I have a Lenovo P51 notebook with an Nvidia GPU and after the latest update the notebooks display remains black.
System Information
sudo mhwd-kernel -li
Currently running: 5.15.81-1-MANJARO (linux515)
* linux515
sudo mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.11.04 false PCI
inxi -Fza
Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=a1ce8d41-cdba-4fac-ad01-f6af1a14c873
rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
Console: pty pts/0 DM: GDM v: 43.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20HH001QGE v: ThinkPad P51 serial: <superuser required>
Chassis: type: 10 serial: <superuser required>
Mobo: LENOVO model: 20HH001QGE v: SDK0J40697 WIN serial: <superuser required> UEFI: LENOVO
v: N1UET72W (1.46 ) date: 10/04/2018
ID-1: BAT0 charge: 89.1 Wh (100.0%) condition: 89.1/90.0 Wh (99.0%) volts: 11.8 min: 11.2
model: SMP 00NY493 type: Li-poly serial: <filter> status: full cycles: 188
Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake gen: core 7 level: v3
note: check built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 9
microcode: 0xF0
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3526 high: 3799 min/max: 800/3800 scaling: driver: intel_pstate
governor: powersave cores: 1: 3526 2: 3442 3: 3445 4: 3541 5: 3502 6: 3500 7: 3453 8: 3799
bogomips: 44817
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GM107GLM [Quadro M1200 Mobile] vendor: Lenovo driver: nvidia v: 525.60.11
alternate: nouveau,nvidia_drm non-free: 520.xx+ status: current (as of 2022-10) arch: Maxwell
code: GMxxx process: TSMC 28nm built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:13b6 class-ID: 0300
Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-8:2 chip-ID: 5986:111c
Display: server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.5 driver: N/A tty: 180x55
API: OpenGL Message: GL data unavailable in console and glxinfo missing.
Device-1: Intel CM238 HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
chip-ID: 8086:a171 class-ID: 0403
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX] driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fbc class-ID: 0403
Sound API: ALSA v: k5.15.81-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.61 running: no
Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:15d6 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:24fd class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-14:6
chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 6.83 TiB used: 332.21 GiB (4.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HAJQ-000L7 size: 476.94 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 3L2QEXA7 temp: 30.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Crucial model: Micron X8 SSD size: 1.82 TiB
block-size: physical: 512 B logical: 512 B type: SSD serial: <filter> scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate model: Portable size: 4.55 TiB
block-size: physical: 4096 B logical: 512 B type: N/A serial: <filter> rev: 9300 scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 332.21 GiB (71.0%) fs: ext4
dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 288 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1 maj-min: 259:1
journalctl
journalctl --boot=-1 --priority=3 --no-pager
Dez 07 16:24:35 cptLegendary kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_PR.CPU0._CPC], AE_NOT_FOUND (20210730/psargs-330)
Dez 07 16:24:35 cptLegendary kernel: ACPI Error: Aborting method \_PR.CPU1._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dez 07 16:24:35 cptLegendary kernel: ACPI Error: Aborting method \_PR.CPU2._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dez 07 16:24:35 cptLegendary kernel: ACPI Error: Aborting method \_PR.CPU3._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dez 07 16:24:35 cptLegendary kernel: ACPI Error: Aborting method \_PR.CPU4._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dez 07 16:24:35 cptLegendary kernel: ACPI Error: Aborting method \_PR.CPU5._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dez 07 16:24:35 cptLegendary kernel: ACPI Error: Aborting method \_PR.CPU6._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dez 07 16:24:35 cptLegendary kernel: ACPI Error: Aborting method \_PR.CPU7._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dez 07 16:24:37 cptLegendary kernel:
Dez 07 16:24:38 cptLegendary kernel: Bluetooth: hci0: Reading supported features failed (-16)
Dez 07 16:24:38 cptLegendary bluetoothd[652]: src/plugin.c:plugin_init() Failed to init vcp plugin
Dez 07 16:24:38 cptLegendary bluetoothd[652]: src/plugin.c:plugin_init() Failed to init mcp plugin
Dez 07 16:24:38 cptLegendary bluetoothd[652]: src/plugin.c:plugin_init() Failed to init bap plugin
Dez 07 16:24:39 cptLegendary gdm-autologin][807]: gkr-pam: couldn't unlock the login keyring.
Dez 07 16:24:46 cptLegendary smbd[851]: [2022/12/07 16:24:46.182136, 0] ../../source3/smbd/server.c:1741(main)
Dez 07 16:24:46 cptLegendary smbd[851]: smbd version 4.17.3 started.
Dez 07 16:24:46 cptLegendary smbd[851]: Copyright Andrew Tridgell and the Samba Team 1992-2022
Dez 07 16:25:00 cptLegendary systemd-backlight[1026]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
Dez 07 16:25:00 cptLegendary systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:nvidia_0.
Dez 07 16:25:06 cptLegendary kernel: nvidia-modeset: ERROR: GPU:0: Idling display engine timed out: 0x0000947d:0:0:407
Dez 07 16:37:13 cptLegendary gdm[719]: Gdm: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
Dez 07 16:37:13 cptLegendary systemd-coredump[9644]: Failed to connect to coredump service: Connection refused
Xorg.0.log
cat /var/log/Xorg.0.log
[ 5.564] (--) Log file renamed from "/var/log/Xorg.pid-844.log" to "/var/log/Xorg.0.log"
[ 5.566]
X.Org X Server 1.21.1.4
[ 5.566] Current Operating System: Linux cptLegendary 5.15.81-1-MANJARO #1 SMP PREEMPT Fri Dec 2 21:02:26 UTC 2022 x86_64
[ 5.566] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=a1ce8d41-cdba-4fac-ad01-f6af1a14c873 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[ 5.566]
[ 5.566] Current version of pixman: 0.42.2
[ 5.566] Before reporting problems, check http://wiki.x.org
[ 5.566] Markers: (--) probed, (**) from config file, (==) default setting,
[ 5.566] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Dec 7 16:38:38 2022
[ 5.568] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 5.568] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 5.569] (==) ServerLayout "layout"
[ 5.569] (**) |-->Screen "Screen0" (0)
[ 5.569] (**) | |-->Monitor "Monitor0"
[ 5.570] (**) | |-->Device "Device0"
[ 5.570] (==) Automatically adding devices
[ 5.570] (==) Automatically enabling devices
[ 5.570] (==) Automatically adding GPU devices
[ 5.570] (==) Automatically binding GPU devices
[ 5.570] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 5.570] (WW) The directory "/usr/share/fonts/misc" does not exist.
[ 5.570] Entry deleted from font path.
[ 5.570] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 5.570] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 5.570] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 5.570] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 5.570] (==) FontPath set to:
/usr/share/fonts/TTF
[ 5.570] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 5.570] (**) Extension "COMPOSITE" is enabled
[ 5.570] (II) The server relies on udev to provide the list of input devices.
[ 5.570] (II) Module ABI versions:
[ 5.570] X.Org ANSI C Emulation: 0.4
[ 5.570] X.Org Video Driver: 25.2
[ 5.570] X.Org XInput driver : 24.4
[ 5.570] X.Org Server Extension : 10.0
[ 5.571] (++) using VT number 2
[ 5.574] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 5.574] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 5.574] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card0
[ 5.575] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 14 paused 0
[ 5.577] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 5.577] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 5.579] (--) PCI:*(1@0:0:0) 10de:13b6:17aa:2251 rev 162, Mem @ 0xeb000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000d000/128, BIOS @ 0x????????/131072
[ 5.579] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 5.580] (II) LoadModule: "glx"
[ 5.580] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 5.585] (II) Module glx: vendor="X.Org Foundation"
[ 5.585] compiled for 1.21.1.4, module version = 1.0.0
[ 5.585] ABI class: X.Org Server Extension, version 10.0
[ 5.585] (II) LoadModule: "nvidia"
[ 5.586] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 5.589] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 5.589] compiled for 1.6.99.901, module version = 1.0.0
[ 5.589] Module class: X.Org Video Driver
[ 5.590] (II) NVIDIA dlloader X Driver 525.60.11 Wed Nov 23 22:56:57 UTC 2022
[ 5.590] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 5.590] (II) systemd-logind: releasing fd for 226:0
[ 5.591] (II) Loading sub module "fb"
[ 5.591] (II) LoadModule: "fb"
[ 5.592] (II) Module "fb" already built-in
[ 5.592] (II) Loading sub module "wfb"
[ 5.592] (II) LoadModule: "wfb"
[ 5.592] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 5.592] (II) Module wfb: vendor="X.Org Foundation"
[ 5.592] compiled for 1.21.1.4, module version = 1.0.0
[ 5.593] ABI class: X.Org ANSI C Emulation, version 0.4
[ 5.593] (II) Loading sub module "ramdac"
[ 5.593] (II) LoadModule: "ramdac"
[ 5.593] (II) Module "ramdac" already built-in
[ 5.593] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 5.594] (==) NVIDIA(0): RGB weight 888
[ 5.594] (==) NVIDIA(0): Default visual is TrueColor
[ 5.594] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 5.594] (**) Option "AllowNVIDIAGpuScreens"
[ 5.594] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 5.594] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 5.594] (**) NVIDIA(0): Enabling 2D acceleration
[ 5.594] (II) Loading sub module "glxserver_nvidia"
[ 5.594] (II) LoadModule: "glxserver_nvidia"
[ 5.594] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 5.628] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 5.628] compiled for 1.6.99.901, module version = 1.0.0
[ 5.628] Module class: X.Org Server Extension
[ 5.628] (II) NVIDIA GLX Module 525.60.11 Wed Nov 23 22:51:25 UTC 2022
[ 5.629] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 18.285] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 18.285] (--) NVIDIA(0): DFP-0
[ 18.285] (--) NVIDIA(0): DFP-1
[ 18.285] (--) NVIDIA(0): DFP-2
[ 18.285] (--) NVIDIA(0): DFP-3
[ 18.285] (--) NVIDIA(0): DFP-4 (boot)
[ 18.285] (--) NVIDIA(0): DFP-5
[ 18.285] (--) NVIDIA(0): DFP-6
[ 18.286] (II) NVIDIA(0): NVIDIA GPU Quadro M1200 (GM107GL-A) at PCI:1:0:0 (GPU-0)
[ 18.286] (--) NVIDIA(0): Memory: 4194304 kBytes
[ 18.286] (--) NVIDIA(0): VideoBIOS: 82.07.bb.00.14
[ 18.286] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 18.286] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 18.286] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 18.286] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 18.286] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 18.286] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 18.286] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 18.286] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 18.286] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 18.286] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 18.287] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 18.287] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 18.287] (--) NVIDIA(GPU-0): DFP-3: 960.0 MHz maximum pixel clock
[ 18.287] (--) NVIDIA(GPU-0): AU Optronics Corporation (DFP-4): connected
[ 18.287] (--) NVIDIA(GPU-0): AU Optronics Corporation (DFP-4): Internal DisplayPort
[ 18.287] (--) NVIDIA(GPU-0): AU Optronics Corporation (DFP-4): 960.0 MHz maximum pixel clock
[ 18.287] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 18.287] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[ 18.287] (--) NVIDIA(GPU-0): DFP-5: 960.0 MHz maximum pixel clock
[ 18.287] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 18.287] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 18.287] (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[ 18.288] (==) NVIDIA(0):
[ 18.288] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 18.288] (==) NVIDIA(0): will be used as the requested mode.
[ 18.288] (II) NVIDIA(0): Validated MetaModes:
[ 18.288] (II) NVIDIA(0): "DFP-4:nvidia-auto-select"
[ 18.288] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[ 18.290] (--) NVIDIA(0): DPI set to (143, 144); computed from "UseEdidDpi" X config
[ 18.290] (--) NVIDIA(0): option
[ 18.290] (II) NVIDIA: Reserving 6144.00 MB of virtual memory for indirect memory
[ 18.290] (II) NVIDIA: access.
[ 22.295] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 22.295] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 22.295] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 22.295] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 22.295] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 22.295] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 22.295] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 22.295] (II) NVIDIA(0): Config Options in the README.
[ 26.621] (II) NVIDIA(0): Setting mode "DFP-4:nvidia-auto-select"
/etc/X11
ls -alsh *
mhwd.d:
total 12K
4,0K drwxr-xr-x 2 root root 4,0K 7. Dez 16:36 .
4,0K drwxr-xr-x 6 root root 4,0K 12. Feb 2022 ..
4,0K -rw-r--r-- 1 root root 1,5K 7. Dez 16:36 nvidia.conf
0 -rw-r--r-- 1 root root 0 7. Dez 16:36 nvidia.conf.nvidia-xconfig-original
tigervnc:
total 12K
4,0K drwxr-xr-x 2 root root 4,0K 19. Apr 2022 .
4,0K -rwxr-xr-x 1 root root 1,5K 14. Mär 2022 Xsession
xinit:
total 20K
4,0K drwxr-xr-x 3 root root 4,0K 23. Jän 2022 .
4,0K -rw-r--r-- 1 root root 739 10. Okt 2020 xinitrc
4,0K drwxr-xr-x 2 root root 4,0K 7. Dez 13:32 xinitrc.d
4,0K -rw-r--r-- 1 root root 45 10. Okt 2020 xserverrc
xorg.conf.d:
total 12K
4,0K -rw-r--r-- 1 root root 273 11. Feb 2022 00-keyboard.conf
0 lrwxrwxrwx 1 root root 27 7. Dez 16:36 90-mhwd.conf -> /etc/X11/mhwd.d/nvidia.conf
nvdia.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 525.60.11
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
Option "NoLogo" "1"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option "COMPOSITE" "Enable"
EndSection
Section "InputClass"
Identifier "Keyboard Defaults"
MatchIsKeyboard "yes"
Option "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
Any help would be greatly appreciated.
