No HDMI output HP laptop
Hello,
Sorry for my English, I’m not very fluent…
I installed a Manjaro distrib. on a little HP laptop for years. I had problems making the HDMI video output work but it finally did, I don’t know how…
I also had problem with bluetooth. After opening the laptop, it finally work, and I still don’t know why… But now, the HDMI video output doesn’t work. It is listed in the arandr menu in grey.
The journalctl tells that Portal is not running:
    pipewire-pulse[1276]: mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
    pipewire-pulse[1276]: mod.rt: found session bus but no portal
    systemd[1174]: xdg-desktop-portal-gnome.service: Job xdg-desktop-portal-gnome.service/start failed with result 'dependency'.
    xdg-desktop-por[1467]: Failed to create settings proxy: Erreur lors de l’appel de StartServiceByName pour org.freedesktop.impl.portal.desktop.gnome : timeout
It seems that lightdm is also involved:
    lightdm[1150]: pam_systemd_home(lightdm:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
    lightdm[1150]: gkr-pam: unable to locate daemon control file
There’s also a problem with the atomisp driver but I don’t think it is linked to the HDMI output problem…
Here is my inxi -Fza output :
  Kernel: 5.10.181-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=86a2054b-c367-4e97-9b9a-7291cc783849 rw quiet apparmor=1
    security=apparmor resume=UUID=e4ff577f-c0a3-439f-9bcc-d59277aac66d
    udev.log_priority=3
  Desktop: N/A wm: xfwm v: 4.18.0 dm: LightDM v: 1.32.0
  Type: Detachable System: HP product: HP x2 Detachable 10-p0XX v: N/A
    serial: <superuser required> Chassis: type: 32 serial: <superuser required>
  Mobo: HP model: 827C v: 93.23 serial: <superuser required>
    UEFI: American Megatrends v: F.33 date: 10/30/2018
  ID-1: BATC charge: 19.0 Wh (64.4%) condition: 29.5/32.6 Wh (90.6%)
    volts: 7.7 min: 7.7 model: Intel SR 1 SR Real Battery type: Li-ion
    serial: <filter> status: discharging
  Info: model: Intel Atom x5-Z8350 bits: 64 type: MCP arch: Airmont level: v2
    built: 2015-17 process: Intel 14nm family: 6 model-id: 0x4C (76) stepping: 4
    microcode: 0x411
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
    desc: d-4x24 KiB; i-4x32 KiB L2: 2 MiB desc: 2x1024 KiB
  Speed (MHz): avg: 617 high: 718 min/max: 480/1920 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 480 2: 718 3: 558 4: 714
    bogomips: 11524
  Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
  Type: spec_store_bypass status: Not affected
    STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
    Integrated Graphics vendor: Hewlett-Packard driver: i915 v: kernel
    arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
    empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:22b0 class-ID: 0300
  Device-2: Chicony HP TrueVision HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.2:5 chip-ID: 04f2:b5a9
  Display: x11 server: X.Org v: 1.20.11 with: Xwayland v: 23.1.1
    compositor: xfwm v: 4.18.0 driver: X: loaded: modesetting
    alternate: fbdev,vesa dri: swrast gpu: i915 display-ID: localhost:11.0
    screens: 1
  Screen-1: 0 s-res: 3584x1440 s-dpi: 86 s-size: 1057x425mm (41.61x16.73")
    s-diag: 1139mm (44.85")
  Monitor-1: DP-1 pos: primary,right res: 2560x1440 dpi: 109
    size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
  Monitor-2: DVI-I-0 pos: left res: 1024x1280 hz: 60 dpi: 86
    size: 301x376mm (11.85x14.8") diag: 482mm (18.96") modes: N/A
  API: OpenGL v: 4.5 Mesa 23.0.4 renderer: llvmpipe (LLVM 15.0.7 128 bits)
    direct-render: Yes
  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
    Imaging Unit vendor: Hewlett-Packard driver: N/A alternate: atomisp
    bus-ID: 00:03.0 chip-ID: 8086:22b8 class-ID: 0480
  API: ALSA v: k5.10.181-2-MANJARO status: kernel-api with: aoss
  Server-1: PipeWire v: 0.3.70 status: active (process) with:
    3: pipewire-alsa type: plugin 4: pw-jack type: plugin
  Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:3165 class-ID: 0280
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4.1:4
    chip-ID: 8087:0a2a class-ID: e001
  Local Storage: total: 177.33 GiB used: 26.03 GiB (14.7%)
  ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: HP model: DF4064 size: 58.24 GiB
    block-size: physical: 512 B logical: 512 B tech: SSD serial: <filter>
    fw-rev: 0x8 scheme: GPT
  ID-2: /dev/mmcblk2 maj-min: 179:24 model: SC128 size: 119.08 GiB
    scheme: MBR
  ID-1: / raw-size: 52.15 GiB size: 51.03 GiB (97.85%) used: 20.7 GiB (40.6%)
    fs: ext4 dev: /dev/mmcblk0p2 maj-min: 179:2
    used: 288 KiB (0.1%) fs: vfat dev: /dev/mmcblk0p1 maj-min: 179:1
  ID-1: swap-1 type: partition size: 5.79 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/mmcblk0p3 maj-min: 179:3
  System Temperatures: cpu: 50.0 C mobo: N/A
  Processes: 246 Uptime: 2h 3m wakeups: 1 Memory: available: 3.74 GiB
  used: 1.07 GiB (28.7%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1430 libs: 407 tools: pamac,yay pm: flatpak pkgs: 0 Shell: Bash
  v: 5.1.16 running-in: sshd (SSH) inxi: 3.3.27
Any idea ?
Greetings,
Sylvain
Can share the output of: xrandr ?
Looks like there is no HDMI involved? It is a DVI connection.
Could this be related? Check if you find a solution within this thread.
Here is the xrandr:
Screen 0: minimum 8 x 8, current 3584 x 1440, maximum 16384 x 16384
DVI-I-0 connected 1024x1280+0+0 right (normal left inverted right x axis y axis) 376mm x 301mm
   1280x1024     60.02*+  75.02
   1024x768      75.03    60.00
   800x600       75.00    60.32
   640x480       75.00    59.94
DVI-I-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-0 disconnected (normal left inverted right x axis y axis)
DVI-D-0 disconnected (normal left inverted right x axis y axis)
DP-1 connected primary 2560x1440+1024+0 (normal left inverted right x axis y axis) 597mm x 336mm
   2560x1440     59.95 + 120.00*   74.97
   1920x1200     59.88
   1920x1080    119.88   100.00    60.00    59.94
   1680x1050     59.95
   1600x900      60.00
   1440x900      59.89
   1280x1024     60.02
   1280x800      59.81
   1280x720      60.00    59.94
   1024x768      60.00
   800x600       60.32
   720x480       59.94
   640x480       59.94    59.93
Could the HDMI cable be out of order ? It worked fine till monday 06/12…
As a last chance, I have changed the HDMI cable and you know what ? Tada ! It works…
I don’t understand why the old cable now doesn’t work. It was fine till the begining of the week. I have no over way to test it.
There is still a problem with xdg-desktop-portal… I look the link you gave upside. Thank you !
