Hello everyone,
after the latest stable update there was some problem with my graphic card driver and my system booted into a black screen. I was using video-linux and changed to video-modesetting which solved the problem.
(base) david-ssd% mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
However, the system freezes from time to time with this driver.
Now, I am really not sure which driver to use. The available drivers are:
> 0000:01:00.0 (0300:10de:11c6) Display controller nVidia Corporation:
video-nvidia-470xx 2021.11.04 false PCI
video-nvidia-390xx 2021.11.04 false PCI
video-vesa 2017.03.12 true PCI
> 0000:04:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2016.04.20 true PCI
> 0000:00:02.0 (0380:8086:0152) Display controller Intel Corporation:
I read that video-vesa is only for really old hardware, video-linux is not working, video-nvidia-470xx can not be installed (the error message is error: target not found: linux512-nvidia-470xx) and video-nvidia-390xx is not supported since the latest stable update.
Here is some information about my system:
(base) david-ssd% inxi -Fazy
Kernel: 5.15.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=220113d4-7c42-4307-b854-540214ec07d1 rw quiet splash apparmor=1
Desktop: GNOME 41.1 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 41.0
Type: Desktop Mobo: ASUSTeK model: P8B75-M LX PLUS v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 0501
date: 10/10/2012
Info: Quad Core model: Intel Core i5-3330 bits: 64 type: MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 23955
Speed: 2438 MHz min/max: 1600/3200 MHz Core speeds (MHz): 1: 2053 2: 1664
3: 1710 4: 1780
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: srbds status: Vulnerable: No microcode
Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics
vendor: ASUSTeK P8H77-I driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0152 class-ID: 0380
Device-2: NVIDIA GK106 [GeForce GTX 650 Ti] vendor: Gigabyte driver: nouveau
v: kernel bus-ID: 01:00.0 chip-ID: 10de:11c6 class-ID: 0300
Device-3: Microdia Webcam Vitade AF type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 2-1.5:3 chip-ID: 0c45:6366 class-ID: 0102 serial: <filter>
Display: wayland server: X.org 1.21.1.1 compositor: gnome-shell driver:
loaded: modesetting alternate: fbdev,vesa display-ID: 0
OpenGL: renderer: NVE6 v: 4.3 Mesa 21.2.5 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: ASUSTeK P8Z77-V LX driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1e20 class-ID: 0403
Device-2: NVIDIA GK106 HDMI Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e0b class-ID: 0403
Sound Server-1: ALSA v: k5.15.2-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Realtek RTL8192CE PCIe Wireless Network Adapter vendor: ASUSTeK
driver: rtl8192ce v: kernel port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8178
class-ID: 0280
vendor: ASUSTeK P8 series driver: r8169 v: kernel port: c000 bus-ID: 04:00.0
IF: enp4s0 state: down mac: <filter>
Local Storage: total: 1.36 TiB used: 165.39 GiB (11.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDH3 500G
type: SSD serial: <filter> rev: 00RL scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HDS721010DLE630
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: A650 scheme: GPT
ID-1: / raw-size: 57.74 GiB size: 56.53 GiB (97.91%) used: 36.01 GiB (63.7%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda4 maj-min: 8:4
ID-3: /home raw-size: 372.53 GiB size: 365.62 GiB (98.14%)
used: 129.38 GiB (35.4%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 7.45 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 28.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 1380
Processes: 230 Uptime: 15m wakeups: 0 Memory: 7.63 GiB
used: 2.08 GiB (27.2%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1560 lib: 387 flatpak: 0 Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.09
