No HDMI Audio over Radeon R 285/380
Hello,
I wanted to watch some video-files on my TV fron my PC, which is connected with HDMI-Cable. But there is no sound, just only my wallpaper and the video. I also used 2 other Monitos (One DVI and one VGA) and my Headphones, but there is no porblem. The hdmi-cable is not broken or something, because I tested with my laptop.
I don´t know, how to solve it. I tested it with Pipewire and ALSA, but nothing works.
I am using the gnome-version of manjaro, btw.
Can anyone help me?
Welcome to the community!
If the sound works on your monitors but not the TV, it’s the tv, not your system.
If you are saying the sound works in your headphones, that might mean you need to change the output from headphones to hdmi.
I do not use GNOME so I cant tell you how.
Might be as easy as you just pulling the plug of the headphones.
Well if I didn´t change the output, then I wouldn´t asking for some help. BUT I did changing the output to HDMI and IT DIDN`T WORK after ALL.
What does inxi -A return?
Open a terminal and type above command.
Then use the </> button at the top of the message window and paste the output.
Device-1: Intel 8 Series/C220 Series High Definition Audio
driver: snd_hda_intel
Device-2: AMD Tonga HDMI Audio [Radeon R9 285/380] driver: snd_hda_intel
Device-3: Kingston HyperX 7.1 Audio
driver: hid-generic,snd-usb-audio,usbhid type: USB
API: ALSA v: k6.6.1-1-MANJARO status: kernel-api
Server-1: PipeWire v: 0.3.85 status: active
It’s there.
Sorry, I do not use GNOME, I can not help you more. On my system I would just click the sound icon and change it to hdmi and sound would come there.
A TV should be able to support audio over HDMI
Online hardware scans for AMD Tonga HDMI Audio [Radeon R9 285/380] shows it has 7 audio outputs for audio playback in ALSA
PipeWire might be trying to play audio to HDMI output for one of the monitors instead of TV
Check PipeWire audio Profiles and Ports
pactl list sinks
That should show model name of TV and whether it is available
Also check if HDMI output to TV is unmuted ( [on] ) in ALSA
amixer -c HDMI
[quote="nikgnomic, post:7, topic:152230, full:true]
pactl list sinks
[/quote]
Sink #134
State: SUSPENDED
Description: Tonga HDMI Audio [Radeon R9 285/380] (Radeon R9 285/380 HDMI Audio) Digital Stereo (HDMI)
Driver: PipeWire
Sample Specification: s16le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 4294967295
Mute: no
Volume: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB
balance 0,00
Base Volume: 65536 / 100% / 0,00 dB
Monitor Source: alsa_output.pci-0000_01_00.1.hdmi-stereo.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE DECIBEL_VOLUME LATENCY SET_FORMATS
Properties:
object.path = “alsa:pcm:1:hdmi:1:playback”
api.alsa.path = “hdmi:1”
api.alsa.pcm.card = “1”
api.alsa.pcm.stream = “playback”
audio.channels = “2”
audio.position = “FL,FR”
device.routes = “1”
alsa.resolution_bits = “16”
device.api = “alsa”
device.class = “sound”
alsa.class = “generic”
alsa.subclass = “generic-mix”
alsa.name = “HDMI 0”
alsa.id = “HDMI 0”
alsa.subdevice = “0”
alsa.subdevice_name = “subdevice #0
alsa.device = “3”
alsa.card = “1”
alsa.card_name = “HDA ATI HDMI”
alsa.long_card_name = “HDA ATI HDMI at 0xf0260000 irq 34”
alsa.driver_name = “snd_hda_intel”
device.profile.name = “hdmi-stereo”
device.profile.description = “Digital Stereo (HDMI)”
card.profile.device = “6”
device.id = “42”
factory.name = “api.alsa.pcm.sink”
priority.driver = “632”
priority.session = “632”
media.class = “Audio/Sink”
node.nick = “HDA ATI HDMI”
node.name = “alsa_output.pci-0000_01_00.1.hdmi-stereo”
device.description = “Tonga HDMI Audio [Radeon R9 285/380] (Radeon R9 285/380 HDMI Audio)”
device.icon_name = “audio-card-hdmi”
device.bus = “pci”
device.bus_path = “pci-0000:01:00.1”
node.pause-on-idle = “false”
factory.id = “18”
clock.quantum-limit = “8192”
client.id = “33”
node.driver = “true”
factory.mode = “merge”
audio.adapt.follower = “”
library.name = “audioconvert/libspa-audioconvert”
object.id = “66”
object.serial = “134”
device.enum.api = “udev”
api.alsa.card = “1”
api.alsa.card.name = “HDA ATI HDMI”
api.alsa.card.longname = “HDA ATI HDMI at 0xf0260000 irq 34”
device.plugged.usec = “3236298”
sysfs.path = “/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1”
device.subsystem = “sound”
device.vendor.id = “0x1002”
device.vendor.name = “Advanced Micro Devices, Inc. [AMD/ATI]”
device.product.id = “0xaad8”
device.product.name = “Tonga HDMI Audio [Radeon R9 285/380] (Radeon R9 285/380 HDMI Audio)”
device.name = “alsa_card.pci-0000_01_00.1”
device.nick = “HDA ATI HDMI”
api.alsa.use-acp = “true”
api.acp.auto-profile = “false”
api.acp.auto-port = “false”
api.dbus.ReserveDevice1 = “Audio1”
device.string = “1”
Ports:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, availability group: Legacy 1, available)
Active Port: hdmi-output-0
Formats:
pcm
dts-iec61937, format.rate = “{ "min": 32000, "max": 48000 }”
ac3-iec61937, format.rate = “{ "min": 32000, "max": 48000 }”
mpeg-iec61937, format.rate = “{ "min": 32000, "max": 48000 }”
mpeg2-aac-iec61937, format.rate = “{ "min": 32000, "max": 48000 }”
amixer -c HDMI
[/quote]
Simple mixer control ‘IEC958’,0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Simple mixer control ‘IEC958’,1
Mono: Playback [on]
Simple mixer control ‘IEC958’,2
Mono: Playback [on]
Simple mixer control ‘IEC958’,3
Mono: Playback [on]
Simple mixer control ‘IEC958’,4
Mono: Playback [on]
Simple mixer control ‘IEC958’,5
Mono: Playback [on]
So whats the solution now?
ALSA data is OK - all outputs shown as [on]
But PipeWire data is showing active profile only: No other profiles listed. Nothing to suggest which of the 7 possible outputs is connected to TV, but it probably isn’t the first output
I suggest check audio controls on the TV to make sure audio is correctly configured to use HDMI input and audio is not muted or volume turned down
Then use audio GUI controls to change the audio profile to use the other HDMI outputs until you find the one connected to TV that works
If you cannot find a way to change Profile in default GUI controls, Install Pulseaudio Volume Control
( pavucontrol ) and go to Configuration tab ( pavucontrol --tab=5 ) to change card Profile
Well, then tell me why my FireTV-Stick or even my PS4 Pro Console have sound thorugh the HDMI-Ports of my TV?
I already used and checked it, that doesn´t helped it. No sound by changing the profile.
AFAIK Fire TV device only has one HDMI output and could not be configured to an incorrect HDMI output if there is only one option. I don’t know how many HDMI outputs the PS4 console has
If you do not mention something you tried to troubleshoot this issue, it is very likely that you will be asked to try again and report results
I suggest you boot the Live ISO image you used to install Manjaro
and post more information about audio devices detected in PulseAudio
pactl list cards; pactl list sinks
that should at least help identify which output is connected to TV
Well the problem is, that I don´t have the Live ISO Image anymore, so whats now?
Is there an another solution?
I suggest:
  1. Disable both monitors in display settings, so the GPU can only use TV for audio & video output
  2. Check pactl list sinks to see if PipeWire has switched to use the TV sink
  3. Shutdown system and unplug both monitors; the USB headset and any jacks plugged in to onboard audio device
  4. Reboot and check pactl list sinks again to see if the TV sink is detected
By disable both monitors:
Sink #48
State: SUSPENDED
Description: Built-in Audio Digital Stereo (IEC958)
Driver: PipeWire
Sample Specification: s32le 2ch 48000Hz
Mute: no
balance 0,00
Monitor Source: alsa_output.pci-0000_00_1b.0.iec958-stereo.monitor
Flags: HARDWARE HW_MUTE_CTRL DECIBEL_VOLUME LATENCY SET_FORMATS
Properties:
object.path = “alsa:pcm:0:iec958:0:playback”
api.alsa.path = “iec958:0”
api.alsa.pcm.card = “0”
device.routes = “1”
device.api = “alsa”
alsa.name = “ALC892 Digital”
alsa.id = “ALC892 Digital”
alsa.device = “1”
alsa.card = “0”
alsa.card_name = “HDA Intel PCH”
alsa.long_card_name = “HDA Intel PCH at 0xf0410000 irq 33”
device.profile.name = “iec958-stereo”
device.profile.description = “Digital Stereo (IEC958)”
card.profile.device = “14”
device.id = “45”
priority.driver = “736”
priority.session = “736”
node.nick = “HDA Intel PCH”
node.name = “alsa_output.pci-0000_00_1b.0.iec958-stereo”
device.description = “Built-in Audio”
device.icon_name = “audio-card-iec958”
device.bus = “pci”
device.bus_path = “pci-0000:00:1b.0”
device.form_factor = “internal”
factory.id = “18”
client.id = “33”
object.id = “35”
object.serial = “48”
api.alsa.card = “0”
api.alsa.card.name = “HDA Intel PCH”
api.alsa.card.longname = “HDA Intel PCH at 0xf0410000 irq 33”
device.plugged.usec = “4778821”
sysfs.path = “/devices/pci0000:00/0000:00:1b.0/sound/card0”
device.vendor.id = “0x8086”
device.vendor.name = “Intel Corporation”
device.product.id = “0x8c20”
device.product.name = “8 Series/C220 Series Chipset High Definition Audio Controller”
device.name = “alsa_card.pci-0000_00_1b.0”
device.nick = “HDA Intel PCH”
api.dbus.ReserveDevice1 = “Audio0”
device.string = “0”
Ports:
iec958-stereo-output: Digital Output (S/PDIF) (type: SPDIF, priority: 0, availability unknown)
Active Port: iec958-stereo-output
Formats:
pcm
Sink #319
State: SUSPENDED
Driver: PipeWire
Mute: no
balance 0,00
Properties:
device.routes = “1”
device.api = “alsa”
alsa.id = “HDMI 0”
alsa.device = “3”
alsa.card = “1”
device.id = “42”
device.bus = “pci”
factory.id = “18”
client.id = “33”
object.id = “72”
object.serial = “319”
api.alsa.card = “1”
device.plugged.usec = “4738045”
device.string = “1”
Ports:
Formats:
pcm
By unplugged both monitors and sounds:
Sink #45
State: SUSPENDED
Driver: PipeWire
Mute: no
balance 0,00
Properties:
device.routes = “1”
device.api = “alsa”
alsa.name = “HDMI 0 *”
alsa.id = “HDMI 0”
alsa.device = “3”
alsa.card = “1”
device.id = “42”
device.bus = “pci”
factory.id = “18”
client.id = “33”
object.id = “45”
object.serial = “45”
api.alsa.card = “1”
device.plugged.usec = “3239599”
device.string = “1”
Ports:
Formats:
pcm
Sink #46
State: SUSPENDED
Driver: PipeWire
Mute: no
balance 0,00
Properties:
device.routes = “1”
device.api = “alsa”
alsa.device = “1”
alsa.card = “0”
device.id = “44”
device.bus = “pci”
factory.id = “18”
client.id = “33”
object.id = “35”
object.serial = “46”
api.alsa.card = “0”
device.plugged.usec = “3287422”
device.string = “0”
Ports:
Formats:
pcm
Data now shows 2 sink outputs
The HDMI sink is the same as before:
alsa.device = “3”
alsa.card = “1”`
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, availability group: Legacy 1, available)`
Output is shown as available so this might have been the correct sink output for TV all along
but PipeWire might have been using another sink on another card
Data also shows SPDIF output from onboard audio card
alsa.device = “1”
alsa.card = “0”
I suggest check which of the 2 remaining sinks is set as default for audio playback
pactl get-default-sink
If response shows the SPDIF output is set as default sink:
change default sink to HDMI output
pactl set-default-sink alsa_output.pci-0000_01_00.1.hdmi-stereo
If PipeWire is still not using HDMI sink, disable the SPDIF sink
pactl set-card-profile alsa_card.pci-0000_00_1b.0 off
and to ensure HDMI output is not suspended (except when idle)
pactl suspend-sink alsa_output.pci-0000_01_00.1.hdmi-stereo 0
But still no sound
Stop pipewire-pulse systemd units
systemctl --user stop pipewire-pulse.socket pipewire-pulse.service
and test audio playback direct to ALSA device
speaker-test -Dhw:1,3 -c2 -l3 -twav
If that does not work, please post more information about ALSA playback devices
aplay -l
Now I don´t have no sound…also on my headphones.
**** Liste der Hardware-Geräte (PLAYBACK) ****
Karte 0: PCH [HDA Intel PCH], Gerät 0: ALC892 Analog [ALC892 Analog]
Sub-Geräte: 1/1
Sub-Gerät #0: subdevice #0
Karte 0: PCH [HDA Intel PCH], Gerät 1: ALC892 Digital [ALC892 Digital]
Sub-Geräte: 1/1
Karte 1: HDMI [HDA ATI HDMI], Gerät 3: HDMI 0 [HDMI 0 *]
Sub-Geräte: 1/1
Karte 1: HDMI [HDA ATI HDMI], Gerät 7: HDMI 1 [HDMI 1]
Sub-Geräte: 1/1
Karte 1: HDMI [HDA ATI HDMI], Gerät 8: HDMI 2 [HDMI 2]
Sub-Geräte: 1/1
Karte 1: HDMI [HDA ATI HDMI], Gerät 9: HDMI 3 [HDMI 3]
Sub-Geräte: 1/1
Karte 1: HDMI [HDA ATI HDMI], Gerät 10: HDMI 4 [HDMI 4]
Sub-Geräte: 1/1
Karte 1: HDMI [HDA ATI HDMI], Gerät 11: HDMI 5 [HDMI 5]
Sub-Geräte: 1/1
Karte 2: Sound [HyperX Virtual Surround Sound], Gerät 0: USB Audio [USB Audio]
Sub-Geräte: 1/1
Check if speaker-test works playing to USB headset
speaker-test -Dhw:2,0 -c2 -l3 -twav
Asterisk showing for HMDI 0 output [HDMI 0 *] in aplay -l suggests the connected device (TV) is not detected correctly
If HDMI output was working I would expect to see more information about connected device
I suggest: reconnect the primary monitor, disconnect the TV and check aplay -l again
If HDMI 0 is not showing an asterisk after TV is disconnected it is likely that the HDMI output is not capable of sending audio to the TV if it cannot be detected propely
The only thing I can think of to try next is to connect the TV to another output from the GPU (DVI or DisplayPort), Check if the TV connection is detected in aplay-l and run a speaker-test if it is detected without an asterisk
But you will probably need to borrow/buy a DisplayPort > HDMI cable or DVI > HDMI cable
(assuming the TV does not have other input connections for video+audio)
Why do you asked fo my headset, if my problem is something with my TV and HDMI-Connection?
If I disconnect the TV, then it will be no HDMI-Connected device there. Why should I do that, If my primary and secondary monitor (My primary dual-monitor-system, which using DVI and VGA)? That doesn´t make sense.
My primary Dual-Monitor-System using DVI and VGA!!!
the funny thing is, that my previous Linux-Distribution, which was Solus, had no sound with my TV.
