So far as I can tell, Linux can’t find any PWM fan control devices. Some assorted information:
$ uname -a
Linux *** 5.15.2-2-MANJARO #1 SMP PREEMPT Sat Nov 13 19:25:38 UTC 2021 x86_64 GNU/Linux
$ lsmod | grep coretemp
coretemp 20480 0
$ dmidecode -t0,1
# dmidecode 3.3
Getting SMBIOS data from sysfs.
SMBIOS 3.3.0 present.
Handle 0x0000, DMI type 0, 26 bytes
BIOS Information
Vendor: Insyde Corp.
Version: V1.16
Release Date: 08/18/2021
Address: 0xE0000
Runtime Size: 128 kB
ROM Size: 4096 MB
Characteristics:
PCI is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
EDD is supported
Japanese floppy for NEC 9800 1.2 MB is supported (int 13h)
Japanese floppy for Toshiba 1.2 MB is supported (int 13h)
5.25"/360 kB floppy services are supported (int 13h)
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
8042 keyboard services are supported (int 9h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
BIOS boot specification is supported
Targeted content distribution is supported
UEFI is supported
BIOS Revision: 1.16
Firmware Revision: 1.16
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: Acer
Product Name: Aspire A515-56
Version: V1.16
Serial Number: *********************
UUID: ****************
Wake-up Type: Power Switch
SKU Number: 0000000000000000
Family: Aspire 5
$ tlp-stat
--- TLP 1.4.0 --------------------------------------------
+++ Configured Settings:
defaults.conf L0004: TLP_ENABLE="1"
defaults.conf L0005: TLP_WARN_LEVEL="3"
defaults.conf L0006: TLP_PERSISTENT_DEFAULT="0"
defaults.conf L0007: DISK_IDLE_SECS_ON_AC="0"
defaults.conf L0008: DISK_IDLE_SECS_ON_BAT="2"
defaults.conf L0009: MAX_LOST_WORK_SECS_ON_AC="15"
defaults.conf L0010: MAX_LOST_WORK_SECS_ON_BAT="60"
defaults.conf L0011: CPU_ENERGY_PERF_POLICY_ON_AC="balance_performance"
defaults.conf L0012: CPU_ENERGY_PERF_POLICY_ON_BAT="balance_power"
defaults.conf L0013: SCHED_POWERSAVE_ON_AC="0"
defaults.conf L0014: SCHED_POWERSAVE_ON_BAT="1"
defaults.conf L0015: NMI_WATCHDOG="0"
defaults.conf L0016: DISK_DEVICES="nvme0n1 sda"
defaults.conf L0017: DISK_APM_LEVEL_ON_AC="254 254"
defaults.conf L0018: DISK_APM_LEVEL_ON_BAT="128 128"
defaults.conf L0019: DISK_APM_CLASS_DENYLIST="usb ieee1394"
defaults.conf L0020: DISK_IOSCHED="keep keep"
defaults.conf L0021: SATA_LINKPWR_ON_AC="med_power_with_dipm max_performance"
defaults.conf L0022: SATA_LINKPWR_ON_BAT="med_power_with_dipm min_power"
defaults.conf L0023: AHCI_RUNTIME_PM_ON_AC="on"
defaults.conf L0024: AHCI_RUNTIME_PM_ON_BAT="auto"
defaults.conf L0025: AHCI_RUNTIME_PM_TIMEOUT="15"
defaults.conf L0026: PCIE_ASPM_ON_AC="default"
defaults.conf L0027: PCIE_ASPM_ON_BAT="default"
defaults.conf L0028: RADEON_DPM_PERF_LEVEL_ON_AC="auto"
defaults.conf L0029: RADEON_DPM_PERF_LEVEL_ON_BAT="auto"
defaults.conf L0030: RADEON_POWER_PROFILE_ON_AC="default"
defaults.conf L0031: RADEON_POWER_PROFILE_ON_BAT="default"
defaults.conf L0032: WIFI_PWR_ON_AC="off"
defaults.conf L0033: WIFI_PWR_ON_BAT="on"
defaults.conf L0034: WOL_DISABLE="Y"
defaults.conf L0035: SOUND_POWER_SAVE_ON_AC="1"
defaults.conf L0036: SOUND_POWER_SAVE_ON_BAT="1"
defaults.conf L0037: SOUND_POWER_SAVE_CONTROLLER="Y"
defaults.conf L0038: BAY_POWEROFF_ON_AC="0"
defaults.conf L0039: BAY_POWEROFF_ON_BAT="0"
defaults.conf L0040: BAY_DEVICE="sr0"
defaults.conf L0041: RUNTIME_PM_ON_AC="on"
defaults.conf L0042: RUNTIME_PM_ON_BAT="auto"
defaults.conf L0043: RUNTIME_PM_DRIVER_DENYLIST="mei_me nouveau radeon"
defaults.conf L0044: USB_AUTOSUSPEND="1"
defaults.conf L0045: USB_EXCLUDE_AUDIO="1"
defaults.conf L0046: USB_EXCLUDE_BTUSB="0"
defaults.conf L0047: USB_EXCLUDE_PHONE="0"
defaults.conf L0048: USB_EXCLUDE_PRINTER="1"
defaults.conf L0049: USB_EXCLUDE_WWAN="0"
defaults.conf L0050: USB_AUTOSUSPEND_DISABLE_ON_SHUTDOWN="0"
defaults.conf L0051: RESTORE_DEVICE_STATE_ON_STARTUP="0"
defaults.conf L0052: RESTORE_THRESHOLDS_ON_BAT="0"
defaults.conf L0053: NATACPI_ENABLE="1"
defaults.conf L0054: TPACPI_ENABLE="1"
defaults.conf L0055: TPSMAPI_ENABLE="1"
+++ System Info
System = Acer V1.16 Aspire A515-56
BIOS = V1.16
OS Release = Manjaro Linux
Kernel = 5.15.2-2-MANJARO #1 SMP PREEMPT Sat Nov 13 19:25:38 UTC 2021 x86_64
/proc/cmdline = BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=2a39dac0-c758-4405-b20f-62481416b434 rw quiet PM_RUNTIME=y cryptdevice=UUID=32e1c496-80ab-4c31-9803-12e6070ec42a:luks-32e1c496-80ab-4c31-9803-12e6070ec42a root=/dev/mapper/luks-32e1c496-80ab-4c31-9803-12e6070ec42a udev.log_priority=3
Init system = systemd
Boot mode = UEFI
+++ TLP Status
State = enabled
RDW state = not installed
Last run = 04:38:18 PM, 331 sec(s) ago
Mode = AC
Power source = AC
Warning: systemd-rfkill.service is not masked, radio device switching may not work as configured.
>>> Invoke 'systemctl mask systemd-rfkill.service' to correct this.
Warning: systemd-rfkill.socket is not masked, radio device switching may not work as configured.
>>> Invoke 'systemctl mask systemd-rfkill.socket' to correct this.
+++ Processor
CPU model = 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
/sys/devices/system/cpu/cpu0/cpufreq/scaling_driver = intel_pstate
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor = powersave
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq = 400000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq = 4200000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_preference = balance_performance [HWP.EPP]
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu1..cpu7: omitted for clarity, use -v to show all
/sys/devices/system/cpu/intel_pstate/status = active
/sys/devices/system/cpu/intel_pstate/min_perf_pct = 9 [%]
/sys/devices/system/cpu/intel_pstate/max_perf_pct = 100 [%]
/sys/devices/system/cpu/intel_pstate/no_turbo = 0
/sys/devices/system/cpu/intel_pstate/hwp_dynamic_boost = 0
/sys/devices/system/cpu/intel_pstate/turbo_pct = 47 [%]
/sys/devices/system/cpu/intel_pstate/num_pstates = 39
/sys/module/workqueue/parameters/power_efficient = Y
/proc/sys/kernel/nmi_watchdog = 0
+++ Platform Profile
/sys/firmware/acpi/platform_profile = (not available)
/sys/firmware/acpi/platform_profile_choices = (not available)
+++ Temperatures
CPU temp = 35 [°C]
Fan speed = (not available)
+++ File System
/proc/sys/vm/laptop_mode = 0
/proc/sys/vm/dirty_writeback_centisecs = 1500
/proc/sys/vm/dirty_expire_centisecs = 1500
/proc/sys/vm/dirty_ratio = 20
/proc/sys/vm/dirty_background_ratio = 10
+++ Disks
Devices = nvme0n1 sda
/dev/nvme0n1:
Type = NVMe
Disk ID = nvme-Micron_2210_MTFDHBA1T0QFD_21152E440E63
Model = Micron_2210_MTFDHBA1T0QFD
Firmware = P6MA000
Temp = 42 °C
Scheduler = [none] mq-deadline kyber bfq (multi queue)
Runtime PM:
/sys/block/nvme0n1/power/control = on, autosuspend_delay_ms = (not available)
SMART info:
Critical Warning: 0x00
Temperature: 42 Celsius
Available Spare: 100%
Available Spare Threshold: 5%
Percentage Used: 0%
Data Units Written: 511,120 [261 GB]
Power Cycles: 22
Power On Hours: 70
Unsafe Shutdowns: 9
Media and Data Integrity Errors: 0
/dev/sda: not present.
+++ AHCI Link Power Management (ALPM) :: SATA Links
/sys/bus/pci/devices/10000:e0:17.0/ata1/host0/scsi_host/host0/link_power_management_policy = med_power_with_dipm
/sys/bus/pci/devices/10000:e0:17.0/ata2/host1/scsi_host/host1/link_power_management_policy = med_power_with_dipm
+++ AHCI Port Runtime Power Management :: SATA/ATA Ports
/sys/bus/pci/devices/10000:e0:17.0/ata1/power/control = on
/sys/bus/pci/devices/10000:e0:17.0/ata2/power/control = on
+++ Intel Graphics
/sys/class/drm/card0/device/driver = i915
/sys/class/drm/card0/power/rc6_enable = 1 (enabled)
/sys/kernel/debug/dri/0/i915_fbc_status = FBC enabled
/sys/module/i915/parameters/enable_psr = -1 (use per-chip default)
/sys/class/drm/card0/gt_min_freq_mhz = 100 [MHz]
/sys/class/drm/card0/gt_max_freq_mhz = 1300 [MHz]
/sys/class/drm/card0/gt_boost_freq_mhz = 1300 [MHz]
/sys/class/drm/card0/gt_RPn_freq_mhz = 100 [MHz] (GPU min)
/sys/class/drm/card0/gt_RP0_freq_mhz = 1300 [MHz] (GPU max)
+++ Wireless
bluetooth = off (software)
wifi = on
wwan = none (no device)
hci0(btusb) : bluetooth, not connected
wlp2s0(mt7921e) : wifi, connected, power management = on
+++ Audio
/sys/module/snd_hda_intel/parameters/power_save = 1
/sys/module/snd_hda_intel/parameters/power_save_controller = Y
+++ PCIe Active State Power Management
/sys/module/pcie_aspm/parameters/policy = [default] performance powersave powersupersave
+++ PCIe Runtime Power Management
Enable devices = (disabled)
Disable devices = (disabled)
Device denylist = (disabled)
Driver denylist = mei_me nouveau radeon
/sys/bus/pci/devices/0000:00:00.0/power/control = on (0x060000, Host bridge, no driver)
/sys/bus/pci/devices/0000:00:02.0/power/control = on (0x030000, VGA compatible controller, i915)
/sys/bus/pci/devices/0000:00:08.0/power/control = on (0x088000, System peripheral, no driver)
/sys/bus/pci/devices/0000:00:0e.0/power/control = on (0x010400, RAID bus controller, vmd)
/sys/bus/pci/devices/0000:00:14.0/power/control = on (0x0c0330, USB controller, xhci_hcd)
/sys/bus/pci/devices/0000:00:14.2/power/control = on (0x050000, RAM memory, no driver)
/sys/bus/pci/devices/0000:00:15.0/power/control = on (0x0c8000, Serial bus controller [0c80], intel-lpss)
/sys/bus/pci/devices/0000:00:15.3/power/control = on (0x0c8000, Serial bus controller [0c80], intel-lpss)
/sys/bus/pci/devices/0000:00:16.0/power/control = auto (0x078000, Communication controller, mei_me)
/sys/bus/pci/devices/0000:00:17.0/power/control = on (0x088000, System peripheral, no driver)
/sys/bus/pci/devices/0000:00:19.0/power/control = on (0x0c8000, Serial bus controller [0c80], intel-lpss)
/sys/bus/pci/devices/0000:00:19.1/power/control = on (0x0c8000, Serial bus controller [0c80], intel-lpss)
/sys/bus/pci/devices/0000:00:1d.0/power/control = on (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:1d.1/power/control = on (0x060400, PCI bridge, pcieport)
/sys/bus/pci/devices/0000:00:1f.0/power/control = on (0x060100, ISA bridge, no driver)
/sys/bus/pci/devices/0000:00:1f.3/power/control = auto (0x040100, Multimedia audio controller, sof-audio-pci-intel-tgl)
/sys/bus/pci/devices/0000:00:1f.4/power/control = on (0x0c0500, SMBus, i801_smbus)
/sys/bus/pci/devices/0000:00:1f.5/power/control = on (0x0c8000, Serial bus controller [0c80], intel-spi)
/sys/bus/pci/devices/0000:01:00.0/power/control = on (0x020000, Ethernet controller, r8169)
/sys/bus/pci/devices/0000:02:00.0/power/control = on (0x028000, Network controller, mt7921e)
/sys/bus/pci/devices/0000:10000:e0:17.0/power/control = (not available) (, SATA controller, no driver)
/sys/bus/pci/devices/0000:10000:e0:1c.0/power/control = (not available) (, System peripheral, no driver)
/sys/bus/pci/devices/0000:10000:e0:1c.4/power/control = (not available) (, PCI bridge, no driver)
/sys/bus/pci/devices/0000:10000:e1:00.0/power/control = (not available) (, Non-Volatile memory controller, no driver)
+++ USB
Autosuspend = enabled
Device allowlist = (not configured)
Device denylist = (not configured)
Exclude audio = enabled
Exclude bluetooth = disabled
Exclude phones = disabled
Exclude printers = enabled
Exclude WWAN = disabled
Bus 002 Device 001 ID 1d6b:0003 control = auto, autosuspend_delay_ms = 0 -- Linux Foundation 3.0 root hub (hub)
Bus 001 Device 003 ID 04f2:b72b control = auto, autosuspend_delay_ms = 2000 -- Chicony Electronics Co., Ltd HD User Facing (uvcvideo)
Bus 001 Device 002 ID 04f3:0c4f control = auto, autosuspend_delay_ms = 2000 -- Elan Microelectronics Corp. ELAN:Fingerprint (no driver)
Bus 001 Device 004 ID 04ca:3802 control = auto, autosuspend_delay_ms = 2000 -- Lite-On Technology Corp. Wireless_Device (btusb)
Bus 001 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms = 0 -- Linux Foundation 2.0 root hub (hub)
+++ Battery Care
Plugin: generic
Supported features: none available
+++ Battery Status: BAT1
/sys/class/power_supply/BAT1/manufacturer = COSMX
/sys/class/power_supply/BAT1/model_name = AP20CBL
/sys/class/power_supply/BAT1/cycle_count = 2
/sys/class/power_supply/BAT1/charge_full_design = 4590 [mAh]
/sys/class/power_supply/BAT1/charge_full = 4505 [mAh]
/sys/class/power_supply/BAT1/charge_now = 4505 [mAh]
/sys/class/power_supply/BAT1/current_now = 0 [mA]
/sys/class/power_supply/BAT1/status = Full
/sys/class/power_supply/BAT1/charge_control_start_threshold = (not available)
/sys/class/power_supply/BAT1/charge_control_end_threshold = (not available)
Charge = 100.0 [%]
Capacity = 98.1 [%]
+++ Recommendations
* Reconfigure your Linux kernel with PM_RUNTIME=y to reduce your laptop's power consumption.
$ sensors
coretemp-isa-0000
Adapter: ISA adapter
Package id 0: +34.0°C (high = +100.0°C, crit = +100.0°C)
Core 0: +33.0°C (high = +100.0°C, crit = +100.0°C)
Core 1: +29.0°C (high = +100.0°C, crit = +100.0°C)
Core 2: +29.0°C (high = +100.0°C, crit = +100.0°C)
Core 3: +31.0°C (high = +100.0°C, crit = +100.0°C)
BAT1-acpi-0
Adapter: ACPI interface
in0: 13.07 V
curr1: 0.00 A
nvme-pci-e100
Adapter: PCI adapter
Composite: +41.9°C (low = -0.1°C, high = +86.8°C)
(crit = +89.8°C)
Sensor 1: +41.9°C (low = -273.1°C, high = +65261.8°C)
acpitz-acpi-0
temp1: +27.8°C (crit = +119.0°C)
Running sensors-detect
was only able to find coretemp
