Newly built system and new to Linux. Brightness at max no sign of controls and shortcuts don’t work.
Kernel: 5.15.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=90d5f955-82fc-4731-93ef-05fc630ed2e9 rw quiet apparmor=1
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Mobo: ASUSTeK model: ROG STRIX Z690-E GAMING WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1601
date: 07/07/2022
Info: model: 12th Gen Intel Core i9-12900K bits: 64 type: MST AMCP
arch: Alder Lake family: 6 model-id: 0x97 (151) stepping: 2 microcode: 0x1F
Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
L2: 14 MiB desc: 8x1.2 MiB, 2x2 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 750 high: 801 min/max: 800/5200:3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 700 2: 701 3: 700 4: 701
5: 700 6: 701 7: 700 8: 701 9: 800 10: 800 11: 800 12: 800 13: 700 14: 701
15: 700 16: 700 17: 800 18: 800 19: 800 20: 801 21: 800 22: 800 23: 800
24: 799 bogomips: 153024
Device-1: Intel AlderLake-S GT1 vendor: ASUSTeK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:4680 class-ID: 0300
Device-2: NVIDIA GA102 [GeForce RTX 3090] vendor: ZOTAC driver: nouveau
v: kernel bus-ID: 01:00.0 chip-ID: 10de:2204 class-ID: 0300
Device-3: Linux Foundation WyreStorm FOCUS 210 Camera type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 2-4.4:3 chip-ID: 343b:0306
class-ID: 0102
Display: x11 server: X.org 1.21.1.3 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa resolution: <missing: xdpyinfo>
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7ad0
class-ID: 0403
Device-2: NVIDIA GA102 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:1aef
class-ID: 0403
Device-3: ASUSTek USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:3 chip-ID: 0b05:1996
class-ID: 0300
Device-4: Universal Audio Volt 1 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5.2:8 chip-ID: 2b5a:0020
class-ID: 0300 serial: <filter>
Device-5: Linux Foundation WyreStorm FOCUS 210 Camera type: USB
class-ID: 0102
Sound Server-1: ALSA v: k5.15.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
bus-ID: 06:00.0 chip-ID: 8086:2725 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
port: N/A bus-ID: 08:00.0 chip-ID: 8086:15f3 class-ID: 0200
IF: enp8s0 state: down mac: <filter>
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-14:12 chip-ID: 8087:0032 class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 7.31 TiB used: 10.95 GiB (0.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 type: SSD serial: <filter> rev: 5B2QGXA7 temp: 41.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 type: SSD serial: <filter> rev: 5B2QGXA7 temp: 35.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 2B6Q
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 2TB
ID-5: /dev/sdc maj-min: 8:32 type: USB model: EZITSOL USB Disk
size: 29.49 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 2.00 scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 10.95 GiB (0.6%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 27.8 C mobo: N/A
Processes: 414 Uptime: 1h 47m wakeups: 0 Memory: 31.1 GiB
used: 3.98 GiB (12.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1207 lib: 332 flatpak: 0
Shell: Zsh v: 5.8 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.12
any advice is greatly appreciated.
