I have the KDE install running on my rockpro64. Everything runs fine (well, homebridge is arguing with me but what else is new) but there’s no HDMI audio. I cannot select it as an output device because it simply isn’t there. Is anyone else having this problem?
Couple things…
The video I was watching? corrupted. No audio channel. -facepalm-
However, when I switch to a working file, I have to turn down the audio to 35% to eliminate clipping. HDMI output is not listed as HDMI output, but instead as “Analog Output (Built-in Audio Stereo)”
So its treating the HDMI audio out as an analog out and 100% is way beyond what it should be.
I’ve marked the below answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (I just want to avoid even more subjective opinions being posted and confusing you even more)
P.S. In the future, please mark a solution like this:
