After some this strange behaviour in calling
lsblk -fi
( to simply things I ommited several other block devices that behave correctly )
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
sda
├─sda1 ntfs AE3818E43818ACF9
├─sda2 ntfs 74D604323809405D
├─sda3 ext4 1.0 ManjaroSSD f4bc51ae-9d55-400c-b716-e17bcf600731 12.2G 88% /
└─sda4 ext4 1.0 ssd4 721a05da-d5dc-4109-ac8e-d005406ea9a9
sde
├─sde1 zfs_member 5000 ED320 9330553230942267958
└─sde9
sdf
└─sdf1
sr0
The /dev/sdf1 is a NTFS partition fully accessible via ntfs-3g an usually mounted RW.
Although calling
sudo sfdisk /dev/sdf
Welcome to sfdisk (util-linux 2.39.3).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
Checking that no-one is using this disk right now ... OK
Disk /dev/sdf: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: SAMSUNG HD501LJ
Disklabel type: gpt
Disk identifier: 77CADC7F-F16C-6443-85AF-FF3896423B2A
Old situation:
Device Start End Sectors Size Type
/dev/sdf1 2048 976771071 976769024 465.8G Microsoft basic data
Nothing out of the ordinary …
But If I call :
sudo sfdisk /dev/sdf1
The device contains 'zfs_member' signature and it may be removed by a write command. See sfdisk(8) man page and --wipe option for more details.
Disk /dev/sdf1: 465.76 GiB, 500105740288 bytes, 976769024 sectors
Disklabel type: dos
Disk identifier: 0x73736572
Old situation:
Device Boot Start End Sectors Size Id Type
/dev/sdf1p1 1920221984 3736432267 1816210284 866G 72 unknown
/dev/sdf1p2 1936028192 3889681299 1953653108 931.6G 6c unknown
/dev/sdf1p3 0 0 0 0B 0 Empty
/dev/sdf1p4 27722122 27722568 447 223.5K 0 Empty
Partition table entries are not in disk order.
What happened ?
Some context details :
Previous I did had a ZFS filesystem but how come it appears as 866G ?
Afterwards I formatted into a Exfat filesystem . ( perhaps a Quick format) …
used the HDD for a few days …
Reformatted into NTFS ( again probably a QuickFormat )
Used for a few more days and only now I noticed this detail in lsblk …
Comments are welcome …
Although how can I clean this without destroying the NTFS data ?
