man command not work command like man xxx
will always get the no manual entry.
man-db man-pages installed .
So how to solve it?
6.6.26-1-MANJARO
So how to solve it?
6.6.26-1-MANJARO
All things always?
Like
man pacman
Or
man man
Good.
Do you have certain localization settings? Like language?
If yes, also the accompanying package man-pages-[xx]
(ex: man-pages-de
for German)?
More info may also be found with
man -d
How about the output from
systemctl status man-db.{timer,service}
╰─❯ man pacman ─╯
No manual entry for pacman
╭─ ~ ✘ 16 ─╮
╰─❯ man -d ─╯
ruid=1000, euid=1000
rgid=1001, egid=1001
From the config file /etc/man_db.conf:
Mandatory mandir `/usr/man'.
Mandatory mandir `/usr/share/man'.
Mandatory mandir `/usr/local/share/man'.
Path `/bin' mapped to mandir `/usr/share/man'.
Path `/usr/bin' mapped to mandir `/usr/share/man'.
Path `/sbin' mapped to mandir `/usr/share/man'.
Path `/usr/sbin' mapped to mandir `/usr/share/man'.
Path `/usr/local/bin' mapped to mandir `/usr/local/man'.
Path `/usr/local/bin' mapped to mandir `/usr/local/share/man'.
Path `/usr/local/sbin' mapped to mandir `/usr/local/man'.
Path `/usr/local/sbin' mapped to mandir `/usr/local/share/man'.
Path `/usr/X11R6/bin' mapped to mandir `/usr/X11R6/man'.
Path `/usr/bin/X11' mapped to mandir `/usr/X11R6/man'.
Path `/usr/games' mapped to mandir `/usr/share/man'.
Path `/opt/bin' mapped to mandir `/opt/man'.
Path `/opt/sbin' mapped to mandir `/opt/man'.
Global mandir `/usr/man', catdir `/var/cache/man/fsstnd'.
Global mandir `/usr/share/man', catdir `/var/cache/man'.
Global mandir `/usr/local/man', catdir `/var/cache/man/oldlocal'.
Global mandir `/usr/local/share/man', catdir `/var/cache/man/local'.
Global mandir `/usr/X11R6/man', catdir `/var/cache/man/X11R6'.
Global mandir `/opt/man', catdir `/var/cache/man/opt'.
Global mandir `/var/lib/snapd/snap/man', catdir `/var/cache/man/snap'.
Added sections: `1', `1p', `n', `l', `8', `3', `3p', `0', `0p', `2', `3type', `5', `4', `9', `6', `7'.
is a tty
using less as pager
What manual page do you want?
For example, try 'man man'.
Same with pacman and man.
Seems not related to localization. not installed
● man-db.timer - Daily man-db regeneration
Loaded: loaded (/usr/lib/systemd/system/man-db.timer; disabled; preset: disabled)
Active: active (waiting) since Sat 2024-04-13 09:39:31 CST; 1h 40min ago
Trigger: Sat 2024-04-13 13:10:24 CST; 1h 50min left
Triggers: ● man-db.service
Docs: man:mandb(8)
Apr 13 09:39:31 ori systemd[1]: Started Daily man-db regeneration.
○ man-db.service - Daily man-db regeneration
Loaded: loaded (/usr/lib/systemd/system/man-db.service; static)
Active: inactive (dead)
TriggeredBy: ● man-db.timer
Docs: man:mandb(8)
According to the Arch wiki:
The search feature is provided by a dedicated cache. By default, maintenance of that cache is handled by
man-db.service
which gets periodically triggered byman-db.timer
. If you are getting a “nothing appropriate” message for every search, try manually regenerating the cache by runningmandb
as root.
I’m not entirely certain about this, so you may want to wait for advice from others, but you could either wait 1h 50min for the timer to trigger, or just run sudo mandb
After run command sudo mandb
Processing manual pages under /usr/local/man...
80 man subdirectories contained newer manual pages.
30898 manual pages were added.
0 stray cats were added.
0 old database entries were purged
It shows that many pages added. But still not work.
