7-2600 bits: 64 type: MT MCP cache:
    L2: 1024 KiB
  Speed (MHz): avg: 1599 min/max: 1600/3800 cores: 1: 1600 2: 1600 3: 1596
    4: 1600 5: 1600 6: 1600 7: 1600 8: 1596
  Device-1: NVIDIA GF116 [GeForce GT 545] driver: nouveau v: kernel
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.0
    compositor: kwin_wayland driver: X: loaded: modesetting dri: nouveau
    gpu: nouveau resolution: 1920x1080
  API: OpenGL v: 4.3 Mesa 23.1.6-3 renderer: NVCF
    driver: snd_hda_intel
  Device-2: NVIDIA GF116 High Definition Audio driver: snd_hda_intel
  API: ALSA v: k6.5.3-1-MANJARO status: kernel-api
  Server-1: PulseAudio v: 16.1 status: active
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: N/A
  Local Storage: total: 465.77 GiB used: 59.33 GiB (12.7%)
  ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
  ID-2: /dev/sdb vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
  ID-1: / size: 220.38 GiB used: 59.33 GiB (26.9%) fs: ext4 dev: /dev/sda1
  ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) dev: /dev/sda2
  System Temperatures: cpu: 35.0 C mobo: N/A gpu: nouveau temp: 43.0 C
  Fan Speeds (rpm): N/A
  Processes: 211 Uptime: 16m Memory: total: 8 GiB available: 7.74 GiB
  used: 1.06 GiB (13.7%) Shell: Bash inxi: 3.3.29
And here is my system before the update with working network:
  Host: manjaro64 Kernel: 6.1.51-1-MANJARO arch: x86_64 bits: 64
    date: 08/15/2011
    L2: 1024 KiB
  Speed (MHz): avg: 1605 min/max: 1600/3800 cores: 1: 1600 2: 1600 3: 1600
    4: 1600 5: 1600 6: 1644 7: 1600 8: 1600
  API: ALSA v: k6.1.51-1-MANJARO status: kernel-api
    driver: r8168
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: 8c:89:a5:99:8b:33
  Processes: 242 Uptime: 0m Memory: total: 8 GiB available: 7.74 GiB
  used: 1.12 GiB (14.4%) Shell: Bash inxi: 3.3.29
You can see, there is not network driver active after the update.
Please help me with this problem.
Thank you very much
regards
caho
Strangely, I just applied the update and rebooted. I’m still using the 8168 driver (according to Manjaro Settings Manager), but it’s working with kernel 6.1…
Hello @techm,
the driver was working fine untill 6.5.2.x. Only the last update to kernel 6.5.3.x killed the network.
At the moment, i rolled back with timeshift to kernel 6.5.1.
The same problem do I have with LTS Kernel 6.1.x after this update.
I did the update with sudo pacman -Syu
regards
caho
Ah good stuff! thank you for clarifying.
Save yourself the agony and ditch that r8168 driver. Use the in-kernel r8169 instead. The instructions on how to do it are a couple of posts higher up.
Then, update your system again.
Hello @Aragorn,
thank your for your tip. My english is not so good, but now all works fine again with R8169.
    driver: r8169
Thank you so much for your solution.
regard
caho
