No hibernation on freshly installed btrfs system and after trying some tutorials
Hi community,
I would like to use hibernation on my system.
In the process of trying to set it up I got two symptoms(one after another):
  1. The system shuts down and when I boot it again, it starts up as if I had shut it down normally.
  2. The systems does not shut down and instead I get the login screen.
The first happened on a freshly installed system with automatic partitioning for hibernation enabled.
The second happend after I executed this tutorial.
Another topic I hoped could help me is this one, but it did not (to the best of my memory) change the outcome from symptom 2…
Further I tried to solve the problem using this Arch Wiki entry.
I will be happy to add any information you deem useful. Unfortunately I am very inexperienced and am unsure what would be useful and what just makes the post longer. (I think I remember a post where there was a summary of useful information to supply when opening a topic. But I forgot where it is. If you can point me to it I would be very grateful. Perhaps as a PM, or whats this forums equivalent).
Regards,
Locuthus.
System information:
  • OS: Manjaro (installed from Calamares)
  • WM: Gnome
  • Kernel: Tried 5.16.11, 5.15.25, 5.10.102
  • GPU: integrated(amdgpu)
  • swap was available on its own partition (and I can revert that), but is now there as a swap file.
  • I use luks on root and swap partition
inxi --admin --verbosity=7 --filter --no-host --width:
  Kernel: 5.10.102-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.10-x86_64
    root=UUID=ffe800b6-7f1a-4554-a6b1-a8614a773b1c rw rootflags=subvol=@ quiet
    cryptdevice=UUID=ef96fa19-e1d2-4414-b0ec-7ce7e856472c:luks-ef96fa19-e1d2-4414-b0ec-7ce7e856472c
    root=/dev/mapper/luks-ef96fa19-e1d2-4414-b0ec-7ce7e856472c splash
    apparmor=1 security=apparmor
    resume=/dev/mapper/luks-68491caa-a796-4902-a604-2fffd38ead8b
    udev.log_priority=3 resume=UUID=ffe800b6-7f1a-4554-a6b1-a8614a773b1c
    resume_offset=28078616576
  Desktop: GNOME 41.4 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
  Type: Laptop System: LENOVO product: 20NEA001GE v: ThinkPad E495
  Mobo: LENOVO model: 20NEA001GE serial: <superuser required> UEFI: LENOVO
    v: R11ET28W (1.08 ) date: 07/31/2019
  ID-1: BAT0 charge: 32.9 Wh (100.0%) condition: 32.9/45.0 Wh (73.0%)
    volts: 12.3 min: 11.1 model: LGC 01AV445 type: Li-poly serial: <filter>
    status: Full cycles: 312
  RAM: total: 5.74 GiB used: 2.98 GiB (51.9%)
  RAM Report:
  Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
    type: MT MCP arch: Zen/Zen+ note: check family: 0x17 (23)
    model-id: 0x18 (24) stepping: 1 microcode: 0x8108102
    L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
    desc: 1x4 MiB
  Speed (MHz): avg: 1291 high: 1585 min/max: 1400/2100 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1296 2: 1585
    3: 1230 4: 1226 5: 1222 6: 1307 7: 1233 8: 1231 bogomips: 33553
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
    fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
    mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
    nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
    pse36 rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca
    sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
    syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    disabled, RSB filling
  Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
    vendor: Lenovo ThinkPad E595 driver: amdgpu v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
    bus-ID: 05:00.0 chip-ID: 1002:15d8 class-ID: 0300
  Device-2: Acer SunplusIT Integrated Camera type: USB driver: uvcvideo
    bus-ID: 3-2:3 chip-ID: 5986:2113 class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.0
    compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 model: Chi Mei Innolux built: 2016 res: 1920x1080
    dpi: 158 gamma: 1.2 size: 309x173mm (12.2x6.8") diag: 354mm (13.9")
    ratio: 16:9 modes: max: 1920x1080 min: 640x480
  Message: Wayland GBM/EGL data currently not available.
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
    vendor: Lenovo ThinkPad E595 driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:15de class-ID: 0403
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
    vendor: Lenovo ThinkPad E595 driver: N/A
    alternate: snd_pci_acp3x, snd_rn_pci_acp3x pcie: gen: 3 speed: 8 GT/s
    lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h HD Audio vendor: Lenovo ThinkPad E595
    bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.102-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.47 running: yes
    vendor: Lenovo ThinkPad E595 driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2526 class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
  IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
    mac: <filter>
  IP v6: <filter> type: noprefixroute scope: global
  IF-ID-2: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
  IP v6: <filter> virtual: stable-privacy scope: link
  IF-ID-3: pvpnksintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
  Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
    v: 0.8 bus-ID: 3-1:2 chip-ID: 8087:0025 class-ID: e001
  Device-1: luks-ef96fa19-e1d2-4414-b0ec-7ce7e856472c maj-min: 254:0
    type: LUKS dm: dm-0 size: 229.37 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 229.37 GiB
  Local Storage: total: 1.14 TiB used: 26.79 GiB (2.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lenovo
    model: UMIS RPJTJ256MED1OWX size: 238.47 GiB block-size: physical: 512 B
    logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
    rev: 1331.1.0 temp: 31.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
    type: HDD rpm: 5400 serial: <filter> rev: SBM3 scheme: GPT
  ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
    used: 26.79 GiB (11.7%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-ef96fa19-e1d2-4414-b0ec-7ce7e856472c label: N/A
    uuid: ffe800b6-7f1a-4554-a6b1-a8614a773b1c
    used: 712 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: NO_LABEL uuid: 466E-4C97
  ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
  ID-4: /var/cache raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
  ID-5: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
  ID-1: swap-1 type: file size: 11.72 GiB used: 63.1 MiB (0.5%) priority: -2
    file: /@swap/swapfile
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 3-1:2 info: Intel Wireless-AC 9260 Bluetooth Adapter
    type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 8087:0025 class-ID: e001
  Device-2: 3-2:3 info: Acer SunplusIT Integrated Camera type: Video
  Hub-4: 4-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 61.2 C mobo: 0.0 C gpu: amdgpu temp: 61.0 C
  Fan Speeds (RPM): cpu: 0
  Processes: 320 Uptime: 17h 0m wakeups: 3 Init: systemd v: 250
  tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1269
  lib: 322 flatpak: 0 Shell: Zsh v: 5.8.1 running-in: gnome-terminal
  inxi: 3.3.13
Output of: journalctl --boot -1 | sed -n -r “/Starting.+Hibernate/,/Finished.+Hibernate/p” (without vpn killswitch(many “no connection messages”) and only the first few lines, as the whole output would have been more than the allowed characters.
Mär 10 11:22:15 man-jon-note systemd[1]: Starting Hibernate...
Mär 10 11:22:15 man-jon-note systemd-sleep[2168]: Entering sleep state 'hibernate'...
Mär 10 11:22:15 man-jon-note kernel: PM: hibernation: hibernation entry
Mär 10 11:22:28 man-jon-note kernel: Filesystems sync: 0.052 seconds
Mär 10 11:22:28 man-jon-note kernel: Freezing user space processes ... (elapsed 0.002 seconds) done.
Mär 10 11:22:28 man-jon-note kernel: OOM killer disabled.
Mär 10 11:22:28 man-jon-note kernel: PM: hibernation: Marking nosave pages: [mem 0x00000000-0x00000fff]
Mär 10 11:22:28 man-jon-note kernel: PM: hibernation: Marking nosave pages: [mem 0x00002000-0x0000bfff]
Mär 10 11:22:28 man-jon-note kernel: PM: hibernation: Marking nosave pages: [mem 0x0003f000-0x00086fff]
Mär 10 11:22:28 man-jon-note kernel: PM: hibernation: Marking nosave pages: [mem 0x0008b000-0x0010ffff]
Mär 10 11:22:28 man-jon-note kernel: PM: hibernation: Marking nosave pages: [mem 0x09c00000-0x09d80fff]
Mär 10 11:22:28 man-jon-note kernel: PM: hibernation: Marking nosave pages: [mem 0x09f00000-0x09f0afff]
Mär 10 11:22:28 man-jon-note kernel: PM: hibernation: Marking nosave pages: [mem 0xb85a9000-0xbddfdfff]
Mär 10 11:22:28 man-jon-note kernel: PM: hibernation: Marking nosave pages: [mem 0xbf000000-0xffffffff]
Mär 10 11:22:28 man-jon-note kernel: PM: hibernation: Basic memory bitmaps created
Mär 10 11:22:28 man-jon-note kernel: PM: hibernation: Preallocating image memory
Mär 10 11:22:28 man-jon-note kernel: PM: hibernation: Allocated 519581 pages for snapshot
Mär 10 11:22:28 man-jon-note kernel: PM: hibernation: Allocated 2078324 kbytes in 0.36 seconds (5773.12 MB/s)
Mär 10 11:22:28 man-jon-note kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Mär 10 11:22:28 man-jon-note kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Mär 10 11:22:28 man-jon-note kernel: [drm] free PSP TMR buffer
Mär 10 11:22:28 man-jon-note kernel: amdgpu 0000:05:00.0: amdgpu: MODE2 reset
Mär 10 11:22:28 man-jon-note kernel: ACPI: EC: interrupt blocked
Mär 10 11:22:28 man-jon-note kernel: ACPI: Preparing to enter system sleep state S4
Mär 10 11:22:28 man-jon-note kernel: ACPI: EC: event blocked
Mär 10 11:22:28 man-jon-note kernel: ACPI: EC: EC stopped
Mär 10 11:22:28 man-jon-note kernel: PM: Saving platform NVS memory
Mär 10 11:22:28 man-jon-note kernel: Disabling non-boot CPUs ...
Mär 10 11:22:28 man-jon-note kernel: IRQ 79: no longer affine to CPU1
Mär 10 11:22:28 man-jon-note kernel: smpboot: CPU 1 is now offline
Mär 10 11:22:28 man-jon-note kernel: IRQ 80: no longer affine to CPU2
Mär 10 11:22:28 man-jon-note kernel: smpboot: CPU 2 is now offline
Mär 10 11:22:28 man-jon-note kernel: IRQ 81: no longer affine to CPU3
Mär 10 11:22:28 man-jon-note kernel: smpboot: CPU 3 is now offline
Mär 10 11:22:28 man-jon-note kernel: smpboot: CPU 4 is now offline
Mär 10 11:22:28 man-jon-note kernel: smpboot: CPU 5 is now offline
Mär 10 11:22:28 man-jon-note kernel: smpboot: CPU 6 is now offline
Mär 10 11:22:28 man-jon-note kernel: smpboot: CPU 7 is now offline
Mär 10 11:22:28 man-jon-note kernel: PM: hibernation: Creating image:
Mär 10 11:22:28 man-jon-note kernel: PM: hibernation: Need to copy 563844 pages
Mär 10 11:22:28 man-jon-note kernel: PM: hibernation: Normal pages needed: 563844 + 1024, available pages: 977473
Mär 10 11:22:28 man-jon-note kernel: PM: hibernation: Image created (563844 pages copied)
Mär 10 11:22:28 man-jon-note kernel: PM: Restoring platform NVS memory
Mär 10 11:22:28 man-jon-note kernel: ACPI: EC: EC started
Mär 10 11:22:28 man-jon-note kernel: Enabling non-boot CPUs ...
Mär 10 11:22:28 man-jon-note kernel: x86: Booting SMP configuration:
Mär 10 11:22:28 man-jon-note kernel: smpboot: Booting Node 0 Processor 1 APIC 0x1
Mär 10 11:22:28 man-jon-note kernel: microcode: CPU1: patch_level=0x08108102
Mär 10 11:22:28 man-jon-note kernel: ACPI: \_PR_.C001: Found 2 idle states
Mär 10 11:22:28 man-jon-note kernel: CPU1 is up
Mär 10 11:22:28 man-jon-note kernel: smpboot: Booting Node 0 Processor 2 APIC 0x2
Mär 10 11:22:28 man-jon-note kernel: microcode: CPU2: patch_level=0x08108102
Mär 10 11:22:28 man-jon-note kernel: ACPI: \_PR_.C002: Found 2 idle states
Mär 10 11:22:28 man-jon-note kernel: CPU2 is up
Mär 10 11:22:28 man-jon-note kernel: smpboot: Booting Node 0 Processor 3 APIC 0x3
Mär 10 11:22:28 man-jon-note kernel: microcode: CPU3: patch_level=0x08108102
Mär 10 11:22:28 man-jon-note kernel: ACPI: \_PR_.C003: Found 2 idle states
Mär 10 11:22:28 man-jon-note kernel: CPU3 is up
Mär 10 11:22:28 man-jon-note kernel: smpboot: Booting Node 0 Processor 4 APIC 0x4
Mär 10 11:22:28 man-jon-note kernel: microcode: CPU4: patch_level=0x08108102
Mär 10 11:22:28 man-jon-note kernel: ACPI: \_PR_.C004: Found 2 idle states
Mär 10 11:22:28 man-jon-note kernel: CPU4 is up
Mär 10 11:22:28 man-jon-note kernel: smpboot: Booting Node 0 Processor 5 APIC 0x5
Mär 10 11:22:28 man-jon-note kernel: microcode: CPU5: patch_level=0x08108102
Mär 10 11:22:28 man-jon-note kernel: ACPI: \_PR_.C005: Found 2 idle states
Mär 10 11:22:28 man-jon-note kernel: CPU5 is up
Mär 10 11:22:28 man-jon-note kernel: smpboot: Booting Node 0 Processor 6 APIC 0x6
Mär 10 11:22:28 man-jon-note kernel: microcode: CPU6: patch_level=0x08108102
Mär 10 11:22:28 man-jon-note kernel: ACPI: \_PR_.C006: Found 2 idle states
Mär 10 11:22:28 man-jon-note kernel: CPU6 is up
Mär 10 11:22:28 man-jon-note kernel: smpboot: Booting Node 0 Processor 7 APIC 0x7
Mär 10 11:22:28 man-jon-note kernel: microcode: CPU7: patch_level=0x08108102
Mär 10 11:22:28 man-jon-note kernel: ACPI: \_PR_.C007: Found 2 idle states
Mär 10 11:22:28 man-jon-note kernel: CPU7 is up
Mär 10 11:22:28 man-jon-note kernel: ACPI: Waking up from system sleep state S4
Mär 10 11:22:28 man-jon-note kernel: ACPI: EC: interrupt unblocked
Mär 10 11:22:28 man-jon-note kernel: ACPI: EC: event unblocked
Mär 10 11:22:28 man-jon-note kernel: [drm] PCIE GART of 1024M enabled (table at 0x000000F400900000).
Mär 10 11:22:28 man-jon-note kernel: [drm] PSP is resuming...
Mär 10 11:22:28 man-jon-note kernel: [drm] reserve 0x400000 from 0xf47fc00000 for PSP TMR
Mär 10 11:22:28 man-jon-note kernel: nvme 0000:01:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000a address=0xbe1c6000 flags=0x0000]
Mär 10 11:22:28 man-jon-note kernel: nvme 0000:01:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x000a address=0xbe1c6080 flags=0x0000]
Mär 10 11:22:28 man-jon-note kernel: nvme nvme0: 15/0/0 default/read/poll queues
Mär 10 11:22:28 man-jon-note kernel: amdgpu 0000:05:00.0: amdgpu: RAS: optional ras ta ucode is not available
Mär 10 11:22:28 man-jon-note kernel: amdgpu 0000:05:00.0: amdgpu: RAP: optional rap ta ucode is not available
Mär 10 11:22:28 man-jon-note kernel: [drm] kiq ring mec 2 pipe 1 q 0
Mär 10 11:22:28 man-jon-note kernel: amdgpu: dpm has been enabled
Mär 10 11:22:28 man-jon-note kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Mär 10 11:22:28 man-jon-note kernel: ata1.00: configured for UDMA/133
Mär 10 11:22:28 man-jon-note kernel: [drm] VCN decode and encode initialized successfully(under SPG Mode).
Mär 10 11:22:28 man-jon-note kernel: amdgpu 0000:05:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
Mär 10 11:22:28 man-jon-note kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
Mär 10 11:22:28 man-jon-note kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
Mär 10 11:22:28 man-jon-note kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
Mär 10 11:22:28 man-jon-note kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
Mär 10 11:22:28 man-jon-note kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
Mär 10 11:22:28 man-jon-note kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
Mär 10 11:22:28 man-jon-note kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
Mär 10 11:22:28 man-jon-note kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
Mär 10 11:22:28 man-jon-note kernel: amdgpu 0000:05:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
Mär 10 11:22:28 man-jon-note kernel: amdgpu 0000:05:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
Mär 10 11:22:28 man-jon-note kernel: amdgpu 0000:05:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
Mär 10 11:22:28 man-jon-note kernel: amdgpu 0000:05:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
Mär 10 11:22:28 man-jon-note kernel: amdgpu 0000:05:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
Mär 10 11:22:28 man-jon-note kernel: amdgpu 0000:05:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
Mär 10 11:22:28 man-jon-note kernel: PM: Cannot find swap device, try swapon -a
Mär 10 11:22:28 man-jon-note kernel: PM: Cannot get swap writer
Mär 10 11:22:28 man-jon-note kernel: PM: hibernation: Basic memory bitmaps freed
Mär 10 11:22:28 man-jon-note kernel: OOM killer enabled.
Mär 10 11:22:28 man-jon-note kernel: Restarting tasks ...
Mär 10 11:22:28 man-jon-note kernel: pci_bus 0000:01: Allocating resources
Mär 10 11:22:28 man-jon-note kernel: pcieport 0000:00:01.1: bridge window [io  0x1000-0x0fff] to [bus 01] add_size 1000
Mär 10 11:22:28 man-jon-note kernel: pcieport 0000:00:01.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01] add_size 200000 add_align 100000
Mär 10 11:22:28 man-jon-note kernel: pci_bus 0000:02: Allocating resources
Mär 10 11:22:28 man-jon-note kernel: pcieport 0000:00:01.2: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000 add_align 100000
Mär 10 11:22:28 man-jon-note kernel: pci_bus 0000:03: Allocating resources
Mär 10 11:22:28 man-jon-note kernel: pcieport 0000:00:01.3: bridge window [io  0x1000-0x0fff] to [bus 03] add_size 1000
Mär 10 11:22:28 man-jon-note kernel: pcieport 0000:00:01.3: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03] add_size 200000 add_align 100000
Mär 10 11:22:28 man-jon-note kernel: pci_bus 0000:04: Allocating resources
Mär 10 11:22:28 man-jon-note kernel: pcieport 0000:00:01.1: BAR 15: assigned [mem 0xd0d00000-0xd0efffff 64bit pref]
Mär 10 11:22:28 man-jon-note kernel: pcieport 0000:00:01.2: BAR 15: assigned [mem 0xd0f00000-0xd10fffff 64bit pref]
Mär 10 11:22:28 man-jon-note kernel: pcieport 0000:00:01.3: BAR 15: assigned [mem 0xd1100000-0xd12fffff 64bit pref]
Mär 10 11:22:28 man-jon-note kernel: pcieport 0000:00:01.1: BAR 13: assigned [io  0x4000-0x4fff]
Mär 10 11:22:28 man-jon-note kernel: pcieport 0000:00:01.3: BAR 13: assigned [io  0x5000-0x5fff]
Mär 10 11:22:28 man-jon-note kernel: pci_bus 0000:05: Allocating resources
Mär 10 11:22:28 man-jon-note kernel: pci_bus 0000:06: Allocating resources
Mär 10 11:22:28 man-jon-note kernel: pcieport 0000:00:08.2: bridge window [io  0x1000-0x0fff] to [bus 06] add_size 1000
Mär 10 11:22:28 man-jon-note kernel: pcieport 0000:00:08.2: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 06] add_size 200000 add_align 100000
Mär 10 11:22:28 man-jon-note kernel: pcieport 0000:00:08.2: BAR 15: assigned [mem 0xd1300000-0xd14fffff 64bit pref]
Mär 10 11:22:28 man-jon-note kernel: pcieport 0000:00:08.2: BAR 13: assigned [io  0x6000-0x6fff]
Mär 10 11:22:28 man-jon-note kernel: done.
Mär 10 11:22:28 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:22:28 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:22:28 man-jon-note systemd-sleep[2168]: Failed to put system to sleep. System resumed again: No such device
Mär 10 11:22:28 man-jon-note kernel: PM: hibernation: hibernation exit
Mär 10 11:22:29 man-jon-note tlp[2238]: Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
Mär 10 11:22:29 man-jon-note tlp[2238]: >>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Mär 10 11:22:29 man-jon-note tlp[2238]: Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
Mär 10 11:22:29 man-jon-note tlp[2238]: >>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
Mär 10 11:22:29 man-jon-note systemd[1]: systemd-hibernate.service: Main process exited, code=exited, status=1/FAILURE
Mär 10 11:22:29 man-jon-note systemd[1]: systemd-hibernate.service: Failed with result 'exit-code'.
Mär 10 11:22:29 man-jon-note systemd[1]: Failed to start Hibernate.
Mär 10 11:22:29 man-jon-note systemd[1]: Dependency failed for System Hibernation.
Mär 10 11:22:29 man-jon-note audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hibernate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Mär 10 11:22:29 man-jon-note kernel: audit: type=1130 audit(1646907749.396:142): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hibernate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Mär 10 11:22:29 man-jon-note systemd[1]: hibernate.target: Job hibernate.target/start failed with result 'dependency'.
Mär 10 11:22:29 man-jon-note systemd[1]: systemd-hibernate.service: Consumed 1.226s CPU time.
Mär 10 11:22:29 man-jon-note systemd-logind[631]: Operation 'sleep' finished.
Mär 10 11:22:29 man-jon-note systemd[1]: Stopped target Sleep.
Mär 10 11:22:29 man-jon-note NetworkManager[626]: <info>  [1646907749.4028] manager: sleep: wake requested (sleeping: yes  enabled: yes)
Mär 10 11:22:29 man-jon-note NetworkManager[626]: <info>  [1646907749.4031] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mär 10 11:22:29 man-jon-note ModemManager[688]: <info>  [sleep-monitor] system is resuming
Mär 10 11:22:29 man-jon-note kernel: Generic FE-GE Realtek PHY r8169-0-200:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-0-200:00, irq=IGNORE)
Mär 10 11:22:29 man-jon-note NetworkManager[626]: <info>  [1646907749.5679] device (wlp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mär 10 11:22:29 man-jon-note kernel: r8169 0000:02:00.0 enp2s0: Link is Down
Mär 10 11:22:29 man-jon-note NetworkManager[626]: <info>  [1646907749.5703] device (p2p-dev-wlp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mär 10 11:22:29 man-jon-note NetworkManager[626]: <info>  [1646907749.5710] manager: NetworkManager state is now CONNECTED_GLOBAL
Mär 10 11:22:29 man-jon-note NetworkManager[626]: <info>  [1646907749.6390] device (wlp4s0): supplicant interface state: internal-starting -> disconnected
Mär 10 11:22:29 man-jon-note NetworkManager[626]: <info>  [1646907749.6391] device (p2p-dev-wlp4s0): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Mär 10 11:22:29 man-jon-note NetworkManager[626]: <info>  [1646907749.6399] Wi-Fi P2P device controlled by interface wlp4s0 created
Mär 10 11:22:29 man-jon-note NetworkManager[626]: <info>  [1646907749.6405] manager: (p2p-dev-wlp4s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/6)
Mär 10 11:22:29 man-jon-note NetworkManager[626]: <info>  [1646907749.6410] device (p2p-dev-wlp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Mär 10 11:22:29 man-jon-note NetworkManager[626]: <info>  [1646907749.6423] device (wlp4s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Mär 10 11:22:29 man-jon-note NetworkManager[626]: <info>  [1646907749.6435] device (p2p-dev-wlp4s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Mär 10 11:22:29 man-jon-note gnome-shell[1418]: Removing a network device that was not added
Mär 10 11:22:31 man-jon-note dbus-daemon[625]: [system] Activating via systemd: service name='net.reactivated.Fprint' unit='fprintd.service' requested by ':1.65' (uid=1000 pid=1418 comm="/usr/bin/gnome-shell ")
Mär 10 11:22:31 man-jon-note audit: BPF prog-id=34 op=LOAD
Mär 10 11:22:31 man-jon-note systemd[1]: Starting Fingerprint Authentication Daemon...
Mär 10 11:22:31 man-jon-note kernel: audit: type=1334 audit(1646907751.506:143): prog-id=34 op=LOAD
Mär 10 11:22:31 man-jon-note dbus-daemon[625]: [system] Successfully activated service 'net.reactivated.Fprint'
Mär 10 11:22:31 man-jon-note systemd[1]: Started Fingerprint Authentication Daemon.
Mär 10 11:22:31 man-jon-note audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:22:31 man-jon-note kernel: audit: type=1130 audit(1646907751.603:144): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:22:31 man-jon-note dbus-daemon[625]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.100' (uid=0 pid=2467 comm="gdm-session-worker [pam/gdm-password] ")
Mär 10 11:22:31 man-jon-note dbus-daemon[625]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Mär 10 11:22:31 man-jon-note gdm-password][2467]: pam_systemd_home(gdm-password:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Mär 10 11:22:31 man-jon-note ModemManager[688]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0': not supported by any plugin
Mär 10 11:22:31 man-jon-note ModemManager[688]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:01.6/0000:04:00.0': not supported by any plugin
Mär 10 11:22:32 man-jon-note wpa_supplicant[777]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=DE
Mär 10 11:22:32 man-jon-note NetworkManager[626]: <info>  [1646907752.9740] policy: auto-activating connection 'FRITZ!Box 4040 OI' (667b0995-a19c-46dc-87b6-2dc2d07c2832)
Mär 10 11:22:32 man-jon-note NetworkManager[626]: <info>  [1646907752.9751] device (wlp4s0): Activation: starting connection 'FRITZ!Box 4040 OI' (667b0995-a19c-46dc-87b6-2dc2d07c2832)
Mär 10 11:22:32 man-jon-note NetworkManager[626]: <info>  [1646907752.9753] device (wlp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mär 10 11:22:32 man-jon-note NetworkManager[626]: <info>  [1646907752.9760] device (wlp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mär 10 11:22:32 man-jon-note NetworkManager[626]: <info>  [1646907752.9766] device (wlp4s0): Activation: (wifi) access point 'FRITZ!Box 4040 OI' has security, but secrets are required.
Mär 10 11:22:32 man-jon-note NetworkManager[626]: <info>  [1646907752.9766] device (wlp4s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mär 10 11:22:32 man-jon-note NetworkManager[626]: <info>  [1646907752.9796] device (wlp4s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Mär 10 11:22:32 man-jon-note NetworkManager[626]: <info>  [1646907752.9803] device (wlp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mär 10 11:22:32 man-jon-note NetworkManager[626]: <info>  [1646907752.9809] device (wlp4s0): Activation: (wifi) connection 'FRITZ!Box 4040 OI' has security, and secrets exist.  No new secrets needed.
Mär 10 11:22:32 man-jon-note NetworkManager[626]: <info>  [1646907752.9810] Config: added 'ssid' value 'FRITZ!Box 4040 OI'
Mär 10 11:22:32 man-jon-note NetworkManager[626]: <info>  [1646907752.9811] Config: added 'scan_ssid' value '1'
Mär 10 11:22:32 man-jon-note NetworkManager[626]: <info>  [1646907752.9811] Config: added 'bgscan' value 'simple:30:-70:86400'
Mär 10 11:22:32 man-jon-note NetworkManager[626]: <info>  [1646907752.9811] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
Mär 10 11:22:32 man-jon-note NetworkManager[626]: <info>  [1646907752.9812] Config: added 'auth_alg' value 'OPEN'
Mär 10 11:22:32 man-jon-note NetworkManager[626]: <info>  [1646907752.9812] Config: added 'psk' value '<hidden>'
Mär 10 11:22:32 man-jon-note wpa_supplicant[777]: wlp4s0: SME: Trying to authenticate with 7c:ff:4d:10:38:68 (SSID='FRITZ!Box 4040 OI' freq=5220 MHz)
Mär 10 11:22:32 man-jon-note kernel: wlp4s0: authenticate with 7c:ff:4d:10:38:68
Mär 10 11:22:32 man-jon-note kernel: wlp4s0: send auth to 7c:ff:4d:10:38:68 (try 1/3)
Mär 10 11:22:32 man-jon-note NetworkManager[626]: <info>  [1646907752.9965] device (wlp4s0): supplicant interface state: disconnected -> authenticating
Mär 10 11:22:32 man-jon-note NetworkManager[626]: <info>  [1646907752.9966] device (p2p-dev-wlp4s0): supplicant management interface state: disconnected -> authenticating
Mär 10 11:22:33 man-jon-note wpa_supplicant[777]: wlp4s0: Trying to associate with 7c:ff:4d:10:38:68 (SSID='FRITZ!Box 4040 OI' freq=5220 MHz)
Mär 10 11:22:33 man-jon-note NetworkManager[626]: <info>  [1646907753.1390] device (wlp4s0): supplicant interface state: authenticating -> associating
Mär 10 11:22:33 man-jon-note NetworkManager[626]: <info>  [1646907753.1391] device (p2p-dev-wlp4s0): supplicant management interface state: authenticating -> associating
Mär 10 11:22:33 man-jon-note kernel: wlp4s0: authenticated
Mär 10 11:22:33 man-jon-note kernel: wlp4s0: associate with 7c:ff:4d:10:38:68 (try 1/3)
Mär 10 11:22:33 man-jon-note wpa_supplicant[777]: wlp4s0: Associated with 7c:ff:4d:10:38:68
Mär 10 11:22:33 man-jon-note wpa_supplicant[777]: wlp4s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Mär 10 11:22:33 man-jon-note kernel: wlp4s0: RX AssocResp from 7c:ff:4d:10:38:68 (capab=0x1511 status=0 aid=3)
Mär 10 11:22:33 man-jon-note kernel: wlp4s0: associated
Mär 10 11:22:33 man-jon-note NetworkManager[626]: <info>  [1646907753.1523] device (wlp4s0): supplicant interface state: associating -> associated
Mär 10 11:22:33 man-jon-note NetworkManager[626]: <info>  [1646907753.1523] device (p2p-dev-wlp4s0): supplicant management interface state: associating -> associated
Mär 10 11:22:33 man-jon-note NetworkManager[626]: <info>  [1646907753.1614] device (wlp4s0): supplicant interface state: associated -> 4way_handshake
Mär 10 11:22:33 man-jon-note NetworkManager[626]: <info>  [1646907753.1615] device (p2p-dev-wlp4s0): supplicant management interface state: associated -> 4way_handshake
Mär 10 11:22:33 man-jon-note wpa_supplicant[777]: wlp4s0: WPA: Key negotiation completed with 7c:ff:4d:10:38:68 [PTK=CCMP GTK=CCMP]
Mär 10 11:22:33 man-jon-note wpa_supplicant[777]: wlp4s0: CTRL-EVENT-CONNECTED - Connection to 7c:ff:4d:10:38:68 completed [id=0 id_str=]
Mär 10 11:22:33 man-jon-note kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp4s0: link becomes ready
Mär 10 11:22:33 man-jon-note wpa_supplicant[777]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-67 noise=9999 txrate=650000
Mär 10 11:22:33 man-jon-note NetworkManager[626]: <info>  [1646907753.1754] device (wlp4s0): supplicant interface state: 4way_handshake -> completed
Mär 10 11:22:33 man-jon-note NetworkManager[626]: <info>  [1646907753.1755] device (wlp4s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "FRITZ!Box 4040 OI"
Mär 10 11:22:33 man-jon-note NetworkManager[626]: <info>  [1646907753.1755] device (p2p-dev-wlp4s0): supplicant management interface state: 4way_handshake -> completed
Mär 10 11:22:33 man-jon-note NetworkManager[626]: <info>  [1646907753.1760] device (wlp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mär 10 11:22:33 man-jon-note NetworkManager[626]: <info>  [1646907753.1765] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Mär 10 11:22:33 man-jon-note wpa_supplicant[777]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-67 noise=9999 txrate=650000
Mär 10 11:22:33 man-jon-note kernel: wlp4s0: Limiting TX power to 23 (23 - 0) dBm as advertised by 7c:ff:4d:10:38:68
Mär 10 11:22:33 man-jon-note NetworkManager[626]: <info>  [1646907753.2593] dhcp4 (wlp4s0): state changed unknown -> bound, address=192.168.178.99
Mär 10 11:22:33 man-jon-note NetworkManager[626]: <info>  [1646907753.2608] device (wlp4s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Mär 10 11:22:33 man-jon-note NetworkManager[626]: <info>  [1646907753.2646] device (wlp4s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Mär 10 11:22:33 man-jon-note NetworkManager[626]: <info>  [1646907753.2649] device (wlp4s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Mär 10 11:22:33 man-jon-note NetworkManager[626]: <info>  [1646907753.2892] device (wlp4s0): Activation: successful, device activated.
Mär 10 11:22:33 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:22:33 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:22:34 man-jon-note gdm-password][2467]: gkr-pam: unlocked login keyring
Mär 10 11:22:34 man-jon-note audit[2467]: USER_AUTH pid=2467 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="my_account" exe="/usr/lib/gdm-session-worker" hostname=man-jon-note addr=? terminal=/dev/tty1 res=success'
Mär 10 11:22:34 man-jon-note kernel: audit: type=1100 audit(1646907754.663:145): pid=2467 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="my_account" exe="/usr/lib/gdm-session-worker" hostname=man-jon-note addr=? terminal=/dev/tty1 res=success'
Mär 10 11:22:34 man-jon-note audit[2467]: USER_ACCT pid=2467 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="my_account" exe="/usr/lib/gdm-session-worker" hostname=man-jon-note addr=? terminal=/dev/tty1 res=success'
Mär 10 11:22:34 man-jon-note audit[2467]: CRED_REFR pid=2467 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="my_account" exe="/usr/lib/gdm-session-worker" hostname=man-jon-note addr=? terminal=/dev/tty1 res=success'
Mär 10 11:22:34 man-jon-note kernel: audit: type=1101 audit(1646907754.666:146): pid=2467 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="my_account" exe="/usr/lib/gdm-session-worker" hostname=man-jon-note addr=? terminal=/dev/tty1 res=success'
Mär 10 11:22:34 man-jon-note kernel: audit: type=1110 audit(1646907754.666:147): pid=2467 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="my_account" exe="/usr/lib/gdm-session-worker" hostname=man-jon-note addr=? terminal=/dev/tty1 res=success'
Mär 10 11:22:34 man-jon-note NetworkManager[626]: <info>  [1646907754.9210] agent-manager: agent[3a3e428d41554700,:1.65/org.gnome.Shell.NetworkAgent/1000]: agent registered
Mär 10 11:22:35 man-jon-note systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Mär 10 11:22:35 man-jon-note audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:22:35 man-jon-note kernel: audit: type=1131 audit(1646907755.763:148): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:22:38 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:22:38 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:22:43 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:22:43 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:22:48 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:22:48 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:22:53 man-jon-note gnome-shell[1418]: libinput error: event14 - SynPS/2 Synaptics TouchPad: kernel bug: Touch jump detected and discarded.
Mär 10 11:22:53 man-jon-note gnome-shell[1418]: See https://wayland.freedesktop.org/libinput/doc/1.20.0/touchpad-jumping-cursors.html for details
Mär 10 11:22:53 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:22:53 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:22:57 man-jon-note gnome-shell[1418]: libinput error: event14 - SynPS/2 Synaptics TouchPad: kernel bug: Touch jump detected and discarded.
Mär 10 11:22:57 man-jon-note gnome-shell[1418]: See https://wayland.freedesktop.org/libinput/doc/1.20.0/touchpad-jumping-cursors.html for details
Mär 10 11:22:58 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:22:58 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:23:01 man-jon-note systemd[1]: fprintd.service: Deactivated successfully.
Mär 10 11:23:01 man-jon-note audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:23:01 man-jon-note kernel: audit: type=1131 audit(1646907781.553:149): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:23:01 man-jon-note audit: BPF prog-id=34 op=UNLOAD
Mär 10 11:23:01 man-jon-note kernel: audit: type=1334 audit(1646907781.589:150): prog-id=34 op=UNLOAD
Mär 10 11:23:03 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:23:03 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:23:08 man-jon-note gnome-shell[1418]: libinput error: event14 - SynPS/2 Synaptics TouchPad: kernel bug: Touch jump detected and discarded.
Mär 10 11:23:08 man-jon-note gnome-shell[1418]: See https://wayland.freedesktop.org/libinput/doc/1.20.0/touchpad-jumping-cursors.html for details
Mär 10 11:23:08 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:23:08 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:23:09 man-jon-note gnome-shell[1418]: libinput error: event14 - SynPS/2 Synaptics TouchPad: kernel bug: Touch jump detected and discarded.
Mär 10 11:23:09 man-jon-note gnome-shell[1418]: See https://wayland.freedesktop.org/libinput/doc/1.20.0/touchpad-jumping-cursors.html for details
Mär 10 11:23:13 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:23:13 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:23:18 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:23:18 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:23:23 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:23:23 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:23:28 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:23:28 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:23:33 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:23:33 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:23:38 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:23:38 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:23:43 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:23:43 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:23:48 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:23:48 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:23:53 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:23:53 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:23:58 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:23:58 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:24:03 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:24:03 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:24:08 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:24:08 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:24:13 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:24:13 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:24:18 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:24:18 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:24:23 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:24:23 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:24:28 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:24:28 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:24:33 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:24:33 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:24:38 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:24:38 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:24:43 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:24:43 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:24:49 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:24:49 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:24:54 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:24:54 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:24:59 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:24:59 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:25:04 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:25:04 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:25:09 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:25:09 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:25:14 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:25:14 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:25:19 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:25:19 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:25:24 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:25:24 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:25:29 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:25:29 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:25:34 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:25:34 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:25:39 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:25:39 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:25:44 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:25:44 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:25:49 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:25:49 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:25:54 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:25:54 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:25:59 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:25:59 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:26:04 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:26:04 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:26:09 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:26:09 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:26:14 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:26:14 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:26:19 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:26:19 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:26:24 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:26:24 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:26:29 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:26:29 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:26:34 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:26:34 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:26:39 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:26:39 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:26:44 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:26:44 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:26:49 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:26:49 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:26:54 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:26:54 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:26:59 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:26:59 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:27:04 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:27:04 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:27:09 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:27:09 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:27:14 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:27:14 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:27:19 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:27:19 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:27:24 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:27:24 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:27:29 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:27:29 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:27:34 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:27:34 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:27:39 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:27:39 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:27:39 man-jon-note wpa_supplicant[777]: wlp4s0: WPA: Group rekeying completed with 7c:ff:4d:10:38:68 [GTK=CCMP]
Mär 10 11:27:44 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:27:44 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:27:49 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:27:49 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:27:54 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:27:54 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:27:59 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:27:59 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:28:04 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:28:04 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:28:09 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:28:09 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:28:12 man-jon-note gnome-shell[1418]: meta_window_set_stack_position_no_sync: assertion 'window->stack_position >= 0' failed
Mär 10 11:28:14 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:28:14 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:28:19 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:28:19 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:28:24 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:28:24 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:28:29 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:28:29 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:28:33 man-jon-note audit[626]: USYS_CONFIG pid=626 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-delete uuid=59812d1b-a57d-4ff3-affa-2c70103ac994 name=50726F746F6E56504E204445233635 pid=2548 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mär 10 11:28:33 man-jon-note NetworkManager[626]: <info>  [1646908113.7220] audit: op="connection-delete" uuid="59812d1b-a57d-4ff3-affa-2c70103ac994" name="ProtonVPN DE#65" pid=2548 uid=1000 result="success"
Mär 10 11:28:33 man-jon-note kernel: audit: type=1111 audit(1646908113.717:151): pid=626 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-delete uuid=59812d1b-a57d-4ff3-affa-2c70103ac994 name=50726F746F6E56504E204445233635 pid=2548 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mär 10 11:28:34 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:28:34 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:28:36 man-jon-note NetworkManager[626]: <info>  [1646908116.8162] device (pvpnksintrf0): state change: activated -> deactivating (reason 'connection-removed', sys-iface-state: 'managed')
Mär 10 11:28:36 man-jon-note audit[626]: USYS_CONFIG pid=626 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-delete uuid=9bd669cf-80ec-4ffd-a46f-297bcbe6d2cf name="pvpn-killswitch" pid=2571 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mär 10 11:28:36 man-jon-note NetworkManager[626]: <info>  [1646908116.8172] audit: op="connection-delete" uuid="9bd669cf-80ec-4ffd-a46f-297bcbe6d2cf" name="pvpn-killswitch" pid=2571 uid=1000 result="success"
Mär 10 11:28:36 man-jon-note kernel: audit: type=1111 audit(1646908116.814:152): pid=626 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-delete uuid=9bd669cf-80ec-4ffd-a46f-297bcbe6d2cf name="pvpn-killswitch" pid=2571 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mär 10 11:28:36 man-jon-note dbus-daemon[625]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.2' (uid=0 pid=626 comm="/usr/bin/NetworkManager --no-daemon ")
Mär 10 11:28:36 man-jon-note systemd[1]: Starting Network Manager Script Dispatcher Service...
Mär 10 11:28:36 man-jon-note dbus-daemon[625]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Mär 10 11:28:36 man-jon-note systemd[1]: Started Network Manager Script Dispatcher Service.
Mär 10 11:28:36 man-jon-note audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:28:36 man-jon-note kernel: audit: type=1130 audit(1646908116.831:153): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:28:36 man-jon-note NetworkManager[626]: <info>  [1646908116.8379] device (pvpnksintrf0): state change: deactivating -> disconnected (reason 'connection-removed', sys-iface-state: 'managed')
Mär 10 11:28:36 man-jon-note NetworkManager[626]: <info>  [1646908116.8546] policy: set 'FRITZ!Box 4040 OI' (wlp4s0) as default for IPv4 routing and DNS
Mär 10 11:28:36 man-jon-note NetworkManager[626]: <info>  [1646908116.8839] device (pvpnksintrf0): state change: disconnected -> unmanaged (reason 'user-requested', sys-iface-state: 'managed')
Mär 10 11:28:36 man-jon-note gnome-shell[1418]: Removing a network device that was not added
Mär 10 11:28:39 man-jon-note touchegg.desktop[1710]: Error connecting to Touchégg daemon: Could not connect: Connection refused
Mär 10 11:28:39 man-jon-note touchegg.desktop[1710]: Reconnecting in 5 seconds...
Mär 10 11:28:39 man-jon-note systemd-logind[631]: System is rebooting.
Mär 10 11:28:39 man-jon-note systemd[1]: Stopping Session 3 of User my_account...
Mär 10 11:28:39 man-jon-note systemd[1]: Removed slice Slice /system/getty.
Mär 10 11:28:39 man-jon-note nm-dispatcher[2575]: Caught signal 15, shutting down...
Mär 10 11:28:39 man-jon-note systemd[1]: Removed slice Slice /system/modprobe.
Mär 10 11:28:39 man-jon-note bluetoothd[753]: Terminating
Mär 10 11:28:39 man-jon-note systemd[1]: Stopped target Bluetooth Support.
Mär 10 11:28:39 man-jon-note systemd[1]: Stopped target Graphical Interface.
Mär 10 11:28:39 man-jon-note systemd[1]: Stopped target Sound Card.
Mär 10 11:28:39 man-jon-note systemd[1]: Stopped target Timer Units.
Mär 10 11:28:39 man-jon-note systemd[1]: logrotate.timer: Deactivated successfully.
Mär 10 11:28:39 man-jon-note systemd[1]: Stopped Daily rotation of log files.
Mär 10 11:28:39 man-jon-note systemd[1]: man-db.timer: Deactivated successfully.
Mär 10 11:28:39 man-jon-note systemd[1]: Stopped Daily man-db regeneration.
Mär 10 11:28:39 man-jon-note systemd[1]: pamac-cleancache.timer: Deactivated successfully.
Mär 10 11:28:39 man-jon-note systemd[1]: Stopped Monthly clean packages cache.
Mär 10 11:28:39 man-jon-note systemd[1]: pamac-mirrorlist.timer: Deactivated successfully.
Mär 10 11:28:39 man-jon-note systemd[1]: Stopped Generate mirrorlist weekly.
Mär 10 11:28:39 man-jon-note systemd[1]: shadow.timer: Deactivated successfully.
Mär 10 11:28:39 man-jon-note systemd[1]: Stopped Daily verification of password and group files.
Mär 10 11:28:39 man-jon-note systemd[1]: systemd-tmpfiles-clean.timer: Deactivated successfully.
Mär 10 11:28:39 man-jon-note systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Mär 10 11:28:39 man-jon-note systemd[1]: lvm2-lvmpolld.socket: Deactivated successfully.
Mär 10 11:28:39 man-jon-note systemd[1]: Closed LVM2 poll daemon socket.
Mär 10 11:28:39 man-jon-note systemd[1]: systemd-coredump.socket: Deactivated successfully.
Mär 10 11:28:39 man-jon-note systemd[1]: Closed Process Core Dump Socket.
Mär 10 11:28:39 man-jon-note systemd[1]: systemd-rfkill.socket: Deactivated successfully.
Mär 10 11:28:39 man-jon-note systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Mär 10 11:28:39 man-jon-note systemd[1]: Stopping Network Manager Script Dispatcher Service...
Mär 10 11:28:39 man-jon-note systemd[1]: Stopping Accounts Service...
Mär 10 11:28:39 man-jon-note systemd[1]: Stopping Save/Restore Sound Card State...
Mär 10 11:28:39 man-jon-note systemd[1]: Stopping Bluetooth service...
Mär 10 11:28:39 man-jon-note systemd[1]: Stopping Manage, Install and Generate Color Profiles...
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopped target GNOME Wayland Session (session: gnome).
Mär 10 11:28:39 man-jon-note systemd[1]: Stopping CUPS Scheduler...
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopped target Current graphical user session.
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopped target GNOME Session.
Mär 10 11:28:39 man-jon-note systemd[1]: Stopping GNOME Display Manager...
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopped target GNOME Wayland Session.
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopped target GNOME session X11 services.
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopped target GNOME Session (session: gnome).
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopped target GNOME accessibility target.
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopped target GNOME color management target.
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopped target GNOME date & time target.
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopped target GNOME maintenance of expirable data target.
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopped target GNOME keyboard configuration target.
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopped target GNOME keyboard shortcuts target.
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopped target GNOME power management target.
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopped target GNOME printer notifications target.
Mär 10 11:28:39 man-jon-note kernel: rfkill: input handler enabled
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopped target GNOME RFKill support target.
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopped target GNOME FreeDesktop screensaver target.
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopped target GNOME file sharing target.
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopped target GNOME smartcard target.
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopped target GNOME sound sample caching target.
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopped target GNOME USB protection target.
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopped target GNOME Wacom tablet support target.
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopped target GNOME XSettings target.
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopping GNOME Terminal Server...
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopping GNOME accessibility service...
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopping GNOME color management service...
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopping GNOME date & time service...
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopping GNOME maintenance of expirable data service...
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopping GNOME keyboard configuration service...
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopping GNOME keyboard shortcuts service...
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopping GNOME power management service...
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopping GNOME printer notifications service...
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopping GNOME RFKill support service...
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopping GNOME FreeDesktop screensaver service...
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopping GNOME file sharing service...
Mär 10 11:28:39 man-jon-note systemd[1]: Starting Generate shutdown-ramfs...
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopping GNOME smartcard service...
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopping GNOME sound sample caching service...
Mär 10 11:28:39 man-jon-note systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopping GNOME USB protection service...
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopping GNOME Wacom tablet support service...
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopping GNOME XSettings service...
Mär 10 11:28:39 man-jon-note systemd[1]: Stopping Load/Save Random Seed...
Mär 10 11:28:39 man-jon-note systemd[1]: Stopping TLP system startup/shutdown...
Mär 10 11:28:39 man-jon-note systemd[1]: Stopping Disk Manager...
Mär 10 11:28:39 man-jon-note systemd[1]: Stopping Daemon for power management...
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopped GNOME Terminal Server.
Mär 10 11:28:39 man-jon-note systemd[1370]: gnome-terminal-server.service: Consumed 2.423s CPU time.
Mär 10 11:28:39 man-jon-note systemd[1]: cups.service: Deactivated successfully.
Mär 10 11:28:39 man-jon-note systemd[1]: Stopped CUPS Scheduler.
Mär 10 11:28:39 man-jon-note systemd[1370]: Stopped GNOME accessibility service.
Mär 10 11:28:39 man-jon-note audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:28:40 man-jon-note systemd[1]: rtkit-daemon.service: Deactivated successfully.
Mär 10 11:28:40 man-jon-note systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
Mär 10 11:28:39 man-jon-note audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:28:40 man-jon-note systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Mär 10 11:28:40 man-jon-note systemd[1]: Stopped Network Manager Script Dispatcher Service.
Mär 10 11:28:39 man-jon-note audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:28:40 man-jon-note kernel: audit: type=1131 audit(1646908119.997:154): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:28:40 man-jon-note kernel: audit: type=1131 audit(1646908119.997:155): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:28:40 man-jon-note kernel: audit: type=1131 audit(1646908119.997:156): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:28:40 man-jon-note systemd[1]: alsa-restore.service: Deactivated successfully.
Mär 10 11:28:40 man-jon-note systemd[1]: Stopped Save/Restore Sound Card State.
Mär 10 11:28:40 man-jon-note systemd[1370]: vte-spawn-29de9747-555a-4170-9105-67902d51403d.scope: Consumed 1min 35.953s CPU time.
Mär 10 11:28:40 man-jon-note audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:28:40 man-jon-note systemd[1]: session-3.scope: Deactivated successfully.
Mär 10 11:28:40 man-jon-note systemd[1]: Stopped Session 3 of User my_account.
Mär 10 11:28:40 man-jon-note kernel: audit: type=1131 audit(1646908120.001:157): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped GNOME RFKill support service.
Mär 10 11:28:40 man-jon-note udisksd[1520]: udisks daemon version 2.9.4 exiting
Mär 10 11:28:40 man-jon-note systemd[1]: accounts-daemon.service: Deactivated successfully.
Mär 10 11:28:40 man-jon-note systemd[1]: Stopped Accounts Service.
Mär 10 11:28:40 man-jon-note audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:28:40 man-jon-note audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:28:40 man-jon-note systemd[1]: colord.service: Deactivated successfully.
Mär 10 11:28:40 man-jon-note systemd[1]: Stopped Manage, Install and Generate Color Profiles.
Mär 10 11:28:40 man-jon-note systemd[1]: udisks2.service: Deactivated successfully.
Mär 10 11:28:40 man-jon-note systemd[1]: Stopped Disk Manager.
Mär 10 11:28:40 man-jon-note audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:28:40 man-jon-note kernel: audit: type=1131 audit(1646908120.041:158): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:28:40 man-jon-note kernel: audit: type=1131 audit(1646908120.044:159): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:28:40 man-jon-note kernel: audit: type=1131 audit(1646908120.044:160): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:28:40 man-jon-note systemd[1]: systemd-random-seed.service: Deactivated successfully.
Mär 10 11:28:40 man-jon-note audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:28:40 man-jon-note systemd[1]: Stopped Load/Save Random Seed.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped GNOME date & time service.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped GNOME keyboard shortcuts service.
Mär 10 11:28:40 man-jon-note kernel: audit: type=1131 audit(1646908120.047:161): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped GNOME file sharing service.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped GNOME color management service.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped GNOME maintenance of expirable data service.
Mär 10 11:28:40 man-jon-note systemd[1]: Stopping User Manager for UID 1000...
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped GNOME keyboard configuration service.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped GNOME power management service.
Mär 10 11:28:40 man-jon-note systemd-logind[631]: Removed session 3.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped GNOME FreeDesktop screensaver service.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped GNOME smartcard service.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped GNOME sound sample caching service.
Mär 10 11:28:40 man-jon-note mkinitcpio[2594]: ==> Starting build: none
Mär 10 11:28:40 man-jon-note systemd[1]: upower.service: Deactivated successfully.
Mär 10 11:28:40 man-jon-note systemd[1]: Stopped Daemon for power management.
Mär 10 11:28:40 man-jon-note audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped GNOME USB protection service.
Mär 10 11:28:40 man-jon-note kernel: audit: type=1131 audit(1646908120.061:162): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped GNOME Wacom tablet support service.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped GNOME printer notifications service.
Mär 10 11:28:40 man-jon-note mkinitcpio[2594]:   -> Running build hook: [sd-shutdown]
Mär 10 11:28:40 man-jon-note systemd[1370]: Activating special unit Exit the Session...
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped GNOME XSettings service.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopping Application launched by gnome-session-binary...
Mär 10 11:28:40 man-jon-note systemd[1370]: Removed slice Slice /app/org.gnome.Terminal.
Mär 10 11:28:40 man-jon-note systemd[1370]: app-org.gnome.Terminal.slice: Consumed 1min 38.376s CPU time.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped target Main User Target.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped target GNOME session X11 services.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped target GNOME Session is initialized.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped target GNOME Shell.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopping Accessibility services bus...
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopping D-Bus User Message Bus...
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopping User preferences database...
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopping Evolution address book service...
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopping Evolution calendar service...
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopping Evolution source registry...
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopping Virtual filesystem service - Apple File Conduit monitor...
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopping Virtual filesystem service...
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopping Virtual filesystem service - GNOME Online Accounts monitor...
Mär 10 11:28:40 man-jon-note gnome-session-binary[1403]: WARNING: Lost name on bus: org.gnome.SessionManager
Mär 10 11:28:40 man-jon-note audit: BPF prog-id=24 op=UNLOAD
Mär 10 11:28:40 man-jon-note audit: BPF prog-id=23 op=UNLOAD
Mär 10 11:28:40 man-jon-note gnome-session[1403]: gnome-session-binary[1403]: WARNING: Lost name on bus: org.gnome.SessionManager
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopping Virtual filesystem metadata service...
Mär 10 11:28:40 man-jon-note kernel: audit: type=1334 audit(1646908120.084:163): prog-id=24 op=UNLOAD
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopping Virtual filesystem service - Media Transfer Protocol monitor...
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopping Virtual filesystem service - disk device monitor...
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopping GNOME Shell on Wayland...
Mär 10 11:28:40 man-jon-note pulseaudio[1505]: X11 I/O error handler called
Mär 10 11:28:40 man-jon-note pulseaudio[1505]: X11 I/O error exit handler called, preparing to tear down X11 modules
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopping Sound Service...
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopping sandboxed app permission store...
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped Monitor Session leader for GNOME Session.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped Virtual filesystem service - Media Transfer Protocol monitor.
Mär 10 11:28:40 man-jon-note systemd[1]: run-user-1000-gvfs.mount: Deactivated successfully.
Mär 10 11:28:40 man-jon-note systemd[1]: Unmounted /run/user/1000/gvfs.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped User preferences database.
Mär 10 11:28:40 man-jon-note systemd[1370]: gvfs-daemon.service: Killing process 1454 (gvfs-fuse-sub) with signal SIGKILL.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped Virtual filesystem service - GNOME Online Accounts monitor.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped Virtual filesystem service.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped Virtual filesystem metadata service.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped Accessibility services bus.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped sandboxed app permission store.
Mär 10 11:28:40 man-jon-note systemd[1370]: dbus.service: Killing process 1536 (gdbus) with signal SIGKILL.
Mär 10 11:28:40 man-jon-note systemd[1370]: dbus.service: Killing process 1600 (JS Helper) with signal SIGKILL.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped Evolution source registry.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped Virtual filesystem service - disk device monitor.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped Evolution calendar service.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped Evolution address book service.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped Virtual filesystem service - Apple File Conduit monitor.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped D-Bus User Message Bus.
Mär 10 11:28:40 man-jon-note systemd[1370]: dbus.service: Consumed 1.533s CPU time.
Mär 10 11:28:40 man-jon-note systemd[1370]: Stopped Application launched by gnome-session-binary.
Mär 10 11:28:40 man-jon-note systemd[1]: tlp.service: Deactivated successfully.
Mär 10 11:28:40 man-jon-note systemd[1]: Stopped TLP system startup/shutdown.
output of sudo journalctl -u systemd-hibernate.service
Mär 09 09:38:42 man-jon-note systemd[1]: Starting Hibernate...
Mär 09 09:38:42 man-jon-note systemd-sleep[9849]: Entering sleep state 'hibernate'...
-- Boot 4497628da99145b9b5f0c56225105da4 --
Mär 09 09:55:11 man-jon-note systemd[1]: Starting Hibernate...
Mär 09 09:55:11 man-jon-note systemd-sleep[2566]: Entering sleep state 'hibernate'...
-- Boot 09e190f434e7403eafbbfa46f4af3948 --
Mär 09 10:00:12 man-jon-note systemd[1]: Starting Hibernate...
Mär 09 10:00:12 man-jon-note systemd-sleep[2615]: Entering sleep state 'hibernate'...
-- Boot 13acdcc8dc364ef1b486419e5923905f --
Mär 09 10:42:38 man-jon-note systemd[1]: Starting Hibernate...
Mär 09 10:42:38 man-jon-note systemd-sleep[16878]: Entering sleep state 'hibernate'...
-- Boot a6e74058048b4a2da55a4025db18febf --
Mär 09 15:02:28 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 09 15:02:38 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 09 15:02:42 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 09 15:02:43 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 09 15:02:43 man-jon-note systemd[1]: Starting Hibernate...
Mär 09 15:02:43 man-jon-note systemd-sleep[2557]: Entering sleep state 'hibernate'...
Mär 09 15:02:53 man-jon-note systemd-sleep[2557]: Failed to put system to sleep. System resumed again: No such device
Mär 09 15:02:54 man-jon-note systemd[1]: systemd-hibernate.service: Main process exited, code=exited, status=1/FAILURE
Mär 09 15:02:54 man-jon-note systemd[1]: systemd-hibernate.service: Failed with result 'exit-code'.
Mär 09 15:02:54 man-jon-note systemd[1]: Failed to start Hibernate.
Mär 09 15:02:54 man-jon-note systemd[1]: systemd-hibernate.service: Consumed 1.975s CPU time.
-- Boot 03727ed9d93d45f4a41131404d6589a3 --
Mär 09 15:10:41 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 09 15:10:47 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 09 15:10:52 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 09 15:10:53 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 09 15:10:53 man-jon-note systemd[1]: Starting Hibernate...
Mär 09 15:10:53 man-jon-note systemd-sleep[1993]: Entering sleep state 'hibernate'...
Mär 09 15:11:05 man-jon-note systemd-sleep[1993]: Failed to put system to sleep. System resumed again: No such device
Mär 09 15:11:06 man-jon-note systemd[1]: systemd-hibernate.service: Main process exited, code=exited, status=1/FAILURE
Mär 09 15:11:06 man-jon-note systemd[1]: systemd-hibernate.service: Failed with result 'exit-code'.
Mär 09 15:11:06 man-jon-note systemd[1]: Failed to start Hibernate.
Mär 09 15:11:06 man-jon-note systemd[1]: systemd-hibernate.service: Consumed 1.183s CPU time.
-- Boot 89e105ae099a457f97aa3b9e25c3e0d3 --
Mär 09 15:14:35 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 09 15:14:48 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 09 15:14:53 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 09 15:14:58 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 09 15:14:58 man-jon-note systemd[1]: Starting Hibernate...
Mär 09 15:14:58 man-jon-note systemd-sleep[2491]: Entering sleep state 'hibernate'...
Mär 09 15:15:18 man-jon-note systemd-sleep[2491]: Failed to put system to sleep. System resumed again: No such device
Mär 09 15:15:19 man-jon-note systemd[1]: systemd-hibernate.service: Main process exited, code=exited, status=1/FAILURE
Mär 09 15:15:19 man-jon-note systemd[1]: systemd-hibernate.service: Failed with result 'exit-code'.
Mär 09 15:15:19 man-jon-note systemd[1]: Failed to start Hibernate.
Mär 09 15:15:19 man-jon-note systemd[1]: systemd-hibernate.service: Consumed 1.975s CPU time.
-- Boot 3cbea732983e4bfe996eb08620e89cfd --
Mär 09 15:25:22 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 09 15:25:34 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 09 15:25:49 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 09 15:25:53 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 09 15:25:55 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 09 15:25:55 man-jon-note systemd[1]: Starting Hibernate...
Mär 09 15:25:55 man-jon-note systemd-sleep[2673]: Entering sleep state 'hibernate'...
Mär 09 15:26:05 man-jon-note systemd-sleep[2673]: Failed to put system to sleep. System resumed again: No such device
Mär 09 15:26:06 man-jon-note systemd[1]: systemd-hibernate.service: Main process exited, code=exited, status=1/FAILURE
Mär 09 15:26:06 man-jon-note systemd[1]: systemd-hibernate.service: Failed with result 'exit-code'.
Mär 09 15:26:06 man-jon-note systemd[1]: Failed to start Hibernate.
Mär 09 15:26:06 man-jon-note systemd[1]: systemd-hibernate.service: Consumed 2.163s CPU time.
-- Boot dc7c8f3b644c4e089650e80eef25de64 --
Mär 10 11:20:30 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 10 11:22:09 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 10 11:22:14 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 10 11:22:15 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 10 11:22:15 man-jon-note systemd[1]: Starting Hibernate...
Mär 10 11:22:15 man-jon-note systemd-sleep[2168]: Entering sleep state 'hibernate'...
Mär 10 11:22:28 man-jon-note systemd-sleep[2168]: Failed to put system to sleep. System resumed again: No such device
Mär 10 11:22:29 man-jon-note systemd[1]: systemd-hibernate.service: Main process exited, code=exited, status=1/FAILURE
Mär 10 11:22:29 man-jon-note systemd[1]: systemd-hibernate.service: Failed with result 'exit-code'.
Mär 10 11:22:29 man-jon-note systemd[1]: Failed to start Hibernate.
Mär 10 11:22:29 man-jon-note systemd[1]: systemd-hibernate.service: Consumed 1.226s CPU time.
-- Boot cbc24b2bef0f43409b9fe8c8d67d0902 --
Mär 10 11:31:44 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 10 11:32:07 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 10 11:32:10 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 10 11:32:11 man-jon-note systemd[1]: /etc/systemd/system/systemd-hibernate.service.d/bypass_hibernation_memory_check.conf:2: Assignment outside of section. Ignoring.
Mär 10 11:32:11 man-jon-note systemd[1]: Starting Hibernate...
Mär 10 11:32:11 man-jon-note systemd-sleep[2069]: Entering sleep state 'hibernate'...
Mär 10 11:32:24 man-jon-note systemd-sleep[2069]: Failed to put system to sleep. System resumed again: No such device
Mär 10 11:32:25 man-jon-note systemd[1]: systemd-hibernate.service: Main process exited, code=exited, status=1/FAILURE
Mär 10 11:32:25 man-jon-note systemd[1]: systemd-hibernate.service: Failed with result 'exit-code'.
Mär 10 11:32:25 man-jon-note systemd[1]: Failed to start Hibernate.
Mär 10 11:32:25 man-jon-note systemd[1]: systemd-hibernate.service: Consumed 1.131s CPU time.
Hello @Locuthus :wink:
It would be useful to have journal log…
For example this will grab the previous boot and cut out the hibernation part:
journalctl --boot -1 | sed -n -r "/Starting.+Hibernate/,/Finished.+Hibernate/p"
Hi @megavolt,
This is the first around 250 lines of the requested journal entries. I have around 1250 if you need more though. The last occurrence of “hibernat” is at line 147 so I hope that I got it all. You reminded me, that there was another part of the journal in one of the post. I will include the output of that one(for the systemd-hibernate.service) as well.
Should be self-explained:
So for any reason, it cannot find the swapfile. And I guess the reason is that you target the swapfile inside an encrypted device.
Maybe that is is the issue?
:notebook: I am not using encryption.
At least I completely forgot about it. XD
I have an encrypted swapfile on an ext4 system and did not think of this detail. The script from the HowTo I used did though, so that’s not the problem, unfortunately. :thinking:
I just looked at the journal again, and the same mention, that it cannot detect the swap device, is still there.
I overlooked another detail though. Bloody unwarranted routine XD
I did not calculate the resume_offset correctly. Specifically I did not divide with the pagesize and logically it could find the file at the wrong place XD
Thanks for the help!
Now I knew what to look for, and what not to forget XD
