I’m interested in deploying a javafx application, but this requires the use of the jpackage executable, which isn’t on the command line for some reason.
According to all the documentation I’ve read, it should be, so I’m either confused, or it should be there.
A root/system level find didn’t turn up anything matching jpackage.
I have jdk-openjdk (20.0.1) installed.
How can I get the jpackage executable?
Kernel: 6.3.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.3-x86_64
root=UUID=f11386cf-342d-47ac-84e6-484b7b2f377d rw rootflags=subvol=@
radeon.modeset=1 nvdia-drm.modeset=1 quiet
cryptdevice=UUID=059df4b4-5be4-44d6-a23a-de81135eb5b4:luks-disk
root=/dev/mapper/luks-disk apparmor=1 security=apparmor
resume=/dev/mapper/luks-swap udev.log_priority=3
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 4408 date: 10/27/2022
System RAM: available: 62.71 GiB used: 56.6 GiB (90.3%)
Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
note: est.
Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 16 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
width (bits): data: 64 total: 64 manufacturer: G-Skill
part-no: F4-3200C16-16GVK serial: N/A
Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 9 5950X socket: AM4 bits: 64 type: MT MCP arch: Zen 3+
gen: 4 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3209 high: 4100 min/max: 2200/6358 boost: disabled
base/boost: 4100/5050 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.1 V ext-clock: 100 MHz cores: 1: 4100 2: 2200 3: 2200 4: 4100
5: 2200 6: 2200 7: 2200 8: 4100 9: 4100 10: 4100 11: 4100 12: 4100 13: 4100
14: 4100 15: 4100 16: 4100 17: 2200 18: 2200 19: 2200 20: 2200 21: 2200
22: 2200 23: 4100 24: 2200 25: 4100 26: 2200 27: 2200 28: 4100 29: 2200
30: 4100 31: 4100 32: 4100 bogomips: 262517
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ASUSTeK driver: nvidia
v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 0b:00.0 chip-ID: 10de:2484 class-ID: 0300
Device-2: AMD Cape Verde PRO [Radeon HD 7750/8740 / R7 250E]
vendor: VISIONTEK driver: radeon v: kernel alternate: amdgpu arch: GCN-1
code: Southern Islands process: TSMC 28nm built: 2011-20 pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 ports: active: DP-3,DP-4
empty: DP-1, DP-2, DP-5, DP-6 bus-ID: 0c:00.0 chip-ID: 1002:683f
class-ID: 0300 temp: 54.0 C
Device-3: Microdia USB 2.0 Camera driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 9-2:3 chip-ID: 0c45:6367
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: radeonsi
gpu: radeon display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x2160 s-dpi: 80 s-size: 1829x686mm (72.01x27.01")
s-diag: 1953mm (76.91")
Monitor-1: DP-1 pos: 1-2 res: 1920x1080 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
Monitor-2: DP-1-3 pos: 2-1 res: 1920x1080 dpi: 82
size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
Monitor-3: DP-1-4 pos: 1-1 res: 1920x1080 dpi: 93
Monitor-4: DP-3 pos: primary,2-2 res: 1920x1080 dpi: 82
Monitor-5: DP-4 pos: 2-4 res: 1920x1080 dpi: 82
Monitor-6: HDMI-0 pos: 1-3 res: 1920x1080 dpi: 93
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX
3070/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 0b:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series] vendor: VISIONTEK driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 0c:00.1
chip-ID: 1002:aab0 class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: Schiit Audio Unison Universal Dac driver: snd-usb-audio type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 30be:1019
class-ID: 0102
Device-5: JMTek LLC. Plugable USB Audio Device
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 5-2:3 chip-ID: 0c76:120b class-ID: 0300
serial: <filter>
Device-6: ASUSTek ASUS AI Noise-Cancelling Mic Adapter
lanes: 1 mode: 1.1 bus-ID: 5-4:4 chip-ID: 0b05:194e class-ID: 0300
serial: <filter>
Device-7: Microdia USB 2.0 Camera driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.3.3-1-MANJARO status: kernel-api
Server-2: PipeWire v: 0.3.70 status: n/a (root, process) with:
1: pipewire-pulse status: active 2: pipewire-media-session status: active
3: pipewire-alsa type: plugin 4: pw-jack type: plugin
tools: pactl,pw-cat,pw-cli
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-5.3:7
chip-ID: 0a12:0001 class-ID: e001
Device-1: luks-c847cf9f-c6b5-4624-a25e-4531e318851a maj-min: 254:2
type: LUKS dm: dm-2 size: 3.64 TiB
Components:
p-1: sda1 maj-min: 8:1 size: 3.64 TiB
Device-2: luks-swap maj-min: 254:1 type: LUKS dm: dm-1 size: 12 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 12 GiB
Device-3: luks-disk maj-min: 254:0 type: LUKS dm: dm-0 size: 919.01 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 919.01 GiB
Local Storage: total: 9.13 TiB used: 3.76 TiB (41.2%)
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 111110WD temp: 56.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 313d 22h cycles: 828
read-units: 183,942,486 [94.1 TB] written-units: 198,750,919 [101 TB]
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 211070WD temp: 51.9 C scheme: GPT
SMART: yes health: PASSED on: 2y 22d 12h cycles: 990
read-units: 1,220,498,755 [624 TB] written-units: 1,301,346,314 [666 TB]
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD4005FZBX-00K5WB0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: 1A01 temp: 49 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 115d 8h cycles: 574
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
serial: <filter> fw-rev: 1A01 temp: 44 C scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: ASolid model: USB size: 29.3 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: 0000
scheme: MBR
ID-6: /dev/sdd maj-min: 8:48 vendor: SanDisk model: Gaming Xbox 360
size: 7.48 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 8.02
scheme: MBR
ID-1: / raw-size: 919.01 GiB size: 919.01 GiB (100.00%)
used: 610.77 GiB (66.5%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-disk label: N/A uuid: N/A
used: 40.2 MiB (7.9%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: EFI uuid: 8922-E04D
ID-3: /home raw-size: 919.01 GiB size: 919.01 GiB (100.00%)
ID-4: /run/media/sarah/5ECA358FCA356485 raw-size: 456 GiB
size: 456 GiB (100.00%) used: 438.25 GiB (96.1%) fs: ntfs block-size: 4096 B
dev: /dev/nvme1n1p2 maj-min: 259:6 label: N/A uuid: 5ECA358FCA356485
ID-5: /run/media/sarah/ConvergentRefuge raw-size: 3.64 TiB
size: 3.64 TiB (100.00%) used: 2.6 TiB (71.5%) fs: btrfs block-size: 4096 B
dev: /dev/dm-2 maj-min: 254:2
mapped: luks-c847cf9f-c6b5-4624-a25e-4531e318851a label: ConvergentRefuge
uuid: 7d295e73-4143-4eb1-9d22-75a06b1d2984
ID-6: /run/media/sarah/MSS_EXtended raw-size: 475.51 GiB
size: 475.51 GiB (100.00%) used: 121.7 GiB (25.6%) fs: btrfs
block-size: 4096 B dev: /dev/nvme1n1p1 maj-min: 259:5 label: MSS EXtended
uuid: f98b3a12-e0e4-48c7-91c2-6e3aa6dcd32c
ID-1: swap-1 type: partition size: 12 GiB used: 11.99 GiB (99.9%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1 mapped: luks-swap label: SWAP
uuid: c8991364-85a7-4e6c-8380-49cd5bd7a873
ID-1: /dev/sdb1 maj-min: 8:17 size: 3.64 TiB fs: ntfs label: JerichoVariance
uuid: 1AB22D5664889CBD
ID-2: /dev/sdc1 maj-min: 8:33 size: 3.65 GiB fs: iso9660
ID-3: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 6551-AC40
ID-4: /dev/sdd1 maj-min: 8:49 size: 3.57 GiB fs: iso9660
ID-5: /dev/sdd2 maj-min: 8:50 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 5C67-4BF8
Hub-2: 1-2:2 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 chip-ID: 045b:0209 class-ID: 0900
Device-1: 1-4:3 info: Microsoft Xbox One Controller (Firmware 2015)
type: <vendor specific> driver: xpad interfaces: 3 rev: 2.0
chip-ID: 045e:02dd class-ID: ff00 serial: <filter>
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.0
Hub-4: 2-2:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 chip-ID: 045b:0210 class-ID: 0900
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-6: 3-1:2 info: VIA Labs Hub ports: 4 rev: 2.1
chip-ID: 2109:3431 class-ID: 0900
Hub-7: 3-1.2:3 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2813
Hub-8: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
Hub-9: 4-2:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0813
Hub-10: 5-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 5-1:2 info: Schiit Audio Unison Universal Dac type: audio
driver: snd-usb-audio interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 30be:1019 class-ID: 0102
Device-2: 5-2:3 info: JMTek LLC. Plugable USB Audio Device type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
chip-ID: 0c76:120b class-ID: 0300 serial: <filter>
Device-3: 5-4:4 info: ASUSTek ASUS AI Noise-Cancelling Mic Adapter
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
chip-ID: 0b05:194e class-ID: 0300 serial: <filter>
Hub-11: 5-5:5 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 5-5.3:7 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-12: 5-6:6 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-13: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-14: 7-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 7-4:2 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
serial: <filter>
Device-2: 7-6:3 info: SanDisk Cruzer Micro Flash Drive type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 200mA chip-ID: 0781:5151 class-ID: 0806
serial: <filter>
Hub-15: 8-0:1 info: super-speed hub ports: 4 rev: 3.1
Device-1: 8-1:2 info: ASolid USB_0114 type: mass storage
driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 144mA chip-ID: 24a9:205a class-ID: 0806
serial: <filter>
Hub-16: 9-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-17: 9-1:2 info: Terminus FE 2.1 7-port Hub ports: 7 rev: 2.0
chip-ID: 1a40:0201 class-ID: 0900
Device-1: 9-1.1:4 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
type: mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
chip-ID: 1bcf:08a0 class-ID: 0301
Device-2: 9-1.5:7 info: Microdia Backlit Gaming Keyboard
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 400mA
chip-ID: 0c45:652f class-ID: 0301
Device-3: 9-1.6:10 info: HUION H420 type: mouse,HID driver: uclogic,usbhid
interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 256c:006e class-ID: 0300
Hub-18: 9-1.7:12 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Device-1: 9-1.7.2:13 info: GoPro MMP SDK type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 4255:0001 class-ID: 0000 serial: <filter>
Device-2: 9-1.7.4:14 info: Texas Instruments TI-Nspire Calculator
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
chip-ID: 0451:e012 class-ID: 0000
Device-3: 9-2:3 info: Microdia USB 2.0 Camera type: video,audio
chip-ID: 0c45:6367 class-ID: 0102 serial: <filter>
Device-4: 9-3:16 info: VKB-Sim © Alex Oz 2021 VKBsim Gladiator EVO R
type: HID driver: hid-generic,usbhid interfaces: 1 rev: 2.0
chip-ID: 231d:0200 class-ID: 0300
Device-5: 9-4:15 info: VKB-Sim © Alex Oz 2021 VKBsim Gladiator EVO L
chip-ID: 231d:0201 class-ID: 0300
Hub-19: 10-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 43.5 C mobo: 46.0 C gpu: radeon temp: 54.0 C
Fan Speeds (RPM): fan-1: 1168 fan-2: 826 fan-3: 1061 fan-4: 1011
fan-5: 3125 fan-6: 0 fan-7: 0
Processes: 852 Uptime: 2h 23m wakeups: 0 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 alt: 10
clang: 15.0.7 Packages: 2230 pm: pacman pkgs: 2173 libs: 506 tools: pamac,yay
pm: flatpak pkgs: 40 pm: snap pkgs: 17 Shell: Bash (su) v: 5.1.16
running-in: yakuake inxi: 3.3.27
