after a restart my laptops keyboard stopped giving out output when pressing the keys, except for:
- when in the overview of the different desktops
- when logging in (quite fortunate(and it may be running X, and that’s why))
- when logging in at Xorg(obviously)
- when pressing meta keys(volume up-down, keyboard light(which in my case involves the fn key))
it’s quite strange, when focusing on a search bar and pressing the keyboard it “unfocuses” but when pressing the bar again to focus it doesn’t, as if it already is focused.
so there is some kind output when pressing keys.
also when opening Krunner through the keyboard shortcut, it starts and autocloses here’s the systemlog output:
30.04.2023 19.12 kwin_wayland|QProcess::start: Process is already running|
30.04.2023 19.12 krunner QCommandLineParser: argument list cannot be empty, it should contain at least the executable name|
30.04.2023 19.12 krunner qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
and here’s my xorg inxi:
Host: simon-m-zephyrusg14-ga402rkga402rk Kernel: 6.3.0-1-MANJARO
arch: x86_64 bits: 64 Desktop: KDE Plasma v: 5.27.4 Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA402RK_GA402RK
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: GA402RK v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: GA402RK.318 date: 03/09/2023
ID-1: BAT0 charge: 56.3 Wh (93.1%) condition: 60.5/76.0 Wh (79.7%)
volts: 15.9 min: 15.9
Info: 8-core model: AMD Ryzen 9 6900HS with Radeon Graphics bits: 64
type: MT MCP cache: L2: 4 MiB
Speed (MHz): avg: 1568 min/max: 1600/4934 cores: 1: 1339 2: 1600 3: 1600
4: 1291 5: 1600 6: 1600 7: 3300 8: 1346 9: 1600 10: 1600 11: 1348 12: 1307
13: 1360 14: 1359 15: 1326 16: 1519
Device-1: AMD Navi 23 [Radeon RX 6650 XT / 6700S 6800S] driver: amdgpu
v: kernel
Device-2: AMD Rembrandt [Radeon 680M] driver: amdgpu v: kernel
Device-3: Quanta USB2.0 HD UVC WebCam type: USB driver: uvcvideo
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1 driver: X:
loaded: amdgpu unloaded: modesetting,radeon dri: radeonsi gpu: amdgpu
resolution: 2560x1600~120Hz
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: AMD Radeon RX 6800S (navi23 LLVM
15.0.7 DRM 3.52 6.3.0-1-MANJARO)
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel
Device-2: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp6x
Device-4: AMD Family 17h/19h HD Audio driver: snd_hda_intel
API: ALSA v: k6.3.0-1-MANJARO status: kernel-api
Server-1: PulseAudio v: 16.1 status: active
Device-1: MEDIATEK driver: mt7921e
IF: wlp5s0 state: up mac: b4:8c:9d:5c:77:db
Device-1: IMC Networks Wireless_Device type: USB driver: btusb
Local Storage: total: 1.89 TiB used: 182.87 GiB (9.4%)
ID-1: /dev/mmcblk0 model: SN32G size: 29.72 GiB
ID-2: /dev/nvme0n1 vendor: Toshiba model: N/A size: 1.86 TiB
ID-1: / size: 673.34 GiB used: 79.08 GiB (11.7%) fs: ext4
dev: /dev/nvme0n1p5
ID-2: /boot/efi size: 256 MiB used: 67.8 MiB (26.5%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 301.14 GiB used: 103.72 GiB (34.4%) fs: ntfs
dev: /dev/nvme0n1p6
System Temperatures: cpu: 68.9 C mobo: N/A
Fan Speeds (RPM): cpu: 2000
GPU: device: amdgpu temp: 57.0 C fan: 0 device: amdgpu temp: 58.0 C
Processes: 390 Uptime: 1h 15m Memory: 30.58 GiB used: 4.17 GiB (13.6%)
Shell: Zsh inxi: 3.3.26
Moderator edit: Removed poor attempt at converting terminal output into a table for no reason.
