So I am not a power user and have a problem. Since I updated my computer a few days ago, I can’t seem to connect to any websites on the internet or even on my local network. My computer is connected to a wifi repeater over ethernet. To write this, I have currently reverted to a previous timeshift snapshot.
My inxi --admin --verbosity=7 --filter --no-host --width output after the update:
Kernel: 5.12.9-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=cd060ac7-704e-4fcb-930f-7f560822c1f2 rw quiet apparmor=1
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Micro-Star model: MS-B9071 v: 1.0 serial: <filter>
UEFI: American Megatrends v: 8.00 date: 12/07/2016
RAM: total: 15.58 GiB used: 1.62 GiB (10.4%)
Info: Quad Core model: Intel Core i5-7400 bits: 64 type: MCP arch: Kaby Lake
family: 6 model-id: 9E (158) stepping: 9 microcode: DE cache: L2: 6 MiB
bogomips: 24008
Speed: 1721 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 1721 2: 2100
3: 1903 4: 2100
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme
vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Micro-Star MSI
driver: nvidia v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c03 class-ID: 0300
Device-2: Logitech OrbiCam type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-8:9 chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 4240x1550 s-dpi: 85 s-size: 1266x462mm (49.8x18.2")
s-diag: 1348mm (53.1")
Monitor-1: HDMI-0 res: 1680x1050 hz: 60 dpi: 99 size: 433x271mm (17.0x10.7")
diag: 511mm (20.1")
Monitor-2: DP-2 res: 2560x1440 dpi: 90 size: 725x428mm (28.5x16.9")
diag: 842mm (33.1")
OpenGL: renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2
v: 4.6.0 NVIDIA 465.31 direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f1
class-ID: 0403
Device-3: Samson Meteor condenser microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2:3 chip-ID: 17a0:0310
class-ID: 0300
Device-4: Logitech OrbiCam type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.12.9-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: yes
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel port: e000 bus-ID: 03:00.0 chip-ID: 8086:24fb class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet vendor: Micro-Star MSI
driver: alx v: kernel port: d000 bus-ID: 04:00.0 chip-ID: 1969:10a1
class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-9:10 chip-ID: 8087:0aa7 class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 2.1
lmp-v: 4.2 sub-v: 1100 hci-v: 4.2 rev: 1100
Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff
link-mode: slave accept
service-classes: rendering, capturing, object transfer, audio
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 1.48 TiB used: 1.09 TiB (73.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKKW128G7
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: PSF100C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-22MFCA0
rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 840 EVO 500GB
rotation: SSD serial: <filter> rev: BB0Q scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUD0N rev: 1.00
dev-links: cdrom
ID-1: / raw-size: 118.95 GiB size: 116.58 GiB (98.01%)
used: 102.5 GiB (87.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: cd060ac7-704e-4fcb-930f-7f560822c1f2
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: AE36-BE50
ID-3: /mnt/HDD raw-size: 931.51 GiB size: 915.89 GiB (98.32%)
used: 623.17 GiB (68.0%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 5df6d233-2ce9-4d3f-9d8a-011a2bb990c4
ID-4: /mnt/SATASSD raw-size: 465.76 GiB size: 457.45 GiB (98.22%)
used: 394.06 GiB (86.1%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
label: SATASSD uuid: 425ec365-8605-4125-8d7a-e767d6e99597
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-1:2 info: Wacom CTL-472 [One by Wacom (S)] type: Mouse,HID
driver: usbhid,wacom interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 498mA
chip-ID: 056a:037a class-ID: 0300 serial: <filter>
Device-2: 1-2:3 info: Samson Meteor condenser microphone type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 17a0:0310 class-ID: 0300
Hub-2: 1-4:4 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5411 class-ID: 0900
Device-1: 1-4.2:6 info: Yubicom Yubikey 4/5 OTP+U2F+CCID
type: Keyboard,HID,Smart Card driver: hid-generic,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 30mA chip-ID: 1050:0407 class-ID: 0b00
Device-2: 1-5:5 info: Razer USA Ornata Chroma type: Keyboard,Mouse
driver: razerkbd,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 1532:021e class-ID: 0300
Device-3: 1-6:7 info: Logitech G402 Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c07e class-ID: 0300 serial: <filter>
Device-4: 1-7:8 info: MCS PRO X MINI v2 type: HID driver: hid-generic,usbhid
interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 500mA chip-ID: 16d0:0b40
Device-5: 1-8:9 info: Logitech OrbiCam type: Video,Audio
power: 500mA chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
Device-6: 1-9:10 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 54.0 C mobo: 27.8 C gpu: nvidia temp: 59 C
Processes: 211 Uptime: 4m wakeups: 0 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.0 Packages: 1627 pacman: 1624 lib: 440
flatpak: 0 snap: 3 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.04
For a list of updates that are causing the problem here is the output of pamac checkupdates; I typed export LANG=C before the command, but the output is still in german.
176 Aktualisierungen verfügbar:
accounts-qml-module 0.7-3 -> 0.7-4 extra
alsa-card-profiles 1:0.3.28-1 -> 1:0.3.30-1 extra
alsa-lib 1.2.4-3 -> 1.2.5-2 extra
alsa-plugins 1:1.2.2-2 -> 1:1.2.5-2 extra
alsa-topology-conf 1.2.4-2 -> 1.2.5-1 extra
alsa-ucm-conf 1.2.4-2 -> 1.2.5-1 extra
alsa-utils 1.2.4-2 -> 1.2.5-3 extra
at-spi2-core 2.40.1-1 -> 2.40.2-1 extra
boost 1.75.0-3 -> 1.75.0-5 extra
boost-libs 1.75.0-3 -> 1.75.0-5 extra
breeze 5.21.5-1 -> 5.21.5-2 extra
ca-certificates 20181109-4 -> 20210529-1 core
ca-certificates-utils 20181109-4 -> 20210529-1 core
clang 11.1.0-1 -> 12.0.0-1 extra
colord 1.4.5-1 -> 1.4.5-4 extra
colord-sane 1.4.5-1 -> 1.4.5-4 extra
compiler-rt 11.1.0-1 -> 12.0.0-1 extra
dialog 1:1.3_20210509-1 -> 1:1.3_20210530-1 core
docker 1:20.10.6-1 -> 1:20.10.7-1 community
dolphin-emu 1:5.0.r14095.f60d29f2b7-1 -> 1:5.0.r14344.acc7d3710d-1 community
elfutils 0.184-1 -> 0.185-1 core
faudio 21.05-1 -> 21.06-1 community
firefox 89.0-1 -> 89.0.1-1 extra
firefox-i18n-de 89.0-1 -> 89.0.1-1 extra
firefox-i18n-en-us 89.0-1 -> 89.0.1-1 extra
flatpak 1.11.1-1 -> 1.11.1-2 extra
geogebra 6.0.640.0-1 -> 6.0.646.0-1 community
git 2.31.1-1 -> 2.32.0-1 extra
gnome-desktop 1:40.1-1 -> 1:40.1-2 extra
gnutls 3.7.1-1 -> 3.7.2-1 core
go 2:1.16.4-1 -> 2:1.16.5-1 community
grub 2.04-22 -> 2.06-1 core
gsl 2.6-2 -> 2.7-1 extra
gtk-update-icon-cache 1:4.2.1-1 -> 1:4.2.1-2 extra
gtk3 1:3.24.29-1 -> 1:3.24.29-2 extra
gupnp 1.2.6-1 -> 1.2.7-1 extra
imagemagick 7.0.11.13-3 -> 7.0.11.14-1 extra
imagewriter 1.10.1432200249.1d253d9.2.6-1 -> 1.10.1432200249.1d253d9.2.7-1 community
imath 3.0.3-1 -> 3.0.4-1 extra
inetutils 1.9.4-9 -> 2.0-1 core
inkscape 1.1-1 -> 1.1-3 extra
js78 78.10.1-1 -> 78.11.0-1 extra
kimageannotator 0.5.0-2 -> 0.5.1-1 extra
lib32-alsa-lib 1.2.4-2 -> 1.2.5-2 multilib
lib32-alsa-plugins 1.2.2-1 -> 1.2.5-1 multilib
lib32-at-spi2-core 2.40.1-1 -> 2.40.2-1 multilib
lib32-colord 1.4.5-2 -> 1.4.5-3 multilib
lib32-faudio 21.05-1 -> 21.06-1 multilib
lib32-gnutls 3.7.1-1 -> 3.7.2-1 multilib
lib32-libcanberra 0.30+2+gc0620e4-3 -> 0.30+2+gc0620e4-4 multilib
lib32-libelf 0.184-1 -> 0.185-1 multilib
lib32-libgusb 0.3.6-1 -> 0.3.7-1 multilib
lib32-libogg 1.3.4-2 -> 1.3.5-1 multilib
lib32-librsvg 2:2.50.6-1 -> 2:2.50.7-1 multilib
lib32-libtirpc 1.3.1-1 -> 1.3.2-1 multilib
lib32-libva-mesa-driver 21.1.2-0 -> 21.1.2-1 multilib
lib32-libx11 1.7.1-1 -> 1.7.2-1 multilib
lib32-libxcrypt 4.4.20-1 -> 4.4.22-2 multilib
lib32-llvm-libs 11.1.0-1 -> 12.0.0-1 multilib
lib32-mesa 21.1.2-0 -> 21.1.2-1 multilib
lib32-mesa-vdpau 21.1.2-0 -> 21.1.2-1 multilib
lib32-polkit 0.118-1 -> 0.119-1 multilib
lib32-systemd 247.7-1 -> 248.3-1 multilib
lib32-util-linux 2.36.2-1 -> 2.37-1 multilib
lib32-vulkan-intel 21.1.2-0 -> 21.1.2-1 multilib
lib32-vulkan-radeon 21.1.2-0 -> 21.1.2-1 multilib
lib32-zstd 1.4.9-1 -> 1.5.0-2 multilib
libaccounts-glib 1.25-3 -> 1.25-4 extra
libaccounts-qt 1.16-2 -> 1.16-3 extra
libcanberra 0.30+2+gc0620e4-3 -> 0.30+2+gc0620e4-4 extra
libedit 20210419_3.1-1 -> 20210522_3.1-1 core
libelf 0.184-1 -> 0.185-1 core
libgusb 0.3.6-1 -> 0.3.7-1 extra
libinput 1.17.3-1 -> 1.18.0-1 extra
liblouis 3.17.0-1 -> 3.18.0-1 extra
libmbim 1.24.6-1 -> 1.24.8-1 extra
libmm-glib 1.16.4-1 -> 1.16.6-1 extra
libnftnl 1.1.9-1 -> 1.2.0-1 core
libnice 0.1.18-1 -> 0.1.18-2 extra
libogg 1.3.4-2 -> 1.3.5-1 extra
libqmi 1.28.4-1 -> 1.28.6-1 extra
libreoffice-still 7.0.6-1 -> 7.0.6-2 extra
librsvg 2:2.50.6-1 -> 2:2.50.7-1 extra
libva-mesa-driver 21.1.2-0 -> 21.1.2-1 extra
libvips 8.10.6-3 -> 8.10.6-5 community
libx11 1.7.1-1 -> 1.7.2-1 extra
libxcrypt 4.4.20-1 -> 4.4.22-4 core
libxnvctrl 465.27-1 -> 465.31-1 extra
linux414 4.14.234-1 -> 4.14.235-1 core
linux414-headers 4.14.234-1 -> 4.14.235-1 core
linux414-nvidia 465.31-3 -> 465.31-4 extra
linux414-virtualbox-host-modules 6.1.22-5 -> 6.1.22-6 extra
linux510 5.10.41-1 -> 5.10.42-1 core
linux510-headers 5.10.41-1 -> 5.10.42-1 core
linux510-nvidia 465.31-5 -> 465.31-6 extra
linux510-virtualbox-host-modules 6.1.22-11 -> 6.1.22-12 extra
linux512 5.12.8-1 -> 5.12.9-1 core
linux512-headers 5.12.8-1 -> 5.12.9-1 core
linux512-nvidia 465.31-6 -> 465.31-7 extra
linux512-virtualbox-host-modules 6.1.22-12 -> 6.1.22-13 extra
linux54 5.4.123-1 -> 5.4.124-1 core
linux54-headers 5.4.123-1 -> 5.4.124-1 core
linux54-nvidia 465.31-5 -> 465.31-6 extra
linux54-virtualbox-host-modules 6.1.22-11 -> 6.1.22-12 extra
llvm 11.1.0-1 -> 12.0.0-1 extra
llvm-libs 11.1.0-1 -> 12.0.0-1 extra
manjaro-release 21.0.6-1 -> 21.0.7-1 core
manjaro-system 20210523-1 -> 20210612-1 core
mesa 21.1.2-0 -> 21.1.2-1 extra
mesa-vdpau 21.1.2-0 -> 21.1.2-1 extra
meson 0.58.0-2 -> 0.58.1-1 extra
mhwd-db 0.6.5-7 -> 0.6.5-9 core
mkinitcpio 29-1.0 -> 30-2 core
modemmanager 1.16.4-1 -> 1.16.6-1 extra
mpg123 1.27.2-1 -> 1.28.0-1 extra
nettle 3.7.2-1 -> 3.7.3-1 core
nextcloud-client 3.2.1-1 -> 3.2.2-1 community
nodejs 16.2.0-1 -> 16.3.0-1 community
npm 7.15.0-1 -> 7.16.0-1 community
obs-studio 26.1.2-2 -> 27.0.0-2 community
openexr 3.0.3-1 -> 3.0.4-1 extra
openmpi 4.0.5-3 -> 4.1.1-1 extra
pambase 20200721.1-2 -> 20210605-2 core
pipewire 1:0.3.28-1 -> 1:0.3.30-1 extra
polkit 0.118-1 -> 0.119-1 extra
poppler 21.05.0-1 -> 21.06.1-1 extra
poppler-glib 21.05.0-1 -> 21.06.1-1 extra
poppler-qt5 21.05.0-1 -> 21.06.1-1 extra
postgresql-libs 13.3-2 -> 13.3-3 extra
pulseaudio-alsa 1:1.2.2-2 -> 1:1.2.5-2 extra
python-distlib 0.3.1-2 -> 0.3.2-1 community
python-idna 3.1-1 -> 3.2-1 extra
python-orjson 3.5.2-1 -> 3.5.3-1 community
python-setuptools 1:56.2.0-1 -> 1:57.0.0-2 extra
qt5-declarative 5.15.2+kde+r26-1 -> 5.15.2+kde+r28-1 extra
qt5-tools 5.15.2+kde+r17-1 -> 5.15.2+kde+r17-2 extra
qt5-webengine 5.15.3-5 -> 5.15.4-3 extra
re2 1:20210401-1 -> 1:20210601-1 extra
rubberband 1.9.1-1 -> 1.9.2-1 community
rubygems 3.2.15-1 -> 3.2.18-1 extra
signal-desktop 5.3.0-1 -> 5.4.1-1 community
syncthing 1.16.1-1 -> 1.17.0-1 community
systemd 247.7-1 -> 248.3-3 core
systemd-libs 247.7-1 -> 248.3-3 core
systemd-sysvcompat 247.7-1 -> 248.3-3 core
thunderbird 78.11.0-0.1 -> 78.11.0-1 extra
thunderbird-i18n-de 78.11.0-0.1 -> 78.11.0-1 extra
thunderbird-i18n-en-us 78.11.0-0.1 -> 78.11.0-1 extra
timeshift 20.11.1.r3.g08d0e59-2 -> 20.11.1.r28.gefed117-2 community
transcode 1.1.7-37 -> 1.1.7-38 community
util-linux 2.36.2-1 -> 2.37-3 core
util-linux-libs 2.36.2-1 -> 2.37-3 core
vte-common 0.64.1-1 -> 0.64.2-2 extra
vte3 0.64.1-1 -> 0.64.2-2 extra
vulkan-intel 21.1.2-0 -> 21.1.2-1 extra
vulkan-radeon 21.1.2-0 -> 21.1.2-1 extra
webrtc-audio-processing 0.3.1-2 -> 0.3.1-3 extra
wine 6.9-1 -> 6.10-1 multilib
yay 10.2.2-1 -> 10.2.3-1 community
yelp 40.0-1 -> 40.2-1 extra
yelp-xsl 40.0-1 -> 40.2-1 extra
youtube-dl 2021.05.16-1 -> 2021.06.06-1 community
zbar 0.23.1-6 -> 0.23.1-7 extra
bluez-utils-compat 5.58-1 -> 5.59-1 AUR
freetube-bin 0.12.0-4 -> 0.13.1-1 AUR
jellyfin-bin 10.7.5-1 -> 10.7.6-1 AUR
jellyfin-server-bin 10.7.5-1 -> 10.7.6-1 AUR
jellyfin-web-bin 10.7.5-1 -> 10.7.6-1 AUR
nordvpn-bin 3.9.4_1-1 -> 3.10.0_1-1 AUR
paru-bin 1.7.1-1 -> 1.7.2-1 AUR
protonmail-import-export-app-bin 1.3.1-1 -> 1.3.3-1 AUR
skypeforlinux-stable-bin 8.72.0.82-1 -> 8.73.0.92-1 AUR
subtitleedit 3.6.0-1 -> 3.6.1-1 AUR
mangohud-git 0.6.1.r123.gd8a1ddf-1 -> 0.6.3.r1.g5330573-1 AUR
lib32-mangohud-git 0.6.1.r123.gd8a1ddf-1 -> 0.6.3.r1.g5330573-1 AUR
mangohud-common-git 0.6.1.r123.gd8a1ddf-1 -> 0.6.3.r1.g5330573-1 AUR
Veraltet:
xinput_calibrator 0.7.5-3 AUR
What should I do now?
