Hi,
Manjaro disconnects from the network after all users are disconnected. The connection by ssh or the operation of a web server thus becomes impossible.
How to configure manjaro to stay connected to the network after all users are disconnected?
The computer is connected via wifi and is an ARM platform, but I think that’s not relevant information.
When a user is connected locally, directly on the computer, the wifi connection works well, including remotely. (ssh, web server OK).
xabbu
28 December 2022 09:27
2
The Wifi part the the most relevant information you shared. Just make sure you save the password in clear text, otherwise it will be stored encrypted in the users keyring. With the password stored in clear text, the wifi connection is independent from a user.
How to do this?
The whole hard disk is encrypted by LUKS, so “clear” wifi passwords are not a real problem.
xabbu
28 December 2022 09:40
4
There is usually a symbol in the wifi password text field. You can click on it and select another method. There are also different ways to so this via cmd.
The passwords are already in clear in /etc/NetworkManager/system-connections
Isn’t it more of a service issue, which is only started when an user logs in?
$ systemctl list-unit-files --state=enabled
UNIT FILE STATE PRESET
acpid.service enabled disabled
bluetooth.service enabled disabled
bootsplash-hide-when-booted.service enabled disabled
bootsplash-show-on-shutdown.service enabled disabled
earlyoom.service enabled disabled
getty@.service enabled enabled
haveged.service enabled disabled
httpd.service enabled disabled
NetworkManager-dispatcher.service enabled disabled
NetworkManager-wait-online.service enabled disabled
NetworkManager.service enabled disabled
sddm.service enabled disabled
sshd.service enabled disabled
systemd-homed.service enabled enabled
systemd-networkd-wait-online.service enabled disabled
systemd-networkd.service enabled enabled
systemd-pstore.service enabled enabled
systemd-timesyncd.service enabled enabled
zswap-arm.service enabled disabled
systemd-networkd.socket enabled disabled
systemd-userdbd.socket enabled enabled
machines.target enabled enabled
reboot.target enabled enabled
remote-cryptsetup.target enabled enabled
remote-fs.target enabled enabled
fstrim.timer enabled disabled
26 unit files listed.
What is PRESET in systemd? We see NetworkManager.service and sshd.service are disabled in PRESET.
xabbu
28 December 2022 12:29
6
By default all services are disabled in the Arch World. But the State column shows if a service is enabled or disabled on this system.
No, not for networking. However, connections created via the NetworkManager can be restricted to a user. So, can the Wifi connection only be used by a specific user or is the connection available to everyone? In the GUI, there is a checkbox that can be ticked.
xabbu
28 December 2022 12:38
7
You should only use one network setup. Since you are using 2, you should expect side effects and other wired stuff.
Are you using systemd-home with an encrypted extra home? If you need ssh access, you need to do some extra stuff. See the Arch Wiki.
No, this is all by default, including on a new pinebook pro. When you log out all users, can you log in by ssh, over the network, by wifi?
Ok the solution is here . (wpa_supplicant)
I will give the detailed solution later, it’s late in my country.
