Hi there,
i saw a quite similar thread here before, but the solution which was marked there doesnt fixed my problem.
After the last big Update of the Kernel and Nvidia Driver
(from Kernel 5.7 and Nvidia proprietary 440.xx to Kernel 5.8 and Nvidia proprietary 450.xx)
my Displayport Sound output device dissapeared. I also checked Alsamixer with sudo alsamixer.
It only shows my Steelseries USB Headset and the Mainboard Audiocard.
I already tried to reinstall the graphics driver, but nothing changed.
I also tried to boot with the old kernel, but that doesnt work either.
Any ideas?
inxi -Fazy
Kernel: 5.8.3-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=27bbc37b-c472-408f-af38-ad098aebd1b0 rw quiet apparmor=1
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop Mobo: ASRock model: B450M Pro4 serial: <filter>
UEFI [Legacy]: American Megatrends v: P4.20 date: 07/07/2020
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Topology: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: N/A microcode: 8701021
L2 cache: 3072 KiB
bogomips: 100646
Speed: 4191 MHz min/max: 2200/4200 MHz boost: enabled Core speeds (MHz):
1: 4191 2: 4192 3: 4191 4: 4192 5: 4192 6: 4191 7: 4192 8: 4190 9: 4192
10: 4191 11: 4191 12: 4191
conditional, RSB filling
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: Micro-Star MSI
driver: nvidia v: 450.66 alternate: nouveau,nvidia_drm bus ID: 07:00.0
chip ID: 10de:1b81
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa display ID: :0
screens: 1
Screen-1: 0 s-res: 3360x2560 s-dpi: 80 s-size: 1066x812mm (42.0x32.0")
s-diag: 1340mm (52.8")
Monitor-1: DP-2 res: 1440x2560 hz: 60
Monitor-2: DP-4 res: 1920x1080 dpi: 82 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
OpenGL: renderer: GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 450.66
direct render: Yes
Device-1: AMD Starship/Matisse HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus ID: 09:00.4 chip ID: 1022:1487
Device-2: SteelSeries ApS SteelSeries Arctis 7 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-3:3 chip ID: 1038:12ad
Sound Server: ALSA v: k5.8.3-2-MANJARO
vendor: ASRock driver: r8169 v: kernel port: f000 bus ID: 05:00.0
chip ID: 10ec:8168
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.27 TiB used: 664.72 GiB (28.5%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 500GB size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: 2B2QEXE7 scheme: MBR
ID-2: /dev/sda vendor: Seagate model: ST2000LM015-2E8174 size: 1.82 TiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: SDM1 scheme: GPT
ID-1: / raw size: 465.76 GiB size: 457.45 GiB (98.22%)
used: 105.62 GiB (23.1%) fs: ext4 dev: /dev/nvme0n1p1
System Temperatures: cpu: 52.8 C mobo: N/A gpu: nvidia temp: 57 C
Processes: 312 Uptime: 27m Memory: 15.57 GiB used: 3.99 GiB (25.6%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages: 1387
pacman: 1372 lib: 392 flatpak: 5 snap: 10 Shell: Bash v: 5.0.18
running in: yakuake inxi: 3.1.05
