No Login-Screen with 2 Monitors
Hi Folks!
Since the second-last update, my computer does not want to start correctly, when two monitors are connected at boot. That is, i can only access the Terminal-Login when hitting Ctrl+Alt+F2.
Now here comes the fun:
IF i unplug one monitor and reboot. I can see the login-screen, login and connect the second monitor again, and everything works perfectly fine. I only did that unplugging-procedure with the monitor connected via HDMI, so i didnt check if it depends on DVI vs HDMI (see inxi output below).
(I am running a Ryzen processor without a graphics unit… and the only graphics unit is a GTX 960)
Have you guys experienced anything like that before?
Cheers and many thanks for any info or discussion in advance!
inxi -G
  Host: XXX-pc Kernel: 5.16.14-1-MANJARO x86_64 bits: 64 compiler: gcc
    v: 11.2.0 Desktop: KDE Plasma 5.24.3 tk: Qt 5.15.3 wm: kwin_x11 vt: 1
  Type: Desktop Mobo: Micro-Star model: B450-A PRO MAX (MS-7B86) v: 4.0
    serial: <superuser required> UEFI: American Megatrends v: M.30
    date: 09/18/2019
  Info: 6-core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP smt: enabled
    arch: Zen 2 rev: 0 cache: L1: 384 KiB L2: 3 MiB L3: 32 MiB
  Speed (MHz): avg: 2416 high: 3834 min/max: 2200/4208 boost: enabled
    cores: 1: 3834 2: 2179 3: 2117 4: 2199 5: 2197 6: 2198 7: 3571 8: 2053
    9: 2054 10: 2199 11: 2199 12: 2199 bogomips: 86430
  Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: Gigabyte driver: nvidia
    v: 510.54 pcie: speed: 8 GT/s lanes: 16 ports: active: none
    off: DVI-D-1,HDMI-A-1 empty: DP-1,DVI-I-1 bus-ID: 26:00.0
    chip-ID: 10de:1401 class-ID: 0300
  Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
    loaded: N/A unloaded: nvidia gpu: nvidia note:  X driver n/a display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 4240x1440 s-dpi: 83 s-size: 1296x440mm (51.0x17.3")
    s-diag: 1369mm (53.9")
  Monitor-1: DVI-D-0 pos: bottom-l res: 1680x1050 hz: 60 dpi: 90
    size: 474x296mm (18.7x11.7") diag: 559mm (22")
  Monitor-2: HDMI-0 pos: primary,top-right res: 2560x1440 hz: 60 dpi: 109
    size: 597x336mm (23.5x13.2") diag: 685mm (27")
  OpenGL: renderer: NVIDIA GeForce GTX 960/PCIe/SSE2 v: 4.6.0 NVIDIA 510.54
    direct render: Yes
  Device-1: NVIDIA GM206 High Definition Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
    bus-ID: 26:00.1 chip-ID: 10de:0fba class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16
    bus-ID: 28:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Elite Systems (ECS) 32bit DAC type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:2 chip-ID: 1019:0103
    class-ID: 0102
  Sound Server-1: ALSA v: k5.16.14-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.48 running: yes
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: speed: 2.5 GT/s
    lanes: 1 port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp34s0 state: up speed: 1000 Mbps duplex: full
    mac: XXX
  IF-ID-1: docker0 state: down mac: XXX
  Local Storage: total: 465.76 GiB used: 125.82 GiB (27.0%)
  ID-1: /dev/sda vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB
    speed: 6.0 Gb/s type: SSD serial: 2003E281A79E rev: 023 scheme: GPT
  ID-1: / size: 448.5 GiB used: 125.82 GiB (28.1%) fs: ext4 dev: /dev/sda2
  ID-2: /boot/efi size: 299.4 MiB used: 280 KiB (0.1%) fs: vfat
    dev: /dev/sda1
    dev: /dev/sda3
  System Temperatures: cpu: 27.0 C mobo: 27.0 C gpu: nvidia temp: 24 C
  Fan Speeds (RPM): fan-1: 0 fan-2: 1580 fan-3: 0 fan-4: 0 fan-5: 790
    fan-6: 375 gpu: nvidia fan: 20%
  Processes: 291 Uptime: 14m wakeups: 0 Memory: 15.63 GiB
  used: 3.12 GiB (19.9%) Init: systemd v: 250 Compilers: gcc: 11.2.0
  clang: 13.0.1 Packages: 1552 pacman: 1545 snap: 7 Shell: Bash v: 5.1.16
  running-in: konsole inxi: 3.3.13
And this was my output from a few weeks ago, with the older Kernel, but two monitors attached:
[     5.194] (--) Log file renamed from "/var/log/Xorg.pid-845.log" to "/var/log/Xorg.0.log"
[     5.196]
X.Org X Server 1.21.1.3
[     5.196] Current Operating System: Linux XXX-pc 5.16.11-2-MANJARO #1 SMP PREEMPT Fri Feb 25 11:27:31 UTC 2022 x86_64
[     5.196] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64 root=UUID=0219c266-2c95-4b1e-8427-599492c54c7a rw quiet apparmor=1 security=apparmor resume=UUID=a8f42de9-435d-4dd1-9cfd-52d191ad793e udev.log_priority=3
[     5.196]
[     5.196] Current version of pixman: 0.40.0
[     5.196] 	Before reporting problems, check http://wiki.x.org
[     5.196] Markers: (--) probed, (**) from config file, (==) default setting,
[     5.196] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Mar  7 08:57:35 2022
[     5.199] (==) Using config file: "/etc/X11/xorg.conf"
[     5.199] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     5.199] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     5.202] (==) ServerLayout "layout"
[     5.202] (**) |-->Screen "Screen0" (0)
[     5.202] (**) |   |-->Monitor "Monitor0"
[     5.202] (**) |   |-->Device "Device0"
[     5.202] (**) |   |-->GPUDevice "Device1"
[     5.202] (**) |   |-->GPUDevice "Device0"
[     5.202] (==) Automatically adding devices
[     5.202] (==) Automatically enabling devices
[     5.202] (==) Automatically adding GPU devices
[     5.202] (==) Automatically binding GPU devices
[     5.202] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     5.207] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     5.207] 	Entry deleted from font path.
[     5.207] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     5.207] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[     5.207] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[     5.207] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[     5.207] (==) ModulePath set to "/usr/lib/xorg/modules"
[     5.207] (**) Extension "COMPOSITE" is enabled
[     5.207] (II) The server relies on udev to provide the list of input devices.
[     5.207] (II) Module ABI versions:
[     5.207] 	X.Org ANSI C Emulation: 0.4
[     5.207] 	X.Org Video Driver: 25.2
[     5.207] 	X.Org XInput driver : 24.4
[     5.207] 	X.Org Server Extension : 10.0
[     5.207] (++) using VT number 1
[     5.207] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     5.208] (II) xfree86: Adding drm device (/dev/dri/card0)
[     5.208] (II) Platform probe for /sys/devices/pci0000:00/0000:00:03.1/0000:26:00.0/drm/card0
[     5.209] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[     5.209] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[     5.210] (--) PCI:*(38@0:0:0) 10de:1401:1458:36c2 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[     5.210] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     5.210] (II) LoadModule: "glx"
[     5.214] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     5.225] (II) Module glx: vendor="X.Org Foundation"
[     5.225] 	compiled for 1.21.1.3, module version = 1.0.0
[     5.225] 	ABI class: X.Org Server Extension, version 10.0
[     5.225] (II) LoadModule: "nvidia"
[     5.227] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[     5.233] (II) Module nvidia: vendor="NVIDIA Corporation"
[     5.233] 	compiled for 1.6.99.901, module version = 1.0.0
[     5.233] 	Module class: X.Org Video Driver
[     5.234] (II) NVIDIA dlloader X Driver  510.54  Tue Feb  8 04:38:00 UTC 2022
[     5.234] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[     5.235] (II) Loading sub module "fb"
[     5.235] (II) LoadModule: "fb"
[     5.235] (II) Module "fb" already built-in
[     5.235] (II) Loading sub module "wfb"
[     5.235] (II) LoadModule: "wfb"
[     5.236] (II) Loading /usr/lib/xorg/modules/libwfb.so
[     5.236] (II) Module wfb: vendor="X.Org Foundation"
[     5.236] 	compiled for 1.21.1.3, module version = 1.0.0
[     5.236] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     5.236] (II) Loading sub module "ramdac"
[     5.236] (II) LoadModule: "ramdac"
[     5.236] (II) Module "ramdac" already built-in
[     5.267] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[     5.267] (==) NVIDIA(0): RGB weight 888
[     5.267] (==) NVIDIA(0): Default visual is TrueColor
[     5.267] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[     5.267] (**) Option "AllowNVIDIAGpuScreens"
[     5.267] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[     5.267] (**) NVIDIA(0): Option "Stereo" "0"
[     5.267] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-1"
[     5.267] (**) NVIDIA(0): Option "SLI" "Off"
[     5.267] (**) NVIDIA(0): Option "MultiGPU" "Off"
[     5.267] (**) NVIDIA(0): Option "BaseMosaic" "off"
[     5.267] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[     5.267] (**) NVIDIA(0): Stereo disabled by request
[     5.267] (**) NVIDIA(0): NVIDIA SLI disabled.
[     5.267] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
[     5.267] (**) NVIDIA(0): Option "MetaModes" "HDMI-0: nvidia-auto-select +1680+0, DP-3: nvidia-auto-select +0+390"
[     5.267] (**) NVIDIA(G0): Option "MetaModes" "HDMI-0: nvidia-auto-select +1680+0, DP-3: nvidia-auto-select +0+390"
[     5.267] (**) NVIDIA(G1): Option "MetaModes" "HDMI-0: nvidia-auto-select +1680+0, DP-3: nvidia-auto-select +0+390"
[     5.267] (**) NVIDIA(0): Enabling 2D acceleration
[     5.267] (II) Loading sub module "glxserver_nvidia"
[     5.267] (II) LoadModule: "glxserver_nvidia"
[     5.267] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[     5.317] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[     5.317] 	compiled for 1.6.99.901, module version = 1.0.0
[     5.317] 	Module class: X.Org Server Extension
[     5.317] (II) NVIDIA GLX Module  510.54  Tue Feb  8 04:36:31 UTC 2022
[     5.319] (II) NVIDIA: The X server supports PRIME Render Offload.
[     5.344] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:38:0:0
[     5.344] (--) NVIDIA(0):     CRT-0
[     5.344] (--) NVIDIA(0):     DFP-0
[     5.344] (--) NVIDIA(0):     DFP-1
[     5.344] (--) NVIDIA(0):     DFP-2
[     5.344] (--) NVIDIA(0):     DFP-3
[     5.344] (--) NVIDIA(0):     DFP-4 (boot)
[     5.344] (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce GTX 960 (GM206-A) at PCI:38:0:0
[     5.344] (II) NVIDIA(0):     (GPU-0)
[     5.344] (--) NVIDIA(0): Memory: 4194304 kBytes
[     5.344] (--) NVIDIA(0): VideoBIOS: 84.06.26.00.11
[     5.344] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[     5.348] (--) NVIDIA(GPU-0): CRT-0: disconnected
[     5.348] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[     5.352] (--) NVIDIA(GPU-0): DFP-0: disconnected
[     5.352] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[     5.352] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[     5.352] (--) NVIDIA(GPU-0): DFP-1: disconnected
[     5.352] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[     5.352] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[     5.352] (--) NVIDIA(GPU-0): DFP-2: disconnected
[     5.352] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[     5.352] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[     5.352] (--) NVIDIA(GPU-0): DFP-3: disconnected
[     5.352] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[     5.352] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[     5.368] (--) NVIDIA(GPU-0): LG Electronics W2242 (DFP-4): connected
[     5.368] (--) NVIDIA(GPU-0): LG Electronics W2242 (DFP-4): Internal TMDS
[     5.368] (--) NVIDIA(GPU-0): LG Electronics W2242 (DFP-4): 330.0 MHz maximum pixel clock
[     5.370] (WW) NVIDIA(0): No valid modes for
[     5.370] (WW) NVIDIA(0):     "HDMI-0:nvidia-auto-select+1680+0,DP-3:nvidia-auto-select+0+390";
[     5.370] (WW) NVIDIA(0):     removing.
[     5.370] (WW) NVIDIA(0): Unable to validate any modes; falling back to the default mode
[     5.370] (WW) NVIDIA(0):     "nvidia-auto-select".
[     5.370] (II) NVIDIA(0): Validated MetaModes:
[     5.370] (II) NVIDIA(0):     "DFP-4:nvidia-auto-select"
[     5.370] (II) NVIDIA(0): Virtual screen size determined to be 1680 x 1050
[     5.373] (--) NVIDIA(0): DPI set to (87, 83); computed from "UseEdidDpi" X config
[     5.373] (--) NVIDIA(0):     option
[     5.373] (II) NVIDIA(G0): NVIDIA GeForce GTX 960 (GPU-0) already has an X screen
[     5.373] (II) NVIDIA(G0):     assigned; skipping this GPU screen
[     5.373] (EE) NVIDIA(G0): Failing initialization of X screen
[     5.373] (II) NVIDIA(G1): NVIDIA GeForce GTX 960 (GPU-0) already has an X screen
[     5.373] (II) NVIDIA(G1):     assigned; skipping this GPU screen
[     5.373] (EE) NVIDIA(G1): Failing initialization of X screen
[     5.373] (II) UnloadModule: "nvidia"
[     5.373] (II) UnloadSubModule: "wfb"
[     5.373] (II) NVIDIA: Reserving 6144.00 MB of virtual memory for indirect memory
[     5.373] (II) NVIDIA:     access.
[     5.375] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[     5.375] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[     5.375] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[     5.375] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[     5.375] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[     5.375] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[     5.375] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[     5.375] (II) NVIDIA(0):     Config Options in the README.
[     5.387] (II) NVIDIA(0): Setting mode "DFP-4:nvidia-auto-select"
[     5.429] (==) NVIDIA(0): Disabling shared memory pixmaps
[     5.429] (==) NVIDIA(0): Backing store enabled
[     5.429] (==) NVIDIA(0): Silken mouse enabled
[     5.429] (**) NVIDIA(0): DPMS enabled
[     5.429] (WW) NVIDIA(0): Option "NoLogo" is not used
[     5.429] (II) Loading sub module "dri2"
[     5.429] (II) LoadModule: "dri2"
[     5.429] (II) Module "dri2" already built-in
[     5.429] (II) NVIDIA(0): [DRI2] Setup complete
[     5.429] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[     5.429] (II) Initializing extension Generic Event Extension
[     5.429] (II) Initializing extension SHAPE
[     5.429] (II) Initializing extension MIT-SHM
[     5.430] (II) Initializing extension XInputExtension
[     5.430] (II) Initializing extension XTEST
[     5.430] (II) Initializing extension BIG-REQUESTS
[     5.430] (II) Initializing extension SYNC
[     5.430] (II) Initializing extension XKEYBOARD
[     5.430] (II) Initializing extension XC-MISC
[     5.430] (II) Initializing extension SECURITY
[     5.430] (II) Initializing extension XFIXES
[     5.430] (II) Initializing extension RENDER
[     5.430] (II) Initializing extension RANDR
[     5.430] (II) Initializing extension COMPOSITE
[     5.430] (II) Initializing extension DAMAGE
[     5.430] (II) Initializing extension MIT-SCREEN-SAVER
[     5.430] (II) Initializing extension DOUBLE-BUFFER
[     5.430] (II) Initializing extension RECORD
[     5.431] (II) Initializing extension DPMS
[     5.431] (II) Initializing extension Present
[     5.431] (II) Initializing extension DRI3
[     5.431] (II) Initializing extension X-Resource
[     5.431] (II) Initializing extension XVideo
[     5.431] (II) Initializing extension XVideo-MotionCompensation
[     5.431] (II) Initializing extension GLX
[     5.431] (II) Indirect GLX disabled.
[     5.431] (II) GLX: Another vendor is already registered for screen 0
[     5.431] (II) Initializing extension XFree86-VidModeExtension
[     5.431] (II) Initializing extension XFree86-DGA
[     5.431] (II) Initializing extension XFree86-DRI
[     5.431] (II) Initializing extension DRI2
[     5.431] (II) Initializing extension NV-GLX
[     5.431] (II) Initializing extension NV-CONTROL
[     5.431] (II) Initializing extension XINERAMA
[     5.509] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     5.509] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     5.509] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     5.509] (**) Power Button: Applying InputClass "system-keyboard"
[     5.509] (**) Power Button: Applying InputClass "Keyboard Defaults"
[     5.509] (II) LoadModule: "libinput"
[     5.512] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     5.516] (II) Module libinput: vendor="X.Org Foundation"
[     5.516] 	compiled for 1.21.1.3, module version = 1.2.1
[     5.516] 	Module class: X.Org XInput Driver
[     5.516] 	ABI class: X.Org XInput driver, version 24.4
[     5.516] (II) Using input driver 'libinput' for 'Power Button'
[     5.516] (**) Power Button: always reports core events
[     5.516] (**) Option "Device" "/dev/input/event1"
[     5.522] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     5.522] (II) event1  - Power Button: device is a keyboard
[     5.522] (II) event1  - Power Button: device removed
[     5.556] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[     5.556] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     5.556] (**) Option "xkb_model" "pc105"
[     5.556] (**) Option "xkb_layout" "de"
[     5.556] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     5.571] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     5.571] (II) event1  - Power Button: device is a keyboard
[     5.571] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[     5.571] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     5.571] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     5.571] (**) Power Button: Applying InputClass "system-keyboard"
[     5.571] (**) Power Button: Applying InputClass "Keyboard Defaults"
[     5.571] (II) Using input driver 'libinput' for 'Power Button'
[     5.571] (**) Power Button: always reports core events
[     5.571] (**) Option "Device" "/dev/input/event0"
[     5.572] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     5.572] (II) event0  - Power Button: device is a keyboard
[     5.572] (II) event0  - Power Button: device removed
[     5.610] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[     5.610] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[     5.610] (**) Option "xkb_model" "pc105"
[     5.610] (**) Option "xkb_layout" "de"
[     5.610] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     5.610] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     5.611] (II) event0  - Power Button: device is a keyboard
[     5.611] (II) config/udev: Adding input device Sharkoon Technologies GmbH Sharkoon Light² 200 (/dev/input/event2)
[     5.611] (**) Sharkoon Technologies GmbH Sharkoon Light² 200: Applying InputClass "evdev pointer catchall"
[     5.611] (**) Sharkoon Technologies GmbH Sharkoon Light² 200: Applying InputClass "libinput pointer catchall"
[     5.611] (II) Using input driver 'libinput' for 'Sharkoon Technologies GmbH Sharkoon Light² 200'
[     5.611] (**) Sharkoon Technologies GmbH Sharkoon Light² 200: always reports core events
[     5.611] (**) Option "Device" "/dev/input/event2"
[     5.667] (II) event2  - Sharkoon Technologies GmbH Sharkoon Light² 200: is tagged by udev as: Mouse
[     5.667] (II) event2  - Sharkoon Technologies GmbH Sharkoon Light² 200: device is a pointer
[     5.668] (II) event2  - Sharkoon Technologies GmbH Sharkoon Light² 200: device removed
[     5.733] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-8/1-8:1.0/0003:2EA8:2203.0002/input/input3/event2"
[     5.733] (II) XINPUT: Adding extended input device "Sharkoon Technologies GmbH Sharkoon Light² 200" (type: MOUSE, id 8)
[     5.733] (**) Option "AccelerationScheme" "none"
[     5.733] (**) Sharkoon Technologies GmbH Sharkoon Light² 200: (accel) selected scheme none/0
[     5.733] (**) Sharkoon Technologies GmbH Sharkoon Light² 200: (accel) acceleration factor: 2.000
[     5.733] (**) Sharkoon Technologies GmbH Sharkoon Light² 200: (accel) acceleration threshold: 4
[     5.791] (II) event2  - Sharkoon Technologies GmbH Sharkoon Light² 200: is tagged by udev as: Mouse
[     5.791] (II) event2  - Sharkoon Technologies GmbH Sharkoon Light² 200: device is a pointer
[     5.792] (II) config/udev: Adding input device Sharkoon Technologies GmbH Sharkoon Light² 200 (/dev/input/mouse0)
[     5.792] (II) No input driver specified, ignoring this device.
[     5.792] (II) This device may have been added with another device file.
[     5.792] (II) config/udev: Adding input device Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard (/dev/input/event3)
[     5.792] (**) Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard: Applying InputClass "evdev keyboard catchall"
[     5.792] (**) Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard: Applying InputClass "libinput keyboard catchall"
[     5.792] (**) Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard: Applying InputClass "system-keyboard"
[     5.792] (**) Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard: Applying InputClass "Keyboard Defaults"
[     5.792] (II) Using input driver 'libinput' for 'Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard'
[     5.792] (**) Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard: always reports core events
[     5.792] (**) Option "Device" "/dev/input/event3"
[     5.793] (II) event3  - Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard: is tagged by udev as: Keyboard
[     5.794] (II) event3  - Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard: device is a keyboard
[     5.794] (II) event3  - Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard: device removed
[     5.823] (II) libinput: Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard: needs a virtual subdevice
[     5.823] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-8/1-8:1.1/0003:2EA8:2203.0003/input/input4/event3"
[     5.823] (II) XINPUT: Adding extended input device "Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard" (type: MOUSE, id 9)
[     5.823] (**) Option "AccelerationScheme" "none"
[     5.823] (**) Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard: (accel) selected scheme none/0
[     5.823] (**) Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard: (accel) acceleration factor: 2.000
[     5.823] (**) Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard: (accel) acceleration threshold: 4
[     5.824] (II) event3  - Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard: is tagged by udev as: Keyboard
[     5.824] (II) event3  - Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard: device is a keyboard
[     5.825] (II) config/udev: Adding input device HID 046a:010d (/dev/input/event4)
[     5.825] (**) HID 046a:010d: Applying InputClass "evdev keyboard catchall"
[     5.825] (**) HID 046a:010d: Applying InputClass "libinput keyboard catchall"
[     5.825] (**) HID 046a:010d: Applying InputClass "system-keyboard"
[     5.825] (**) HID 046a:010d: Applying InputClass "Keyboard Defaults"
[     5.825] (II) Using input driver 'libinput' for 'HID 046a:010d'
[     5.825] (**) HID 046a:010d: always reports core events
[     5.825] (**) Option "Device" "/dev/input/event4"
[     5.827] (II) event4  - HID 046a:010d: is tagged by udev as: Keyboard
[     5.827] (II) event4  - HID 046a:010d: device is a keyboard
[     5.827] (II) event4  - HID 046a:010d: device removed
[     5.850] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-9/1-9:1.0/0003:046A:010D.0004/input/input6/event4"
[     5.850] (II) XINPUT: Adding extended input device "HID 046a:010d" (type: KEYBOARD, id 10)
[     5.850] (**) Option "xkb_model" "pc105"
[     5.850] (**) Option "xkb_layout" "de"
[     5.850] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     5.851] (II) event4  - HID 046a:010d: is tagged by udev as: Keyboard
[     5.852] (II) event4  - HID 046a:010d: device is a keyboard
[     5.853] (II) config/udev: Adding input device HID 046a:010d (/dev/input/event5)
[     5.853] (**) HID 046a:010d: Applying InputClass "evdev keyboard catchall"
[     5.853] (**) HID 046a:010d: Applying InputClass "libinput keyboard catchall"
[     5.853] (**) HID 046a:010d: Applying InputClass "system-keyboard"
[     5.853] (**) HID 046a:010d: Applying InputClass "Keyboard Defaults"
[     5.853] (II) Using input driver 'libinput' for 'HID 046a:010d'
[     5.853] (**) HID 046a:010d: always reports core events
[     5.853] (**) Option "Device" "/dev/input/event5"
[     5.854] (II) event5  - HID 046a:010d: is tagged by udev as: Keyboard
[     5.854] (II) event5  - HID 046a:010d: device is a keyboard
[     5.854] (II) event5  - HID 046a:010d: device removed
[     5.890] (II) libinput: HID 046a:010d: needs a virtual subdevice
[     5.890] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-9/1-9:1.1/0003:046A:010D.0005/input/input7/event5"
[     5.890] (II) XINPUT: Adding extended input device "HID 046a:010d" (type: MOUSE, id 11)
[     5.890] (**) Option "AccelerationScheme" "none"
[     5.890] (**) HID 046a:010d: (accel) selected scheme none/0
[     5.890] (**) HID 046a:010d: (accel) acceleration factor: 2.000
[     5.890] (**) HID 046a:010d: (accel) acceleration threshold: 4
[     5.892] (II) event5  - HID 046a:010d: is tagged by udev as: Keyboard
[     5.892] (II) event5  - HID 046a:010d: device is a keyboard
[     5.893] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event8)
[     5.893] (II) No input driver specified, ignoring this device.
[     5.893] (II) This device may have been added with another device file.
[     5.893] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event9)
[     5.893] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event10)
[     5.894] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event11)
[     5.894] (II) No input driver specified, ignoring this device.
[     5.894] (II) This device may have been added with another device file.
[     5.894] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event12)
[     5.894] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event13)
[     5.895] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event7)
[     5.895] (II) No input driver specified, ignoring this device.
[     5.895] (II) This device may have been added with another device file.
[     5.895] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event14)
[     5.895] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event15)
[     5.896] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event16)
[     5.896] (II) No input driver specified, ignoring this device.
[     5.896] (II) This device may have been added with another device file.
[     5.896] (II) config/udev: Adding input device HD-Audio Generic Line Out Front (/dev/input/event17)
[     5.896] (II) config/udev: Adding input device HD-Audio Generic Line Out Surround (/dev/input/event18)
[     5.897] (II) config/udev: Adding input device HD-Audio Generic Line Out CLFE (/dev/input/event19)
[     5.897] (II) No input driver specified, ignoring this device.
[     5.897] (II) This device may have been added with another device file.
[     5.897] (II) config/udev: Adding input device HD-Audio Generic Line Out Side (/dev/input/event20)
[     5.897] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event21)
[     5.897] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[     5.903] (**) Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard: Applying InputClass "evdev keyboard catchall"
[     5.903] (**) Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard: Applying InputClass "libinput keyboard catchall"
[     5.903] (**) Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard: Applying InputClass "system-keyboard"
[     5.903] (**) Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard: Applying InputClass "Keyboard Defaults"
[     5.903] (II) Using input driver 'libinput' for 'Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard'
[     5.903] (**) Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard: always reports core events
[     5.903] (**) Option "Device" "/dev/input/event3"
[     5.903] (II) libinput: Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard: is a virtual subdevice
[     5.903] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-8/1-8:1.1/0003:2EA8:2203.0003/input/input4/event3"
[     5.903] (II) XINPUT: Adding extended input device "Sharkoon Technologies GmbH Sharkoon Light² 200 Keyboard" (type: KEYBOARD, id 12)
[     5.903] (**) Option "xkb_model" "pc105"
[     5.903] (**) Option "xkb_layout" "de"
[     5.903] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     5.903] (**) HID 046a:010d: Applying InputClass "evdev keyboard catchall"
[     5.903] (**) HID 046a:010d: Applying InputClass "libinput keyboard catchall"
[     5.903] (**) HID 046a:010d: Applying InputClass "system-keyboard"
[     5.903] (**) HID 046a:010d: Applying InputClass "Keyboard Defaults"
[     5.903] (II) Using input driver 'libinput' for 'HID 046a:010d'
[     5.903] (**) HID 046a:010d: always reports core events
[     5.903] (**) Option "Device" "/dev/input/event5"
[     5.903] (II) libinput: HID 046a:010d: is a virtual subdevice
[     5.903] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-9/1-9:1.1/0003:046A:010D.0005/input/input7/event5"
[     5.903] (II) XINPUT: Adding extended input device "HID 046a:010d" (type: KEYBOARD, id 13)
[    50.781] (--) NVIDIA(GPU-0): CRT-0: disconnected
[    50.781] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[    50.785] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    50.785] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    50.785] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    50.785] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    50.785] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    50.785] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    50.785] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    50.785] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[    50.785] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[    50.785] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    50.785] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    50.785] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    50.801] (--) NVIDIA(GPU-0): LG Electronics W2242 (DFP-4): connected
[    50.801] (--) NVIDIA(GPU-0): LG Electronics W2242 (DFP-4): Internal TMDS
[    50.801] (--) NVIDIA(GPU-0): LG Electronics W2242 (DFP-4): 330.0 MHz maximum pixel clock
[    50.898] (--) NVIDIA(GPU-0): CRT-0: disconnected
[    50.898] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[    50.902] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    50.902] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    50.902] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    50.902] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    50.902] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    50.902] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    50.902] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    50.902] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[    50.902] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[    50.903] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    50.903] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[    50.903] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[    50.918] (--) NVIDIA(GPU-0): LG Electronics W2242 (DFP-4): connected
[    50.918] (--) NVIDIA(GPU-0): LG Electronics W2242 (DFP-4): Internal TMDS
[    50.918] (--) NVIDIA(GPU-0): LG Electronics W2242 (DFP-4): 330.0 MHz maximum pixel clock
[    73.502] (--) NVIDIA(GPU-0): BenQ EW2780Q (DFP-1): connected
[    73.502] (--) NVIDIA(GPU-0): BenQ EW2780Q (DFP-1): Internal TMDS
[    73.502] (--) NVIDIA(GPU-0): BenQ EW2780Q (DFP-1): 600.0 MHz maximum pixel clock
[    74.248] (II) NVIDIA(0): Setting mode "DVI-D-0: nvidia-auto-select @1680x1050 +0+390 {ViewPortIn=1680x1050, ViewPortOut=1680x1050+0+0}"
[    74.280] (II) NVIDIA(0): Setting mode "DVI-D-0: nvidia-auto-select @1680x1050 +0+390 {ViewPortIn=1680x1050, ViewPortOut=1680x1050+0+0}, HDMI-0: nvidia-auto-select @2560x1440 +1680+0 {ViewPortIn=2560x1440, ViewPortOut=2560x1440+0+0}"
[   142.241] (EE) event4  - HID 046a:010d: client bug: event processing lagging behind by 23ms, your system is too slow
[   585.434] (--) NVIDIA(GPU-0): CRT-0: disconnected
[   585.434] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[   585.439] (--) NVIDIA(GPU-0): DFP-0: disconnected
[   585.439] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[   585.439] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[   585.529] (--) NVIDIA(GPU-0): BenQ EW2780Q (DFP-1): connected
[   585.529] (--) NVIDIA(GPU-0): BenQ EW2780Q (DFP-1): Internal TMDS
[   585.529] (--) NVIDIA(GPU-0): BenQ EW2780Q (DFP-1): 600.0 MHz maximum pixel clock
[   585.529] (--) NVIDIA(GPU-0): DFP-2: disconnected
[   585.529] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[   585.529] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[   585.529] (--) NVIDIA(GPU-0): DFP-3: disconnected
[   585.529] (--) NVIDIA(GPU-0): DFP-3: Internal TMDS
[   585.529] (--) NVIDIA(GPU-0): DFP-3: 165.0 MHz maximum pixel clock
[   585.561] (--) NVIDIA(GPU-0): LG Electronics W2242 (DFP-4): connected
[   585.561] (--) NVIDIA(GPU-0): LG Electronics W2242 (DFP-4): Internal TMDS
[   585.561] (--) NVIDIA(GPU-0): LG Electronics W2242 (DFP-4): 330.0 MHz maximum pixel clock
When you do not get a login screen please test the following:
Do as if you would see it, and type in the password for the user you used last, and press enter.
This helps in my installation, where my 2nd seat seems to get no login screen, but in reality has an invisible(dark) login screen. When i type the password for the last used user on this “black” screen and press enter, suddenly the login is possible, and then the screen works. :wink:
To rule something out, “Friendo”, since you mentioned a recent update, try this:
  1. Log out of KDE
  2. Switch to TTY2 with CTRL + ALT + F2
  3. Login with your username/password to this terminal
  4. Stop the SDDM service
sudo systemctl stop sddm
  1. Rebuild KDE cache
kbuildsycoca5 --noincremental
  1. Wait about ten seconds
  2. Reset the KDE Display & Monitor settings
rm -rfv ~/.local/share/kscreen
  1. Restart the SDDM service
sudo systemctl restart sddm && exit
  1. Switch back to TTY1 with CTRL + ALT + F1 and login to your KDE session
  2. Re-do your Display & Monitor settings back to your desired preferences
Hi @andreas85 and @winnie
Thanks a lot for your input!
I tried both of your suggestions, but unfortunately none worked :sweat_smile:
maybe i need to build a mechanical switch to unplug one monitor-cable when booting :hammer_and_wrench: :laughing:
Ok but seriously…Do you guys have any other suggestions? :sweat_smile:
Cheers!
This is yours
Compared to mine:
  Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: eVga.com. driver: nvidia
    v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 2 speed: 5 GT/s lanes: 16
    bus-ID: 08:00.0 chip-ID: 10de:1401 class-ID: 0300
    loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 101 s-size: 966x272mm (38.0x10.7")
    s-diag: 1004mm (39.5")
  Monitor-1: DVI-D-0 pos: right res: 1920x1080 hz: 60 dpi: 102
    size: 476x268mm (18.7x10.6") diag: 546mm (21.5")
  Monitor-2: DVI-I-1 pos: primary,left res: 1920x1080 hz: 60 dpi: 102
    size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
    direct render: Yes
I do not use the HDMI connector, but i use a fixed layout in /etc/X11/mhwd.d/nvidia.conf
Probably you can make use of it and adapt it for your connected ports
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
    Option         "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "Module"
    Load           "dbe"
    Load           "extmod"
    Load           "type1"
    Load           "freetype"
    Load           "glx"
EndSection
Section "InputDevice"
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    # generated from default
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "LG Electronics"
    ModelName      "LG Electronics W2253"
    HorizSync       30.0 - 83.0
    VertRefresh     56.0 - 75.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "GeForce GTX 960"
    Option         "TripleBuffer"  "On"
    Option  "ConnectToAcpid"    "Off"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "DFP-0"
    Option         "metamodes" "DVI-I-1: 1920x1080_60 +0+0 {ForceCompositionPipeline=On}, DVI-D-0: 1920x1080_60 +1920+0 {ForceCompositionPipeline=On}"
    Option         "SLI" "Off"
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Section "Extensions"
    Option         "COMPOSITE" "Enable"
EndSection
Section "InputClass"
    Identifier          "Keyboard Defaults"
    MatchIsKeyboard        "yes"
    Option              "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
Mostly, this is the only part you have to change
Hey Sorry for the late reply…
I tried to use your script as a template, but unfortunately it did not work…
The only solution to my problem at the moment is
  • unplugging the monitor plugged in via HDMI
  • boot the computer until login-screen (with only one monitor it works)
  • after seeing the login-screen, plug-in the monitor
  • be happy
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 510.54
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 495.44
#Section "ServerLayout"
#    Identifier     "Layout0"
#    Screen      0  "Screen0" 0 0
#    InputDevice    "Keyboard0" "CoreKeyboard"
#    InputDevice    "Mouse0" "CorePointer"
#    Option         "Xinerama" "0"
#EndSection
Section "Files"
EndSection
    Identifier     "Mouse0"
    Driver         "mouse"
EndSection
    Driver         "kbd"
EndSection
Section "Monitor"
    # HorizSync source: edid, VertRefresh source: edid
    VendorName     "BenQ"
    ModelName      "BenQ EW2780Q"
    HorizSync       30.0 - 90.0
    VertRefresh     24.0 - 76.0
    Option         "DPMS"
EndSection
Section "Monitor"
    Identifier     "Monitor1"
    VendorName     "LG"
    ModelName      "LG Electronics W2242"
    Option         "DPMS"
EndSection
Section "Device"
    Driver         "nvidia"
    BoardName      "NVIDIA GeForce GTX 960"
    BusID          "PCI:38:0:0"
    Screen	    0
	Option "NoLogo" "1"
EndSection
Section "Device"
    Identifier     "Device1"
    Driver         "nvidia"
    BusID          "PCI:38:0:0"
    Screen          1
	Option "NoLogo" "1"
EndSection
Section "Screen"
# Removed Option "metamodes" "HDMI-0: nvidia-auto-select +0+0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "metamodes" "HDMI-0: nvidia-auto-select +1680+0"#,DP-3: nvidia-auto-select +0+390"
    Option         "SLI" "Off"
        Depth       24
    EndSubSection
EndSection
Section "Screen"
    Identifier     "Screen1"
    Device         "Device1"
    Monitor        "Monitor1"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "metamodes" "DVI-I-1: nvidia-auto-select +0+0"# {AllowGSYNC=Off}"
    Option         "SLI" "Off"
        Depth       24
    EndSubSection
EndSection
    Screen      1  "Screen1" LeftOf "Screen0"
    Option         "Xinerama" "on"
    Option 	   "SingleCard" "true"
EndSection
EndSection
EndSection
this is my nvidia.config file as of now…
As you can see, i am using
and
HDMI-0 and DVI-I-1, although my inxi -Gxx gives
    chip-ID: 10de:1401
but nvidia-settings gives me the information of HDMI-0 and DVI-D-0
But you managed to make it more convoluted than is needed …
You establish the primary monitor but also keep in mind the order they get activated by BIOS till Xorg kicks in. That order is VGA > DVI-I > DVI-D > HDMI > Displayport.
From your previous post i deduce that
has the LG Electronics connected to it and that is the Secondary monitor.
Your BenQ EW2780Q is connected to
and is the Primary monitor, right?
In that case, this should be better:
EndSection
Section "Files"
EndSection
    Identifier     "Mouse0"
    Driver         "mouse"
EndSection
    Driver         "kbd"
EndSection
Section "Monitor"
    VendorName     "BenQ"
    Option         "DPMS"
EndSection
Section "Device"
    Driver         "nvidia"
EndSection
Section "Screen"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "metamodes" "HDMI-0: 2560x1440_60+1680+0",DVI-I-1: 1680x1050_60+0+0"
    Option         "SLI" "Off"
        Depth       24
    EndSubSection
EndSection
EndSection
EndSection
Hi Bogdan,
thanks again for your reply!
I copied your suggestion to /etc/X11/mhwd.d/nvidia.conf but unfortunately it still does not work.
When i reboot, both displays only show my BIOS-logo and no login screen :sweat_smile:
I dont know what i am doing wrong tbh.
I think this phenomenon with the BIOS-Logo on both screens appears, when using this line with two screens:
Cheers,
Well, for me the
that i got from you here
is not quite what i think is correct, but even tho we share the same GPU model, i don’t know what else is off.
Try using
Also, as pointed out earlier, i use
and i also use
And to be sure that once you modify /etc/X11/mhwd.d/nvidia.conf to run from terminal:
sudo mhwd-gpu --setmod nvidia --setxorg /etc/X11/mhwd.d/nvidia.conf
So, i used the script from your first reply again and used this now:
EndSection
Section "Files"
EndSection
Section "Module"
    Load           "dbe"
    Load           "extmod"
    Load           "type1"
    Load           "freetype"
    Load           "glx"
EndSection
    Identifier     "Mouse0"
    Driver         "mouse"
EndSection
    Driver         "kbd"
EndSection
Section "Monitor"
    VendorName     "BenQ"
    Option         "DPMS"
EndSection
Section "Device"
    Driver         "nvidia"
EndSection
Section "Screen"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "metamodes" "HDMI-0: 2560x1440_60+1680+0, DVI-I-1: 1680x1050_60+0+0"
    Option         "SLI" "Off"
        Depth       24
    EndSubSection
EndSection
EndSection
EndSection
This actually changed the BENQ to the ‘main’ monitor. → And i dont need to unplug one screen anymore to get to login-screen. Now i can leave both monitors plugged in. However, i still have only one monitor (the BENQ now) working. The LG is Off. nvidia-settings gives me the status disabled for the LG monitor.
The option
shifted my background somehow, but when commented it out, the BENQ works as it should.
But still, no LG-monitor working.
This drive me crazy guys :sweat_smile:
And if you change this to this:
    Option         "metamodes" "DVI-I-1: 1680x1050_60+0+0, HDMI-0: 2560x1440_60+1680+0"
What is happening?
Tried it. No Change:
→ BENQ is coming to the login-screen.
→ LG stays off and nvidia-settings says (Disabled)
Bogdan, you are using two of the same monitors, right?
In the last script above, i tell it to just identify one, namely the BENQ… does that may have any effect?
No, are two different monitors … In KDE Plasma Display settings, can you turn it on? Here is mine:
And To be honest, i avoid Nvidia Settings UI, one because adds funky stuff to the conf, and i use my own config for very long time and it never failed me.
But here is how is set in Nvidia Settings:
The primary is the LG
The secondary is the Cintiq
Ah okay! Thanks!
I just use the nvidia-settings thing to check whats going on, i dont use the save to x.org-thing.
I noticed one more thing, my LG monitor seems to be plugged in in DVI-D-0, according to nvidia-settings:
Now here comes the fun again :sweat_smile:
when i change
to
Option         "metamodes" "DVI-D-0: 1680x1050_60+0+0, HDMI-0: 2560x1440_60+1680+0"
and use sudo mhwd-gpu --setmod nvidia --setxorg /etc/X11/mhwd.d/nvidia.conf and reboot
The LG turns on! – but guess what – The BENQ turns OFF :laughing:
Revert the order to:
Option         "metamodes" "HDMI-0: 2560x1440_60+1680+0, DVI-D-0: 1680x1050_60+0+0"
Not suer that works, but the KDE Plasma settings must match the nvidia.conf
Same effect…
But i agree, it must be something in there… :confused:
Can you please start the pc by pressing e while in grub menu, and replace the quiet with nomodeset then press F10 to save and continue booting?
Maybe you have to enable early kms.
See here
Hi Bogdan,
I tried that but it did not solve the problem…
But I found a solution !!1!!11! :raised_hands:
I looked at the Xorg.0.log file again and noticed that it still loads the xorg.conf in
and copied the
from above to
/etc/X11/xorg.conf
et Voilà, now i have two working monitors again and can see the login-screen from the beginning!
  • However, i ask myself,why setting the configuration fileto /etc/X11/mhwd.d/nvidia.conf with sudo mhwd-gpu --setmod nvidia --setxorg /etc/X11/mhwd.d/nvidia.conf
    did not do the job?
For the sake of completeness, here is my working configuration file (xorg.conf) again (props out to @anon89812132!) :
EndSection
Section "Files"
EndSection
Section "Module"
    Load           "dbe"
    Load           "extmod"
    Load           "type1"
    Load           "freetype"
    Load           "glx"
EndSection
    Identifier     "Mouse0"
    Driver         "mouse"
EndSection
    Driver         "kbd"
EndSection
Section "Monitor"
    VendorName     "BenQ"
    Option         "DPMS"
EndSection
Section "Device"
    Driver         "nvidia"
EndSection
Section "Screen"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "SLI" "Off"
        Depth       24
    EndSubSection
EndSection
EndSection
EndSection
Thanks again to all!
that should have been solved by this command
but maybe xorg decided to ignore it.
Anyway, glad you sort it out.
