HansD
8 September 2021 06:51
1
Hi there,
I got a really strange misbehaviour in my GNOME MJ with 5.13 Kernel.
If I set my Sound Output (and Input) in system configuration to my USB Audio Interface (Focusrite Scarlett 2i2) as always, it still plays sound to the internal soundcard from my laptop.
But if I start JACK with PulseAudio bridge, it plays the system sounds without flaws through my usb sound system.
IDK where to start looking about this issue.
It’s normally shown in “lsusb” and should work. Pulse Audio restart or reset does not work.
greg
8 September 2021 08:11
2
first it would be nice if you installed inxi and showed the output to
$ inxi -Axxx
Leaping ahead…most internal sound devices use kernel module snd_hda_intel
so if you created a blacklist config and full reboot to disable intel …that would be a start,
but do you need intel device?
https://wiki.archlinux.org/title/Kernel_module#Using_files_in_/etc/modprobe.d/_2
$ cat /etc/modprobe.d/blacklist.conf
install snd_hda_intel /bin/true
Secondly…ALSA tends to “never” give index=0 to usb devices. But if you always use usb sound devices, we can fix that, with luck
How about showing us (so we can see the indices) …that is aplay lowercase L
$ aplay -l
HansD
8 September 2021 09:12
3
greg:
$ inxi -Axxx
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo ThinkPad T480
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0403
Device-2: Focusrite-Novation Focusrite Scarlett 2i2 2nd Gen type: USB
driver: snd-usb-audio bus-ID: 1-2.4:27 chip-ID: 1235:8202 class-ID: 0102
Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
Sound Server-2: JACK v: 1.9.19 running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Yes. I “need” both alternating.
greg:
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: USB [Scarlett 2i2 USB], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: PCH [HDA Intel PCH], device 0: ALC257 Analog [ALC257 Analog]
Subdevices: 1/1
This file is nonexistent.
HansD
8 September 2021 12:27
4
I fixed it in tlp (TLPUI) somehow.
I un-and-re-checked usb-autosuspend and usb_blacklist and after a restart it works as it should.
greg
8 September 2021 13:50
5
since you need intel …no need to create that blacklist file
but you are running both pulseaudio and pipewire. I know little about pipewire but you might like to read
This is very true, but the internet is full of mismatched information (see references), which is why in another post of mine I wrote…
It would also be nice to hear them (Manjaro Team).
Precisely to be able to know what was happening and to be able to help others too.
So knowing what decision the Manjaro Team made - If this was the case - I would decide what I should do. Use “pulseaudio” or “pipewire”.
Thank you very much for all the information and clarific…
essentially …Alsa is a backend and the other 2 are front ends.
i am also facing same error, how can i solve this?
If the solution already posted does not work for you it is unlikely to be the exact same error
I suggest you start a new topic and post system information and diagnostics in similar manner to OP
system
Closed
11 September 2021 05:53
8
