windows detectaba mis 8gb de ram pero al pasarme a manjaro no me percate que solo detectaba 4gb hasta que por casualidad entre en Htop y note que solo decia que habia disponibles 3.29gb
adjunto la salida del comando inxi -Fxxxza --no-host
Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=4744673f-d380-401f-a4d0-c55ad726285b rw quiet apparmor=1
security=apparmor resume=UUID=27967dc8-26b6-437d-8f64-eba488911f18
udev.log_priority=3
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: TOSHIBA product: Satellite C40D-A v: PSCDSM-005TM1
serial: <filter>
Mobo: AMD model: Larne serial: <filter> UEFI: Insyde v: 1.20
date: 05/31/2013
Topology: Quad Core model: AMD A6-5200 APU with Radeon HD Graphics
bits: 64 type: MCP arch: Jaguar family: 16 (22) model-id: N/A stepping: 1
microcode: 700010F L2 cache: 2048 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 15979
Speed: 798 MHz min/max: 800/2000 MHz Core speeds (MHz): 1: 798 2: 799
3: 799 4: 798
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Kabini [Radeon HD 8400 / R3 Series] vendor: Toshiba
driver: radeon v: kernel alternate: amdgpu bus ID: 00:01.0
chip ID: 1002:9830
Display: x11 server: X.Org 1.20.8 driver: ati,radeon unloaded: modesetting
alternate: fbdev,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: HDMI-0 res: 1366x768 hz: 60 dpi: 60
size: 575x323mm (22.6x12.7") diag: 660mm (26")
OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.8.6-1-MANJARO LLVM 10.0.1)
v: 4.5 Mesa 20.1.8 direct render: Yes
Device-1: AMD Kabini HDMI/DP Audio driver: snd_hda_intel v: kernel
bus ID: 00:01.1 chip ID: 1002:9840
Device-2: AMD FCH Azalia vendor: Toshiba driver: snd_hda_intel v: kernel
bus ID: 00:14.2 chip ID: 1022:780d
Sound Server: ALSA v: k5.8.6-1-MANJARO
Device-1: Qualcomm Atheros AR8162 Fast Ethernet vendor: Toshiba
driver: alx v: kernel port: 2000 bus ID: 01:00.0 chip ID: 1969:1090
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lite-On driver: ath9k v: kernel port: 2000 bus ID: 05:00.0
chip ID: 168c:0036
IF: wlp5s0 state: down mac: <filter>
Local Storage: total: 698.64 GiB used: 105.35 GiB (15.1%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABD075 size: 698.64 GiB
block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 3M scheme: GPT
ID-1: / raw size: 691.10 GiB size: 679.25 GiB (98.29%)
used: 104.38 GiB (15.4%) fs: ext4 dev: /dev/sda2
ID-1: swap-1 type: partition size: 7.24 GiB used: 990.5 MiB (13.4%)
priority: -2 dev: /dev/sda3
System Temperatures: cpu: 70.2 C mobo: N/A gpu: radeon temp: 69 C
Processes: 215 Uptime: 13h 07m Memory: 3.29 GiB used: 1.81 GiB (54.9%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1151 lib: 378
flatpak: 0 Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.05
mbb
3 October 2020 14:12
2
Memoria de video?
[mbb@mbb-laptop ~]$ lspci
00:00.0 Host bridge: Intel Corporation 3rd Gen Core processor DRAM Controller (rev 09)
00:02.0 VGA compatible controller: Intel Corporation 3rd Gen Core processor Graphics Controller (rev 09)
00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04)
00:16.0 Communication controller: Intel Corporation 7 Series/C216 Chipset Family MEI Controller #1 (rev 04)
00:19.0 Ethernet controller: Intel Corporation 82579LM Gigabit Network Connection (Lewisville) (rev 04)
00:1a.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 7 Series/C216 Chipset Family High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 7 Series/C216 Chipset Family PCI Express Root Port 1 (rev c4)
00:1c.2 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 3 (rev c4)
00:1c.3 PCI bridge: Intel Corporation 7 Series/C216 Chipset Family PCI Express Root Port 4 (rev c4)
00:1d.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation QM77 Express Chipset LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 7 Series Chipset Family 6-port SATA Controller [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 7 Series/C216 Chipset Family SMBus Controller (rev 04)
02:00.0 System peripheral: JMicron Technology Corp. SD/MMC Host Controller (rev 30)
02:00.2 SD Host controller: JMicron Technology Corp. Standard SD Host Controller (rev 30)
03:00.0 Network controller: Intel Corporation Centrino Advanced-N 6235 (rev 24)
La tarjeta gráfica (VGA) es el dispositivo 00:02.0
[mbb@mbb-laptop ~]$ lspci -v -s 00:02.0
00:02.0 VGA compatible controller: Intel Corporation 3rd Gen Core processor Graphics Controller (rev 09) (prog-if 00 [VGA controller])
DeviceName: 64
Subsystem: Hewlett-Packard Company Device 18df
Flags: bus master, fast devsel, latency 0, IRQ 29
Memory at d0000000 (64-bit, non-prefetchable) [size=4M]
Memory at c0000000 (64-bit, prefetchable) [size=256M]
I/O ports at 2000 [size=64]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Capabilities: <access denied>
Kernel driver in use: i915
Kernel modules: i915
Memoria de video es 256 MB
También:
[mbb@mbb-laptop ~]$ sudo dmidecode --type memory
[sudo] senha para mbb:
# dmidecode 3.2
Getting SMBIOS data from sysfs.
SMBIOS 2.7 present.
Handle 0x0018, DMI type 16, 23 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 16 GB
Error Information Handle: Not Provided
Number Of Devices: 2
Handle 0x0019, DMI type 17, 34 bytes
Memory Device
Array Handle: 0x0018
Total Width: 64 bits
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: Bottom-Slot 1(top)
Bank Locator: BANK 0
Type: DDR3
Type Detail: Synchronous
Speed: 1600 MT/s
Manufacturer: Hynix/Hyundai
Serial Number: 441F2E7B
Asset Tag: 9876543210
Part Number: HMT41GS6MFR8C-PB
Rank: Unknown
Configured Memory Speed: Unknown
Handle 0x001B, DMI type 17, 34 bytes
Memory Device
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: Bottom-Slot 2(under)
Bank Locator: BANK 2
Type: DDR3
Speed: 1600 MT/s
Serial Number: 2C26F9EE
Part Number: 9905428-186.A00G
Rank: Unknown
Veo que tengo dos dimms de 8GB
Yo siento decirte que lo más probable es que tengas un slot estropeado o que un módulo de memoria sea defectuoso. Ya ha habido otros usuarios con problemas parecidos y siempre es lo mismo.
Puedes ver información sobre la memoria detectada con:
sudo inxi -m
sudo dmidecode --type Memory
tengo entendido que si las detecta
sudo inxi -m
RAM: total: 3.29 GiB used: 1.49 GiB (45.2%)
Array-1: capacity: 8 GiB slots: 2 EC: None
Device-1: DIMM 0 size: 4 GiB speed: 1334 MT/s
Device-2: DIMM 1 size: 4 GiB speed: 1600 MT/s
# dmidecode 3.2
SMBIOS 2.7 present.
Handle 0x0020, DMI type 16, 23 bytes
Use: System Memory
Maximum Capacity: 8 GB
Error Information Handle: 0x0029
Handle 0x0021, DMI type 17, 34 bytes
Memory Device
Array Handle: 0x0020
Error Information Handle: 0x0023
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: DIMM 0
Bank Locator: CHANNEL A
Type: DDR3
Type Detail: Synchronous Unbuffered (Unregistered)
Speed: 1334 MT/s
Manufacturer: Not Specified
Serial Number: 5B29D950
Asset Tag: Asset Tag:
Part Number: HMT351S6BFR8C-H9
Rank: 2
Configured Memory Speed: 1334 MT/s
Handle 0x0022, DMI type 6, 12 bytes
Memory Module Information
Socket Designation: DIMM 0
Bank Connections: None
Current Speed: Unknown
Type: DIMM
Installed Size: 4096 MB (Single-bank Connection)
Enabled Size: 4096 MB (Single-bank Connection)
Error Status: OK
Handle 0x0025, DMI type 17, 34 bytes
Memory Device
Error Information Handle: 0x0027
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: DIMM 1
Type: DDR3
Speed: 1600 MT/s
Manufacturer: Samsung
Serial Number: E150025F
Part Number: M471B5273CH0-YK0
Rank: 2
Handle 0x0026, DMI type 6, 12 bytes
Socket Designation: DIMM 1
Type: DIMM
Error Status: OK
Handle 0x002B, DMI type 5, 20 bytes
Memory Controller Information
Error Detecting Method: None
Error Correcting Capabilities:
None
Supported Interleave: One-way Interleave
Current Interleave: One-way Interleave
Maximum Memory Module Size: 8192 MB
Maximum Total Memory Size: 16384 MB
Supported Speeds:
Other
Unknown
70 ns
60 ns
50 ns
Supported Memory Types:
Other
Unknown
Standard
FPM
SIMM
Burst EDO
Memory Module Voltage: 3.3 V
Associated Memory Slots: 2
0x0022
0x0026
Enabled Error Correcting Capabilities:
None
Single-bit Error Correcting
Double-bit Error Correcting
Error Scrubbing
Haz un test de memoria con memtest86+ o alguna utilidad similar
También pudieras darle mtto, probar otro modulo de memoria en el slot, por cierto al encender la maquina no hace un pitido largo esto lo hace la placa base cuando existe un modulo defectuoso por ejemplo
opte por hacerle mantenimiento limpiando los módulos y los slots, después de ello la computadora me detecto los módulos de ram, pero igual presiento que algo terminara fallando muchas gracias por sus respuestas marco como solucionado.
JoZ3
9 October 2020 03:23
8
Por pura casualidad ¿qué marca es la motherboard?
