I am doing a fresh install of manjaro on a blank drive. Once I finish setting up my partitions, I get an error stating that I have not configured the EFI partition, and need to create a FAT32 partition with boot flag enabled and mounted to boot/efi. That’s exactly what I had done in the previous step – the very first partition is a 200MiB partition, fat32, mounted to /boot/efi and the boot flag is selected under flags.
So I am very confused as to what’s causing this and what I am doing wrong. Any help would be greatly appreciated.
I screenshot would be handy to see exactly your partitions.
Also, check your boot sequence in your BIOS/UEFI, if it points to that drive.
check info in your UEFI motherboard
disable secure boot
disable fast boot
disks on AHCI
no legacy
no CSM
UEFI only or others ( not windows )
you should see
UEFI < USB vendor name > < partition 1 > → boot in EFI
open a terminal and check before install
inxi -Mxa ( check for UEFI only )
test -d /sys/firmware/efi && echo efi || echo bios
sudo lsbk -fs ( check uuid /boot/efi)
sudo parted -l ( disk format should GPT)
you can also use Gparted to format and create partitions size
I tried, but it seems that I don’t have permission to post screenshots yet as I just created my account here.
Either way, I ignored the warning and my system installed just fine, I can boot into manjaro no problem. I don’t know what that prompt was about, but my best guess is that the installer was looking for an existing efi partition that simply wasn’t there yet and gave me an error because of that. Purely uneducated speculation though.
As I mentioned in another reply, just ignoring the warning and proceeding with the install worked fine. I did boot into the live usb again though to see if I get the warning again; I still do, so I went through your steps, results are below:
All bios settings are correct
I am indeed in UEFI mode
inxi:
Machine: Type: Desktop Mobo: BIOSTAR model: X470NH serial: <superuser required> UEFI: American Megatrends LLC. v: 5.17
date: 02/23/2021
test returns efi
Output of parted for my drive here:
Model: Samsung SSD 970 EVO Plus 1TB (nvme)
Disk /dev/nvme0n1: 1000GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
3 1049kB 269MB 268MB fat32 boot, esp
1 269MB 17.0GB 16.8GB linux-swap(v1) swap
2 17.0GB 69.5GB 52.4GB ext4
4 69.5GB 1000GB 931GB ext4
Full output of lsblk here:
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0 squashfs 4.0 0 100% /run/miso/sfs/livefs
loop1 squashfs 4.0 0 100% /run/miso/sfs/mhwdfs
loop2 squashfs 4.0 0 100% /run/miso/sfs/desktopfs
loop3 squashfs 4.0 0 100% /run/miso/sfs/rootfs
sda1
└─sda
sda2 ntfs 8C2E5B532E5B3584
└─sda
sda3 ext4 1.0 0d7e504c-4891-4655-87e8-7fd9e209e596
└─sda
sda4 ext4 1.0 a4fa1e1d-83cd-4f9b-a5ce-0fc9c66f33a8
└─sda
sdb1 vfat FAT32 B152-775E
└─sdb
sdb2 swsuspend s1suspend 080f1af3-166a-4350-b647-0348b5ed5362
└─sdb
sdb3 ext4 1.0 2fc5424c-bdda-4157-a212-78f0e95447ef
└─sdb
sdb4 ext4 1.0 02c663d1-fa62-4675-a54e-ba4cdebe0e60
└─sdb
sdb5
└─sdb
sdb6
└─sdb
sdb7 ntfs 329E84B19E846EE3
└─sdb
sdc1 crypto_LUKS 2 1b78ed90-ddfd-4c69-8b04-0b6f358226fd
└─sdc
sdd1 iso9660 Joliet Extens MANJARO_GNOME_2113 2021-09-16-12-15-29-00
└─sdd iso9660 Joliet Extens MANJARO_GNOME_2113 2021-09-16-12-15-29-00 0 100% /run/miso/bootmnt
sdd2 vfat FAT12 MISO_EFI E45F-2361
nvme0n1p1 swap 1 a4e93aef-fa32-4fc4-af7d-ff92880e7153
└─nvme0n1
nvme0n1p2 ext4 1.0 21c89769-b282-4d51-8a5e-9c5144118cce
└─nvme0n1
nvme0n1p3 vfat FAT32 NO_LABEL D861-8147
└─nvme0n1
nvme0n1p4 ext4 1.0 923523d9-7cc0-44d7-94cc-99572d0604cc
└─nvme0n1
One curious thing I don’t understand is why the number for my efi partition is 3, as I had that set up as the first partition.
have you mixed disks MBR & GPT ?
sda is MBR or GPT ?
sdc is MBR or GPT ?
maybe missing flag ESP , have you checked with gparted before reboot ?
other try with 512Mib for /boot/efi
sudo parted -l
I had a similar problem when I installed Manjaro for the first time in Lenovo Ideapad.
The problem was with the VMD controller. When the VMD controller is on the Manjaro does not boot up and returns Disk bot found or bootable partition not found.
Make sure of two things:
- You make a separate boot partition instead of the given 100 MB partition.
- And Turn the VMD controller off from the secure mode.
Hope it helps.
There is a “bug” in Calamares where it complains about the EFI partition if it is smaller than 500MiB. I think is already fixed, but I suppose it should land in the next ISO version.
EDIT: Manual partition shows wrong error message · Issue #1761 · calamares/calamares · GitHub
thank you very much for your help.
