Hi
I’ve got a brand new ISP modem/router (with a built in 4 ports switch) and a brand new Netgear GS108 unmanaged switch (8 ports).
The switch is connected to the modem router via LAN.
The rooms are connected to the switch via LAN.
An old modem/router is connected to the Netgear switch to serve as access point. It has also a mini switch built in (4 ports). It has the dhcp disbled
Everything is working fine, all the cables have been n-times checked and swapped and them are working ok too. All ports of all switches are working.
All the pcs connect to wifi.
All the pcs but one connect by LAN; they connect either to the switch or to the modem/router or to the access point built in switch , flawlessy.
Only one laptop has a strange behaviour: it connects via LAN at 1gb if connected directly to the modem/router.
If connected to the Netgear switch doesn’t link (no led blink at all on Netgear).
If connected to the AP switch then connected to the Netgear switch doesn’t link (no led blink at all on Netgear).
If connected to the AP switch then connected to the Modem/router doesn’t link.
I tried with Netgear support, but with no sucess.
System is up to date (kernel 5.16); I tried older kernels but with same results.
I disabled any parental control on the modem/router.
NetworkManager has default settings (auto connect too), with no static ip or whatever.
I tryed an archbang live iso with same results.
What else can I try to make this laptop connect to the switch?
Thank you,
[denver@denver-asus ~]$ inxi --admin --verbosity=7 --filter --width
Kernel: 5.16.5-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=c539f19b-1873-445c-83a3-9adc90460848 rw rootfstype=ext4
rootflags=defaults,noatime rd.udev.log_priority=3 audit=0
bootsplash.bootfile=bootsplash-themes/manjaro-green/bootsplash
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel, plank
wm: xfwm 4.16.1 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: ASUSTeK product: K52F v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: K52F v: 1.0 serial: <superuser required>
BIOS: American Megatrends v: K52F.218 date: 07/12/2011
ID-1: BAT0 charge: 6.9 Wh (54.8%) condition: 12.6/48.4 Wh (26.1%)
volts: 10.7 min: 10.8 model: ASUSTek K52F-44 type: Li-ion serial: N/A
status: Discharging
RAM: total: 3.62 GiB used: 1.36 GiB (37.5%)
RAM Report:
Info: model: Intel Pentium P6200 bits: 64 type: MCP arch: Westmere family: 6
model-id: 0x25 (37) stepping: 5 microcode: 0x7
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 3 MiB
desc: 1x3 MiB
Speed (MHz): avg: 963 high: 995 min/max: 933/2133 scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 931 2: 995 bogomips: 8514
Flags: acpi aperfmperf apic arat arch_perfmon bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts est flush_l1d fpu
fxsr ht ibpb ibrs lahf_lm lm mca mce mmx monitor msr mtrr nonstop_tsc nopl
nx pae pat pbe pcid pdcm pebs pge pni popcnt pse pse36 pti rdtscp rep_good
sep ssbd sse sse2 ssse3 stibp syscall tm tm2 tsc vme xtopology xtpr
Type: itlb_multihit status: KVM: VMX unsupported
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Device-1: Intel Core Processor Integrated Graphics vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0046 class-ID: 0300
Device-2: IMC Networks Integrated Webcam type: USB driver: uvcvideo
bus-ID: 1-1.2:3 chip-ID: 13d3:5130 class-ID: 0e02
Display: x11 server: X.Org 1.21.1.3 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS-1 res: 1366x768 hz: 60 dpi: 101
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
class-ID: 0403
Sound Server-1: ALSA v: k5.16.5-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: no
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter
vendor: AzureWave AW-NE785 / AW-NE785H 802.11bgn driver: ath9k v: kernel
bus-ID: 02:00.0 chip-ID: 168c:002b class-ID: 0280
IF: wls1 state: up mac: <filter>
Device-2: JMicron JMC250 PCI Express Gigabit Ethernet vendor: ASUSTeK
driver: jme v: 1.0.8 port: a000 bus-ID: 04:00.5 chip-ID: 197b:0250
class-ID: 0200
IF: ens5f5 state: down mac: <filter>
Local Storage: total: 465.76 GiB used: 78.26 GiB (16.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST9500325AS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: SDM1 scheme: MBR
Optical-1: /dev/sr0 vendor: PIONEER model: DVD-RW DVRTD10RS rev: 1.00
dev-links: cdrom
ID-1: / raw-size: 14.2 GiB size: 13.91 GiB (97.99%) used: 8.48 GiB (61.0%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: ROOT
uuid: c539f19b-1873-445c-83a3-9adc90460848
ID-2: /home raw-size: 10.02 GiB size: 9.8 GiB (97.81%)
used: 784.5 MiB (7.8%) fs: ext4 dev: /dev/sda7 maj-min: 8:7 label: HOME
uuid: 1bc9f42e-70f4-4d47-8ce0-88ff70c60a8f
ID-3: /media/Archivio raw-size: 431.54 GiB size: 424.64 GiB (98.40%)
used: 68.84 GiB (16.2%) fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: ARCHIVIO
uuid: 18c03f19-166a-4fb8-a4ba-2cab24ed65b1
ID-4: /media/Dati raw-size: 10 GiB size: 9.72 GiB (97.18%)
used: 167.9 MiB (1.7%) fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: DATI
uuid: c0911a05-0ce9-48df-b690-7aa0f0302ee3
ID-1: /dev/sda4 maj-min: 8:4 size: 1 KiB fs: <superuser required> label: N/A
uuid: N/A
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0020 class-ID: 0900
Device-1: 1-1.2:3 info: IMC Networks Integrated Webcam type: Video
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
System Temperatures: cpu: 43.0 C mobo: N/A
Processes: 175 Uptime: 9m wakeups: 2 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1243 lib: 402
flatpak: 0 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.12
[denver@denver-asus ~]$ export
declare -x COLORTERM="truecolor"
declare -x DBUS_SESSION_BUS_ADDRESS="unix:path=/run/user/1000/bus"
declare -x DESKTOP_SESSION="xfce"
declare -x DISPLAY=":0.0"
declare -x EDITOR="/usr/bin/nano"
declare -x GDMSESSION="xfce"
declare -x GDM_LANG="it_IT.utf8"
declare -x GIO_LAUNCHED_DESKTOP_FILE="/usr/share/applications/xfce4-terminal-emulator.desktop"
declare -x GIO_LAUNCHED_DESKTOP_FILE_PID="2594"
declare -x GSETTINGS_SCHEMA_DIR="/home/denver/data"
declare -x GTK2_RC_FILES="/home/denver/.gtkrc-2.0"
declare -x GTK_MODULES="canberra-gtk-module:canberra-gtk-module"
declare -x HOME="/home/denver"
declare -x LANG="it_IT.utf8"
declare -x LC_ADDRESS="it_IT.UTF-8"
declare -x LC_IDENTIFICATION="it_IT.UTF-8"
declare -x LC_MEASUREMENT="it_IT.UTF-8"
declare -x LC_MONETARY="it_IT.UTF-8"
declare -x LC_NAME="it_IT.UTF-8"
declare -x LC_NUMERIC="it_IT.UTF-8"
declare -x LC_PAPER="it_IT.UTF-8"
declare -x LC_TELEPHONE="it_IT.UTF-8"
declare -x LC_TIME="it_IT.UTF-8"
declare -x LD_PRELOAD="/usr/lib/libv4l/v4l1compat.so"
declare -x LIBV4LCONTROL_FLAGS="2"
declare -x LOGNAME="denver"
declare -x LS_COLORS="rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=01;05;37;41:mi=01;05;37;41:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.pdf=00;32:*.ps=00;32:*.txt=00;32:*.patch=00;32:*.diff=00;32:*.log=00;32:*.tex=00;32:*.doc=00;32:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.axa=00;36:*.oga=00;36:*.spx=00;36:*.xspf=00;36:"
declare -x MAIL="/var/spool/mail/denver"
declare -x MOTD_SHOWN="pam"
declare -x OLDPWD
declare -x PATH="/home/denver/.local/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl"
declare -x PWD="/home/denver"
declare -x QT_AUTO_SCREEN_SCALE_FACTOR="0"
declare -x QT_QPA_PLATFORMTHEME="qt5ct"
declare -x SESSION_MANAGER="local/denver-asus:@/tmp/.ICE-unix/801,unix/denver-asus:/tmp/.ICE-unix/801"
declare -x SHELL="/bin/bash"
declare -x SHLVL="1"
declare -x SSH_AGENT_PID="854"
declare -x SSH_AUTH_SOCK="/tmp/ssh-XXXXXXAFRUOH/agent.853"
declare -x TERM="xterm-256color"
declare -x USER="denver"
declare -x VTE_VERSION="6602"
declare -x WINDOWID="58720259"
declare -x XAUTHORITY="/home/denver/.Xauthority"
declare -x XDG_CONFIG_DIRS="/etc/xdg"
declare -x XDG_CURRENT_DESKTOP="XFCE"
declare -x XDG_DATA_DIRS="/home/denver/.local/share/flatpak/exports/share:/var/lib/flatpak/exports/share:/usr/local/share:/usr/share:/usr/share"
declare -x XDG_GREETER_DATA_DIR="/var/lib/lightdm-data/denver"
declare -x XDG_MENU_PREFIX="xfce-"
declare -x XDG_RUNTIME_DIR="/run/user/1000"
declare -x XDG_SEAT="seat0"
declare -x XDG_SEAT_PATH="/org/freedesktop/DisplayManager/Seat0"
declare -x XDG_SESSION_CLASS="user"
declare -x XDG_SESSION_DESKTOP="xfce"
declare -x XDG_SESSION_ID="2"
declare -x XDG_SESSION_PATH="/org/freedesktop/DisplayManager/Session0"
declare -x XDG_SESSION_TYPE="x11"
declare -x XDG_VTNR="7"
declare -x YAOURT_COLORS="nb=1:pkg=1:ver=1;32:lver=1;45:installed=1;42:grp=1;34:od=1;41;5:votes=1;44:dsc=0:other=1;35"
[denver@denver-asus ~]$ lsmod
Module Size Used by
dm_mod 188416 0
ccm 20480 6
qrtr 57344 4
uvcvideo 151552 0
videobuf2_vmalloc 20480 1 uvcvideo
videobuf2_memops 20480 1 videobuf2_vmalloc
videobuf2_v4l2 40960 1 uvcvideo
videobuf2_common 86016 4 videobuf2_vmalloc,videobuf2_v4l2,uvcvideo,videobuf2_memops
videodev 307200 3 videobuf2_v4l2,uvcvideo,videobuf2_common
mc 65536 4 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common
snd_hda_codec_hdmi 86016 1
snd_hda_codec_conexant 28672 1
snd_hda_codec_generic 98304 1 snd_hda_codec_conexant
ledtrig_audio 16384 1 snd_hda_codec_generic
joydev 28672 0
mousedev 24576 0
ath9k 188416 0
ath9k_common 40960 1 ath9k
ath9k_hw 532480 2 ath9k_common,ath9k
snd_hda_intel 61440 3
snd_intel_dspcfg 32768 1 snd_hda_intel
ath 40960 3 ath9k_common,ath9k,ath9k_hw
snd_intel_sdw_acpi 20480 1 snd_intel_dspcfg
iTCO_wdt 16384 0
intel_pmc_bxt 16384 1 iTCO_wdt
snd_hda_codec 184320 4 snd_hda_codec_generic,snd_hda_codec_conexant,snd_hda_codec_hdmi,snd_hda_intel
mac80211 1232896 2 ath9k,ath9k_hw
i915 3293184 6
intel_powerclamp 20480 0
snd_hda_core 118784 5 snd_hda_codec_generic,snd_hda_codec_conexant,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec
snd_hwdep 20480 1 snd_hda_codec
coretemp 20480 0
iTCO_vendor_support 16384 1 iTCO_wdt
snd_pcm 167936 4 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_core
jme 53248 0
intel_cstate 20480 0
snd_timer 45056 1 snd_pcm
intel_uncore 208896 0
psmouse 212992 0
snd 126976 14 snd_hda_codec_generic,snd_hda_codec_conexant,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_timer,snd_pcm
libarc4 16384 1 mac80211
jmb38x_ms 24576 0
soundcore 16384 1 snd
cfg80211 1077248 4 ath9k_common,ath9k,ath,mac80211
asus_laptop 40960 0
sparse_keymap 16384 1 asus_laptop
rfkill 32768 5 ath9k,asus_laptop,cfg80211
mii 16384 1 jme
memstick 24576 1 jmb38x_ms
pcspkr 16384 0
mei_me 53248 0
mac_hid 16384 0
mei 167936 1 mei_me
intel_ips 32768 0
i2c_i801 45056 0
ttm 86016 1 i915
lpc_ich 28672 0
i2c_smbus 20480 1 i2c_i801
intel_agp 24576 0
intel_gtt 28672 2 intel_agp,i915
video 57344 2 i915,asus_laptop
acpi_cpufreq 32768 1
ip6t_REJECT 16384 1
nf_reject_ipv6 24576 1 ip6t_REJECT
xt_hl 16384 22
ip6t_rt 20480 3
ipt_REJECT 16384 1
nf_reject_ipv4 16384 1 ipt_REJECT
xt_LOG 20480 10
nf_log_syslog 24576 10
xt_limit 16384 13
xt_addrtype 16384 4
xt_tcpudp 20480 18
xt_conntrack 16384 16
nf_conntrack 180224 1 xt_conntrack
nf_defrag_ipv6 24576 1 nf_conntrack
nf_defrag_ipv4 16384 1 nf_conntrack
libcrc32c 16384 1 nf_conntrack
ip6table_filter 16384 1
ip6_tables 36864 53 ip6table_filter
iptable_filter 16384 1
uinput 20480 0
crypto_user 20480 0
fuse 172032 3
ip_tables 32768 9 iptable_filter
x_tables 61440 13 ip6table_filter,xt_conntrack,iptable_filter,xt_LOG,xt_tcpudp,xt_addrtype,ip6t_rt,ip6_tables,ipt_REJECT,ip_tables,xt_limit,xt_hl,ip6t_REJECT
ext4 999424 4
crc32c_generic 16384 7
crc16 16384 1 ext4
mbcache 16384 1 ext4
jbd2 192512 1 ext4
serio_raw 20480 0
sdhci_pci 77824 0
atkbd 36864 0
libps2 20480 2 atkbd,psmouse
cqhci 40960 1 sdhci_pci
sr_mod 28672 0
sdhci 90112 1 sdhci_pci
cdrom 81920 1 sr_mod
i8042 45056 0
mmc_core 225280 3 sdhci,cqhci,sdhci_pci
serio 28672 9 serio_raw,atkbd,psmouse,i8042
connected to Netgear switch:
[denver@denver-asus ~]$ ip -d -h address
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 promiscuity 0 minmtu 0 maxmtu 0 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: ens5f5: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether bc:ae:c5:a3:3f:4e brd ff:ff:ff:ff:ff:ff promiscuity 0 minmtu 1280 maxmtu 9202 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535 parentbus pci parentdev 0000:04:00.5
altname enp4s0f5
3: wls1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 48:5d:60:c9:18:8c brd ff:ff:ff:ff:ff:ff promiscuity 0 minmtu 256 maxmtu 2304 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535 parentbus pci parentdev 0000:02:00.0
altname wlp2s0
inet 192.168.1.67/24 brd 192.168.1.255 scope global dynamic noprefixroute wls1
valid_lft 84293sec preferred_lft 84293sec
inet6 2001:b07:ac9:3ecd:3002:456e:2ce0:401a/64 scope global dynamic noprefixroute
valid_lft 86391sec preferred_lft 86391sec
inet6 fe80::920b:9c8c:51fe:9084/64 scope link noprefixroute
connected to modem/router:
2: ens5f5: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
altname enp4s0f5
inet 192.168.1.204/24 brd 192.168.1.255 scope global dynamic noprefixroute ens5f5
inet6 2001:b07:ac9:3ecd:cd51:7caa:8866:f08a/64 scope global dynamic noprefixroute
valid_lft 86396sec preferred_lft 86396sec
inet6 fe80::b299:d1b0:76db:f5e9/64 scope link noprefixroute
altname wlp2s0
valid_lft 84195sec preferred_lft 84195sec
valid_lft 86309sec preferred_lft 86309sec
