I like to use the ‘locate’ cmd to search for files. I can never get ‘find’ to work, and ‘locate’ always does… at least on other Linux OS’s.
Then install it.
pamac install mlocate
Yes, the package is called mlocate.
Most official ISOs have findutils
to provide /usr/bin/find
But only Xfce ISO includes mlocate
to provide /usr/bin/locate
Manjaro extra repository also has plocate
I dont know what your issues are with find.
Its what I use for most things.
It may also be worth noting that find and locate work a bit differently.
Syntax of course … but the main point would be that locate
uses a constructed database …
This requires some extra resources, but should return speed improvements over find
It can also mean that the database is incorrect - locate may return invalid results depending on the validity of the db.*
I will also mention the difference of plocate
and mlocate
mlocate
should only return files accessible by the user. -
plocate
converts the locate db into an index that purports to be smaller and faster.
* - This can be mitigated by making sure to updatedb
. The 2 packages also offer 2 different timers for this purpose. updatedb.timer
(mlocate
) and plocate-updatedb.timer
(plocate
plocate nvim 1 ✘
pread: Short read (file corrupted?)
Did you start one of the timers and/or update the db as mentioned above ?
