No Internet access despite wifi-conncetion
Dear community,
although I am connected to my router via Wi-fi or Ethernet, I cannot access the internet.
This problem seemed to appear after a sudden power-interruption.
These are my System-information (shortened):
inxi -Fazy
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=d3baf4e2-eb31-4f4d-b851-0ddf97bbd9d2 ro quiet splash apparmor=1
Desktop: GNOME 41.2 tk: GTK 3.24.31 wm: gnome-shell
dm: GDM 41.0, LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: ZenBook UX425IA_UM425IA v: 1.0
serial:
Mobo: ASUSTeK model: UX425IA v: 1.0 serial:
UEFI: American Megatrends v: UX425IA.309 date: 01/29/2021
Info: model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600104
Topology: cpus: 1x cores: 8 smt: cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1402 high: 1491 min/max: 1400/2000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1458 2: 1300
3: 1383 4: 1397 5: 1397 6: 1491 7: 1397 8: 1397 bogomips: 31948
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 01:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp1s0 state: up mac:
IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
mac:
IF-ID-2: pvpnksintrf0 state: unknown speed: N/A duplex: N/A mac:
journalctl -b - u NetworkManager
Jan 25 13:39:14 manjaro systemd[1]: Starting Network Manager…
Jan 25 13:39:14 manjaro NetworkManager[751]: [1643114354.9206] NetworkManager (version 1.32.12-2) is starting… (for the first time)
Jan 25 13:39:14 manjaro NetworkManager[751]: [1643114354.9211] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf) (etc: deepin.dde.daemon.conf)
Jan 25 13:39:14 manjaro systemd[1]: Started Network Manager.
Jan 25 13:39:14 manjaro NetworkManager[751]: [1643114354.9481] bus-manager: acquired D-Bus service “org.freedesktop.NetworkManager”
Jan 25 13:39:14 manjaro NetworkManager[751]: [1643114354.9537] manager[0x563a8df6b000]: monitoring kernel firmware directory ‘/lib/firmware’.
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.0434] hostname: hostname: using hostnamed
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.0435] hostname: hostname changed from (none) to “manjaro”
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.0437] dns-mgr[0x563a8df24250]: init: dns=default,systemd-resolved rc-manager=symlink
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.0442] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/ieee80211/phy0/rfkill0) (driver iwlwifi)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.0444] manager[0x563a8df6b000]: rfkill: Wi-Fi hardware radio set enabled
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.0444] manager[0x563a8df6b000]: rfkill: WWAN hardware radio set enabled
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.0548] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.32.12-2/libnm-device-plugin-wifi.so)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.0559] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.32.12-2/libnm-device-plugin-adsl.so)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.0632] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.32.12-2/libnm-device-plugin-team.so)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.0648] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.32.12-2/libnm-device-plugin-ovs.so)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.0677] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.32.12-2/libnm-device-plugin-wwan.so)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.0701] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.32.12-2/libnm-device-plugin-bluetooth.so)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.0704] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.0705] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.0705] manager: Networking is enabled by state file
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.0711] dhcp-init: Using DHCP client ‘internal’
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.0723] settings: Loaded settings plugin: keyfile (internal)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.1074] device (lo): carrier: link connected
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.1077] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.1091] device (wlp1s0): driver supports Access Point (AP) mode
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.1097] manager: (wlp1s0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/2)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.1102] device (wlp1s0): state change: unmanaged → unavailable (reason ‘managed’, sys-iface-state: ‘external’)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.3593] device (wlp1s0): set-hw-addr: set MAC address to AA:3A:02:A5:AD:B0 (scanning)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.5961] manager: (ipv6leakintrf0): new Dummy device (/org/freedesktop/NetworkManager/Devices/3)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.5993] device (ipv6leakintrf0): state change: unmanaged → unavailable (reason ‘managed’, sys-iface-state: ‘external’)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6002] manager: (pvpnksintrf0): new Dummy device (/org/freedesktop/NetworkManager/Devices/4)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6009] device (pvpnksintrf0): state change: unmanaged → unavailable (reason ‘managed’, sys-iface-state: ‘external’)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6024] ovsdb: Could not connect: No such file or directory
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6024] ovsdb: disconnected from ovsdb
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6041] device (ipv6leakintrf0): state change: unavailable → disconnected (reason ‘none’, sys-iface-state: ‘managed’)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6055] device (pvpnksintrf0): state change: unavailable → disconnected (reason ‘none’, sys-iface-state: ‘managed’)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6067] modem-manager: ModemManager available
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6070] policy: auto-activating connection ‘pvpn-ipv6leak-protection’ (d60f6cc3-eb5b-48f2-9978-6d0b9f3a4f76)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6077] policy: auto-activating connection ‘pvpn-killswitch’ (ee40775a-b706-419c-ab65-d3e4a28bce7d)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6085] device (ipv6leakintrf0): Activation: starting connection ‘pvpn-ipv6leak-protection’ (d60f6cc3-eb5b-48f2-9978-6d0b9f3a4f76)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6087] device (pvpnksintrf0): Activation: starting connection ‘pvpn-killswitch’ (ee40775a-b706-419c-ab65-d3e4a28bce7d)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6128] device (ipv6leakintrf0): state change: disconnected → prepare (reason ‘none’, sys-iface-state: ‘managed’)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6131] manager: NetworkManager state is now CONNECTING
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6135] device (ipv6leakintrf0): state change: prepare → config (reason ‘none’, sys-iface-state: ‘managed’)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6140] device (pvpnksintrf0): state change: disconnected → prepare (reason ‘none’, sys-iface-state: ‘managed’)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6144] device (pvpnksintrf0): state change: prepare → config (reason ‘none’, sys-iface-state: ‘managed’)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6150] device (ipv6leakintrf0): state change: config → ip-config (reason ‘none’, sys-iface-state: ‘managed’)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6154] dhcp4 (ipv6leakintrf0): activation: beginning transaction (timeout in 45 seconds)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6162] device (pvpnksintrf0): state change: config → ip-config (reason ‘none’, sys-iface-state: ‘managed’)
Jan 25 13:39:15 manjaro NetworkManager[751]: ((…/NetworkManager/src/core/nm-ip4-config.c:2273)): assertion ‘’ failed
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6182] device (ipv6leakintrf0): state change: ip-config → ip-check (reason ‘none’, sys-iface-state: ‘managed’)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6200] acd[0x563a8df11ca0,4]: couldn’t init ACD for announcing addresses on interface ‘pvpnksintrf0’: Operation not permitted
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6202] device (pvpnksintrf0): state change: ip-config → ip-check (reason ‘none’, sys-iface-state: ‘managed’)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6239] device (ipv6leakintrf0): state change: ip-check → secondaries (reason ‘none’, sys-iface-state: ‘managed’)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6241] device (ipv6leakintrf0): state change: secondaries → activated (reason ‘none’, sys-iface-state: ‘managed’)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6247] policy: set ‘pvpn-killswitch’ (pvpnksintrf0) as default for IPv4 routing and DNS
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6248] policy: set ‘pvpn-ipv6leak-protection’ (ipv6leakintrf0) as default for IPv6 routing and DNS
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6315] device (ipv6leakintrf0): Activation: successful, device activated.
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6323] manager: NetworkManager state is now CONNECTED_GLOBAL
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6337] device (pvpnksintrf0): state change: ip-check → secondaries (reason ‘none’, sys-iface-state: ‘managed’)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6373] device (pvpnksintrf0): state change: secondaries → activated (reason ‘none’, sys-iface-state: ‘managed’)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6427] device (pvpnksintrf0): Activation: successful, device activated.
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6712] device (wlp1s0): supplicant interface state: internal-starting → disconnected
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6713] Wi-Fi P2P device controlled by interface wlp1s0 created
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6714] manager: (p2p-dev-wlp1s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/5)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6715] device (p2p-dev-wlp1s0): state change: unmanaged → unavailable (reason ‘managed’, sys-iface-state: ‘external’)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6718] device (wlp1s0): state change: unavailable → disconnected (reason ‘supplicant-available’, sys-iface-state: ‘managed’)
Jan 25 13:39:15 manjaro NetworkManager[751]: [1643114355.6724] device (p2p-dev-wlp1s0): state change: unavailable → disconnected (reason ‘none’, sys-iface-state: ‘managed’)
Jan 25 13:39:17 manjaro NetworkManager[751]: [1643114357.9146] agent-manager: agent[3726fc7f1edca913,:1.26/org.gnome.Shell.NetworkAgent/120]: agent registered
Jan 25 13:39:18 manjaro NetworkManager[751]: [1643114358.3695] policy: auto-activating connection ‘Bass Gang’ (e55726e7-772e-40c1-9fba-ca36e5d4a7ec)
Jan 25 13:39:18 manjaro NetworkManager[751]: [1643114358.3699] device (wlp1s0): Activation: starting connection ‘Bass Gang’ (e55726e7-772e-40c1-9fba-ca36e5d4a7ec)
Jan 25 13:39:18 manjaro NetworkManager[751]: [1643114358.3699] device (wlp1s0): state change: disconnected → prepare (reason ‘none’, sys-iface-state: ‘managed’)
Jan 25 13:39:18 manjaro NetworkManager[751]: [1643114358.3724] device (wlp1s0): set-hw-addr: reset MAC address to 34:CF:F6:4F:A6:6E (preserve)
Jan 25 13:39:18 manjaro NetworkManager[751]: [1643114358.3748] device (wlp1s0): state change: prepare → config (reason ‘none’, sys-iface-state: ‘managed’)
Jan 25 13:39:18 manjaro NetworkManager[751]: [1643114358.3750] device (wlp1s0): Activation: (wifi) access point ‘Bass Gang’ has security, but secrets are required.
Jan 25 13:39:18 manjaro NetworkManager[751]: [1643114358.3750] device (wlp1s0): state change: config → need-auth (reason ‘none’, sys-iface-state: ‘managed’)
Jan 25 13:39:18 manjaro NetworkManager[751]: [1643114358.3751] sup-iface[4989b773cccceff8,0,wlp1s0]: wps: type pbc start…
Jan 25 13:39:18 manjaro NetworkManager[751]: [1643114358.3783] device (wlp1s0): state change: need-auth → prepare (reason ‘none’, sys-iface-state: ‘managed’)
Jan 25 13:39:18 manjaro NetworkManager[751]: [1643114358.3785] device (wlp1s0): state change: prepare → config (reason ‘none’, sys-iface-state: ‘managed’)
Jan 25 13:39:18 manjaro NetworkManager[751]: [1643114358.3787] device (wlp1s0): Activation: (wifi) connection ‘Bass Gang’ has security, and secrets exist. No new secrets needed.
Jan 25 13:39:18 manjaro NetworkManager[751]: [1643114358.3787] Config: added ‘ssid’ value ‘Bass Gang’
Jan 25 13:39:18 manjaro NetworkManager[751]: [1643114358.3787] Config: added ‘scan_ssid’ value ‘1’
Jan 25 13:39:18 manjaro NetworkManager[751]: [1643114358.3787] Config: added ‘bgscan’ value ‘simple:30:-70:86400’
Jan 25 13:39:18 manjaro NetworkManager[751]: [1643114358.3787] Config: added ‘key_mgmt’ value ‘WPA-PSK WPA-PSK-SHA256 FT-PSK’
Jan 25 13:39:18 manjaro NetworkManager[751]: [1643114358.3787] Config: added ‘auth_alg’ value ‘OPEN’
Jan 25 13:39:18 manjaro NetworkManager[751]: [1643114358.3788] Config: added ‘psk’ value ‘’
Jan 25 13:39:18 manjaro NetworkManager[751]: [1643114358.4185] device (wlp1s0): supplicant interface state: disconnected → scanning
Jan 25 13:39:18 manjaro NetworkManager[751]: [1643114358.4186] device (p2p-dev-wlp1s0): supplicant management interface state: disconnected → scanning
Jan 25 13:39:19 manjaro NetworkManager[751]: [1643114359.9967] device (wlp1s0): supplicant interface state: scanning → authenticating
Jan 25 13:39:19 manjaro NetworkManager[751]: [1643114359.9967] device (p2p-dev-wlp1s0): supplicant management interface state: scanning → authenticating
Jan 25 13:39:20 manjaro NetworkManager[751]: [1643114360.1230] device (wlp1s0): supplicant interface state: authenticating → associating
Jan 25 13:39:20 manjaro NetworkManager[751]: [1643114360.1231] device (p2p-dev-wlp1s0): supplicant management interface state: authenticating → associating
Jan 25 13:39:20 manjaro NetworkManager[751]: [1643114360.1626] device (wlp1s0): supplicant interface state: associating → associated
Jan 25 13:39:20 manjaro NetworkManager[751]: [1643114360.1627] device (p2p-dev-wlp1s0): supplicant management interface state: associating → associated
Jan 25 13:39:21 manjaro NetworkManager[751]: [1643114361.1659] device (wlp1s0): supplicant interface state: associated → 4way_handshake
Jan 25 13:39:21 manjaro NetworkManager[751]: [1643114361.1660] device (p2p-dev-wlp1s0): supplicant management interface state: associated → 4way_handshake
Jan 25 13:39:21 manjaro NetworkManager[751]: [1643114361.2257] device (wlp1s0): supplicant interface state: 4way_handshake → completed
Jan 25 13:39:21 manjaro NetworkManager[751]: [1643114361.2258] device (wlp1s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network “Bass Gang”
Jan 25 13:39:21 manjaro NetworkManager[751]: [1643114361.2258] device (p2p-dev-wlp1s0): supplicant management interface state: 4way_handshake → completed
Jan 25 13:39:21 manjaro NetworkManager[751]: [1643114361.2260] device (wlp1s0): state change: config → ip-config (reason ‘none’, sys-iface-state: ‘managed’)
Jan 25 13:39:21 manjaro NetworkManager[751]: [1643114361.2264] dhcp4 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
Jan 25 13:39:21 manjaro NetworkManager[751]: [1643114361.3924] dhcp4 (wlp1s0): state changed unknown → bound, address=192.168.0.62
Jan 25 13:39:21 manjaro NetworkManager[751]: [1643114361.3949] device (wlp1s0): state change: ip-config → ip-check (reason ‘none’, sys-iface-state: ‘managed’)
Jan 25 13:39:21 manjaro NetworkManager[751]: [1643114361.3982] device (wlp1s0): state change: ip-check → secondaries (reason ‘none’, sys-iface-state: ‘managed’)
Jan 25 13:39:21 manjaro NetworkManager[751]: [1643114361.3984] device (wlp1s0): state change: secondaries → activated (reason ‘none’, sys-iface-state: ‘managed’)
Jan 25 13:39:21 manjaro NetworkManager[751]: [1643114361.4051] device (wlp1s0): Activation: successful, device activated.
Jan 25 13:39:21 manjaro NetworkManager[751]: [1643114361.4062] manager: startup complete
Jan 25 13:39:22 manjaro NetworkManager[751]: [1643114362.6452] dhcp6 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
Jan 25 13:39:22 manjaro NetworkManager[751]: [1643114362.7603] dhcp6 (wlp1s0): state changed unknown → bound
Jan 25 13:39:30 manjaro NetworkManager[751]: [1643114370.6188] agent-manager: agent[d45703bc80eaf03e,:1.67/org.gnome.Shell.NetworkAgent/1000]: agent registered
Jan 25 13:40:01 manjaro NetworkManager[751]: [1643114401.0863] dhcp4 (ipv6leakintrf0): request timed out
Jan 25 13:40:01 manjaro NetworkManager[751]: [1643114401.0863] dhcp4 (ipv6leakintrf0): state changed unknown → timeout
Jan 25 13:45:18 manjaro NetworkManager[751]: [1643114718.8047] device (wlp1s0): supplicant interface state: completed → disconnected
Jan 25 13:45:18 manjaro NetworkManager[751]: [1643114718.8048] device (p2p-dev-wlp1s0): supplicant management interface state: completed → disconnected
Jan 25 13:45:20 manjaro NetworkManager[751]: [1643114720.5973] device (wlp1s0): supplicant interface state: disconnected → authenticating
Jan 25 13:45:20 manjaro NetworkManager[751]: [1643114720.5974] device (p2p-dev-wlp1s0): supplicant management interface state: disconnected → authenticating
Jan 25 13:45:20 manjaro NetworkManager[751]: [1643114720.6527] device (wlp1s0): supplicant interface state: authenticating → associating
Jan 25 13:45:20 manjaro NetworkManager[751]: [1643114720.6529] device (p2p-dev-wlp1s0): supplicant management interface state: authenticating → associating
Jan 25 13:45:20 manjaro NetworkManager[751]: [1643114720.6953] device (wlp1s0): supplicant interface state: associating → 4way_handshake
Jan 25 13:45:20 manjaro NetworkManager[751]: [1643114720.6954] device (p2p-dev-wlp1s0): supplicant management interface state: associating → 4way_handshake
Jan 25 13:45:20 manjaro NetworkManager[751]: [1643114720.6956] device (wlp1s0): DHCPv4 lease renewal requested
Jan 25 13:45:20 manjaro NetworkManager[751]: [1643114720.7253] dhcp4 (wlp1s0): canceled DHCP transaction
Jan 25 13:45:20 manjaro NetworkManager[751]: [1643114720.7254] dhcp4 (wlp1s0): state changed bound → terminated
Jan 25 13:45:20 manjaro NetworkManager[751]: [1643114720.7260] dhcp4 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
Jan 25 13:45:20 manjaro NetworkManager[751]: [1643114720.7261] device (wlp1s0): DHCPv6 lease renewal requested
Jan 25 13:45:20 manjaro NetworkManager[751]: [1643114720.7262] dhcp6 (wlp1s0): canceled DHCP transaction
Jan 25 13:45:20 manjaro NetworkManager[751]: [1643114720.7262] dhcp6 (wlp1s0): state changed bound → terminated
Jan 25 13:45:20 manjaro NetworkManager[751]: [1643114720.7265] dhcp6 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
Jan 25 13:45:21 manjaro NetworkManager[751]: [1643114721.8341] device (wlp1s0): supplicant interface state: 4way_handshake → completed
Jan 25 13:45:21 manjaro NetworkManager[751]: [1643114721.8364] device (p2p-dev-wlp1s0): supplicant management interface state: 4way_handshake → completed
Jan 25 13:45:23 manjaro NetworkManager[751]: [1643114723.4649] dhcp4 (wlp1s0): state changed unknown → bound, address=192.168.0.62
Jan 25 13:45:23 manjaro NetworkManager[751]: [1643114723.6793] dhcp6 (wlp1s0): state changed unknown → bound
Jan 25 13:45:25 manjaro NetworkManager[751]: [1643114725.5957] device (wlp1s0): supplicant interface state: completed → disconnected
Jan 25 13:45:25 manjaro NetworkManager[751]: [1643114725.5959] device (p2p-dev-wlp1s0): supplicant management interface state: completed → disconnected
Jan 25 13:45:25 manjaro NetworkManager[751]: [1643114725.6737] device (wlp1s0): supplicant interface state: disconnected → scanning
Jan 25 13:45:25 manjaro NetworkManager[751]: [1643114725.6738] device (p2p-dev-wlp1s0): supplicant management interface state: disconnected → scanning
Jan 25 13:45:27 manjaro NetworkManager[751]: [1643114727.0709] device (wlp1s0): supplicant interface state: scanning → authenticating
Jan 25 13:45:27 manjaro NetworkManager[751]: [1643114727.0710] device (p2p-dev-wlp1s0): supplicant management interface state: scanning → authenticating
Jan 25 13:45:27 manjaro NetworkManager[751]: [1643114727.1223] device (wlp1s0): supplicant interface state: authenticating → associating
Jan 25 13:45:27 manjaro NetworkManager[751]: [1643114727.1224] device (p2p-dev-wlp1s0): supplicant management interface state: authenticating → associating
Jan 25 13:45:27 manjaro NetworkManager[751]: [1643114727.3940] device (wlp1s0): supplicant interface state: associating → associated
Jan 25 13:45:27 manjaro NetworkManager[751]: [1643114727.3941] device (p2p-dev-wlp1s0): supplicant management interface state: associating → associated
Jan 25 13:45:27 manjaro NetworkManager[751]: [1643114727.3941] device (wlp1s0): DHCPv4 lease renewal requested
Jan 25 13:45:27 manjaro NetworkManager[751]: [1643114727.4158] dhcp4 (wlp1s0): canceled DHCP transaction
Jan 25 13:45:27 manjaro NetworkManager[751]: [1643114727.4159] dhcp4 (wlp1s0): state changed bound → terminated
Jan 25 13:45:27 manjaro NetworkManager[751]: [1643114727.4170] dhcp4 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
Jan 25 13:45:27 manjaro NetworkManager[751]: [1643114727.4174] device (wlp1s0): DHCPv6 lease renewal requested
Jan 25 13:45:27 manjaro NetworkManager[751]: [1643114727.4176] dhcp6 (wlp1s0): canceled DHCP transaction
Jan 25 13:45:27 manjaro NetworkManager[751]: [1643114727.4176] dhcp6 (wlp1s0): state changed bound → terminated
Jan 25 13:45:27 manjaro NetworkManager[751]: [1643114727.4180] dhcp6 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
Jan 25 13:45:28 manjaro NetworkManager[751]: [1643114728.2046] device (wlp1s0): supplicant interface state: associated → 4way_handshake
Jan 25 13:45:28 manjaro NetworkManager[751]: [1643114728.2047] device (p2p-dev-wlp1s0): supplicant management interface state: associated → 4way_handshake
Jan 25 13:45:28 manjaro NetworkManager[751]: [1643114728.2520] device (wlp1s0): supplicant interface state: 4way_handshake → completed
Jan 25 13:45:28 manjaro NetworkManager[751]: [1643114728.2554] device (p2p-dev-wlp1s0): supplicant management interface state: 4way_handshake → completed
Jan 25 13:45:28 manjaro NetworkManager[751]: [1643114728.7161] dhcp6 (wlp1s0): state changed unknown → bound
Jan 25 13:45:29 manjaro NetworkManager[751]: [1643114729.8393] dhcp4 (wlp1s0): state changed unknown → bound, address=192.168.0.62
Jan 25 13:46:37 manjaro NetworkManager[751]: [1643114797.1246] device (wlp1s0): supplicant interface state: completed → disconnected
Jan 25 13:46:37 manjaro NetworkManager[751]: [1643114797.1247] device (p2p-dev-wlp1s0): supplicant management interface state: completed → disconnected
Jan 25 13:46:39 manjaro NetworkManager[751]: [1643114799.3116] device (wlp1s0): supplicant interface state: disconnected → authenticating
Jan 25 13:46:39 manjaro NetworkManager[751]: [1643114799.3117] device (p2p-dev-wlp1s0): supplicant management interface state: disconnected → authenticating
Jan 25 13:46:39 manjaro NetworkManager[751]: [1643114799.3767] device (wlp1s0): supplicant interface state: authenticating → associating
Jan 25 13:46:39 manjaro NetworkManager[751]: [1643114799.3768] device (p2p-dev-wlp1s0): supplicant management interface state: authenticating → associating
Jan 25 13:46:39 manjaro NetworkManager[751]: [1643114799.4162] device (wlp1s0): supplicant interface state: associating → associated
Jan 25 13:46:39 manjaro NetworkManager[751]: [1643114799.4163] device (p2p-dev-wlp1s0): supplicant management interface state: associating → associated
Jan 25 13:46:39 manjaro NetworkManager[751]: [1643114799.4164] device (wlp1s0): DHCPv4 lease renewal requested
Jan 25 13:46:39 manjaro NetworkManager[751]: [1643114799.4512] dhcp4 (wlp1s0): canceled DHCP transaction
Jan 25 13:46:39 manjaro NetworkManager[751]: [1643114799.4513] dhcp4 (wlp1s0): state changed bound → terminated
Jan 25 13:46:39 manjaro NetworkManager[751]: [1643114799.4520] dhcp4 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
Jan 25 13:46:39 manjaro NetworkManager[751]: [1643114799.4522] device (wlp1s0): DHCPv6 lease renewal requested
Jan 25 13:46:39 manjaro NetworkManager[751]: [1643114799.4523] dhcp6 (wlp1s0): canceled DHCP transaction
Jan 25 13:46:39 manjaro NetworkManager[751]: [1643114799.4523] dhcp6 (wlp1s0): state changed bound → terminated
Jan 25 13:46:39 manjaro NetworkManager[751]: [1643114799.4527] dhcp6 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
Jan 25 13:46:39 manjaro NetworkManager[751]: [1643114799.5277] device (wlp1s0): supplicant interface state: associated → 4way_handshake
Jan 25 13:46:39 manjaro NetworkManager[751]: [1643114799.5278] device (p2p-dev-wlp1s0): supplicant management interface state: associated → 4way_handshake
Jan 25 13:46:39 manjaro NetworkManager[751]: [1643114799.6268] device (wlp1s0): supplicant interface state: 4way_handshake → completed
Jan 25 13:46:39 manjaro NetworkManager[751]: [1643114799.6283] device (p2p-dev-wlp1s0): supplicant management interface state: 4way_handshake → completed
Jan 25 13:46:40 manjaro NetworkManager[751]: [1643114800.7335] dhcp6 (wlp1s0): state changed unknown → bound
Jan 25 13:46:42 manjaro NetworkManager[751]: [1643114802.8522] dhcp4 (wlp1s0): state changed unknown → bound, address=192.168.0.62
Thank you for your replies!
5.9 is EOL. Switch to a supported kernel:
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
sudo mhwd-kernel -i linux515
Then reboot into 5.15 (Press Esc during boot to get into grub menu and boot with 5.15)
Double check your running kernel is not 5.9 then remove it:
uname -r #to check kernel version
sudo mhwd-kernel -r linux59
is there any alternative if i have a second linux device which has an internet connection which the problematic doesn’t
@ishaan2479 unfortunately it is still the same in another kernel. Any other ideas?
maybe check the DHCP configuration in your internet router. If in doubt, make a screenshot of your router configurations (DHCP, IPv4/6 configs) and ask again.
HP
