toppat
4 February 2024 21:13
1
Hi!
When I start the intall of manjaro 6.6 LTS, i have no ethernet connection. On my second drive I have Windows and ethernet works. Unfortunatly I have no Wifi.
When I continue and install manjaro I get a black screen after login, mouse is working. Maybe a graphical Problem.
I don’t know what to do.
I have:
i7 4790K
Asus Maximus VI Hero
GeForce GTX 1080
32 GB Ram & 250 GB SSD
toppat
5 February 2024 12:03
2
The problem the ethernet I fixed, was a disturbance.
The problem with the black screen I fixed with this:
This post assumes you are using proprietary Nvidia drivers and the grub bootloader that Manjaro installed. Tested on a desktop 2070 super with archlinux, Manjaro, kde, and gnome.
For anyone interested in enabling Wayland on NVIDIA. Source material can be found
* DRM kernel modesetting -ArchWiki and
** Preserve video memory after suspend -ArchWiki.
This is also where you should be able to find updated instructions in the future if manjaro maintains compatibility with the upstream distro.
F…
Kobold
5 February 2024 12:15
3
Always post the Output from your system (so we can help you better) and mark the info with control+e:
I also recommend to Edit your first Posting and copy the additional info’s to it, instead double postings.
Edit:
Do you run into this problems, after you changed to Wayland?
You can also try differend Kernels like 6.1 (LTS) or 6.7 (non-LTS). But since you don’t have no Internet Connection, i have no idea how to fix it… i normally would roll back my system to the last working state.
But it looks to me that you fresh installed Manjaro, is that true?
Did you used the newest ISO?
toppat:
So your Manjaro runs flawless now?
toppat
5 February 2024 12:52
4
Yes I installed it fresh and used the newest ISO.
I’m glad that I have the Desktop now!
But, when I go to lockscreen and want to go back to Desktop I get a blackscreen (without mouse). Frozen. Have to restart the Computer…
Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=1a83e5fa-5d8c-4ba6-b9a9-e3fc556c3a32 rw nvidia_drm.modeset=1
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: frameworks
v: 5.113.0 wm: kwin_wayland vt: 1 dm: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Desktop System: ASUS product: All Series v: N/A
serial: <superuser required>
Mobo: ASUSTeK model: MAXIMUS VI HERO v: Rev 1.xx
serial: <superuser required> part-nu: All uuid: <superuser required>
UEFI: American Megatrends v: 1505 date: 06/05/2014
System RAM: total: 32 GiB available: 31.29 GiB used: 2.72 GiB (8.7%)
Array-1: capacity: 32 GiB slots: 4 modules: 4 EC: None
Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 8 GiB speed:
spec: 1600 MT/s actual: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Corsair part-no: CML16GX3M2A1600C10 serial: N/A
Device-2: ChannelA-DIMM1 type: DDR3 detail: synchronous size: 8 GiB speed:
Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 8 GiB speed:
Device-4: ChannelB-DIMM1 type: DDR3 detail: synchronous size: 8 GiB speed:
Info: model: Intel Core i7-4790K bits: 64 type: MT MCP arch: Haswell
gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3285 high: 4400 min/max: 800/4400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 800 2: 4240 3: 4036
4: 4024 5: 3993 6: 3991 7: 4400 8: 800 bogomips: 63874
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs
ida invpcid lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep smep ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust
tsc_deadline_timer vme x2apic xsave xsaveopt xtopology xtpr
Type: itlb_multihit status: KVM: VMX unsupported
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: ASUSTeK driver: nvidia
v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2024-01; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
off: DP-1,HDMI-A-1 empty: DP-2,DVI-D-1,HDMI-A-2 bus-ID: 01:00.0
chip-ID: 10de:1b80 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
compositor: kwin_wayland driver: X: loaded: nvidia gpu: nvidia
d-rect: 4672x2232 display-ID: 0
Monitor-1: DP-1 pos: primary,top-left res: 2752x1152 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: bottom-r res: 1920x1080 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia wayland:
drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 545.29.06 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GTX 1080/PCIe/SSE2
memory: 7.81 GiB display-ID: :1.0
API: Vulkan v: 1.3.274 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1080 driver: nvidia v: 545.29.06
device-ID: 10de:1b80 surfaces: xcb,xlib,wayland
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK 8
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-3: Logitech G933 Wireless Headset Dongle
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-5:4 chip-ID: 046d:0a5b class-ID: 0300
API: ALSA v: k6.6.10-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I217-V vendor: ASUSTeK driver: e1000e v: kernel
port: f040 bus-ID: 00:19.0 chip-ID: 8086:153b class-ID: 0200
Local Storage: total: 7.5 TiB used: 10.97 GiB (0.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST5000LM000-2AN170
size: 4.55 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5526 serial: <filter> fw-rev: 0001 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 EVO 1TB
ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST2000DM001-1CH164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC24 scheme: MBR
ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%) used: 10.97 GiB (4.8%)
fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 1a83e5fa-5d8c-4ba6-b9a9-e3fc556c3a32
used: 296 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 67F1-7967
ID-1: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required> label: N/A
uuid: N/A
ID-2: /dev/sda2 maj-min: 8:2 size: 4.55 TiB fs: ntfs label: Bibliothek
uuid: 5ECC1F51CC1F22B7
ID-3: /dev/sdc1 maj-min: 8:33 size: 100 MiB fs: vfat label: N/A
uuid: 24B3-92A4
ID-4: /dev/sdc2 maj-min: 8:34 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-5: /dev/sdc3 maj-min: 8:35 size: 930.88 GiB fs: ntfs label: Windows
uuid: 9ACCBB76CCBB4B71
ID-6: /dev/sdc4 maj-min: 8:36 size: 527 MiB fs: ntfs label: N/A
uuid: F25E99185E98D727
ID-7: /dev/sdd1 maj-min: 8:49 size: 1.82 TiB fs: ntfs label: Data
uuid: 3C24E81824E7D2C6
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8008
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 14 rev: 2.0
Device-1: 3-3:2 info: Logitech G502 SE HERO Gaming Mouse type: mouse,HID
lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c08b class-ID: 0300
serial: <filter>
Device-2: 3-4:3 info: China Resource Semico USB Keyboard
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 500mA
chip-ID: 1a2c:4c5e class-ID: 0301
Device-3: 3-5:4 info: Logitech G933 Wireless Headset Dongle type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
Hub-6: 4-0:1 info: super-speed hub ports: 6 rev: 3.0
System Temperatures: cpu: 39.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 266 Power: uptime: 2m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 0 hibernate: platform
avail: shutdown,reboot,suspend,test_resume image: 12.46 GiB
daemons: upowerd, org_kde_powerdevil, power-profiles-daemon Init: systemd
v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1177 libs: 346 tools: pamac pm: flatpak pkgs: 0
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.21 running-in: konsole inxi: 3.3.32
Kobold
5 February 2024 13:23
5
Always try to evade hardreset… there are some ways to evade it.
First i would try to use TTY (control+alt+f3) and switch back to desktop (control+alt+f2).
You can also shutdown your system from TTY.
Second is to activate REISUB, when your system is really frozen (almost) to death.
You are using Wayland instead of Xorg.
Switch - use Xorg session.
The session type is changed at the login screen - I presume, I don’t know …
I have no personal experience but from reading here,
Wayland support in Plasma/KDE can be problematic,
as well as having an Nvidia graphic card - which you also have.
Log in there - if you can.
then type reboot or systemctl poweroff
toppat
5 February 2024 14:12
7
Yes I know Hardreset is never good. I got it to reboot.
And I tried the start with Xorg. I don’t have the blackscreen after lockscreen anymore.
Thank you guys!
Kobold
5 February 2024 14:37
8
Fun Fact, KDE want Wayland as the new standard.
As far as i know, the developers want to drop Xorg support in a few years.
Fedora has announced the demise of Xorg as well - discussed on KDE
KDE Plasma 6 is successor to KDE Plasma 5 created by the KDE Community. It is based on Qt 6 and KDE Frameworks 6 and brings many changes and improvements over previous versions. For Fedora Linux, the transition to KDE Plasma 6 will also include...
Reading time: 29 mins 🕑
Likes: 205 ❤
