No Mic Input for Logitech C930e
For some reason my Logitech C930e is not giving me an input option for the Mic. I checked alsamixer and this device isn’t showing up, yet Zoom and Cheese are both detecting the webcam, just not the mic part.
What should I do?
Check if the webcam is detected as an audio capture device in ALSA
arecord -l
Response should look similar to this If the microphone is detected, but might have a different card number
HW probe of ASUSTek M5A99FX PRO R2.0 Desktop Computer #af8e4cfaa1: arecord
**** List of CAPTURE Hardware Devices ****
card 2: C930e [Logitech Webcam C930e], device 0: USB Audio [USB Audio]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
Unfortunately, the Logitech webcam is not showing up.
Check if webcam is recognised as a USB device by system
lsusb -vd 046d:0843
and check for any warnings/errors for audio driver snd_usb_audio
sudo dmesg | grep snd
