No monitor sound (DisplayPort)
Hi everyone. New Manjaro user here.
Just installed Manjaro XFCE to dualboot with Windows 10. Sadly I’m not getting any sound from my monitor, although it works when I plug a headset in my PC.
In the Volume Control the soundbar is moving up and down as if there is sound registered, its just not coming through the speakers.
I have downgraded to the latest LTS kernel (5.4).
In case you find it useful:
System:    Host: chr1s-manjaro Kernel: 5.4.60-2-MANJARO x86_64 bits: 64 Desktop: Xfce 4.14.2 Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: Micro-Star model: B450M MORTAR MAX (MS-7B89) v: 1.0 serial: <superuser/root required>
           UEFI: American Megatrends v: 2.60 date: 12/30/2019
CPU:       Topology: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP L2 cache: 3072 KiB
           Speed: 3598 MHz min/max: 2200/3600 MHz Core speeds (MHz): 1: 3595 2: 2055 3: 2194 4: 2195 5: 2056 6: 2199 7: 2200
           8: 2198 9: 3598 10: 2051 11: 2053 12: 2198
Graphics:  Device-1: NVIDIA TU116 [GeForce GTX 1650 SUPER] driver: nouveau v: kernel
           Display: x11 server: X.Org 1.20.8 driver: modesetting,nouveau resolution: 1920x1080~120Hz
           OpenGL: renderer: llvmpipe (LLVM 10.0.1 256 bits) v: 3.3 Mesa 20.1.6
Audio:     Device-1: NVIDIA TU116 High Definition Audio driver: snd_hda_intel
           Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio driver: snd_hda_intel
           Sound Server: ALSA v: k5.4.60-2-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
           IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: 2c:f0:5d:04:e8:fc
Drives:    Local Storage: total: 465.76 GiB used: 9.22 GiB (2.0%)
           ID-1: /dev/sda vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB
Partition: ID-1: / size: 95.13 GiB used: 9.22 GiB (9.7%) fs: ext4 dev: /dev/sda6
Swap:      ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) dev: /dev/sda5
Sensors:   System Temperatures: cpu: 44.2 C mobo: N/A gpu: nouveau temp: 22 C
           Fan Speeds (RPM): N/A gpu: nouveau fan: 1615
Info:      Processes: 257 Uptime: 35m Memory: 15.65 GiB used: 1.32 GiB (8.4%) Shell: Bash inxi: 3.1.05
Hope you can help, cheers :slight_smile:
Hello!
maybe try this. Open a terminal. Type in:
alsamixer
type F6 and change from standard to another soundcard. Try to adjust the sound there.
Sidenote: alsa is the soundsystem and pulseaudio works on top as “layer” to control alsa more comfortable.
Thanks for you answer!
I can change in between:
  • (default)
    0 HDA NVidia
    1 HD-Audio Generic
Where especially 1 has several adjustments available. How come, I don’t think I’m able to save changes?
When I write up alsamixer after changing soundcard, it’s back at - (default).
The changes you make in alsamixer are normally saved immediately.
Think of this:
Application makes sound -> goes to alsa -> and then to pulseaudio
alsamixer can be adjusted and pulseaudio, but if alsa is set to 0 then pulseaudio wont get any sound to play.
I see. When i just run alsamixer I get a different screen than if I run sudo alsamixer.
Running sudo alsamixer makes the HD NVidia pop up as selected, where there is only S/PDIF’s showing with no adjustments possible. However, PulseAudio is not showing no matter which soundcard I change to.
Running alsamixer makes the default PulseAudio pop up where I can adjust the master item and I can switch between soundcards.
Solution to this problem turned out to be the open-source gpu driver. Installing the proprietary one and removing the open-source one made it work.
