hello
I was trying to update the system but had some python conflicts. couldn’t run the update because of those. I uninstalled them manually and then managed to run the update. after the update i realised i didn’t have icons and the right click doesn’t work. i also have no icons in the tray and cant minimise or maximise, that whole menu is also missing.
I manually re-installed the python files i removed. ran an update and everything is up to date but still hasn’t fixed the issue.
Thank you.
hello I’ve had the same thing happen to me. I was trying to update the system but had some python conflicts. couldn’t run the update because of those. I uninstalled them manually and then managed to run the update. after the update i realised i did’nt have icons and the right click doesn’t work. i also have no icons in the tray and cant minimise or maximise, that whole menu is also missing.
I manually re-installed the python files i removed. ran an update and everything is up to date but no icons etc.
Mod. note: moved to existing thread
what i tried deleting
python dbus
python2-incremental
with these command
sudo pacman -Syu python2-incremental
sudo pacman -Syu python dbus
this is history from pacman
[2021-06-08T13:29:45+0100] [ALPM] removed python2-attrs (20.3.0-1)
[2021-06-08T13:29:45+0100] [ALPM] removed python2-automat (20.2.0-2)
[2021-06-08T13:29:45+0100] [ALPM] removed python2-constantly (15.1.0-6)
[2021-06-08T13:29:45+0100] [ALPM] removed python2-typing (3.7.4.3-1)
[2021-06-08T13:29:45+0100] [ALPM] removed python2-hyperlink (20.0.1-1)
[2021-06-08T13:29:45+0100] [ALPM] removed python2-pyhamcrest (1.9.0-5)
[2021-06-08T13:29:45+0100] [ALPM] removed python2-zope-interface (5.2.0-1)
[2021-06-08T13:29:44+0100] [ALPM] removed python2-twisted (20.3.0-1)
[2021-06-08T13:29:44+0100] [ALPM] removed python2-click (7.1.2-1)
[2021-06-08T13:29:44+0100] [ALPM] removed python2-incremental (17.5.0-4)
(this is me re-stalling wht i think i deleted and also trying re-install my desktop and also trying install cinnamon)
[2021-06-08T16:30:51+0100] [ALPM] installed cinnamon-desktop (4.8.1-1)
[2021-06-08T16:03:23+0100] [ALPM] reinstalled xfdesktop-gtk3 (2019.08.15-1)
[2021-06-08T16:02:51+0100] [ALPM] reinstalled xfdesktop (4.16.0-1)
[2021-06-08T15:59:50+0100] [ALPM] installed xfwm4-themes (4.10.0-4)
[2021-06-08T15:53:53+0100] [ALPM] reinstalled xfdesktop-gtk3 (2019.08.15-1)
[2021-06-08T15:53:34+0100] [ALPM] reinstalled xfdesktop (4.16.0-1)
[2021-06-08T15:53:15+0100] [ALPM] reinstalled xfdesktop (4.16.0-1)
[2021-06-08T15:04:40+0100] [ALPM] reinstalled dbus-python (1.2.16-4)
[2021-06-08T14:55:32+0100] [ALPM] reinstalled python2 (2.7.18-3)
[2021-06-08T14:55:31+0100] [ALPM] reinstalled dbus-python (1.2.16-4)
[2021-06-08T14:55:31+0100] [ALPM] reinstalled glib2 (2.68.2-1)
(this is updating again but updating individual python udates. Because of initial problem of sytem not updating because of conflicts)
[2021-06-08T14:27:54+0100] [ALPM] installed python-sip4 (4.19.25-1)
[2021-06-08T14:27:54+0100] [ALPM] removed python-sip (4.19.24-2)
[2021-06-08T14:20:00+0100] [ALPM] installed python-pyqt5-webengine (5.15.4-1)
[2021-06-08T14:20:00+0100] [ALPM] removed python-pyqtwebengine (5.15.2-1)
this is the sytem updating after i removed python2
[2021-06-08T13:58:39+0100] [ALPM] upgraded yelp (3.38.2-1 -> 40.0-1)
[2021-06-08T13:58:37+0100] [ALPM] upgraded yelp-xsl (3.38.2-1 -> 40.0-1)
[2021-06-08T13:58:36+0100] [ALPM] upgraded xine-lib (1.2.10-5 -> 1.2.11-4)
[2021-06-08T13:58:34+0100] [ALPM] upgraded xfwm4 (4.14.6-1 -> 4.16.1-1)
[2021-06-08T13:58:32+0100] [ALPM] upgraded xfdesktop (4.14.3-1 -> 4.16.0-1)
[2021-06-08T13:58:31+0100] [ALPM] upgraded xfce4-xkb-plugin (0.8.1-3 -> 0.8.2-1)
[2021-06-08T13:58:30+0100] [ALPM] upgraded xfce4-whiskermenu-plugin (2.4.6-1 -> 2.5.3-1)
[2021-06-08T13:58:30+0100] [ALPM] upgraded xfce4-weather-plugin (0.10.2-1 -> 0.11.0-1)
[2021-06-08T13:58:30+0100] [ALPM] upgraded xfce4-wavelan-plugin (0.6.1-2 -> 0.6.2-1)
[2021-06-08T13:58:30+0100] [ALPM] upgraded xfce4-verve-plugin (2.0.0-2 -> 2.0.1-1)
[2021-06-08T13:58:30+0100] [ALPM] upgraded xfce4-time-out-plugin (1.1.1-1 -> 1.1.2-1)
[2021-06-08T13:58:30+0100] [ALPM] upgraded xfce4-terminal (0.8.9.2-2 -> 0.8.10-1)
[2021-06-08T13:58:29+0100] [ALPM] upgraded xfce4-taskmanager (1.2.3-1 -> 1.4.2-1)
[2021-06-08T13:58:29+0100] [ALPM] upgraded xfce4-systemload-plugin (1.2.3-2 -> 1.3.1-1)
[2021-06-08T13:58:29+0100] [ALPM] upgraded xfce4-smartbookmark-plugin (0.5.1-2 -> 0.5.2-1)
[2021-06-08T13:58:29+0100] [ALPM] upgraded xfce4-settings (4.14.3-1 -> 4.16.1-2)
[2021-06-08T13:58:29+0100] [ALPM] upgraded xfce4-session (4.14.2-2 -> 4.16.0-1)
[2021-06-08T13:58:29+0100] [ALPM] upgraded xfce4-sensors-plugin (1.3.92-2 -> 1.3.95-1)
[2021-06-08T13:58:29+0100] [ALPM] upgraded xfce4-screenshooter (1.9.7-2 -> 1.9.9-2)
[2021-06-08T13:58:29+0100] [ALPM] upgraded xfce4-power-manager (1.6.6-1 -> 4.16.0-2)
[2021-06-08T13:58:29+0100] [ALPM] upgraded xfce4-notes-plugin (1.8.1-5 -> 1.9.0-1)
[2021-06-08T13:58:28+0100] [ALPM] upgraded xfce4-netload-plugin (1.3.2-2 -> 1.4.0-1)
[2021-06-08T13:58:28+0100] [ALPM] upgraded xfce4-mount-plugin (1.1.3-2 -> 1.1.5-1)
[2021-06-08T13:58:28+0100] [ALPM] upgraded xfce4-genmon-plugin (4.0.2-2 -> 4.1.1-1)
[2021-06-08T13:58:28+0100] [ALPM] upgraded xfce4-fsguard-plugin (1.1.1-2 -> 1.1.2-1)
[2021-06-08T13:58:28+0100] [ALPM] upgraded xfce4-diskperf-plugin (2.6.2-2 -> 2.6.3-1)
[2021-06-08T13:58:28+0100] [ALPM] upgraded xfce4-cpugraph-plugin (1.1.0-2 -> 1.2.3-1)
[2021-06-08T13:58:28+0100] [ALPM] upgraded xfce4-cpufreq-plugin (1.2.2-1 -> 1.2.5-1)
[2021-06-08T13:58:28+0100] [ALPM] upgraded xfce4-clipman-plugin (1.6.1-1 -> 1.6.2-1)
[2021-06-08T13:58:28+0100] [ALPM] upgraded xfce4-battery-plugin (1.1.3-2 -> 1.1.4-1)
[2021-06-08T13:58:28+0100] [ALPM] upgraded xfce4-panel (4.14.4-1 -> 4.16.3-1)
[2021-06-08T13:58:28+0100] [ALPM] upgraded xfce4-appfinder (4.14.0-2 -> 4.16.1-1)
[2021-06-08T13:58:28+0100] [ALPM] upgraded xf86-video-nouveau (1.0.16-2 -> 1.0.17-1)
[2021-06-08T13:58:28+0100] [ALPM] upgraded xf86-video-intel (1:2.99.917+913+g9236c582-1 -> 1:2.99.917+916+g31486f40-1)
[2021-06-08T13:58:27+0100] [ALPM] upgraded wxgtk2 (3.0.5.1-1 -> 3.0.5.1-2)
[2021-06-08T13:58:27+0100] [ALPM] upgraded wxgtk-common (3.0.5.1-1 -> 3.0.5.1-2)
[2021-06-08T13:58:27+0100] [ALPM] upgraded wine (5.22-1 -> 6.9-1)
[2021-06-08T13:58:05+0100] [ALPM] upgraded wget (1.20.3-3 -> 1.21.1-1)
[2021-06-08T13:58:05+0100] [ALPM] upgraded vulkan-radeon (20.2.3-1 -> 21.1.2-0)
[2021-06-08T13:58:04+0100] [ALPM] upgraded vulkan-intel (20.2.3-1 -> 21.1.2-0)
[2021-06-08T13:58:03+0100] [ALPM] upgraded vlc (3.0.11.1-6 -> 3.0.14-1)
[2021-06-08T13:58:01+0100] [ALPM] upgraded vi (1:070224-4 -> 1:070224-5)
[2021-06-08T13:58:01+0100] [ALPM] upgraded vala (0.50.2-1 -> 0.52.3-1)
[2021-06-08T13:58:01+0100] [ALPM] upgraded unrar (1:6.0.2-1 -> 1:6.0.6-1)
[2021-06-08T13:58:01+0100] [ALPM] upgraded udiskie (2.2.0-2 -> 2.3.3-1)
[2021-06-08T13:58:01+0100] [ALPM] upgraded tumbler (0.2.9-2 -> 4.16.0-2)
[2021-06-08T13:58:01+0100] [ALPM] warning: /etc/xdg/tumbler/tumbler.rc installed as /etc/xdg/tumbler/tumbler.rc.pacnew
[2021-06-08T13:58:01+0100] [ALPM] upgraded ttf-inconsolata (1:3.000-2 -> 1:3.000-3)
[2021-06-08T13:58:00+0100] [ALPM] upgraded tracker3 (3.0.1-1 -> 3.1.1-2)
[2021-06-08T13:57:59+0100] [ALPM] upgraded tk (8.6.10-2 -> 8.6.11.1-1)
[2021-06-08T13:57:58+0100] [ALPM] upgraded thunar-volman (0.9.5-3 -> 4.16.0-1)
[2021-06-08T13:57:58+0100] [ALPM] upgraded thunar (1.8.16-1 -> 4.16.8-1)
[2021-06-08T13:57:58+0100] [ALPM] upgraded texlive-core (2020.55416-1 -> 2021.58710-2)
[2021-06-08T13:57:31+0100] [ALPM] upgraded texlive-bin (2020.54586-6 -> 2021.58686-3)
[2021-06-08T13:57:26+0100] [ALPM] upgraded zziplib (0.13.71-1 -> 0.13.72-1)
[2021-06-08T13:57:26+0100] [ALPM] upgraded terminus-font (4.48-3 -> 4.49.1-2)
[2021-06-08T13:57:25+0100] [ALPM] upgraded tcl (8.6.10-2 -> 8.6.11-1)
[2021-06-08T13:57:25+0100] [ALPM] upgraded systemd-sysvcompat (246.6-1 -> 247.7-1)
[2021-06-08T13:57:25+0100] [ALPM] upgraded system-config-printer (1.5.13-3 -> 1.5.15-1)
[2021-06-08T13:57:24+0100] [ALPM] upgraded sudo (1.9.3.p1-1 -> 1.9.7-1)
[2021-06-08T13:57:24+0100] [ALPM] upgraded subversion (1.14.0-2 -> 1.14.1-3)
[2021-06-08T13:57:24+0100] [ALPM] upgraded steam-manjaro (1.0.0.67-1 -> 1.0.0.70-1)
[2021-06-08T13:57:23+0100] [ALPM] upgraded spectre-meltdown-checker (0.43-1 -> 0.44-1)
[2021-06-08T13:57:23+0100] [ALPM] upgraded source-highlight (3.1.9-2 -> 3.1.9-4)
[2021-06-08T13:57:22+0100] [ALPM] upgraded simplescreenrecorder (0.4.2-1 -> 0.4.3-1)
[2021-06-08T13:57:21+0100] [ALPM] upgraded samba (4.13.2-1 -> 4.14.4-1)
[2021-06-08T13:57:16+0100] [ALPM] upgraded s-nail (14.9.19-2 -> 14.9.22-1)
[2021-06-08T13:57:16+0100] [ALPM] upgraded rsync (3.2.3-1 -> 3.2.3-3)
[2021-06-08T13:57:15+0100] [ALPM] upgraded recordmydesktop (0.3.8.1-9 -> 0.4.0-1)
[2021-06-08T13:57:15+0100] [ALPM] upgraded qt5-webkit (5.212.0alpha4-8 -> 5.212.0alpha4-10)
[2021-06-08T13:57:12+0100] [ALPM] upgraded python2-pyxdg (0.26-6 -> 0.27-1)
[2021-06-08T13:57:11+0100] [ALPM] upgraded python2-pyopenssl (19.1.0-2 -> 20.0.1-1)
[2021-06-08T13:57:11+0100] [ALPM] upgraded python2-pexpect (4.8.0-1 -> 4.8.0-3)
[2021-06-08T13:57:11+0100] [ALPM] upgraded python2-ptyprocess (0.6.0-4 -> 0.7.0-1)
[2021-06-08T13:57:10+0100] [ALPM] upgraded python2-gobject2 (2.28.7-6 -> 2.28.7-6.1)
[2021-06-08T13:57:10+0100] [ALPM] upgraded python2-cryptography (3.2.1-1 -> 3.3.2-1)
[2021-06-08T13:57:10+0100] [ALPM] upgraded python2-idna (2.10-1 -> 2.10-4)
[2021-06-08T13:57:10+0100] [ALPM] upgraded python2-chardet (3.0.4-5 -> 4.0.0-2)
[2021-06-08T13:57:09+0100] [ALPM] upgraded python2-packaging (20.4-1 -> 20.9-1)
[2021-06-08T13:57:09+0100] [ALPM] upgraded python2-pyparsing (2.4.7-1 -> 2.4.7-3)
[2021-06-08T13:57:09+0100] [ALPM] upgraded python2-six (1.15.0-1 -> 1.16.0-1)
[2021-06-08T13:57:08+0100] [ALPM] upgraded python2-cffi (1.14.3-1 -> 1.14.5-1)
[2021-06-08T13:57:08+0100] [ALPM] upgraded python2-pycparser (2.20-1 -> 2.20-3)
[2021-06-08T13:57:07+0100] [ALPM] upgraded python2-ply (3.11-5 -> 3.11-7)
[2021-06-08T13:57:07+0100] [ALPM] upgraded python2-asn1crypto (1.4.0-1 -> 1.4.0-3)
[2021-06-08T13:57:07+0100] [ALPM] upgraded python2-appdirs (1.4.4-1 -> 1.4.4-3)
[2021-06-08T13:57:06+0100] [ALPM] upgraded python2 (2.7.18-2 -> 2.7.18-3)
[2021-06-08T13:57:01+0100] [ALPM] upgraded python-yaml (5.3.1-2 -> 5.4.1.1-2)
[2021-06-08T13:57:01+0100] [ALPM] upgraded python-reportlab (3.5.55-1 -> 3.5.67-1)
[2021-06-08T13:57:01+0100] [ALPM] upgraded python-pytoml (0.1.21-4 -> 0.1.21-6)
[2021-06-08T13:57:01+0100] [ALPM] upgraded python-pyhamcrest (1.9.0-5 -> 1.10.0-1)
[2021-06-08T13:57:01+0100] [ALPM] upgraded python-pycurl (7.43.0.6-1 -> 7.43.0.6-4)
[2021-06-08T13:57:01+0100] [ALPM] upgraded python-pycups (2.0.1-1 -> 2.0.1-3)
[2021-06-08T13:57:01+0100] [ALPM] upgraded python-pip (20.2-1 -> 20.3.1-1)
[2021-06-08T13:57:00+0100] [ALPM] upgraded python-resolvelib (0.5.1-1 -> 0.5.4-1)
[2021-06-08T13:57:00+0100] [ALPM] upgraded python-retrying (1.3.3-7 -> 1.3.3-9)
[2021-06-08T13:57:00+0100] [ALPM] upgraded python-progress (1.5-3 -> 1.5-5)
[2021-06-08T13:57:00+0100] [ALPM] upgraded python-pep517 (0.9.1-1 -> 0.10.0-2)
[2021-06-08T13:57:00+0100] [ALPM] upgraded python-toml (0.10.2-1 -> 0.10.2-3)
[2021-06-08T13:57:00+0100] [ALPM] upgraded python-numpy (1.19.4-1 -> 1.20.3-1)
[2021-06-08T13:56:57+0100] [ALPM] upgraded python-more-itertools (8.6.0-1 -> 8.7.0-1)
[2021-06-08T13:56:57+0100] [ALPM] upgraded python-lockfile (0.12.2-6 -> 0.12.2-8)
[2021-06-08T13:56:57+0100] [ALPM] upgraded python-keyutils (0.6-4 -> 0.6-6)
[2021-06-08T13:56:57+0100] [ALPM] upgraded python-jade-application-kit (3.5.6-2 -> 3.5.6-3)
[2021-06-08T13:56:57+0100] [ALPM] upgraded python-importlib-metadata (2.0.0-1 -> 4.0.1-1)
[2021-06-08T13:56:57+0100] [ALPM] upgraded python-zipp (3.4.0-1 -> 3.4.1-1)
[2021-06-08T13:56:57+0100] [ALPM] upgraded python-html5lib (1.1-4 -> 1.1-6)
[2021-06-08T13:56:57+0100] [ALPM] upgraded python-webencodings (0.5.1-4 -> 0.5.1-6)
[2021-06-08T13:56:57+0100] [ALPM] upgraded python-docopt (0.6.2-7 -> 0.6.2-9)
[2021-06-08T13:56:56+0100] [ALPM] upgraded python-distlib (0.3.1-1 -> 0.3.1-2)
[2021-06-08T13:56:56+0100] [ALPM] upgraded python-contextlib2 (0.6.0.post1-1 -> 0.6.0.post1-3)
[2021-06-08T13:56:56+0100] [ALPM] upgraded python-colorama (0.4.4-1 -> 0.4.4-3)
[2021-06-08T13:56:56+0100] [ALPM] upgraded python-cachecontrol (0.12.6-1 -> 0.12.6-3)
[2021-06-08T13:56:56+0100] [ALPM] upgraded python-msgpack (1.0.0-1 -> 1.0.2-2)
[2021-06-08T13:56:56+0100] [ALPM] upgraded python-asn1crypto (1.4.0-1 -> 1.4.0-3)
[2021-06-08T13:56:56+0100] [ALPM] upgraded pyside2 (5.15.2-1 -> 5.15.2-3)
[2021-06-08T13:56:53+0100] [ALPM] upgraded python-shiboken2 (5.15.2-1 -> 5.15.2-6)
[2021-06-08T13:56:53+0100] [ALPM] upgraded pstoedit (3.75-2 -> 3.75-4)
[2021-06-08T13:56:53+0100] [ALPM] upgraded powertop (2.13-1 -> 2.14-1)
[2021-06-08T13:56:53+0100] [ALPM] upgraded polkit-gnome (0.105-5 -> 0.105-8)
[2021-06-08T13:56:52+0100] [ALPM] upgraded pidgin (2.14.1-3 -> 2.14.4-2)
[2021-06-08T13:56:52+0100] [ALPM] upgraded perl-xml-libxml (2.0206-1 -> 2.0207-2)
[2021-06-08T13:56:52+0100] [ALPM] upgraded perl-parse-yapp (1.21-3 -> 1.21-4)
[2021-06-08T13:56:52+0100] [ALPM] upgraded perl-file-mimeinfo (0.30-1 -> 0.30-2)
[2021-06-08T13:56:52+0100] [ALPM] upgraded perl-file-desktopentry (0.22-7 -> 0.22-8)
[2021-06-08T13:56:52+0100] [ALPM] upgraded perl-file-basedir (0.08-5 -> 0.08-6)
[2021-06-08T13:56:52+0100] [ALPM] upgraded perl-ipc-system-simple (1.30-2 -> 1.30-3)
[2021-06-08T13:56:52+0100] [ALPM] upgraded perl-dbi (1.643-2 -> 1.643-3)
[2021-06-08T13:56:52+0100] [ALPM] upgraded perl-alien-libxml2 (0.17-1 -> 0.17-2)
[2021-06-08T13:56:52+0100] [ALPM] upgraded perl-alien-build (2.37-1 -> 2.40-3)
[2021-06-08T13:56:52+0100] [ALPM] upgraded perl-path-tiny (0.114-1 -> 0.118-2)
[2021-06-08T13:56:52+0100] [ALPM] upgraded perl-file-which (1.23-4 -> 1.24-2)
[2021-06-08T13:56:52+0100] [ALPM] upgraded perl-ffi-checklib (0.27-2 -> 0.28-2)
[2021-06-08T13:56:52+0100] [ALPM] upgraded perl-capture-tiny (0.48-4 -> 0.48-5)
[2021-06-08T13:56:51+0100] [ALPM] upgraded patchutils (0.4.2-1 -> 0.4.2-2)
[2021-06-08T13:56:51+0100] [ALPM] upgraded p7zip (16.02-6 -> 1:17.04-1)
[2021-06-08T13:56:51+0100] [ALPM] upgraded os-prober (1.77-1 -> 1.78-0.1)
[2021-06-08T13:56:51+0100] [ALPM] upgraded openresolv (3.11.0-1 -> 3.12.0-1)
[2021-06-08T13:56:51+0100] [ALPM] upgraded opencv (4.5.0-1 -> 4.5.2-4)
[2021-06-08T13:56:44+0100] [ALPM] upgraded nfs-utils (2.5.2-2 -> 2.5.3-1)
[2021-06-08T13:56:44+0100] [ALPM] upgraded nfsidmap (2.5.2-2 -> 2.5.3-1)
[2021-06-08T13:56:44+0100] [ALPM] upgraded networkmanager-pptp (1.2.9dev+10+gb41b0d0-2 -> 1.2.9dev+10+gb41b0d0-4)
[2021-06-08T13:56:44+0100] [ALPM] upgraded networkmanager-openvpn (1.8.12-1 -> 1.8.14-1)
[2021-06-08T13:56:43+0100] [ALPM] upgraded openvpn (2.5.0-3 -> 2.5.2-1)
[2021-06-08T13:56:42+0100] [ALPM] upgraded networkmanager-openconnect (1.2.7dev+49+gc512d5a-1 -> 1.2.7dev+65+gca4187c-1)
[2021-06-08T13:56:42+0100] [ALPM] upgraded pcsclite (1.9.0-1 -> 1.9.1-1)
[2021-06-08T13:56:42+0100] [ALPM] upgraded network-manager-applet (1.18.0-1 -> 1.22.0-1)
[2021-06-08T13:56:41+0100] [ALPM] upgraded networkmanager (1.26.4-1 -> 1.30.4-3)
[2021-06-08T13:56:40+0100] [ALPM] upgraded wpa_supplicant (2:2.9-7 -> 2:2.9-8)
[2021-06-08T13:56:40+0100] [ALPM] upgraded nm-connection-editor (1.18.0-1 -> 1.22.0-1)
[2021-06-08T13:56:40+0100] [ALPM] upgraded nano (5.3-1 -> 5.7-1)
[2021-06-08T13:56:39+0100] [ALPM] upgraded mysql-workbench (8.0.22-1 -> 8.0.25-1)
[2021-06-08T13:56:38+0100] [ALPM] upgraded proj (6.3.2-1 -> 8.0.1-1)
[2021-06-08T13:56:38+0100] [ALPM] upgraded mugshot (0.4.2-1 -> 0.4.3-1)
[2021-06-08T13:56:38+0100] [ALPM] upgraded python-distutils-extra (2.39-5 -> 2.39-8)
[2021-06-08T13:56:38+0100] [ALPM] upgraded movit (1.6.3-1 -> 1.6.3-2)
[2021-06-08T13:56:37+0100] [ALPM] upgraded mousepad (0.5.0-1 -> 0.5.5-2)
[2021-06-08T13:56:37+0100] [ALPM] installed gtksourceview4 (4.8.1-1)
[2021-06-08T13:56:37+0100] [ALPM] upgraded modemmanager (1.14.8-1 -> 1.16.4-1)
[2021-06-08T13:56:37+0100] [ALPM] upgraded ppp (2.4.7-7 -> 2.4.9-1)
[2021-06-08T13:56:37+0100] [ALPM] upgraded mobile-broadband-provider-info (20190618-2 -> 20201225-1)
[2021-06-08T13:56:37+0100] [ALPM] upgraded mlt (6.22.1-4 -> 7.0.1-1)
[2021-06-08T13:56:36+0100] [ALPM] upgraded mlocate (0.26.git.20170220-5 -> 0.26.git.20170220-7)
[2021-06-08T13:56:36+0100] [ALPM] upgraded mesa-vdpau (20.2.3-1 -> 21.1.2-0)
[2021-06-08T13:56:35+0100] [ALPM] upgraded menulibre (2.2.1-2 -> 2.2.1-3)
[2021-06-08T13:56:34+0100] [ALPM] upgraded python-psutil (5.7.3-1 -> 5.8.0-1)
[2021-06-08T13:56:33+0100] [ALPM] upgraded matcha-gtk-theme (20201123-1 -> 20210602-0.1)
[2021-06-08T13:56:27+0100] [ALPM] upgraded mariadb (10.5.8-1 -> 10.5.10-1)
[2021-06-08T13:56:18+0100] [ALPM] upgraded mariadb-clients (10.5.8-1 -> 10.5.10-1)
[2021-06-08T13:56:17+0100] [ALPM] upgraded mariadb-libs (10.5.8-1 -> 10.5.10-1)
[2021-06-08T13:56:15+0100] [ALPM] upgraded manjaro-settings-manager-notifier (0.5.6-10 -> 0.5.6-14)
[2021-06-08T13:56:15+0100] [ALPM] upgraded manjaro-settings-manager (0.5.6-10 -> 0.5.6-14)
[2021-06-08T13:56:14+0100] [ALPM] upgraded manjaro-release (20.2-1 -> 21.0.6-1)
[2021-06-08T13:56:14+0100] [ALPM] upgraded manjaro-pulse (20200126-1 -> 20210109-1)
[2021-06-08T13:56:14+0100] [ALPM] upgraded pulseaudio-bluetooth (14.0-1 -> 14.2-3)
[2021-06-08T13:56:14+0100] [ALPM] upgraded pulseaudio-equalizer (14.0-1 -> 14.2-3)
[2021-06-08T13:56:14+0100] [ALPM] upgraded python-pyqt5 (5.15.2-1 -> 5.15.4-1)
[2021-06-08T13:56:12+0100] [ALPM] upgraded python-pyqt5-sip (12.8.1-1 -> 12.9.0-1)
[2021-06-08T13:56:12+0100] [ALPM] installed pulseaudio-rtp (14.2-3)
[2021-06-08T13:56:12+0100] [ALPM] upgraded pulseaudio-lirc (14.0-1 -> 14.2-3)
[2021-06-08T13:56:12+0100] [ALPM] upgraded pulseaudio-zeroconf (14.0-1 -> 14.2-3)
[2021-06-08T13:56:12+0100] [ALPM] upgraded pulseaudio-jack (14.0-1 -> 14.2-3)
[2021-06-08T13:56:11+0100] [ALPM] installed sof-firmware (1.7-2)
[2021-06-08T13:56:11+0100] [ALPM] upgraded pulseaudio (14.0-1 -> 14.2-3)
[2021-06-08T13:56:11+0100] [ALPM] upgraded manjaro-hello (0.6.6-3 -> 0.6.6-5)
[2021-06-08T13:56:10+0100] [ALPM] upgraded pamac-gtk (10.0.0-1 -> 10.0.6-2)
[2021-06-08T13:56:10+0100] [ALPM] upgraded manjaro-application-utility (1.3.3-2 -> 1.3.3-4.1)
[2021-06-08T13:56:10+0100] [ALPM] upgraded pamac-cli (10.0.0-1 -> 10.0.6-2)
[2021-06-08T13:56:10+0100] [ALPM] upgraded pamac-common (10.0.0-1 -> 10.0.6-2)
[2021-06-08T13:56:09+0100] [ALPM] upgraded vte3 (0.62.1-1 -> 0.64.1-1)
[2021-06-08T13:56:09+0100] [ALPM] upgraded vte-common (0.62.1-1 -> 0.64.1-1)
[2021-06-08T13:56:09+0100] [ALPM] upgraded manjaro-alsa (20200126-1 -> 20210109-1)
[2021-06-08T13:56:09+0100] [ALPM] upgraded man-pages (5.09-2 -> 5.11-1)
[2021-06-08T13:56:08+0100] [ALPM] upgraded man-db (2.9.3-1 -> 2.9.4-1)
[2021-06-08T13:56:08+0100] [ALPM] upgraded lv2 (1.18.0-1 -> 1.18.2-1)
[2021-06-08T13:56:08+0100] [ALPM] upgraded lua (5.4.1-1 -> 5.4.3-1)
[2021-06-08T13:56:08+0100] [ALPM] upgraded logrotate (3.17.0-1 -> 3.18.0-1)
[2021-06-08T13:55:57+0100] [ALPM] upgraded linux419-r8168 (8.048.03-37 -> 8.048.03-70)
[2021-06-08T13:55:57+0100] [ALPM] upgraded linux419 (4.19.160-1 -> 4.19.192-1)
[2021-06-08T13:55:36+0100] [ALPM] upgraded linux414-r8168 (8.048.03-28 -> 8.048.03-54)
[2021-06-08T13:55:36+0100] [ALPM] upgraded linux414 (4.14.209-1 -> 4.14.234-1)
[2021-06-08T13:55:30+0100] [ALPM] upgraded mkinitcpio-busybox (1.31.1-2 -> 1.32.1-3)
[2021-06-08T13:55:30+0100] [ALPM] upgraded linux-firmware (20201124.r1786.b362fd4-1 -> 20210518.r1928.f846292-1)
[2021-06-08T13:55:03+0100] [ALPM] upgraded lightdm-gtk-greeter-settings (1.2.2-4 -> 1.2.2-5)
[2021-06-08T13:55:03+0100] [ALPM] upgraded light-locker (1.9.0-2 -> 1.9.0-4)
[2021-06-08T13:55:02+0100] [ALPM] upgraded libwnck3 (3.36.0-1 -> 40.0-1)
[2021-06-08T13:55:02+0100] [ALPM] upgraded libvoikko (4.3-2 -> 4.3.1-1)
[2021-06-08T13:55:02+0100] [ALPM] upgraded libva-vdpau-driver (0.7.4-4 -> 0.7.4-5)
[2021-06-08T13:55:02+0100] [ALPM] upgraded libva-mesa-driver (20.2.3-1 -> 21.1.2-0)
[2021-06-08T13:55:02+0100] [ALPM] upgraded libutf8proc (2.5.0-2 -> 2.6.1-1)
[2021-06-08T13:55:02+0100] [ALPM] upgraded liburing (0.7-2 -> 2.0-1)
[2021-06-08T13:55:02+0100] [ALPM] upgraded libupnp (1.14.0-1 -> 1.14.7-1)
[2021-06-08T13:55:02+0100] [ALPM] upgraded libteam (1.31-1 -> 1.31-3)
[2021-06-08T13:55:02+0100] [ALPM] upgraded zeromq (4.3.3-2 -> 4.3.4-1)
[2021-06-08T13:55:02+0100] [ALPM] upgraded libsynctex (2020.54586-6 -> 2021.58686-3)
[2021-06-08T13:55:02+0100] [ALPM] upgraded libsigsegv (2.12-2 -> 2.13-1)
[2021-06-08T13:55:02+0100] [ALPM] upgraded libreoffice-still (6.4.7-2 -> 7.0.6-1)
[2021-06-08T13:54:41+0100] [ALPM] upgraded libzmf (0.0.2-8 -> 0.0.2-10)
[2021-06-08T13:54:40+0100] [ALPM] upgraded libvisio (0.1.7-3 -> 0.1.7-5)
[2021-06-08T13:54:39+0100] [ALPM] upgraded lpsolve (5.5.2.5-4 -> 5.5.2.11-1)
[2021-06-08T13:54:38+0100] [ALPM] upgraded libqxp (0.0.2-4 -> 0.0.2-6)
[2021-06-08T13:54:37+0100] [ALPM] upgraded libquicktime (1.2.4-23 -> 1.2.4-24)
[2021-06-08T13:54:37+0100] [ALPM] upgraded libqmi (1.26.6-1 -> 1.28.4-1)
[2021-06-08T13:54:37+0100] [ALPM] installed libqrtr-glib (1.0.0-1)
[2021-06-08T13:54:37+0100] [ALPM] upgraded libpurple (2.14.1-3 -> 2.14.4-2)
[2021-06-08T13:54:36+0100] [ALPM] upgraded protobuf-c (1.3.3-2 -> 1.3.3-4)
[2021-06-08T13:54:35+0100] [ALPM] upgraded libplacebo (2.72.2-1 -> 3.120.3-1)
[2021-06-08T13:54:35+0100] [ALPM] upgraded shaderc (2020.3-1 -> 2021.0-1)
[2021-06-08T13:54:35+0100] [ALPM] upgraded spirv-tools (2020.4-1 -> 2021.1-1)
[2021-06-08T13:54:35+0100] [ALPM] upgraded liborcus (0.16.1-1 -> 0.16.1-6)
[2021-06-08T13:54:35+0100] [ALPM] upgraded libopenraw (0.2.3-2 -> 0.3.0-1)
[2021-06-08T13:54:35+0100] [ALPM] upgraded libodfgen (0.1.7-2 -> 0.1.8-1)
[2021-06-08T13:54:35+0100] [ALPM] upgraded libnumbertext (1.0.6-1 -> 1.0.7-1)
[2021-06-08T13:54:35+0100] [ALPM] upgraded libnewt (0.52.21-4 -> 0.52.21-5)
[2021-06-08T13:54:35+0100] [ALPM] upgraded libndp (1.7-2 -> 1.8-1)
[2021-06-08T13:54:35+0100] [ALPM] upgraded libmwaw (0.3.17-1 -> 0.3.19-1)
[2021-06-08T13:54:34+0100] [ALPM] upgraded libmspub (0.1.4-8 -> 0.1.4-10)
[2021-06-08T13:54:34+0100] [ALPM] upgraded libmp4v2 (4.1.3-1 -> 4.1.6-1)
[2021-06-08T13:54:34+0100] [ALPM] upgraded libmbim (1.24.4-1 -> 1.24.6-1)
[2021-06-08T13:54:34+0100] [ALPM] upgraded libmatroska (1.6.2-1 -> 1.6.3-1)
[2021-06-08T13:54:34+0100] [ALPM] upgraded libixion (0.16.1-1 -> 0.16.1-5)
[2021-06-08T13:54:34+0100] [ALPM] upgraded libiodbc (3.52.13-2 -> 3.52.14-1)
[2021-06-08T13:54:34+0100] [ALPM] upgraded libglade (2.6.4-7 -> 2.6.4-8)
[2021-06-08T13:54:33+0100] [ALPM] upgraded libfbclient (3.0.6.33328-1 -> 3.0.7.33374-1)
[2021-06-08T13:54:33+0100] [ALPM] upgraded libetonyek (0.1.9-2 -> 0.1.10-1)
[2021-06-08T13:54:33+0100] [ALPM] upgraded libebml (1.4.0-1 -> 1.4.2-1)
[2021-06-08T13:54:33+0100] [ALPM] upgraded libe-book (0.1.3-7 -> 0.1.3-9)
[2021-06-08T13:54:31+0100] [ALPM] upgraded libdvdcss (1.4.2-2 -> 1.4.3-1)
[2021-06-08T13:54:31+0100] [ALPM] upgraded libcmis (0.5.2-4 -> 0.5.2-7)
[2021-06-08T13:54:30+0100] [ALPM] upgraded libcdr (0.1.6-2 -> 0.1.7-2)
[2021-06-08T13:54:29+0100] [ALPM] upgraded libwpd (0.10.3-2 -> 0.10.3-3)
[2021-06-08T13:54:28+0100] [ALPM] upgraded lib32-vulkan-radeon (20.2.3-1 -> 21.1.2-0)
[2021-06-08T13:54:28+0100] [ALPM] upgraded lib32-vulkan-intel (20.2.3-1 -> 21.1.2-0)
[2021-06-08T13:54:25+0100] [ALPM] upgraded lib32-simplescreenrecorder (0.4.2-1 -> 0.4.3-1)
[2021-06-08T13:54:25+0100] [ALPM] upgraded lib32-openal (1.21.0-1 -> 1.21.1-1)
[2021-06-08T13:54:25+0100] [ALPM] upgraded lib32-nss (3.59-1 -> 3.66-1)
[2021-06-08T13:54:25+0100] [ALPM] upgraded lib32-nspr (4.29-1 -> 4.31-1)
[2021-06-08T13:54:24+0100] [ALPM] upgraded lib32-mesa-vdpau (20.2.3-1 -> 21.1.2-0)
[2021-06-08T13:54:24+0100] [ALPM] upgraded lib32-lz4 (1.9.2-1 -> 1.9.3-1)
[2021-06-08T13:54:24+0100] [ALPM] upgraded lib32-libxt (1.2.0-1 -> 1.2.1-1)
[2021-06-08T13:54:24+0100] [ALPM] upgraded lib32-libva-mesa-driver (20.2.3-1 -> 21.1.2-0)
[2021-06-08T13:54:24+0100] [ALPM] upgraded lib32-libva (2.8.0-1 -> 2.11.0-1)
[2021-06-08T13:54:24+0100] [ALPM] upgraded lib32-libsamplerate (0.1.9-3 -> 0.2.1-1)
[2021-06-08T13:54:24+0100] [ALPM] upgraded lib32-libpcap (1.9.1-2 -> 1.10.0-1)
[2021-06-08T13:54:24+0100] [ALPM] upgraded lib32-libidn (1.36-1 -> 1.37-1)
[2021-06-08T13:54:23+0100] [ALPM] upgraded lib32-gtk2 (2.24.32-2 -> 2.24.33-1)
[2021-06-08T13:54:23+0100] [ALPM] upgraded lib32-gstreamer (1.16.2-1 -> 1.18.4-1)
[2021-06-08T13:54:23+0100] [ALPM] upgraded lib32-gtk3 (3.24.23-1 -> 3.24.29-1)
[2021-06-08T13:54:23+0100] [ALPM] upgraded lib32-rest (0.8.1-2 -> 0.8.1-3)
[2021-06-08T13:54:23+0100] [ALPM] upgraded lib32-libxkbcommon (1.0.1-2 -> 1.3.0-1)
[2021-06-08T13:54:23+0100] [ALPM] upgraded lib32-librsvg (2.50.2-1 -> 2:2.50.6-1)
[2021-06-08T13:54:22+0100] [ALPM] upgraded lib32-pango (1:1.48.0-1 -> 1:1.48.5-1)
[2021-06-08T13:54:22+0100] [ALPM] upgraded lib32-libdatrie (0.2.12-1 -> 0.2.13-1)
[2021-06-08T13:54:22+0100] [ALPM] upgraded lib32-libepoxy (1.5.4-1 -> 1.5.8-1)
[2021-06-08T13:54:22+0100] [ALPM] upgraded lib32-json-glib (1.6.0-1 -> 1.6.2-1)
[2021-06-08T13:54:22+0100] [ALPM] upgraded lib32-glib-networking (2.66.0-1 -> 2.68.1-1)
[2021-06-08T13:54:22+0100] [ALPM] upgraded lib32-libproxy (0.4.15-2 -> 0.4.17-1)
[2021-06-08T13:54:22+0100] [ALPM] upgraded lib32-gnutls (3.6.15-1 -> 3.7.1-1)
[2021-06-08T13:54:22+0100] [ALPM] upgraded lib32-p11-kit (0.23.21-1 -> 0.23.22-1)
[2021-06-08T13:54:22+0100] [ALPM] upgraded lib32-libtasn1 (4.16.0-1 -> 4.16.0-2)
[2021-06-08T13:54:22+0100] [ALPM] upgraded lib32-nettle (3.6-1 -> 3.7.2-1)
[2021-06-08T13:54:22+0100] [ALPM] upgraded lib32-gmp (6.2.0-1 -> 6.2.1-1)
[2021-06-08T13:54:22+0100] [ALPM] upgraded lib32-gdk-pixbuf2 (2.42.0-2 -> 2.42.6-1)
[2021-06-08T13:54:22+0100] [ALPM] upgraded lib32-fluidsynth (2.1.5-1 -> 2.1.8-1)
[2021-06-08T13:54:22+0100] [ALPM] upgraded lib32-portaudio (1:19.6.0-4 -> 1:19.7.0-1)
[2021-06-08T13:54:22+0100] [ALPM] upgraded lib32-libinstpatch (1.1.5-1 -> 1.1.6-1)
[2021-06-08T13:54:21+0100] [ALPM] upgraded lib32-libpulse (14.0-1 -> 14.2-2)
[2021-06-08T13:54:21+0100] [ALPM] upgraded lib32-libsndfile (1.0.28-3 -> 1.0.31-1)
[2021-06-08T13:54:21+0100] [ALPM] installed lib32-opus (1.3.1-1)
[2021-06-08T13:54:21+0100] [ALPM] upgraded lib32-faudio (20.12-1 -> 21.05-1)
[2021-06-08T13:54:21+0100] [ALPM] upgraded lib32-sdl2 (2.0.12-1 -> 2.0.14-1)
[2021-06-08T13:54:21+0100] [ALPM] upgraded lib32-libglvnd (1.3.2-1 -> 1.3.3-1)
[2021-06-08T13:54:21+0100] [ALPM] upgraded lib32-mesa (20.2.3-1 -> 21.1.2-0)
[2021-06-08T13:54:18+0100] [ALPM] upgraded lib32-vulkan-icd-loader (1.2.158-1 -> 1.2.176-1)
[2021-06-08T13:54:18+0100] [ALPM] upgraded lib32-lm_sensors (3.6.0-1 -> 1:3.6.0.r41.g31d1f125-1)
[2021-06-08T13:54:18+0100] [ALPM] upgraded lib32-llvm-libs (11.0.0-1 -> 11.1.0-1)
[2021-06-08T13:54:17+0100] [ALPM] upgraded lib32-libunwind (1.3.1-1 -> 1.5.0-1)
[2021-06-08T13:54:17+0100] [ALPM] upgraded lib32-libelf (0.181-1 -> 0.184-1)
[2021-06-08T13:54:17+0100] [ALPM] upgraded lib32-wayland (1.18.0-2 -> 1.19.0-1)
[2021-06-08T13:54:17+0100] [ALPM] upgraded lib32-libxml2 (2.9.10-2 -> 2.9.10-4)
[2021-06-08T13:54:17+0100] [ALPM] upgraded lib32-icu (67.1-1 -> 69.1-1)
[2021-06-08T13:54:15+0100] [ALPM] upgraded lib32-readline (8.0.0-1 -> 8.1.001-1)
[2021-06-08T13:54:15+0100] [ALPM] upgraded lib32-libdrm (2.4.103-1 -> 2.4.106-1)
[2021-06-08T13:54:14+0100] [ALPM] upgraded lib32-curl (7.73.0-1 -> 7.77.0-1)
[2021-06-08T13:54:14+0100] [ALPM] upgraded lib32-libidn2 (2.3.0-1 -> 2.3.1-1)
[2021-06-08T13:54:14+0100] [ALPM] upgraded lib32-colord (1.4.5-1 -> 1.4.5-2)
[2021-06-08T13:54:13+0100] [ALPM] upgraded lib32-sqlite (3.33.0-1 -> 3.35.5-1)
[2021-06-08T13:54:13+0100] [ALPM] upgraded lib32-polkit (0.117-1 -> 0.118-1)
[2021-06-08T13:54:13+0100] [ALPM] upgraded lib32-lcms2 (2.11-1 -> 2.12-1)
[2021-06-08T13:54:13+0100] [ALPM] upgraded lib32-libtiff (4.1.0-1 -> 4.3.0-1)
[2021-06-08T13:54:13+0100] [ALPM] upgraded lib32-libjpeg-turbo (2.0.6-1 -> 2.1.0-1)
[2021-06-08T13:54:13+0100] [ALPM] upgraded lib32-libgusb (0.3.5-1 -> 0.3.6-1)
[2021-06-08T13:54:13+0100] [ALPM] upgraded lib32-libusb (1.0.23-2 -> 1.0.24-1)
[2021-06-08T13:54:13+0100] [ALPM] upgraded lib32-libgudev (234-1 -> 236-1)
[2021-06-08T13:54:13+0100] [ALPM] upgraded lib32-dconf (0.38.0-1 -> 0.40.0-1)
[2021-06-08T13:54:13+0100] [ALPM] upgraded lib32-cairo (1.17.2+25+gaee96d175-1 -> 1.17.4-5)
[2021-06-08T13:54:04+0100] [ALPM] upgraded lib32-fontconfig (2:2.13.91+48+gfcb0420-2 -> 2:2.13.93-4)
[2021-06-08T13:54:04+0100] [ALPM] upgraded lib32-harfbuzz (2.7.2-1 -> 2.8.1-1)
[2021-06-08T13:54:04+0100] [ALPM] upgraded lib32-expat (2.2.10-1 -> 2.4.1-1)
[2021-06-08T13:54:04+0100] [ALPM] upgraded lib32-atk (2.36.0-1 -> 2.36.0-2)
[2021-06-08T13:54:04+0100] [ALPM] upgraded lib32-at-spi2-core (2.38.0-1 -> 2.40.1-1)
[2021-06-08T13:54:04+0100] [ALPM] upgraded lib32-libx11 (1.7.0-1 -> 1.7.1-1)
[2021-06-08T13:54:04+0100] [ALPM] upgraded lib32-systemd (246.6-1 -> 247.7-1)
[2021-06-08T13:54:04+0100] [ALPM] upgraded lib32-zstd (1.4.5-1 -> 1.4.9-1)
[2021-06-08T13:54:04+0100] [ALPM] upgraded lib32-xz (5.2.5-1 -> 5.2.5-2)
[2021-06-08T13:54:04+0100] [ALPM] upgraded lib32-libgcrypt (1.8.7-1 -> 1.9.3-1)
[2021-06-08T13:54:04+0100] [ALPM] upgraded lib32-libgpg-error (1.38-1 -> 1.42-1)
[2021-06-08T13:54:04+0100] [ALPM] upgraded lib32-libcap (2.45-1 -> 2.50-1)
[2021-06-08T13:54:04+0100] [ALPM] upgraded lib32-pam (1.4.0-1 -> 1.5.1-1)
[2021-06-08T13:54:04+0100] [ALPM] upgraded lib32-libnsl (1.3.0-1 -> 1.3.0-2)
[2021-06-08T13:54:04+0100] [ALPM] upgraded lib32-libtirpc (1.2.6-1 -> 1.3.1-1)
[2021-06-08T13:54:04+0100] [ALPM] upgraded lib32-krb5 (1.18.2-1 -> 1.19.1-1)
[2021-06-08T13:54:04+0100] [ALPM] upgraded lib32-libldap (2.4.54-1 -> 2.4.58-1)
[2021-06-08T13:54:04+0100] [ALPM] upgraded lib32-openssl (1:1.1.1.h-1 -> 1:1.1.1.k-1)
[2021-06-08T13:54:04+0100] [ALPM] upgraded lib32-e2fsprogs (1.45.6-1 -> 1.46.2-2)
[2021-06-08T13:54:04+0100] [ALPM] upgraded lib32-glib2 (2.66.2-1 -> 2.68.2-1)
[2021-06-08T13:54:04+0100] [ALPM] upgraded lib32-gcc-libs (10.2.0-3 -> 11.1.0-1)
[2021-06-08T13:54:03+0100] [ALPM] upgraded lib32-zlib (1.2.11-2 -> 1.2.11-3)
[2021-06-08T13:54:03+0100] [ALPM] upgraded lib32-util-linux (2.36.1-1 -> 2.36.2-1)
[2021-06-08T13:54:03+0100] [ALPM] upgraded lib32-libxcrypt (4.4.17-1 -> 4.4.20-1)
[2021-06-08T13:54:03+0100] [ALPM] upgraded lib32-acl (2.2.53-1 -> 2.3.1-1)
[2021-06-08T13:54:03+0100] [ALPM] upgraded languagetool (5.1-1 -> 5.3-1)
[2021-06-08T13:53:37+0100] [ALPM] upgraded ksysguard (5.20.4-1 -> 5.21.5-1)
[2021-06-08T13:53:36+0100] [ALPM] upgraded plasma-desktop (5.20.4-1 -> 5.21.5-1)
[2021-06-08T13:53:35+0100] [ALPM] upgraded systemsettings (5.20.4-1 -> 5.21.5-1)
[2021-06-08T13:53:35+0100] [ALPM] upgraded polkit-kde-agent (5.20.4-1 -> 5.21.5-1)
[2021-06-08T13:53:35+0100] [ALPM] upgraded kmenuedit (5.20.4-1 -> 5.21.5-1)
[2021-06-08T13:53:35+0100] [ALPM] upgraded kinit (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:53:35+0100] [ALPM] upgraded khotkeys (5.20.4-1 -> 5.21.5-1)
[2021-06-08T13:53:35+0100] [ALPM] upgraded plasma-workspace (5.20.4-1 -> 5.21.5-1)
[2021-06-08T13:53:26+0100] [ALPM] upgraded kquickcharts (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:53:26+0100] [ALPM] upgraded libkscreen (5.20.4-1 -> 5.21.5-1)
[2021-06-08T13:53:26+0100] [ALPM] upgraded kpeople (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:53:25+0100] [ALPM] upgraded plasma-integration (5.20.4-1 -> 5.21.5-1)
[2021-06-08T13:53:25+0100] [ALPM] upgraded qqc2-desktop-style (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:53:24+0100] [ALPM] upgraded kwin (5.20.4-1 -> 5.21.5-1)
[2021-06-08T13:53:22+0100] [ALPM] upgraded kwayland-server (5.20.4-1 -> 5.21.5-1)
[2021-06-08T13:53:21+0100] [ALPM] upgraded kscreenlocker (5.20.4-1 -> 5.21.5-1)
[2021-06-08T13:53:21+0100] [ALPM] upgraded prison (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:53:21+0100] [ALPM] upgraded milou (5.20.4-1 -> 5.21.5-1)
[2021-06-08T13:53:21+0100] [ALPM] upgraded krunner (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:53:20+0100] [ALPM] upgraded threadweaver (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:53:20+0100] [ALPM] upgraded plasma-framework (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:53:19+0100] [ALPM] upgraded libqalculate (3.15.0-1 -> 3.19.0-1)
[2021-06-08T13:53:18+0100] [ALPM] upgraded ktexteditor (5.76.0-1 -> 5.82.0-2)
[2021-06-08T13:53:18+0100] [ALPM] upgraded syntax-highlighting (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:53:18+0100] [ALPM] upgraded libksysguard (5.20.4-1 -> 5.21.5-1)
[2021-06-08T13:53:17+0100] [ALPM] upgraded libxres (1.2.0-2 -> 1.2.1-1)
[2021-06-08T13:53:17+0100] [ALPM] upgraded kholidays (1:5.76.0-1 -> 1:5.82.0-1)
[2021-06-08T13:53:17+0100] [ALPM] upgraded kdialog (20.08.3-1 -> 21.04.1-1)
[2021-06-08T13:53:17+0100] [ALPM] upgraded kdenlive (20.08.3-1 -> 21.04.1-1)
[2021-06-08T13:53:17+0100] [ALPM] installed mlt6 (6.26.1-4)
[2021-06-08T13:53:16+0100] [ALPM] upgraded libebur128 (1.2.4-3 -> 1.2.6-1)
[2021-06-08T13:53:16+0100] [ALPM] upgraded purpose (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:53:16+0100] [ALPM] upgraded kirigami2 (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:53:16+0100] [ALPM] upgraded knotifyconfig (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:53:16+0100] [ALPM] installed qt5-networkauth (5.15.2-1)
[2021-06-08T13:53:16+0100] [ALPM] upgraded kdelibs4support (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:53:15+0100] [ALPM] upgraded kparts (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:53:15+0100] [ALPM] upgraded kemoticons (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:53:14+0100] [ALPM] upgraded kitemmodels (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:53:12+0100] [ALPM] upgraded kunitconversion (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:53:11+0100] [ALPM] upgraded kde-cli-tools (5.20.4-1 -> 5.21.5-1)
[2021-06-08T13:53:11+0100] [ALPM] upgraded kdesu (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:53:11+0100] [ALPM] upgraded kpty (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:53:10+0100] [ALPM] upgraded kactivitymanagerd (5.20.4-1 -> 5.21.5-1)
[2021-06-08T13:53:10+0100] [ALPM] upgraded kactivities-stats (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:53:10+0100] [ALPM] upgraded kactivities (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:53:10+0100] [ALPM] upgraded kaccounts-integration (20.08.3-1 -> 21.04.1-1)
[2021-06-08T13:53:10+0100] [ALPM] upgraded libaccounts-glib (1.25-1 -> 1.25-3)
[2021-06-08T13:53:10+0100] [ALPM] upgraded qt5-webengine (5.15.2-1 -> 5.15.3-5)
[2021-06-08T13:53:04+0100] [ALPM] upgraded qt5-location (5.15.2-1 -> 5.15.2-3)
[2021-06-08T13:53:03+0100] [ALPM] upgraded signon-kwallet-extension (20.08.3-1 -> 21.04.1-1)
[2021-06-08T13:53:03+0100] [ALPM] upgraded kcmutils (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:53:03+0100] [ALPM] upgraded kdeclarative (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:53:03+0100] [ALPM] upgraded jdk8-openjdk (8.u265-1 -> 8.u292-1)
[2021-06-08T13:53:03+0100] [ALPM] upgraded jre8-openjdk (8.u265-1 -> 8.u292-1)
[2021-06-08T13:53:02+0100] [ALPM] upgraded jre8-openjdk-headless (8.u265-1 -> 8.u292-1)
[2021-06-08T13:52:54+0100] [ALPM] upgraded iputils (20200821-1 -> 20210202-1)
[2021-06-08T13:52:54+0100] [ALPM] upgraded inxi (3.1.08+1-1 -> 3.3.04.1-1)
[2021-06-08T13:52:53+0100] [ALPM] upgraded intel-ucode (20201118-1 -> 20210216-1)
[2021-06-08T13:52:52+0100] [ALPM] upgraded intel-media-sdk (20.3.1-1 -> 21.1.3-2)
[2021-06-08T13:52:51+0100] [ALPM] upgraded intel-media-driver (20.4.1-1 -> 21.1.3-1)
[2021-06-08T13:52:49+0100] [ALPM] upgraded intel-gmmlib (20.3.3-1 -> 21.1.1-1)
[2021-06-08T13:52:49+0100] [ALPM] upgraded inetutils (1.9.4-8 -> 1.9.4-9)
[2021-06-08T13:52:48+0100] [ALPM] upgraded htop (3.0.2-1 -> 3.0.5-1)
[2021-06-08T13:52:48+0100] [ALPM] upgraded hexchat (2.14.3-3 -> 2.14.3-8)
[2021-06-08T13:52:47+0100] [ALPM] upgraded hdparm (9.58-3 -> 9.61-1)
[2021-06-08T13:52:47+0100] [ALPM] upgraded haveged (1.9.13-1 -> 1.9.14-1)
[2021-06-08T13:52:47+0100] [ALPM] upgraded gvfs-smb (1.46.1-1 -> 1.48.1-1)
[2021-06-08T13:52:47+0100] [ALPM] upgraded gvfs-nfs (1.46.1-1 -> 1.48.1-1)
[2021-06-08T13:52:47+0100] [ALPM] upgraded gvfs-mtp (1.46.1-1 -> 1.48.1-1)
[2021-06-08T13:52:47+0100] [ALPM] upgraded gvfs-gphoto2 (1.46.1-1 -> 1.48.1-1)
[2021-06-08T13:52:47+0100] [ALPM] upgraded libgphoto2 (2.5.26-1 -> 2.5.27-1)
[2021-06-08T13:52:46+0100] [ALPM] upgraded gvfs-afc (1.46.1-1 -> 1.48.1-1)
[2021-06-08T13:52:46+0100] [ALPM] upgraded gvfs (1.46.1-1 -> 1.48.1-1)
[2021-06-08T13:52:45+0100] [ALPM] upgraded psmisc (23.3-2 -> 23.4-1)
[2021-06-08T13:52:44+0100] [ALPM] upgraded guile (2.2.6-2 -> 2.2.7-1)
[2021-06-08T13:52:42+0100] [ALPM] upgraded gufw (20.04.1-4 -> 21.04.0-1)
[2021-06-08T13:52:41+0100] [ALPM] upgraded webkit2gtk (2.30.3-1 -> 2.32.1-1)
[2021-06-08T13:52:37+0100] [ALPM] installed libmanette (0.2.6-2)
[2021-06-08T13:52:37+0100] [ALPM] upgraded wpebackend-fdo (1.8.0-1 -> 1.9.92-1)
[2021-06-08T13:52:36+0100] [ALPM] upgraded libwpe (1.8.0-1 -> 1.10.0-1)
[2021-06-08T13:52:36+0100] [ALPM] upgraded harfbuzz-icu (2.7.2-1 -> 2.8.1-1)
[2021-06-08T13:52:36+0100] [ALPM] upgraded ufw (0.36-3 -> 0.36-5)
[2021-06-08T13:52:35+0100] [ALPM] upgraded gtk-doc (1.33.1-1 -> 1.33.2-1)
[2021-06-08T13:52:35+0100] [ALPM] upgraded python-anytree (2.8.0-1 -> 2.8.0-3)
[2021-06-08T13:52:34+0100] [ALPM] upgraded python-pygments (2.7.2-1 -> 2.9.0-1)
[2021-06-08T13:52:33+0100] [ALPM] upgraded python-lxml (4.6.1-1 -> 4.6.3-1)
[2021-06-08T13:52:33+0100] [ALPM] upgraded gst-plugins-ugly (1.18.1-1 -> 1.18.4-2)
[2021-06-08T13:52:33+0100] [ALPM] upgraded gst-plugins-bad (1.18.1-1 -> 1.18.4-7)
[2021-06-08T13:52:33+0100] [ALPM] upgraded gupnp (1.2.4-1 -> 1.2.6-1)
[2021-06-08T13:52:33+0100] [ALPM] upgraded raptor (2.0.15-14 -> 2.0.15-16)
[2021-06-08T13:52:32+0100] [ALPM] upgraded zxing-cpp (1.1.1-1 -> 1.2.0-1)
[2021-06-08T13:52:32+0100] [ALPM] upgraded svt-hevc (1.5.0-1 -> 1.5.1-1)
[2021-06-08T13:52:32+0100] [ALPM] upgraded zbar (0.23.1-3 -> 0.23.1-6)
[2021-06-08T13:52:32+0100] [ALPM] upgraded wildmidi (0.4.3-3 -> 0.4.4-1)
[2021-06-08T13:52:32+0100] [ALPM] upgraded libdvdnav (6.1.0-2 -> 6.1.1-1)
[2021-06-08T13:52:31+0100] [ALPM] upgraded mjpegtools (2.1.0-5 -> 2.2.0-1)
[2021-06-08T13:52:31+0100] [ALPM] upgraded lilv (0.24.10-1 -> 0.24.12-1)
[2021-06-08T13:52:31+0100] [ALPM] upgraded sratom (0.6.6-1 -> 0.6.8-1)
[2021-06-08T13:52:31+0100] [ALPM] upgraded sord (0.16.6-1 -> 0.16.8-1)
[2021-06-08T13:52:31+0100] [ALPM] upgraded serd (0.30.6-1 -> 0.30.10-1)
[2021-06-08T13:52:31+0100] [ALPM] upgraded gst-plugins-good (1.18.1-1 -> 1.18.4-2)
[2021-06-08T13:52:31+0100] [ALPM] upgraded procps-ng (3.3.16-2 -> 3.3.17-1)
[2021-06-08T13:52:31+0100] [ALPM] upgraded libcaca (0.99.beta19-3 -> 0.99.beta19-5)
[2021-06-08T13:52:30+0100] [ALPM] upgraded imlib2 (1.7.0-1 -> 1.7.1-1)
[2021-06-08T13:52:30+0100] [ALPM] upgraded libshout (1:2.4.4-1 -> 1:2.4.5-1)
[2021-06-08T13:52:30+0100] [ALPM] upgraded gst-plugins-bad-libs (1.18.1-1 -> 1.18.4-7)
[2021-06-08T13:52:30+0100] [ALPM] upgraded gssproxy (0.8.3-1 -> 0.8.4-1)
[2021-06-08T13:52:30+0100] [ALPM] upgraded grub (2.04-12 -> 2.04-22)
[2021-06-08T13:52:27+0100] [ALPM] warning: /etc/default/grub installed as /etc/default/grub.pacnew
[2021-06-08T13:52:27+0100] [ALPM] upgraded groff (1.22.4-3 -> 1.22.4-5)
[2021-06-08T13:52:27+0100] [ALPM] upgraded gparted (1.1.0-1 -> 1.3.0-4)
[2021-06-08T13:52:26+0100] [ALPM] upgraded gtkmm3 (3.24.2-2 -> 3.24.5-2)
[2021-06-08T13:52:25+0100] [ALPM] upgraded pangomm (2.42.1-2 -> 2.46.1-2)
[2021-06-08T13:52:25+0100] [ALPM] upgraded glslang (11.0.0-1 -> 11.4.0-1)
[2021-06-08T13:52:22+0100] [ALPM] upgraded glib2-docs (2.66.2-1 -> 2.68.2-1)
[2021-06-08T13:52:21+0100] [ALPM] upgraded git (2.29.2-1 -> 2.31.1-1)
[2021-06-08T13:52:18+0100] [ALPM] upgraded perl-mailtools (2.21-4 -> 2.21-5)
[2021-06-08T13:52:18+0100] [ALPM] upgraded perl-error (0.17029-2 -> 0.17029-3)
[2021-06-08T13:52:17+0100] [ALPM] upgraded gimp (2.10.22-1 -> 2.10.24-4)
[2021-06-08T13:52:09+0100] [ALPM] upgraded graphviz (2.44.1-4 -> 2.47.2-1)
[2021-06-08T13:52:09+0100] [ALPM] upgraded gsfonts (20200910-1 -> 20200910-2)
[2021-06-08T13:52:09+0100] [ALPM] upgraded libxaw (1.0.13-3 -> 1.0.14-1)
[2021-06-08T13:52:09+0100] [ALPM] upgraded gtk2 (2.24.32-2 -> 2.24.33-2)
[2021-06-08T13:52:08+0100] [ALPM] upgraded libmypaint (1.5.1-2 -> 1.6.1-1)
[2021-06-08T13:52:08+0100] [ALPM] upgraded gegl (0.4.26-1 -> 0.4.30-3)
[2021-06-08T13:52:08+0100] [ALPM] upgraded poppler-glib (20.10.0-1 -> 21.05.0-1)
[2021-06-08T13:52:08+0100] [ALPM] upgraded suitesparse (5.8.1-1 -> 5.10.1-1)
[2021-06-08T13:52:08+0100] [ALPM] upgraded lapack (3.9.0-3 -> 3.9.1-1)
[2021-06-08T13:52:08+0100] [ALPM] upgraded metis (5.1.0.p10-1 -> 5.1.0.p10-2)
[2021-06-08T13:52:08+0100] [ALPM] upgraded lensfun (0.3.95-2 -> 0.3.95-4)
[2021-06-08T13:52:08+0100] [ALPM] upgraded jasper (2.0.19-1 -> 2.0.28-1)
[2021-06-08T13:52:08+0100] [ALPM] upgraded openexr (2.5.3-1 -> 3.0.3-1)
[2021-06-08T13:52:07+0100] [ALPM] installed imath (3.0.3-1)
[2021-06-08T13:52:06+0100] [ALPM] upgraded libgexiv2 (0.12.1-1 -> 0.12.2-1)
[2021-06-08T13:52:05+0100] [ALPM] upgraded gd (2.3.0-1 -> 2.3.2-2)
[2021-06-08T13:52:04+0100] [ALPM] upgraded libheif (1.9.1-2 -> 1.12.0-1)
[2021-06-08T13:52:04+0100] [ALPM] installed libavif (0.9.0-2)
[2021-06-08T13:52:04+0100] [ALPM] installed libyuv (r2212+dfaf7534-2)
[2021-06-08T13:52:03+0100] [ALPM] upgraded gcc (10.2.0-3 -> 11.1.0-1)
[2021-06-08T13:51:50+0100] [ALPM] upgraded gavl (1.4.0-4 -> 1.4.0-5)
[2021-06-08T13:51:50+0100] [ALPM] upgraded garcon (0.6.4-2 -> 4.16.1-1)
[2021-06-08T13:51:48+0100] [ALPM] upgraded game-devices-udev (0.10-1 -> 0.13-1)
[2021-06-08T13:51:48+0100] [ALPM] upgraded fuse3 (3.10.0-1 -> 3.10.3-1)
[2021-06-08T13:51:48+0100] [ALPM] upgraded flatpak (1.9.2-1 -> 1.11.1-1)
[2021-06-08T13:51:47+0100] [ALPM] upgraded xdg-desktop-portal (1.8.0-1 -> 1.8.1-1)
[2021-06-08T13:51:46+0100] [ALPM] upgraded gnome-keyring (1:3.36.0-1 -> 1:40.0-1)
[2021-06-08T13:51:46+0100] [ALPM] upgraded gcr (3.38-1 -> 3.40.0-1)
[2021-06-08T13:51:46+0100] [ALPM] upgraded gnome-desktop (1:3.38.2-1 -> 1:40.1-1)
[2021-06-08T13:51:45+0100] [ALPM] upgraded geoclue (2.5.6-1 -> 2.5.7-3)
[2021-06-08T13:51:45+0100] [ALPM] upgraded libmm-glib (1.14.8-1 -> 1.16.4-1)
[2021-06-08T13:51:45+0100] [ALPM] upgraded pipewire (0.3.15-2 -> 1:0.3.28-1)
[2021-06-08T13:51:45+0100] [ALPM] upgraded libfdk-aac (2.0.1-2 -> 2.0.2-1)
[2021-06-08T13:51:45+0100] [ALPM] installed libopenaptx (0.2.0-1)
[2021-06-08T13:51:45+0100] [ALPM] installed libldac (2.0.2.3-1)
[2021-06-08T13:51:45+0100] [ALPM] upgraded sbc (1.4-2 -> 1.5-2)
[2021-06-08T13:51:45+0100] [ALPM] upgraded xdg-dbus-proxy (0.1.2-2 -> 0.1.2-3)
[2021-06-08T13:51:45+0100] [ALPM] upgraded ostree (2020.8-1 -> 2021.2-1)
[2021-06-08T13:51:44+0100] [ALPM] upgraded fuse-common (3.10.0-1 -> 3.10.3-1)
[2021-06-08T13:51:44+0100] [ALPM] upgraded firefox (84.0-0.1 -> 89.0-1)
[2021-06-08T13:51:26+0100] [ALPM] upgraded ttf-droid (20121017-8 -> 20121017-10)
[2021-06-08T13:51:25+0100] [ALPM] upgraded ttf-dejavu (2.37+18+g9b5d1b2f-2 -> 2.37+18+g9b5d1b2f-3)
[2021-06-08T13:51:24+0100] [ALPM] upgraded noto-fonts (20190926-4 -> 20201226-2)
[2021-06-08T13:51:18+0100] [ALPM] upgraded mailcap (2.1.49-1 -> 2.1.53-1)
[2021-06-08T13:51:18+0100] [ALPM] upgraded file-roller (3.38.0-1 -> 3.40.0-1)
[2021-06-08T13:51:18+0100] [ALPM] upgraded fftw (3.3.8-3 -> 3.3.9-1)
[2021-06-08T13:51:18+0100] [ALPM] upgraded openmpi (4.0.5-2 -> 4.0.5-3)
[2021-06-08T13:51:16+0100] [ALPM] upgraded openssh (8.4p1-2 -> 8.6p1-1)
[2021-06-08T13:51:16+0100] [ALPM] upgraded hwloc (2.2.0-1 -> 2.4.1-1)
[2021-06-08T13:51:16+0100] [ALPM] upgraded faudio (20.11-1 -> 21.05-1)
[2021-06-08T13:51:15+0100] [ALPM] upgraded gst-libav (1.18.1-1 -> 1.18.4-1)
[2021-06-08T13:51:14+0100] [ALPM] upgraded fakeroot (1.25.3-1 -> 1.25.3-2)
[2021-06-08T13:51:14+0100] [ALPM] upgraded exo (0.12.11-5 -> 4.16.2-1)
[2021-06-08T13:51:13+0100] [ALPM] upgraded libxfce4ui (4.14.1-3.1 -> 4.16.0-1)
[2021-06-08T13:51:13+0100] [ALPM] installed libgtop (2.40.0+2+g31db82ef-2)
[2021-06-08T13:51:11+0100] [ALPM] upgraded engrampa (1.24.1-1 -> 1.24.2-1)
[2021-06-08T13:51:10+0100] [ALPM] upgraded less (563-1 -> 1:581.2-1)
[2021-06-08T13:51:10+0100] [ALPM] upgraded enchant (2.2.12-1 -> 2.2.15-2)
[2021-06-08T13:51:10+0100] [ALPM] upgraded dvdauthor (0.7.2-9 -> 0.7.2-10)
[2021-06-08T13:51:10+0100] [ALPM] upgraded libdvdread (6.1.1-1 -> 6.1.2-1)
[2021-06-08T13:51:10+0100] [ALPM] upgraded dnsmasq (2.82-2 -> 2.85-1)
[2021-06-08T13:51:09+0100] [ALPM] upgraded dhcpcd (9.3.3-1 -> 9.4.0-1)
[2021-06-08T13:51:09+0100] [ALPM] upgraded dhclient (4.4.2-2 -> 4.4.2.P1-1)
[2021-06-08T13:51:09+0100] [ALPM] upgraded iproute2 (5.9.0-1 -> 5.12.0-1)
[2021-06-08T13:51:09+0100] [ALPM] upgraded deluge-gtk (2.0.4.dev38+g23a48dd01-2 -> 2.0.4.dev56+g2e466101f-1)
[2021-06-08T13:51:09+0100] [ALPM] upgraded deluge (2.0.4.dev38+g23a48dd01-2 -> 2.0.4.dev56+g2e466101f-1)
[2021-06-08T13:51:08+0100] [ALPM] upgraded python-mako (1.1.3-1 -> 1.1.4-1)
[2021-06-08T13:51:08+0100] [ALPM] upgraded python-beaker (1.11.0-4 -> 1.11.0-6)
[2021-06-08T13:51:07+0100] [ALPM] upgraded python-markupsafe (1.1.1-4 -> 2.0.1-1)
[2021-06-08T13:51:07+0100] [ALPM] upgraded python-geoip (1.3.2-8 -> 1.3.2-10)
[2021-06-08T13:51:07+0100] [ALPM] upgraded geoip-database (20201110-1 -> 20210427-1)
[2021-06-08T13:51:07+0100] [ALPM] upgraded libtorrent-rasterbar (1:1.2.10-2 -> 1:1.2.11-1)
[2021-06-08T13:51:07+0100] [ALPM] upgraded python-distro (1.5.0-1 -> 1.5.0-3)
[2021-06-08T13:51:07+0100] [ALPM] upgraded python-setuptools (1:50.3.2-1 -> 1:56.2.0-1)
[2021-06-08T13:51:07+0100] [ALPM] upgraded python-ordered-set (4.0.2-1 -> 4.0.2-3)
[2021-06-08T13:51:07+0100] [ALPM] upgraded python-packaging (20.4-1 -> 20.9-1)
[2021-06-08T13:51:07+0100] [ALPM] upgraded python-pyparsing (2.4.7-1 -> 2.4.7-3)
[2021-06-08T13:51:07+0100] [ALPM] upgraded python-appdirs (1.4.4-1 -> 1.4.4-3)
[2021-06-08T13:51:07+0100] [ALPM] upgraded python-pillow (7.2.0-1 -> 8.2.0-2)
[2021-06-08T13:51:06+0100] [ALPM] upgraded libimagequant (2.13.1-1 -> 2.15.1-1)
[2021-06-08T13:51:06+0100] [ALPM] upgraded python-setproctitle (1.1.10-5 -> 1.2.2-1)
[2021-06-08T13:51:06+0100] [ALPM] upgraded python-pyxdg (0.26-6 -> 0.27-1)
[2021-06-08T13:51:06+0100] [ALPM] upgraded python-rencode (1.0.6-3 -> 1.0.6-5)
[2021-06-08T13:51:06+0100] [ALPM] upgraded python-pyopenssl (19.1.0-2 -> 20.0.1-1)
[2021-06-08T13:51:06+0100] [ALPM] upgraded python-service-identity (18.1.0-4 -> 21.1.0-1)
[2021-06-08T13:51:06+0100] [ALPM] upgraded python-six (1.15.0-1 -> 1.16.0-1)
[2021-06-08T13:51:06+0100] [ALPM] upgraded python-cryptography (3.2.1-1 -> 3.4.7-1)
[2021-06-08T13:51:06+0100] [ALPM] upgraded python-cffi (1.14.3-1 -> 1.14.5-1)
[2021-06-08T13:51:06+0100] [ALPM] upgraded python-pycparser (2.20-1 -> 2.20-3)
[2021-06-08T13:51:06+0100] [ALPM] upgraded python-ply (3.11-5 -> 3.11-7)
[2021-06-08T13:51:06+0100] [ALPM] upgraded python-pyasn1-modules (0.2.8-1 -> 0.2.8-4)
[2021-06-08T13:51:06+0100] [ALPM] upgraded python-pyasn1 (0.4.8-2 -> 0.4.8-4)
[2021-06-08T13:51:05+0100] [ALPM] upgraded python-twisted (20.3.0-1 -> 21.2.0-3)
[2021-06-08T13:51:04+0100] [ALPM] upgraded python-hyperlink (20.0.1-1 -> 21.0.0-2)
[2021-06-08T13:51:04+0100] [ALPM] upgraded python-automat (20.2.0-2 -> 20.2.0-6)
[2021-06-08T13:51:04+0100] [ALPM] upgraded python-attrs (20.3.0-1 -> 21.2.0-1)
[2021-06-08T13:51:04+0100] [ALPM] upgraded python-incremental (17.5.0-4 -> 21.3.0-2)
[2021-06-08T13:51:04+0100] [ALPM] upgraded python-click (7.1.2-1 -> 8.0.1-1)
[2021-06-08T13:51:04+0100] [ALPM] upgraded python-constantly (15.1.0-6 -> 15.1.0-9)
[2021-06-08T13:51:03+0100] [ALPM] upgraded python-zope-interface (5.2.0-1 -> 5.4.0-1)
[2021-06-08T13:51:03+0100] [ALPM] upgraded cups-pdf (3.0.1-5 -> 3.0.1-6)
[2021-06-08T13:51:03+0100] [ALPM] upgraded ghostscript (9.53.3-2 -> 9.54.0-2)
[2021-06-08T13:51:02+0100] [ALPM] upgraded libidn (1.36-1 -> 1.37-1)
[2021-06-08T13:50:59+0100] [ALPM] upgraded cups (1:2.3.3op1-1 -> 1:2.3.3op2-3)
[2021-06-08T13:50:57+0100] [ALPM] upgraded cups-filters (1.28.5-3 -> 1.28.8-1)
[2021-06-08T13:50:57+0100] [ALPM] upgraded liblouis (3.15.0-1 -> 3.17.0-1)
[2021-06-08T13:50:56+0100] [ALPM] upgraded imagemagick (7.0.10.45-1 -> 7.0.11.13-3)
[2021-06-08T13:50:55+0100] [ALPM] upgraded qpdf (10.0.4-1 -> 10.3.2-1)
[2021-06-08T13:50:16+0100] [ALPM] upgraded cuda (11.1.1-1 -> 11.3.0-2)
[2021-06-08T13:48:20+0100] [ALPM] upgraded mhwd-nvidia-390xx (390.132-1 -> 390.143-1)
[2021-06-08T13:48:19+0100] [ALPM] upgraded mhwd-nvidia (460.73.01-1 -> 465.31-1)
[2021-06-08T13:48:19+0100] [ALPM] upgraded hwinfo (21.70-2 -> 21.74-1)
[2021-06-08T13:48:19+0100] [ALPM] upgraded perl-xml-writer (0.625-6 -> 0.625-7)
[2021-06-08T13:48:19+0100] [ALPM] upgraded perl-xml-parser (2.46-2 -> 2.46-3)
[2021-06-08T13:48:19+0100] [ALPM] upgraded perl-libwww (6.49-1 -> 6.54-2)
[2021-06-08T13:48:18+0100] [ALPM] upgraded perl-www-robotrules (6.02-8 -> 6.02-9)
[2021-06-08T13:48:18+0100] [ALPM] upgraded perl-try-tiny (0.30-5 -> 0.30-6)
[2021-06-08T13:48:18+0100] [ALPM] upgraded perl-net-http (6.19-4 -> 6.21-2)
[2021-06-08T13:48:17+0100] [ALPM] upgraded perl-http-negotiate (6.01-8 -> 6.01-9)
[2021-06-08T13:48:17+0100] [ALPM] upgraded perl-http-daemon (6.06-2 -> 6.06-3)
[2021-06-08T13:48:17+0100] [ALPM] upgraded perl-http-cookies (6.09-1 -> 6.10-2)
[2021-06-08T13:48:17+0100] [ALPM] upgraded perl-html-parser (3.75-1 -> 3.76-2)
[2021-06-08T13:48:17+0100] [ALPM] upgraded perl-http-message (6.26-1 -> 6.32-2)
[2021-06-08T13:48:17+0100] [ALPM] upgraded perl-uri (5.05-1 -> 5.09-2)
[2021-06-08T13:48:16+0100] [ALPM] upgraded perl-lwp-mediatypes (6.02-8 -> 6.02-9)
[2021-06-08T13:48:16+0100] [ALPM] upgraded perl-io-html (1.004-1 -> 1.004-2)
[2021-06-08T13:48:16+0100] [ALPM] upgraded perl-clone (0.45-2 -> 0.45-3)
[2021-06-08T13:48:16+0100] [ALPM] upgraded perl-html-tagset (3.20-10 -> 3.20-11)
[2021-06-08T13:48:16+0100] [ALPM] upgraded perl-file-listing (6.11-1 -> 6.14-2)
[2021-06-08T13:48:16+0100] [ALPM] upgraded perl-http-date (6.05-3 -> 6.05-4)
[2021-06-08T13:48:16+0100] [ALPM] upgraded perl-timedate (2.33-2 -> 2.33-3)
[2021-06-08T13:48:15+0100] [ALPM] upgraded perl-encode-locale (1.05-7 -> 1.05-8)
[2021-06-08T13:48:14+0100] [ALPM] upgraded xorg-server (1.20.10-0 -> 1.20.11-1)
[2021-06-08T13:48:14+0100] [ALPM] upgraded xorg-server-common (1.20.10-0 -> 1.20.11-1)
[2021-06-08T13:48:14+0100] [ALPM] upgraded xorg-xkbcomp (1.4.4-1 -> 1.4.5-1)
[2021-06-08T13:48:14+0100] [ALPM] upgraded xf86-input-libinput (0.30.0-1 -> 1.0.1-1)
[2021-06-08T13:48:13+0100] [ALPM] installed gcc10 (1:10.2.0-3)
[2021-06-08T13:48:05+0100] [ALPM] upgraded libmpc (1.1.0-2 -> 1.2.1-1)
[2021-06-08T13:48:05+0100] [ALPM] installed gcc10-libs (1:10.2.0-3)
[2021-06-08T13:48:00+0100] [ALPM] upgraded ctags (1:r20200106+ga3c87ab5-1 -> 1:r20210106+g08b1c490-1)
[2021-06-08T13:47:59+0100] [ALPM] upgraded cronie (1.5.5-1 -> 1.5.7-2)
[2021-06-08T13:47:58+0100] [ALPM] upgraded run-parts (4.8.6.1-2 -> 4.11.2-1)
[2021-06-08T13:47:58+0100] [ALPM] upgraded crda (4.14-3 -> 4.14-4)
[2021-06-08T13:47:58+0100] [ALPM] upgraded wireless-regdb (2020.04.29-1 -> 2020.11.20-1)
[2021-06-08T13:47:57+0100] [ALPM] upgraded cpupower (5.9-1 -> 5.12-1)
[2021-06-08T13:47:56+0100] [ALPM] upgraded cmake (3.19.1-1 -> 3.20.3-1)
[2021-06-08T13:47:51+0100] [ALPM] upgraded rhash (1.4.0-1 -> 1.4.1-1)
[2021-06-08T13:47:51+0100] [ALPM] upgraded cifs-utils (6.11-1 -> 6.13-2)
[2021-06-08T13:47:51+0100] [ALPM] upgraded smbclient (4.13.2-1 -> 4.14.4-1)
[2021-06-08T13:47:48+0100] [ALPM] installed python-dnspython (1:1.16.0-3)
[2021-06-08T13:47:48+0100] [ALPM] installed python-markdown (3.3.4-1)
[2021-06-08T13:47:48+0100] [ALPM] upgraded ldb (1:2.2.0-1 -> 1:2.3.0-1)
[2021-06-08T13:47:47+0100] [ALPM] upgraded tevent (1:0.10.2-1 -> 1:0.10.2-3)
[2021-06-08T13:47:47+0100] [ALPM] upgraded talloc (2.3.1-3 -> 2.3.2-1)
[2021-06-08T13:47:47+0100] [ALPM] upgraded chromium (87.0.4280.66-1 -> 91.0.4472.77-1)
[2021-06-08T13:47:29+0100] [ALPM] upgraded ttf-liberation (2.1.1-1 -> 2.1.4-1)
[2021-06-08T13:47:28+0100] [ALPM] upgraded ceph-libs (15.2.6-1 -> 15.2.12-1)
[2021-06-08T13:47:21+0100] [ALPM] installed fmt (7.1.3-1)
[2021-06-08T13:47:21+0100] [ALPM] upgraded oath-toolkit (2.6.4-1 -> 2.6.7-1)
[2021-06-08T13:47:21+0100] [ALPM] upgraded xmlsec (1.2.31-1 -> 1.2.32-1)
[2021-06-08T13:47:21+0100] [ALPM] upgraded cblas (3.9.0-3 -> 3.9.1-1)
[2021-06-08T13:47:21+0100] [ALPM] upgraded catfish (1.4.13-3 -> 4.16.0-4)
[2021-06-08T13:47:21+0100] [ALPM] upgraded xfconf (4.14.4-1 -> 4.16.0-1)
[2021-06-08T13:47:20+0100] [ALPM] upgraded libxfce4util (4.14.0-2 -> 4.16.0-1)
[2021-06-08T13:47:20+0100] [ALPM] upgraded python-pexpect (4.8.0-1 -> 4.8.0-3)
[2021-06-08T13:47:20+0100] [ALPM] upgraded python-ptyprocess (0.6.0-4 -> 0.7.0-1)
[2021-06-08T13:47:20+0100] [ALPM] installed dbus-python (1.2.16-4)
[2021-06-08T13:47:20+0100] [ALPM] upgraded cairomm (1.12.2-4 -> 1.14.3-2)
[2021-06-08T13:47:19+0100] [ALPM] upgraded bubblewrap (0.4.1-1 -> 0.4.1-2)
[2021-06-08T13:47:19+0100] [ALPM] upgraded breeze (5.20.4-1 -> 5.21.5-1)
[2021-06-08T13:47:12+0100] [ALPM] upgraded kwayland (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:47:10+0100] [ALPM] upgraded breeze-icons (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:47:05+0100] [ALPM] upgraded kdecoration (5.20.4-1 -> 5.21.5-1)
[2021-06-08T13:47:05+0100] [ALPM] upgraded frameworkintegration (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:47:05+0100] [ALPM] upgraded knewstuff (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:47:05+0100] [ALPM] upgraded kpackage (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:47:04+0100] [ALPM] upgraded boost-libs (1.72.0-2 -> 1.75.0-3)
[2021-06-08T13:47:03+0100] [ALPM] upgraded blueman (2.1.3-1 -> 2.1.4-1)
[2021-06-08T13:47:02+0100] [ALPM] upgraded python-gobject (3.38.0-1 -> 3.40.1-1)
[2021-06-08T13:47:01+0100] [ALPM] upgraded gobject-introspection-runtime (1.66.1-1 -> 1.68.0-1)
[2021-06-08T13:47:01+0100] [ALPM] upgraded python-cairo (1.20.0-1 -> 1.20.0-3)
[2021-06-08T13:47:00+0100] [ALPM] upgraded libnm (1.26.4-1 -> 1.30.4-3)
[2021-06-08T13:47:00+0100] [ALPM] upgraded bluez-libs (5.55-1 -> 5.58-1)
[2021-06-08T13:47:00+0100] [ALPM] upgraded bluez (5.55-1 -> 5.58-1)
[2021-06-08T13:47:00+0100] [ALPM] upgraded libical (3.0.8-2 -> 3.0.10-1)
[2021-06-08T13:46:59+0100] [ALPM] upgraded blas (3.9.0-3 -> 3.9.1-1)
[2021-06-08T13:46:59+0100] [ALPM] upgraded bison (3.7.2-1 -> 3.7.6-1)
[2021-06-08T13:46:56+0100] [ALPM] upgraded binutils (2.35.1-1 -> 2.36.1-3)
[2021-06-08T13:46:54+0100] [ALPM] upgraded elfutils (0.181-1 -> 0.184-1)
[2021-06-08T13:46:53+0100] [ALPM] upgraded libmicrohttpd (0.9.71-1 -> 0.9.73-1)
[2021-06-08T13:46:53+0100] [ALPM] upgraded baloo (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:52+0100] [ALPM] upgraded kio (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:49+0100] [ALPM] upgraded kded (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:49+0100] [ALPM] upgraded ktextwidgets (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:48+0100] [ALPM] upgraded sonnet (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:48+0100] [ALPM] upgraded kcompletion (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:48+0100] [ALPM] upgraded kwallet (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:48+0100] [ALPM] upgraded kservice (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:47+0100] [ALPM] upgraded knotifications (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:47+0100] [ALPM] upgraded gst-plugins-base (1.18.1-1 -> 1.18.4-1)
[2021-06-08T13:46:47+0100] [ALPM] upgraded graphene (1.10.2-1 -> 1.10.6-1)
[2021-06-08T13:46:47+0100] [ALPM] upgraded gst-plugins-base-libs (1.18.1-1 -> 1.18.4-1)
[2021-06-08T13:46:47+0100] [ALPM] upgraded gstreamer (1.18.1-1 -> 1.18.4-1)
[2021-06-08T13:46:44+0100] [ALPM] upgraded openal (1.21.0-1 -> 1.21.1-1)
[2021-06-08T13:46:43+0100] [ALPM] upgraded kbookmarks (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:43+0100] [ALPM] upgraded kxmlgui (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:42+0100] [ALPM] upgraded kiconthemes (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:42+0100] [ALPM] upgraded kitemviews (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:42+0100] [ALPM] upgraded kconfigwidgets (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:42+0100] [ALPM] upgraded kguiaddons (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:41+0100] [ALPM] upgraded qt5-wayland (5.15.2-1 -> 5.15.2+kde+r23-1)
[2021-06-08T13:46:40+0100] [ALPM] upgraded kcodecs (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:40+0100] [ALPM] upgraded kauth (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:39+0100] [ALPM] upgraded kglobalaccel (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:39+0100] [ALPM] upgraded kcrash (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:39+0100] [ALPM] upgraded kwindowsystem (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:38+0100] [ALPM] upgraded kdbusaddons (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:38+0100] [ALPM] upgraded kjobwidgets (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:37+0100] [ALPM] upgraded kwidgetsaddons (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:35+0100] [ALPM] upgraded solid (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:34+0100] [ALPM] upgraded libimobiledevice (1.3.0-1 -> 1.3.0-3)
[2021-06-08T13:46:34+0100] [ALPM] upgraded libplist (2.2.0-1 -> 2.2.0-3)
[2021-06-08T13:46:34+0100] [ALPM] upgraded udisks2 (2.9.1-1 -> 2.9.2-1)
[2021-06-08T13:46:32+0100] [ALPM] upgraded libblockdev (2.24-1 -> 2.25-2)
[2021-06-08T13:46:32+0100] [ALPM] upgraded xfsprogs (5.8.0-1 -> 5.11.0-2)
[2021-06-08T13:46:32+0100] [ALPM] installed libinih (53-1)
[2021-06-08T13:46:32+0100] [ALPM] upgraded volume_key (0.3.12-3 -> 0.3.12-5)
[2021-06-08T13:46:32+0100] [ALPM] upgraded parted (3.3-2 -> 3.4-2)
[2021-06-08T13:46:32+0100] [ALPM] upgraded ndctl (70.1-1 -> 71.1-1)
[2021-06-08T13:46:32+0100] [ALPM] upgraded lvm2 (2.02.187-3 -> 2.03.12-1)
[2021-06-08T13:46:30+0100] [ALPM] upgraded libbytesize (2.4-1 -> 2.5-1)
[2021-06-08T13:46:28+0100] [ALPM] upgraded gptfdisk (1.0.5-1 -> 1.0.7-1)
[2021-06-08T13:46:28+0100] [ALPM] upgraded dmraid (1.0.0.rc16.3-12 -> 1.0.0.rc16.3-13)
[2021-06-08T13:46:28+0100] [ALPM] upgraded dosfstools (4.1-3 -> 4.2-1)
[2021-06-08T13:46:26+0100] [ALPM] upgraded btrfs-progs (5.9-1 -> 5.12.1-1)
[2021-06-08T13:46:26+0100] [ALPM] upgraded kidletime (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:25+0100] [ALPM] upgraded kfilemetadata (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:25+0100] [ALPM] upgraded libzip (1.7.3-1 -> 1.7.3-2)
[2021-06-08T13:46:25+0100] [ALPM] upgraded taglib (1.11.1-4 -> 1.12-1)
[2021-06-08T13:46:25+0100] [ALPM] upgraded poppler-qt5 (20.10.0-1 -> 21.05.0-1)
[2021-06-08T13:46:25+0100] [ALPM] upgraded poppler (20.10.0-1 -> 21.05.0-1)
[2021-06-08T13:46:24+0100] [ALPM] upgraded kcoreaddons (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:24+0100] [ALPM] upgraded kconfig (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:23+0100] [ALPM] upgraded karchive (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:22+0100] [ALPM] upgraded ki18n (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:20+0100] [ALPM] upgraded qt5-declarative (5.15.2-1 -> 5.15.2+kde+r26-1)
[2021-06-08T13:46:18+0100] [ALPM] upgraded babl (0.1.82-1 -> 0.1.86-1)
[2021-06-08T13:46:18+0100] [ALPM] upgraded automake (1.16.2-3 -> 1.16.3-1)
[2021-06-08T13:46:18+0100] [ALPM] upgraded autoconf (2.69-7 -> 2.71-1)
[2021-06-08T13:46:18+0100] [ALPM] upgraded mpfr (4.1.0-1 -> 4.1.0-2)
[2021-06-08T13:46:17+0100] [ALPM] upgraded audacious (4.0.5-1 -> 4.1-3)
[2021-06-08T13:46:17+0100] [ALPM] upgraded audacious-plugins (4.0.5-1 -> 4.1-3)
[2021-06-08T13:46:16+0100] [ALPM] upgraded wavpack (5.3.0-1 -> 5.4.0-1)
[2021-06-08T13:46:16+0100] [ALPM] upgraded mpg123 (1.26.3-2 -> 1.27.2-1)
[2021-06-08T13:46:16+0100] [ALPM] upgraded lirc (1:0.10.1-6 -> 1:0.10.1-8)
[2021-06-08T13:46:15+0100] [ALPM] upgraded libftdi (1.4-4 -> 1.5-2)
[2021-06-08T13:46:15+0100] [ALPM] upgraded confuse (3.3-2 -> 3.3-3)
[2021-06-08T13:46:15+0100] [ALPM] upgraded libsidplayfp (2.0.2-1 -> 2.1.2-1)
[2021-06-08T13:46:15+0100] [ALPM] upgraded fluidsynth (2.1.5-2 -> 2.1.8-1)
[2021-06-08T13:46:15+0100] [ALPM] upgraded portaudio (1:19.6.0-7 -> 1:19.7.0-1)
[2021-06-08T13:46:15+0100] [ALPM] upgraded libinstpatch (1.1.5-1 -> 1.1.6-1)
[2021-06-08T13:46:14+0100] [ALPM] upgraded dbus-glib (0.110-2 -> 0.112-1)
[2021-06-08T13:46:14+0100] [ALPM] upgraded qt5-svg (5.15.2-1 -> 5.15.2+kde+r7-1)
[2021-06-08T13:46:13+0100] [ALPM] upgraded attica (5.76.0-1 -> 5.82.0-1)
[2021-06-08T13:46:10+0100] [ALPM] upgraded atom (1.53.0-1 -> 1.57.0-1)
[2021-06-08T13:45:34+0100] [ALPM] installed electron9 (9.4.4-1)
[2021-06-08T13:45:22+0100] [ALPM] upgraded re2 (1:20201001-1 -> 1:20210401-1)
[2021-06-08T13:45:21+0100] [ALPM] upgraded nss (3.59-1 -> 3.66-1)
[2021-06-08T13:45:20+0100] [ALPM] upgraded nspr (4.29-1 -> 4.31-1)
[2021-06-08T13:45:19+0100] [ALPM] upgraded ffmpeg (2:4.3.1-2 -> 2:4.4-3)
[2021-06-08T13:45:16+0100] [ALPM] upgraded sysfsutils (2.1.0-11 -> 2.1.1-1)
[2021-06-08T13:45:16+0100] [ALPM] upgraded zita-resampler (1.6.2-3 -> 1.8.0-1)
[2021-06-08T13:45:16+0100] [ALPM] upgraded libsamplerate (0.1.9-3 -> 0.2.1-1)
[2021-06-08T13:45:16+0100] [ALPM] installed svt-av1 (0.8.7-1)
[2021-06-08T13:45:15+0100] [ALPM] upgraded srt (1.4.2-1 -> 1.4.3-1)
[2021-06-08T13:45:14+0100] [ALPM] upgraded sdl2 (2.0.12-3 -> 2.0.14-1)
[2021-06-08T13:45:14+0100] [ALPM] upgraded libibus (1.5.23+1+gdd4cc5b0-1 -> 1.5.24-1)
[2021-06-08T13:45:06+0100] [ALPM] upgraded openjpeg2 (2.3.1-2 -> 2.4.0-1)
[2021-06-08T13:45:04+0100] [ALPM] installed zimg (3.0.1-2)
[2021-06-08T13:45:04+0100] [ALPM] upgraded x265 (3.4-1 -> 3.5-1)
[2021-06-08T13:45:02+0100] [ALPM] upgraded x264 (3:0.160.r3011.cde9a93-1 -> 3:0.161.r3039.544c61f-1)
[2021-06-08T13:45:02+0100] [ALPM] upgraded libwebp (1.1.0-1 -> 1.2.0-1)
[2021-06-08T13:45:02+0100] [ALPM] upgraded libvpx (1.9.0-1 -> 1.10.0-1)
[2021-06-08T13:45:01+0100] [ALPM] upgraded libva (2.9.1-1 -> 2.11.0-1)
[2021-06-08T13:45:01+0100] [ALPM] upgraded rav1e (0.3.4-1 -> 0.4.1-1)
[2021-06-08T13:45:00+0100] [ALPM] upgraded libpulse (14.0-1 -> 14.2-3)
[2021-06-08T13:44:59+0100] [ALPM] upgraded libsndfile (1.0.28-3 -> 1.0.31-1)
[2021-06-08T13:44:59+0100] [ALPM] upgraded flac (1.3.3-2 -> 1.3.3-3)
[2021-06-08T13:44:59+0100] [ALPM] upgraded libmfx (20.3.1-1 -> 21.1.3-2)
[2021-06-08T13:44:59+0100] [ALPM] upgraded dav1d (0.7.1-1 -> 0.9.0-1)
[2021-06-08T13:44:58+0100] [ALPM] upgraded libbluray (1.2.1-1 -> 1.3.0-1)
[2021-06-08T13:44:58+0100] [ALPM] upgraded libass (0.15.0-2 -> 0.15.1-1)
[2021-06-08T13:44:58+0100] [ALPM] upgraded atkmm (2.28.0-2 -> 2.28.2-2)
[2021-06-08T13:44:57+0100] [ALPM] upgraded glibmm (2.64.4-1 -> 2.66.1-2)
[2021-06-08T13:44:57+0100] [ALPM] upgraded libsigc++ (2.10.6-1 -> 2.10.7-2)
[2021-06-08T13:44:57+0100] [ALPM] upgraded aspell-en (2019.10.06-1 -> 2020.12.07-1)
[2021-06-08T13:44:56+0100] [ALPM] upgraded asciidoc (9.0.4-1 -> 9.1.0-1)
[2021-06-08T13:44:56+0100] [ALPM] upgraded archlinux-appstream-data (20201128-1 -> 20210423-1)
[2021-06-08T13:44:51+0100] [ALPM] upgraded appstream-qt (0.13.1-1 -> 0.14.3-1)
[2021-06-08T13:44:51+0100] [ALPM] upgraded qt5-base (5.15.2-1 -> 5.15.2+kde+r196-1)
[2021-06-08T13:44:36+0100] [ALPM] upgraded libxt (1.2.0-2 -> 1.2.1-1)
[2021-06-08T13:44:35+0100] [ALPM] upgraded md4c (0.4.6-1 -> 0.4.8-1)
[2021-06-08T13:44:34+0100] [ALPM] upgraded libxkbcommon-x11 (1.0.3-1 -> 1.3.0-1)
[2021-06-08T13:44:34+0100] [ALPM] upgraded libinput (1.16.4-1 -> 1.17.3-1)
[2021-06-08T13:44:33+0100] [ALPM] upgraded libwacom (1.6-1 -> 1.10-1)
[2021-06-08T13:44:32+0100] [ALPM] upgraded libevdev (1.10.0-1 -> 1.11.0-1)
[2021-06-08T13:44:31+0100] [ALPM] upgraded appstream-glib (0.7.18-1 -> 0.7.18-2)
[2021-06-08T13:44:30+0100] [ALPM] upgraded pacman (5.2.2-3 -> 5.2.2-6)
[2021-06-08T13:44:29+0100] [ALPM] upgraded pacman-mirrors (4.16.4-1 -> 4.21.3-2)
[2021-06-08T13:44:27+0100] [ALPM] upgraded python-requests (2.24.0-1 -> 2.25.1-1)
[2021-06-08T13:44:27+0100] [ALPM] upgraded python-idna (2.10-1 -> 3.1-1)
[2021-06-08T13:44:27+0100] [ALPM] upgraded python-chardet (3.0.4-5 -> 4.0.0-2)
[2021-06-08T13:44:26+0100] [ALPM] upgraded python-urllib3 (1.25.10-2 -> 1.26.5-1)
[2021-06-08T13:44:26+0100] [ALPM] upgraded python-npyscreen (4.10.5-4 -> 4.10.5-5)
[2021-06-08T13:44:26+0100] [ALPM] upgraded gpgme (1.15.0-1 -> 1.15.1-1)
[2021-06-08T13:44:26+0100] [ALPM] upgraded gnupg (2.2.25-0.1 -> 2.2.27-1)
[2021-06-08T13:44:25+0100] [ALPM] upgraded pinentry (1.1.0-5 -> 1.1.1-1)
[2021-06-08T13:44:25+0100] [ALPM] upgraded libassuan (2.5.4-1 -> 2.5.5-1)
[2021-06-08T13:44:24+0100] [ALPM] upgraded npth (1.6-2 -> 1.6-3)
[2021-06-08T13:44:24+0100] [ALPM] upgraded perl (5.32.0-3 -> 5.34.0-1)
[2021-06-08T13:44:15+0100] [ALPM] upgraded libarchive (3.4.3-1 -> 3.5.1-1)
[2021-06-08T13:44:15+0100] [ALPM] upgraded gtk3 (1:3.24.23-4 -> 1:3.24.29-1)
[2021-06-08T13:44:12+0100] [ALPM] upgraded tdb (1.4.3-2 -> 1.4.3-4)
[2021-06-08T13:44:12+0100] [ALPM] upgraded libtool (2.4.6+42+gb88cebd5-14 -> 2.4.6+42+gb88cebd5-16)
[2021-06-08T13:44:12+0100] [ALPM] upgraded tar (1.32-3 -> 1.34-1)
[2021-06-08T13:44:10+0100] [ALPM] upgraded js78 (78.5.0-2 -> 78.10.1-1)
[2021-06-08T13:44:03+0100] [ALPM] upgraded libgusb (0.3.5-1 -> 0.3.6-1)
[2021-06-08T13:44:03+0100] [ALPM] upgraded lcms2 (2.11-2 -> 2.12-1)
[2021-06-08T13:44:03+0100] [ALPM] upgraded libgudev (234-1 -> 236-1)
[2021-06-08T13:44:03+0100] [ALPM] upgraded at-spi2-core (2.38.0-1 -> 2.40.1-1)
[2021-06-08T13:44:02+0100] [ALPM] upgraded iso-codes (4.5.0-1 -> 4.6.0-1)
[2021-06-08T13:43:58+0100] [ALPM] upgraded libcups (1:2.3.3op1-1 -> 1:2.3.3op2-3)
[2021-06-08T13:43:58+0100] [ALPM] upgraded avahi (0.8+15+ge8a3dd0-1 -> 0.8+20+gd1e71b3-1)
[2021-06-08T13:43:57+0100] [ALPM] upgraded mesa (20.2.3-1 -> 21.1.2-0)
[2021-06-08T13:43:49+0100] [ALPM] upgraded libxfixes (5.0.3-4 -> 6.0.0-1)
[2021-06-08T13:43:49+0100] [ALPM] upgraded vulkan-icd-loader (1.2.158-1 -> 1.2.176-1)
[2021-06-08T13:43:49+0100] [ALPM] upgraded libglvnd (1.3.2-1 -> 1.3.3-1)
[2021-06-08T13:43:48+0100] [ALPM] upgraded lm_sensors (3.6.0-2 -> 1:3.6.0.r41.g31d1f125-1)
[2021-06-08T13:43:48+0100] [ALPM] upgraded llvm-libs (11.0.0-1 -> 11.1.0-1)
[2021-06-08T13:43:39+0100] [ALPM] upgraded libedit (20191231_3.1-2 -> 20210419_3.1-1)
[2021-06-08T13:43:39+0100] [ALPM] upgraded libunwind (1.3.1-2 -> 1.5.0-1)
[2021-06-08T13:43:38+0100] [ALPM] upgraded libdrm (2.4.103-2 -> 2.4.106-1)
[2021-06-08T13:43:38+0100] [ALPM] upgraded wayland-protocols (1.20-1 -> 1.21-1)
[2021-06-08T13:43:38+0100] [ALPM] upgraded json-glib (1.6.0-1 -> 1.6.2-1)
[2021-06-08T13:43:38+0100] [ALPM] upgraded libxkbcommon (1.0.3-1 -> 1.3.0-1)
[2021-06-08T13:43:37+0100] [ALPM] upgraded xkeyboard-config (2.31-1 -> 2.32-1)
[2021-06-08T13:43:37+0100] [ALPM] upgraded wayland (1.18.0-2 -> 1.19.0-1)
[2021-06-08T13:43:36+0100] [ALPM] upgraded libepoxy (1.5.4-2 -> 1.5.8-1)
[2021-06-08T13:43:36+0100] [ALPM] upgraded appstream (0.13.1-1 -> 0.14.3-1)
[2021-06-08T13:43:33+0100] [ALPM] upgraded libsoup (2.72.0+5+g0b094bff-3 -> 2.72.0+10+gfe1e295d-1)
[2021-06-08T13:43:32+0100] [ALPM] upgraded sqlite (3.33.0-2 -> 3.35.5-1)
[2021-06-08T13:43:31+0100] [ALPM] upgraded glib-networking (2.66.0-1 -> 1:2.68.1-1)
[2021-06-08T13:43:31+0100] [ALPM] upgraded gsettings-desktop-schemas (3.38.0-1 -> 40.0-3)
[2021-06-08T13:43:31+0100] [ALPM] upgraded cantarell-fonts (1:0.201-1 -> 1:0.301-1)
[2021-06-08T13:43:31+0100] [ALPM] upgraded dconf (0.38.0-1 -> 0.40.0-1)
[2021-06-08T13:43:31+0100] [ALPM] upgraded gnutls (3.6.15-1 -> 3.7.1-1)
[2021-06-08T13:43:30+0100] [ALPM] upgraded nettle (3.6-1 -> 3.7.2-1)
[2021-06-08T13:43:30+0100] [ALPM] upgraded libproxy (0.4.15+33+g454a499-2 -> 0.4.17-2)
[2021-06-08T13:43:28+0100] [ALPM] upgraded lmdb (0.9.27-1 -> 0.9.29-1)
[2021-06-08T13:43:28+0100] [ALPM] upgraded apm (2.6.0-1 -> 2.6.1-4)
[2021-06-08T13:43:24+0100] [ALPM] upgraded npm (6.14.8-2 -> 7.15.0-1)
[2021-06-08T13:43:23+0100] [ALPM] upgraded node-gyp (7.1.0-1 -> 8.1.0-1)
[2021-06-08T13:43:21+0100] [ALPM] upgraded semver (7.3.2-1 -> 7.3.5-2)
[2021-06-08T13:43:20+0100] [ALPM] upgraded python (3.8.6-1 -> 3.9.5-3)
[2021-06-08T13:43:15+0100] [ALPM] upgraded gdbm (1.18.1-3 -> 1.19-2)
[2021-06-08T13:43:14+0100] [ALPM] upgraded nodejs (15.3.0-1 -> 16.2.0-1)
[2021-06-08T13:43:12+0100] [ALPM] upgraded libuv (1.40.0-1 -> 1.41.0-1)
[2021-06-08T13:43:12+0100] [ALPM] upgraded libnsl (1.3.0-1 -> 1.3.0-2)
[2021-06-08T13:43:12+0100] [ALPM] upgraded aom (2.0.0-1 -> 3.1.0-1)
[2021-06-08T13:43:12+0100] [ALPM] upgraded antlr4-runtime (4.8-1 -> 4.9.2-2)
[2021-06-08T13:43:12+0100] [ALPM] upgraded android-tools (30.0.5-1 -> 31.0.0-3)
[2021-06-08T13:43:11+0100] [ALPM] upgraded android-udev (20201003-1 -> 20210501-1)
[2021-06-08T13:43:04+0100] [ALPM] upgraded systemd (246.6-1 -> 247.7-1)
[2021-06-08T13:43:01+0100] [ALPM] warning: /etc/systemd/pstore.conf installed as /etc/systemd/pstore.conf.pacnew
[2021-06-08T13:43:01+0100] [ALPM] warning: /etc/systemd/homed.conf installed as /etc/systemd/homed.conf.pacnew
[2021-06-08T13:42:56+0100] [ALPM] upgraded pcre2 (10.35-1 -> 10.37-1)
[2021-06-08T13:42:56+0100] [ALPM] upgraded util-linux (2.36.1-3 -> 2.36.2-1)
[2021-06-08T13:42:55+0100] [ALPM] upgraded file (5.39-1 -> 5.40-5)
[2021-06-08T13:42:55+0100] [ALPM] upgraded libseccomp (2.4.2-1 -> 2.5.1-2)
[2021-06-08T13:42:55+0100] [ALPM] upgraded libelf (0.181-1 -> 0.184-1)
[2021-06-08T13:42:55+0100] [ALPM] upgraded curl (7.73.0-1 -> 7.77.0-1)
[2021-06-08T13:42:54+0100] [ALPM] upgraded ca-certificates-mozilla (3.59-1 -> 3.66-1)
[2021-06-08T13:42:54+0100] [ALPM] upgraded findutils (4.7.0-2 -> 4.8.0-1)
[2021-06-08T13:42:54+0100] [ALPM] upgraded p11-kit (0.23.21-1 -> 0.23.22-1)
[2021-06-08T13:42:54+0100] [ALPM] upgraded gmp (6.2.0-1 -> 6.2.1-1)
[2021-06-08T13:42:53+0100] [ALPM] upgraded libp11-kit (0.23.21-1 -> 0.23.22-1)
[2021-06-08T13:42:52+0100] [ALPM] upgraded libtasn1 (4.16.0-1 -> 4.17.0-1)
[2021-06-08T13:42:52+0100] [ALPM] upgraded libnghttp2 (1.41.0-1 -> 1.43.0-1)
[2021-06-08T13:42:52+0100] [ALPM] upgraded libssh2 (1.9.0-2 -> 1.9.0-3)
[2021-06-08T13:42:51+0100] [ALPM] upgraded libidn2 (2.3.0-1 -> 2.3.1-1)
[2021-06-08T13:42:51+0100] [ALPM] upgraded hwids (20200813.1-1 -> 20201207-1)
[2021-06-08T13:42:51+0100] [ALPM] upgraded kmod (27-2 -> 29-1)
[2021-06-08T13:42:51+0100] [ALPM] upgraded kbd (2.3.0-2 -> 2.4.0-2)
[2021-06-08T13:42:51+0100] [ALPM] upgraded iptables (1:1.8.6-1 -> 1:1.8.7-1)
[2021-06-08T13:42:51+0100] [ALPM] upgraded libpcap (1.9.1-4 -> 1.10.0-1)
[2021-06-08T13:42:51+0100] [ALPM] upgraded libnl (3.5.0-2 -> 3.5.0-3)
[2021-06-08T13:42:50+0100] [ALPM] upgraded libnftnl (1.1.8-1 -> 1.1.9-1)
[2021-06-08T13:42:50+0100] [ALPM] upgraded cryptsetup (2.3.4-1 -> 2.3.6-1)
[2021-06-08T13:42:50+0100] [ALPM] upgraded device-mapper (2.02.187-3 -> 2.03.12-1)
[2021-06-08T13:42:50+0100] [ALPM] upgraded brotli (1.0.9-2 -> 1.0.9-4)
[2021-06-08T13:42:50+0100] [ALPM] upgraded protobuf (3.12.4-1 -> 3.16.0-1)
[2021-06-08T13:42:49+0100] [ALPM] upgraded libusb (1.0.23-3 -> 1.0.24-2)
[2021-06-08T13:42:49+0100] [ALPM] upgraded systemd-libs (246.6-1 -> 247.7-1)
[2021-06-08T13:42:49+0100] [ALPM] upgraded libgcrypt (1.8.7-1 -> 1.9.3-1)
[2021-06-08T13:42:49+0100] [ALPM] upgraded libgpg-error (1.39-1 -> 1.42-1)
[2021-06-08T13:42:49+0100] [ALPM] upgraded libcap (2.45-2 -> 2.50-1)
[2021-06-08T13:42:48+0100] [ALPM] upgraded pam (1.5.0-1 -> 1.5.1-1)
[2021-06-08T13:42:48+0100] [ALPM] upgraded libxcrypt (4.4.17-1 -> 4.4.20-1)
[2021-06-08T13:42:48+0100] [ALPM] upgraded audit (2.8.5-6 -> 3.0.1-1)
[2021-06-08T13:42:48+0100] [ALPM] upgraded libcap-ng (0.8-1 -> 0.8.2-1)
[2021-06-08T13:42:48+0100] [ALPM] upgraded libtirpc (1.2.6-1 -> 1.3.2-1)
[2021-06-08T13:42:47+0100] [ALPM] upgraded krb5 (1.18.2-1 -> 1.19.1-1)
[2021-06-08T13:42:47+0100] [ALPM] upgraded libldap (2.4.54-1 -> 2.4.58-3)
[2021-06-08T13:42:47+0100] [ALPM] upgraded openssl (1.1.1.h-1 -> 1.1.1.k-1)
[2021-06-08T13:42:46+0100] [ALPM] upgraded e2fsprogs (1.45.6-3 -> 1.46.2-1)
[2021-06-08T13:42:44+0100] [ALPM] upgraded alsa-card-profiles (14.0-1 -> 1:0.3.28-1)
[2021-06-08T13:42:43+0100] [ALPM] upgraded adwaita-icon-theme (3.38.0-1 -> 40.1.1-1)
[2021-06-08T13:42:39+0100] [ALPM] upgraded gtk-update-icon-cache (1:3.24.23-4 -> 1:4.2.1-1)
[2021-06-08T13:42:39+0100] [ALPM] upgraded librsvg (2:2.50.2-1 -> 2:2.50.6-1)
[2021-06-08T13:42:39+0100] [ALPM] upgraded pango (1:1.48.0-1 -> 1:1.48.5-1)
[2021-06-08T13:42:39+0100] [ALPM] upgraded libdatrie (0.2.12-2 -> 0.2.13-1)
[2021-06-08T13:42:39+0100] [ALPM] upgraded cairo (1.17.2+25+gaee96d175-1 -> 1.17.4-5)
[2021-06-08T13:42:39+0100] [ALPM] upgraded libx11 (1.7.0-1 -> 1.7.1-1)
[2021-06-08T13:42:38+0100] [ALPM] upgraded xcb-proto (1.14.1-1 -> 1.14.1-3)
[2021-06-08T13:42:38+0100] [ALPM] upgraded xorgproto (2020.1-1 -> 2021.4-1)
[2021-06-08T13:42:29+0100] [ALPM] upgraded fontconfig (2:2.13.91+48+gfcb0420-2 -> 2:2.13.93-4)
[2021-06-08T13:42:29+0100] [ALPM] warning: /etc/fonts/fonts.conf installed as /etc/fonts/fonts.conf.pacnew
[2021-06-08T13:42:29+0100] [ALPM] upgraded harfbuzz (2.7.2-1 -> 2.8.1-1)
[2021-06-08T13:42:29+0100] [ALPM] upgraded expat (2.2.10-2 -> 2.4.1-1)
[2021-06-08T13:42:29+0100] [ALPM] upgraded gdk-pixbuf2 (2.42.0-2 -> 2.42.6-1)
[2021-06-08T13:42:28+0100] [ALPM] upgraded shared-mime-info (2.0+1+g6bf9e4f-2 -> 2.0+57+gc1d1c70-1)
[2021-06-08T13:42:28+0100] [ALPM] upgraded libxml2 (2.9.10-6 -> 2.9.10-9)
[2021-06-08T13:42:26+0100] [ALPM] upgraded icu (67.1-1 -> 69.1-1)
[2021-06-08T13:42:24+0100] [ALPM] upgraded libtiff (4.1.0-2 -> 4.3.0-1)
[2021-06-08T13:42:23+0100] [ALPM] upgraded zstd (1.4.5-1 -> 1.5.0-1)
[2021-06-08T13:42:22+0100] [ALPM] upgraded lz4 (1:1.9.2-2 -> 1:1.9.3-2)
[2021-06-08T13:42:22+0100] [ALPM] upgraded libjpeg-turbo (2.0.6-1 -> 2.1.0-1)
[2021-06-08T13:42:22+0100] [ALPM] upgraded glib2 (2.66.2-1 -> 2.68.2-1)
[2021-06-08T13:42:18+0100] [ALPM] upgraded bash (5.0.018-1 -> 5.1.008-3)
[2021-06-08T13:42:17+0100] [ALPM] upgraded bashrc-manjaro (5.0.018-1 -> 5.1.008-3)
[2021-06-08T13:42:16+0100] [ALPM] upgraded readline (8.0.004-1 -> 8.1.001-1)
[2021-06-08T13:42:16+0100] [ALPM] upgraded ncurses (6.2-1 -> 6.2-2)
[2021-06-08T13:42:12+0100] [ALPM] upgraded gcc-libs (10.2.0-3 -> 11.1.0-1)
[2021-06-08T13:42:03+0100] [ALPM] upgraded util-linux-libs (2.36.1-3 -> 2.36.2-1)
[2021-06-08T13:42:03+0100] [ALPM] upgraded adobe-source-code-pro-fonts (2.032ro+1.052it+1.012var-1 -> 2.038ro+1.058it+1.018var-1)
[2021-06-08T13:42:03+0100] [ALPM] upgraded acl (2.2.53-3 -> 2.3.1-1)
[2021-06-08T13:42:03+0100] [ALPM] upgraded lib32-attr (2.4.48-1 -> 2.5.1-1)
[2021-06-08T13:42:03+0100] [ALPM] upgraded lib32-glibc (2.32-5 -> 2.33-5)
[2021-06-08T13:42:02+0100] [ALPM] upgraded attr (2.4.48-3 -> 2.5.1-1)
[2021-06-08T13:41:54+0100] [ALPM] upgraded glibc (2.32-5 -> 2.33-5)
[2021-06-08T13:41:53+0100] [ALPM] upgraded filesystem (2020.09-2 -> 2021.01.19-1)
[2021-06-08T13:41:52+0100] [ALPM] upgraded iana-etc (20201012-1 -> 20210202-1)
[2021-06-08T13:41:52+0100] [ALPM] upgraded tzdata (2020d-1 -> 2021a-1)
[2021-06-08T13:41:51+0100] [ALPM] upgraded linux-api-headers (5.8-1 -> 5.12.3-1)
[2021-06-08T13:41:51+0100] [ALPM] removed python-dbus-common (1.2.16-1)
[2021-06-08T13:41:51+0100] [ALPM] removed python-dbus (1.2.16-1)
[2021-06-08T13:41:51+0100] [ALPM] removed knetattach (5.20.4-1)
[2021-06-08T13:41:51+0100] [ALPM] removed mhwd-nvidia-418xx (418.113-1)
[2021-06-08T13:41:51+0100] [ALPM] removed mhwd-nvidia-430xx (430.64-1.0)
[2021-06-08T13:41:51+0100] [ALPM] removed mhwd-nvidia-435xx (435.21-1.0)
[2021-06-08T13:41:51+0100] [ALPM] removed mhwd-nvidia-440xx (440.100-1)
[2021-06-08T13:41:51+0100] [ALPM] removed mhwd-nvidia-450xx (450.80.02-1)
[2021-06-08T13:41:51+0100] [ALPM] removed mhwd-nvidia-455xx (455.45.01-1)
Detailing how would greatly help other users with the same issue.
I did a fresh install lol…wiped the slate clean and started a fresh. No idea how to actually ‘‘solve’’ it.
