No games work on steam
Anybody else on unstable experience that absolutely no games work on steam?
I haven’t played anything for the last 4 days so I can not pinpoint exactly where it stopped working.
If I launch a game, it just does this in cli and sits there doing nothing until I close it in steam.
wine: Using setpriority to control niceness in the [-10,10] range
/bin/sh\0-c\0/home/bedna/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=457140 -- /home/bedna/.local/share/Steam/ubuntu12_32/steam-launch-wrapper -- '/media/games/SteamLibrary/steamapps/common/SteamLinuxRuntime_sniper'/_v2-entry-point --verb=waitforexitandrun -- '/media/games/SteamLibrary/steamapps/common/Proton 8.0'/proton waitforexitandrun  '/media/games/SteamLibrary/steamapps/common/OxygenNotIncluded/OxygenNotIncluded.exe'\0
chdir "/media/games/SteamLibrary/steamapps/common/OxygenNotIncluded"
ERROR: ld.so: object '/home/bedna/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
ERROR: ld.so: object '/home/bedna/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
fsync: up and running.
I recently installed protontricks and it warned me that I was trying to launch 64 bit in a 32 bit prefix. But that is no news is it?
Anyway, I could play steam games after installing that and I did not do anything in any prefix with the program anyway, just thought it was worth mentioning.
News
Just now, when I was typing this, the game suddenly “launched” (I pressed launch when I copy pasted the log above), and by “launched” I mean the icon appeared and everything froze.
In cli it threw out one line:
[S_API FAIL] SteamAPI_Init() failed; create pipe failed.Fossilize INFO: Overriding serialization path: "/media/games/SteamLibrary/steamapps/shadercache/457140/fozpipelinesv6/steamapprun_pipeline_cache".
The strange thing is, I have one single game I run with lutris with a wine prefix (everspace 2), and that launches without any trouble at all so it HAS to be steam, maybe in combination with the wine prefix?
I have no idea how to move forward, not much to go on here.
I guess I ask for recommendations of what I can do further to diagnose this.
$ inxi -Fazy
  Kernel: 6.6.6-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64
    root=UUID=700d034d-b99a-482b-880b-9060acf3a6b3 rw rootflags=subvol=@
    nvidia_drm.modeset=1 resume=UUID=5ae8fbf5-a704-41ea-be6d-bf26b38325ed
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
  Type: Desktop Mobo: Gigabyte model: X670 AORUS ELITE AX v: x.x
    serial: <superuser required> UEFI: American Megatrends LLC. v: F11
    date: 11/08/2023
  Info: model: AMD Ryzen 9 7900X bits: 64 type: MT MCP arch: Zen 4 gen: 5
    level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
    model-id: 0x61 (97) stepping: 2 microcode: 0xA601203
  Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
    L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB desc: 12x1024 KiB
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 1055 high: 3681 min/max: 400/5733 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 3681 3: 3347
    4: 3591 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 3520
    14: 400 15: 400 16: 400 17: 400 18: 400 19: 3594 20: 400 21: 400 22: 400
    23: 400 24: 400 bogomips: 225262
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GA102 [GeForce RTX 3090] vendor: eVga.com. driver: nvidia
    v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
    (as of 2023-11; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: none empty: DP-1,
    DP-2, DP-3, HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2204 class-ID: 0300
  Device-2: AMD Raphael vendor: Gigabyte driver: amdgpu v: kernel
    arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: HDMI-A-2 empty: DP-4,DP-5,DP-6
    bus-ID: 15:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 52.0 C
  Display: x11 server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2
    compositor: kwin_x11 driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: HDMI-A-2 mapped: HDMI-A-1 model: Asus VX279 serial: <filter>
    built: 2015 res: 1920x1080 hz: 60 dpi: 79 gamma: 1.2
    size: 621x341mm (24.45x13.43") diag: 690mm (27.2") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia x11: drv: radeonsi inactive: wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics
    (raphael_mendocino LLVM 16.0.6 DRM 3.54 6.6.6-2-MANJARO)
    device-ID: 1002:164e memory: 500 MiB unified: no
  API: Vulkan v: 1.3.269 layers: 9 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 3090 driver: nvidia v: 545.29.06
    device-ID: 10de:2204 surfaces: xcb,xlib device: 1 type: integrated-gpu
    name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv
    v: 23.1.9-manjaro1.1 device-ID: 1002:164e surfaces: xcb,xlib
  Device-1: NVIDIA GA102 High Definition Audio vendor: eVga.com.
    bus-ID: 01:00.1 chip-ID: 10de:1aef class-ID: 0403
  Device-2: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 15:00.1
    chip-ID: 1002:1640 class-ID: 0403
  Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
    bus-ID: 15:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.6.6-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0e:00.0
  IF: enp14s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 0f:00.0
    chip-ID: 14c3:0616 class-ID: 0280
  IF: wlp15s0 state: down mac: <filter>
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:5 chip-ID: 0e8d:0616
  Local Storage: total: 4.09 TiB used: 1.68 TiB (41.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 45.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD30EFRX-68EUZN0 size: 2.73 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
    fw-rev: 0A80 scheme: GPT
  ID-1: / raw-size: 122 GiB size: 122 GiB (100.00%) used: 54.93 GiB (45.0%)
    fs: btrfs dev: /dev/sda7 maj-min: 8:7
    used: 296 KiB (0.1%) fs: vfat dev: /dev/sda5 maj-min: 8:5
  ID-3: /home raw-size: 104.53 GiB size: 104.53 GiB (100.00%)
    used: 52.9 GiB (50.6%) fs: btrfs dev: /dev/sda8 maj-min: 8:8
  ID-4: /var/log raw-size: 122 GiB size: 122 GiB (100.00%)
    used: 54.93 GiB (45.0%) fs: btrfs dev: /dev/sda7 maj-min: 8:7
  ID-1: swap-1 type: partition size: 38 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda6 maj-min: 8:6
  System Temperatures: cpu: 60.6 C mobo: 44.0 C gpu: amdgpu temp: 52.0 C
  Fan Speeds (rpm): N/A
  Processes: 502 Uptime: 1h 41m wakeups: 0 Memory: total: 32 GiB note: est.
  available: 30.5 GiB used: 8.26 GiB (27.1%) Init: systemd v: 254
  Packages: 1561 pm: pacman pkgs: 1552 libs: 432 tools: pamac,yay pm: flatpak
  pkgs: 9 Shell: Zsh v: 5.9 default: Bash v: 5.2.21 running-in: yakuake
  inxi: 3.3.31
Edit
Forgot to say, I have obv tried with different proton version.
Valheim also f.ex in both “normal” and OpenGL, no change except sometimes the loading animation shows, and then freeze until I close in steam.
I havent been doing any ping-pew-pew recently either … Let us see …
Checked with Torchlight 2, Albion Online (the other AO) then checked with Soulstone Survivors: Prologue to see about a Proton title.
They all launched fine. :person_shrugging:
Then I know it’s something on my machine.
Thanks.
Edit
Does this line look ok?
I can’t remember what it normally looks like but this looks strange to me…
Yes it looks normal.
Do you have Launch options? Remove them all in case. Try to delete (rename it preferably for safe keeping) the Proton prefix of a game before starting it.
Usually yes, but not now when trying to find the issue.
For a little while, the game threw out a ■■■■■■■■ of “fixme” after I forced OpenGL with PROTON_USE_WINED3D=1 but that is gone now again. :open_mouth:
Sample:
00f0:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
00f0:fixme:dxgi:DXGID3D10CreateDevice Ignoring flags 0x20.
00f0:fixme:d3d11:d3d11_device_CheckFeatureSupport Unhandled feature 0xe.
00f0:fixme:wbemprox:client_security_SetBlanket 00006FFFF6320E80, 00007FFFFE8ED5C0, 10, 0, (null), 3, 3, 0000000000000000, 0
00f0:fixme:wbemprox:client_security_Release 00006FFFF6320E80
00f0:fixme:d3d11:d3d11_device_CheckFeatureSupport Returning fake Options support data.
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 29, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d:wined3d_check_device_multisample_type multisample_type 32 not handled yet.
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 61, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 49, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 28, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 63, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 51, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 31, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 62, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 50, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 30, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 64, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 52, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 32, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 56, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 35, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 11, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 58, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 37, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 13, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 57, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 36, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 12, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 59, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 38, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 14, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 42, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 17, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 7, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 3, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 43, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 18, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 8, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 4, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 54, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 34, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 10, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 41, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 16, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 6, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 2, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 65, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 91, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 87, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 115, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 85, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 86, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 67, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 26, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 24, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 25, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 89, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 55, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 45, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 40, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 20, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 47, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 72, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 71, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 75, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 74, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 78, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 77, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 80, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 81, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 83, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 84, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 95, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 96, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 99, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 98, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:d3d11:d3d11_device_CheckFormatSupport iface 00007FFFFF9C02D0, format 107, format_support 00007FFFFE1EF3B8 partial-stub!
00f0:fixme:dxgi:dxgi_factory_IsWindowedStereoEnabled iface 00007FFFFF9C73F0 stub!
00f0:fixme:d3d11:d3d11_device_CheckFeatureSupport Returning fake Options1 support data.
00f0:fixme:d3d11:d3d11_device_CheckFeatureSupport Returning fake threading support data.
00f0:fixme:dxgi:DXGID3D10CreateDevice Ignoring flags 0x820.
00f0:fixme:d3d11:d3d10_multithread_SetMultithreadProtected iface 00007FFFFF9CC020, enable 0x1 stub!
01cc:fixme:dxgi:dxgi_resource_GetSharedHandle iface 00007FFFFF9CAEA8, shared_handle 00007F7E099EE600 stub!
00f0:fixme:dxgi:dxgi_output_GetDisplayModeList iface 00007FFFFF9C7530, format DXGI_FORMAT_R8G8B8A8_UNORM, flags 0, mode_count 00007FFFFE1EF680, modes 0000000000000000 partial stub!
00f0:fixme:dxgi:dxgi_output_GetDisplayModeList iface 00007FFFFF9C7530, format DXGI_FORMAT_R8G8B8A8_UNORM, flags 0, mode_count 00007FFFFE1EF680, modes 00007F7F10000010 partial stub!
00f0:fixme:dxgi:dxgi_output_GetDesc1 iface 00007FFFFF9C74B0, desc 00007FFFFE1EF4E0 semi-stub!
00f0:fixme:dxgi:wined3d_swapchain_flags_from_dxgi Unhandled flags 0x840.
00f0:fixme:d3d:wined3d_swapchain_init The application requested more than one back buffer, this is not properly supported.
Please configure the application to use double buffering (1 back buffer) if possible.
00f0:fixme:d3d:wined3d_swapchain_init Unimplemented swap effect 0x3.
00f0:fixme:dxgi:d3d11_swapchain_GetDesc Ignoring ScanlineOrdering and Scaling.
00f0:fixme:dxgi:d3d11_swapchain_ResizeBuffers Ignoring flags 0x2.
00f0:fixme:win:RegisterTouchWindow hwnd 000000000002004E, flags 0 stub!
00f0:fixme:dxgi:d3d11_swapchain_GetFrameStatistics iface 00007FFFFE8ED8C0, stats 00007FFFFE1EF8C0 stub!
00f0:fixme:system:NtUserQueryDisplayConfig flags 0x2, paths_count 0x7ffffe1ef770, paths 0x7f7f10000010, modes_count 0x7ffffe1ef8f8, modes 0x7f7f10000070, topology_id (nil) semi-stub
01cc:fixme:d3d11:d3d_rasterizer_state_init Ignoring MultisampleEnable 0x1.
01c8:fixme:d3d:state_linepattern_w Setting line patterns is not supported in OpenGL core contexts.
00f0:fixme:dxgi:d3d11_swapchain_GetFrameStatistics iface 00007FFFFE8ED8C0, stats 00007FFFFE1EF890 stub!
00f0:fixme:system:NtUserQueryDisplayConfig flags 0x2, paths_count 0x7ffffe1ef740, paths 0x7f7f10000010, modes_count 0x7ffffe1ef8c8, modes 0x7f7f10000070, topology_id (nil) semi-stub
01f0:fixme:kernelbase:AppPolicyGetThreadInitializationType FFFFFFFFFFFFFFFA, 00007F7DBB93FF50
00f0:fixme:wbemprox:client_security_SetBlanket 00006FFFF6320E80, 00007FFFFFA7BB30, 10, 0, (null), 3, 3, 0000000000000000, 0
00f0:fixme:wbemprox:wbem_services_CreateInstanceEnum unsupported flags 0x30
00f0:fixme:dxgi:dxgi_output_GetDesc1 iface 00007FFFFF9C76F0, desc 00007FFFFE1EF1F0 semi-stub!
0118:fixme:kernelbase:AppPolicyGetProcessTerminationMethod FFFFFFFFFFFFFFFA, 00007FFFFE1FFEB0
0294:fixme:kernelbase:AppPolicyGetProcessTerminationMethod FFFFFFFFFFFFFFFA, 00007FFFFE1FFEB0
I did that a little while ago, using protontricks, deleted the whole prefix. No change.
This is beyond strange.
I will try to reset steam and see the result. sigh.
Tomorrow, time for bed now.
Something else in ~/.config maybe?
I cant begin to guess … backing it up or just trying a new user etc may be some checks.
I did some checking before I was going to resett steam and found this. the name of that dir cant be right.
$ ls -l ~/.local/share/Steam
drwxr-xr-x 1 bedna bedna        0 Oct 24 16:57 ''$'\237\216\f'
I can not prove this, but a lot of strange things have happened since the ext4 corruption bug. This directory is on btrfs, but the games are on my ext4 partition.
I just hope I will not have to reinstall Manjaro. :frowning:
Edit
This seems to be connected to my x11 config.
If I enable proton logs and run a proton game it throws these errors multiple times:
83.780:0020:011c:err:xrandr:xrandr14_get_adapters Failed to get adapters
I have for a day or two started to try correctly configure my nvidia-AMD as it actually should be, not me using the motherboard hdmi to get my AMD to be used normally and nvidia only with prime-run.
It seems the Bus-ID is not being detected correctly because whatever I do in nvidia.conf in combination to the Bus-ID:
  1. AMD is never detected.
  2. If I use my mortherboard hdmi, only tty
If I log in tho that tty and runs startx it trows an error in ~/.local/share/xorg/Xorg.0.log
[    41.036]
X.Org X Server 1.21.1.9
[    41.036] Current Operating System: Linux bednaManjaro 6.6.6-2-MANJARO #1 SMP PREEMPT_DYNAMIC Tue Dec 12 00:55:59 UTC 2023 x86_64
[    41.036] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64 root=UUID=700d034d-b99a-482b-880b-9060acf3a6b3 rw rootflags=subvol=@ nvidia_drm.modeset=1 resume=UUID=5ae8fbf5-a704-41ea-be6d-bf26b38325ed udev.log_priority=3
[    41.036]
[    41.036] Current version of pixman: 0.42.2
[    41.036] 	Before reporting problems, check http://wiki.x.org
[    41.036] Markers: (--) probed, (**) from config file, (==) default setting,
[    41.037] (==) Log file: "/home/bedna/.local/share/xorg/Xorg.0.log", Time: Wed Dec 13 21:45:08 2023
[    41.037] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    41.037] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    41.037] (==) ServerLayout "layout"
[    41.037] (**) |-->Screen "Screen0" (0)
[    41.037] (**) |   |-->Monitor "Monitor0"
[    41.037] (**) |   |-->Device "Device1"
[    41.037] (**) |   |-->GPUDevice "Device0"
[    41.037] (==) Automatically adding devices
[    41.037] (==) Automatically enabling devices
[    41.037] (==) Automatically adding GPU devices
[    41.037] (==) Automatically binding GPU devices
[    41.037] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    41.037] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    41.037] 	Entry deleted from font path.
[    41.037] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    41.037] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[    41.037] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[    41.037] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[    41.037] (==) ModulePath set to "/usr/lib/xorg/modules"
[    41.037] (II) The server relies on udev to provide the list of input devices.
[    41.037] (II) Module ABI versions:
[    41.037] 	X.Org ANSI C Emulation: 0.4
[    41.037] 	X.Org Video Driver: 25.2
[    41.037] 	X.Org XInput driver : 24.4
[    41.037] 	X.Org Server Extension : 10.0
[    41.037] (++) using VT number 2
[    41.038] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[    41.039] (II) xfree86: Adding drm device (/dev/dri/card0)
[    41.039] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/drm/card0
[    41.039] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
[    41.039] (II) xfree86: Adding drm device (/dev/dri/card1)
[    41.039] (II) Platform probe for /sys/devices/pci0000:00/0000:00:08.1/0000:15:00.0/drm/card1
[    41.039] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 14 paused 0
[    41.042] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[    41.042] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[    41.044] (--) PCI: (1@0:0:0) 10de:2204:3842:3975 rev 161, Mem @ 0xfb000000/16777216, 0xf000000000/34359738368, 0xf800000000/33554432, I/O @ 0x0000f000/128, BIOS @ 0x????????/524288
[    41.044] (--) PCI:*(21@0:0:0) 1002:164e:1458:d000 rev 194, Mem @ 0xf810000000/268435456, 0xf820000000/2097152, 0xfcc00000/524288, I/O @ 0x0000d000/256
[    41.044] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    41.044] (II) LoadModule: "glx"
[    41.044] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    41.045] (II) Module glx: vendor="X.Org Foundation"
[    41.045] 	compiled for 1.21.1.9, module version = 1.0.0
[    41.045] 	ABI class: X.Org Server Extension, version 10.0
[    41.045] (II) LoadModule: "modesetting"
[    41.045] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    41.045] (II) Module modesetting: vendor="X.Org Foundation"
[    41.045] 	compiled for 1.21.1.9, module version = 1.21.1
[    41.045] 	Module class: X.Org Video Driver
[    41.045] 	ABI class: X.Org Video Driver, version 25.2
[    41.045] (II) LoadModule: "nvidia"
[    41.045] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    41.045] (II) Module nvidia: vendor="NVIDIA Corporation"
[    41.045] 	compiled for 1.6.99.901, module version = 1.0.0
[    41.045] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    41.045] (II) NVIDIA dlloader X Driver  545.29.06  Thu Nov 16 01:52:34 UTC 2023
[    41.045] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    41.045] (WW) Falling back to old probe method for modesetting
[    41.045] (II) modeset(0): using default device
[    41.045] (II) systemd-logind: releasing fd for 226:0
[    41.079] (II) Loading sub module "fb"
[    41.079] (II) LoadModule: "fb"
[    41.079] (II) Module "fb" already built-in
[    41.079] (II) Loading sub module "wfb"
[    41.079] (II) LoadModule: "wfb"
[    41.079] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    41.079] (II) Module wfb: vendor="X.Org Foundation"
[    41.079] 	compiled for 1.21.1.9, module version = 1.0.0
[    41.079] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    41.079] (II) modeset(G1): using drv /dev/dri/card1
[    41.079] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[    41.079] (EE)
Fatal server error:
[    41.079] (EE) Cannot run in framebuffer mode. Please specify busIDs        for all framebuffer devices
[    41.079] (EE)
[    41.079] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[    41.079] (EE) Please also check the log file at "/home/bedna/.local/share/xorg/Xorg.0.log" for additional information.
[    41.079] (EE)
[    41.084] (EE) Server terminated with error (1). Closing log file.
The lines
Seems to indicate it is looking for my AMD at PCI 21 but:
$ lspci | grep VGA
01:00.0 VGA compatible controller: NVIDIA Corporation GA102 [GeForce RTX 3090] (rev a1)
15:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Raphael (rev c2)
And xrander:
$ xrandr --listproviders
Providers: number : 2
Provider 0: id: 0x56 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 4 outputs: 4 associated providers: 1 name:AMD Radeon Graphics @ pci:0000:15:00.0
Provider 1: id: 0x20f cap: 0x2, Sink Output crtcs: 4 outputs: 7 associated providers: 1 name:NVIDIA-G0
What the heck am I to do here?
The more I look into this the more confusing it gets.
And I am absolutely not sure resetting steam will fix anything about this.
To be clear, I was only playing around with the new nvidia config, I am not running it, I am stilll using the same setup that has been working since install.
I mention that because in both instances xrander seems to be involved.
Ok, thank whoever invented btrfs and snapshots…
I found a snapshot where it still works, witch tells me it is something on my system, not in any prefix, config on my /home (separate from /) or related to my ext4 game drive.
I have to pop away, I am still when typing this r/o on this snapshot, just found that it works here so this evening when I come back I will restore it and do updates and whatnot and see if it breaks again.
The snapshot is only 4 days old so the breakage was very resent, only done 2, or 3 updates since where I am on this snapshot.
Do you guys want me to keep you updated or should I close the thread?
Just wondering since I am on unstable, have not really done anything out of the ordinary to change my system (can’t recall I changed anything at all during these days) or installed anything so maybe it could be useful to know?
I have all logs available, can check system as on snapshot now etc.
I’ll be back in a few hours.
Let me know. @Manjaro-Team :heart:
