I am trying to play some video’s off my laptop on my TV, and the HDMI sound option is not showing in the pulseaudio volume control. There is no sound coming from the TV. I have played video using another laptop with sound from a different windows laptop so I know the TV supports this.
Normally I just plug my laptop in and the sound works, but this time it is not.
I tried the Arch wiki instructions, but did not get any sound.
inxi -Gza
Device-1: Intel UHD Graphics 620 vendor: CLEVO/KAPOK driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: HDMI-A-2,eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: Chicony USB2.0 Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 04f2:b59d
Display: unspecified server: X.org v: 1.21.1.14 compositor: xfwm4 driver:
X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 tty: 80x24
Monitor-1: HDMI-A-2 model: Toshiba 50UHD_LCD_TV built: 2023 res: 3840x2160
dpi: 89 gamma: 1.2 size: 800x450mm (31.5x17.72") diag: 1263mm (49.7")
ratio: 16:9 modes: max: 3840x2160 min: 720x400
Monitor-2: eDP-1 model: LG Display 0x0545 built: 2016 res: 3200x1800
dpi: 277 gamma: 1.2 size: 293x165mm (11.54x6.5") diag: 336mm (13.2")
ratio: 16:9 modes: 3200x1800
API: OpenGL Message: GL data unavailable in console, glxinfo missing.
Info: Tools: de: xfce4-display-settings x11: xdpyinfo, xprop, xrandr
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC269VC Analog [ALC269VC Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [50UHD_LCD_TV]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
If it try sending direct to the TV no sound comes out.
aplay -D plughw:0,3 /usr/share/sounds/alsa/Front_Right.wav
Playing WAVE '/usr/share/sounds/alsa/Front_Right.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
Hi @RonaldDuncan
Some system context might be useful for those wishing to help. Please provide full system information using the following inxi command;
inxi --admin --verbosity=8 --filter --no-host --width
I’ve taken the liberty of leaving you the filtered command which obfuscates any personally identifiable information from the output. You might like to add this to your notes.
Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=ce5d8de5-3fda-42e3-9989-5686384e8dba rw quiet apparmor=1
security=apparmor resume=UUID=d3cc99e8-09f6-4096-ad28-d60afafdeb6a
udev.log_priority=3
Console: pty pts/1 DM: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
Type: Laptop System: System76 product: Galago Pro v: galp3
Mobo: System76 model: Galago Pro v: galp3 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: 1.05.08RSA
date: 12/08/2017
ID-1: BAT0 charge: 21.1 Wh (100.0%) condition: 21.1/36.5 Wh (57.8%)
volts: 11.8 min: 11.4 model: Notebook BAT type: Li-ion serial: <filter>
status: full
System RAM: total: 32 GiB available: 31.22 GiB used: 1.75 GiB (5.6%)
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous unbuffered
(unregistered) size: 16 GiB speed: 2400 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Samsung
part-no: M471A2K43BB1-CRC serial: <filter>
Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous unbuffered
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF6
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 400 min/max: 400/4000 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 bogomips: 32012
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
vulnerable
X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 tty: 80x43
dpi: 89 gamma: 1.2 chroma: red: x: 0.663 y: 0.322 green: x: 0.251 y: 0.624
blue: x: 0.141 y: 0.051 white: x: 0.314 y: 0.329
size: 800x450mm (31.5x17.72") diag: 1263mm (49.7") ratio: 16:9
modes: 3840x2160, 4096x2160, 1920x1080, 1920x1080i, 1600x1200, 1680x1050,
1400x1050, 1280x1024, 1440x900, 1280x960, 1280x800, 1152x864, 1280x720,
1024x768, 832x624, 800x600, 720x576, 720x576i, 720x480, 720x480i, 640x480,
720x400
EDID-Warnings: 1: parse_edid: unhandled CEA mode 93 2: parse_edid:
unhandled CEA mode 94 3: parse_edid: unhandled CEA mode 95 4: parse_edid:
unhandled CEA mode 98 5: parse_edid: unhandled CEA mode 99 6: parse_edid:
unhandled CEA mode 100
dpi: 277 gamma: 1.2 chroma: red: x: 0.639 y: 0.333 green: x: 0.306 y: 0.627
blue: x: 0.153 y: 0.043 white: x: 0.314 y: 0.329
size: 293x165mm (11.54x6.5") diag: 336mm (13.2") ratio: 16:9
modes: 3200x1800
Device-1: Intel Sunrise Point-LP HD Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: off tools: pw-cli
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with:
tools: pacat,pactl,pavucontrol
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 3a:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp58s0f1 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 3b:00.0 chip-ID: 8086:24fd class-ID: 0280
IF: wlp59s0 state: up mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
Info: services: NetworkManager, sshd, wpa_supplicant
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 8087:0a2b
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 2.27 TiB used: 205.11 GiB (8.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B7QCXE7 temp: 30.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LX001-1RG174
tech: HDD rpm: 5400 serial: <filter> fw-rev: SDM1 scheme: GPT
ID-1: / raw-size: 431.09 GiB size: 423.26 GiB (98.18%)
used: 205.11 GiB (48.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: ce5d8de5-3fda-42e3-9989-5686384e8dba
used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: C9B5-676E
ID-1: swap-1 type: partition size: 34.37 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: d3cc99e8-09f6-4096-ad28-d60afafdeb6a
ID-1: /dev/sda1 maj-min: 8:1 size: 1.82 TiB fs: ext4 label: ExtraDrive1
uuid: 8bc9d0c1-a7c7-450c-bb27-ba8a6c110295
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-4:2 info: Chicony USB2.0 Camera type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 04f2:b59d class-ID: 0e02 serial: <filter>
Device-2: 1-5:3 info: Intel Bluetooth wireless interface type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:0a2b class-ID: e001
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
System Temperatures: cpu: 42.0 C pch: 38.5 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1407 libs: 438 tools: pamac pm: flatpak pkgs: 0
1: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
2: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
3: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
4: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
5: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
6: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
7: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
9: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
10: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
11: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
12: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
13: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
14: https://mirrors2.manjaro.org/stable/$repo/$arch
15: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
16: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
17: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
18: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
19: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
20: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
21: http://manjaro.mirror.ac.za/stable/$repo/$arch
22: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
23: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
24: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
25: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
26: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
27: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
28: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
29: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
30: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
31: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
32: https://mirror.23m.com/manjaro/stable/$repo/$arch
33: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
34: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
35: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
36: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
37: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
38: https://linorg.usp.br/manjaro/stable/$repo/$arch
39: https://muug.ca/mirror/manjaro/stable/$repo/$arch
40: https://mirror.funami.tech/manjaro/stable/$repo/$arch
41: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
42: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
43: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
44: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
45: https://mirrors.manjaro.org/repo/stable/$repo/$arch
46: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
47: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
48: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
49: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
50: https://mirror.koddos.net/manjaro/stable/$repo/$arch
51: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
52: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
53: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
54: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
55: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
56: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
57: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
58: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
59: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
60: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
61: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
62: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
63: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
64: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
65: http://manjaro.grena.ge/stable/$repo/$arch
66: http://mirror.fcix.net/manjaro/stable/$repo/$arch
67: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
68: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
69: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
70: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
71: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
72: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
73: https://manjaro.ynh.ovh/stable/$repo/$arch
74: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
75: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
76: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
77: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
78: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
79: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
80: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
81: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
82: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
83: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
84: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
85: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
86: https://manjaro.kurdy.org/stable/$repo/$arch
87: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
88: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
89: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
90: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
91: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
92: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
93: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
94: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
95: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
96: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
97: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
98: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
99: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
100: https://mirror.easyname.at/manjaro/stable/$repo/$arch
101: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
102: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
103: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
104: https://mirror.dc.uz/manjaro/stable/$repo/$arch
105: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
106: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
107: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
108: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
109: https://mirror.zetup.net/manjaro/stable/$repo/$arch
110: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
111: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
112: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
113: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
114: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
115: https://mirror.init7.net/manjaro/stable/$repo/$arch
116: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
117: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
118: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 214
1: cpu: 0.1% command: blueman-tray started-by: python pid: 2267
mem: 57.2 MiB (0.1%)
2: cpu: 0.0% command: init pid: 1 mem: 12.7 MiB (0.0%)
3: cpu: 0.0% command: [kthreadd] pid: 2 mem: 0.00 MiB (0.0%)
4: cpu: 0.0% command: [pool_workqueue_release] pid: 3 mem: 0.00 MiB (0.0%)
5: cpu: 0.0% command: [kworker/R-rcu_gp] pid: 4 mem: 0.00 MiB (0.0%)
Memory top: 5 of 214
1: mem: 278.3 MiB (0.8%) command: teams pid: 2728 cpu: 0.0%
2: mem: 168.9 MiB (0.5%) command: teams pid: 2771 cpu: 0.0%
3: mem: 167.7 MiB (0.5%) command: xfwm4 pid: 1860 cpu: 0.0%
4: mem: 148.7 MiB (0.4%) command: xfdesktop pid: 1970 cpu: 0.0%
5: mem: 144.3 MiB (0.4%) command: teams pid: 2730 cpu: 0.0%
Processes: 214 Power: uptime: 1d 8h 39m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: upowerd,xfce4-power-manager
Init: systemd v: 256 default: graphical tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Bash v: 5.2.37
running-in: pty pts/1 (SSH) inxi: 3.3.37
Please post more information about onboard audio device detected in PulseAudio
pacmd list-cards; pacmd list-sinks
1 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 6
properties:
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xdc320000 irq 126"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "9d71"
device.product.name = "Sunrise Point-LP HD Audio"
device.string = "0"
device.description = "Built-in Audio"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
input:analog-stereo: Analog Stereo Input (priority 32833, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 39268, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 39333, available: unknown)
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 38668, available: unknown)
output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (priority 38733, available: unknown)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 33568, available: unknown)
output:hdmi-surround+input:analog-stereo: Digital Surround 5.1 (HDMI) Output + Analog Stereo Input (priority 33633, available: unknown)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 33568, available: unknown)
output:hdmi-surround71+input:analog-stereo: Digital Surround 7.1 (HDMI) Output + Analog Stereo Input (priority 33633, available: unknown)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
output:hdmi-stereo-extra1+input:analog-stereo: Digital Stereo (HDMI 2) Output + Analog Stereo Input (priority 5765, available: unknown)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround71-extra1+input:analog-stereo: Digital Surround 7.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
output:hdmi-stereo-extra2+input:analog-stereo: Digital Stereo (HDMI 3) Output + Analog Stereo Input (priority 5765, available: unknown)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround71-extra2+input:analog-stereo: Digital Surround 7.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: unknown)
off: Off (priority 0, available: unknown)
active profile: <output:analog-stereo+input:analog-stereo>
sinks:
alsa_output.pci-0000_00_1f.3.analog-stereo/#0: Built-in Audio Analog Stereo
sources:
alsa_output.pci-0000_00_1f.3.analog-stereo.monitor/#0: Monitor of Built-in Audio Analog Stereo
alsa_input.pci-0000_00_1f.3.analog-stereo/#1: Built-in Audio Analog Stereo
ports:
analog-input-internal-mic: Internal Microphone (priority 8900, latency offset 0 usec, available: unknown)
properties:
analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: no)
properties:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: yes)
properties:
device.product.name = "50UHD_LCD_TV"
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
1 sink(s) available.
* index: 0
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9039
volume: front-left: 67502 / 103% / 0.77 dB, front-right: 66295 / 101% / 0.30 dB
balance -0.02
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 0.00 ms
max request: 0 KiB
max rewind: 0 KiB
monitor source: 0
sample spec: s16le 2ch 44100Hz
channel map: front-left,front-right
Stereo
used by: 0
linked by: 0
configured latency: 0.00 ms; range is 0.50 .. 2000.00 ms
card: 0 <alsa_card.pci-0000_00_1f.3>
module: 6
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "ALC269VC Analog"
alsa.id = "ALC269VC Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "0"
device.bus = "pci"
device.string = "front:0"
device.buffering.buffer_size = "352800"
device.buffering.fragment_size = "176400"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Built-in Audio Analog Stereo"
ports:
properties:
properties:
active port: <analog-output-speaker>
Looking at the card output the hdmi-output-0 port is showing as available.
properties:
however when it try to set it
$ pacmd set-sink-port 0 hdmi-output-0
Failed to set sink port to 'hdmi-output-0'.
Any ideas welcome
I tried updating /etc/pulse/default.pa
and putting in
##rjd fix to try and force hdmi to load a hdmi is card 0 device 3
load-module module-alsa-sink device=hw:0,3
this had no effect at the end of the file, at the beginning. It changed the default as follows
pacmd list-cards
0 card(s) available.
and
pacmd list-sinks
* index: 0
driver: <module-alsa-sink.c>
flags: HARDWARE DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: IDLE
suspend cause: (none)
priority: 9030
volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
volume steps: 65537
muted: no
current latency: 6.55 ms
max request: 1 KiB
max rewind: 1 KiB
monitor source: 0
Stereo
used by: 0
linked by: 1
configured latency: 6.94 ms; range is 0.50 .. 2000.00 ms
module: 0
properties:
device.api = "alsa"
alsa.name = "50UHD_LCD_TV"
alsa.id = "HDMI 0"
alsa.device = "3"
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xdc320000 irq 125"
device.bus = "pci"
device.string = "hw:0,3"
So the correct sink shows up, but no sound comes out an the gui shows an audio card with all setting grayed out.
I have tried different positioning for the
within the /etc/pulse/default.pa
However
pulseaudio -k
pulseaudio --start
Does not restore normal sound even when I go back to the original
I need to restart lightdm to get sound working normally again.
sudo systemctl restart lightdm
Putting the
within the /etc/pulse/default.pa below the automatic hardware detection section
results in laptop speakers working, but still does not play on hdmi, although the hdmi section is now showing in the gui, and you can see the sound volume fluctuating as you play.
pacmd list-sinks now shows hdmi as an output although not called hdmi
2 sink(s) available.
* index: 0
state: IDLE
priority: 9039
volume: front-left: 65536 / 100% / 0.00 dB, front-right: 64322 / 98% / -0.49 dB
balance -0.02
volume steps: 65537
muted: no
current latency: 6.84 ms
max request: 1 KiB
max rewind: 1 KiB
monitor source: 0
sample spec: s16le 2ch 48000Hz
Stereo
used by: 0
linked by: 3
configured latency: 6.94 ms; range is 0.50 .. 1837.50 ms
module: 6
properties:
device.api = "alsa"
alsa.device = "0"
alsa.card = "0"
device.bus = "pci"
ports:
properties:
properties:
index: 1
state: IDLE
priority: 9030
balance 0.00
volume steps: 65537
muted: no
current latency: 7.57 ms
max request: 1 KiB
max rewind: 1 KiB
monitor source: 2
Stereo
used by: 0
linked by: 1
module: 7
properties:
device.api = "alsa"
alsa.id = "HDMI 0"
alsa.device = "3"
alsa.card = "0"
device.bus = "pci"
pacmd (or pactl) commands to set the sink-port can use the sink name instead of sink number:
pacmd set-sink-port alsa_card.pci-0000_00_1f.3 hdmi-output-0
Sink port can also be selected in PulseAudio Volume Control > Output Devices tab
pavucontrol --tab=3
Archwiki - PulseAudio - Configuration
Configuration files
PulseAudio will first look for configuration files in the home directory ~/.config/pulse/, and if they are not found, the system-wide configuration from /etc/pulse/ will be applied.
Tip:
- It is strongly suggested not to edit system-wide configuration files, but rather edit user ones.
cp /etc/pulse/default.pa ~/.config/pulse/default.pa
I tried this and got
No sink found by this name or index.
Had a look at https://unix.stackexchange.com/questions/175930/change-default-port-for-pulseaudio-line-out-not-headphones looking for syntax of set-sink-port
pacmd list | grep "active port"
active port: <analog-input-internal-mic>
then looked at [Solved] PulseAudio can't remember default device after logout/login / Multimedia and Games / Arch Linux Forums
which gave me
pacmd list-cards
profiles:
and
pacmd set-card-profile 0 output:hdmi-stereo
Gave me HDMI sound.
So good news I now have HDMI sound. So laptop and TV work together.
Just need to figure out how to make it work with out having to go to the command line so that hdmi is an option in the gui.
PulseAudio card Profile can be selected in PulseAudio Volume Control > Configuration tab
pavucontrol --tab=5
There is also a button to lock the card profile
