Hi I’m new here, im having troublings trying install manjaro
i have 2 ssd 1 with windows and the other with manjaro
so I dont se grub when install manjaro i need to choice manually
i have asus motherboard
pd: i try install fedora and same so i think is some configuration idk
sorry 4 m english.
So then it is installed correctly. Go to your UEFI/BIOS and change the boot order/priority to Manjaro.
I do that I can select windows or Manjaro manually but not grub appears
Not “Select”, that is by all meaning the plain “UEFI Bootloader”. I mean changing the Boot order at the settings of the UEFI.
I change order, but nothing
I will reinstall to try
Are you referring to the Grub “menu” screen?
If that’s the case, you can change the GRUB_TIMEOUT and GRUB_TIMEOUT_STYLE options:
Post for reference:
What is your GRUB_TIMEOUT_STYLE option?
Look under the file,
/etc/default/grub
By default, it boots straight into the latest kernel, unless you interrupt the process with LEFT-SHIFT quickly enough. Otherwise, you need to change the value of the following options and sudo update-grub once again:
GRUB_TIMEOUT_STYLE
GRUB_TIMEOUT
An example might look like:
GRUB_TIMEOUT_STYLE=menu
GRUB_TIMEOUT=10
winnie:
eferen
How can edit that, I’m really a noob.
So was that I have only active from grub to show menu and increase the time to appears
thxs
system
Closed
18 August 2021 17:16
9
