I reanimated my old notebook so I can post logs.
Reinstalling xorg did not helped.
In the Xorg.0.log it looks like that the NVidia Driver works properly.
Could you see something in the log (besides the Xorg crash) what might cause the problem?
[ 26.670] (--) Log file renamed from "/var/log/Xorg.pid-1299.log" to "/var/log/Xorg.0.log"
[ 26.670]
This is a pre-release version of the X server from The X.Org Foundation.
It is not supported in any way.
Bugs may be filed in the bugzilla at http://bugs.freedesktop.org/.
Select the "xorg" product for bugs you find in this release.
Before reporting bugs in pre-release versions please check the
latest version in the X.Org Foundation git repository.
See http://wiki.x.org/wiki/GitPage for git access instructions.
[ 26.670]
X.Org X Server 1.21.1.1
[ 26.671] Current Operating System: Linux whiteknight 5.15.2-2-MANJARO #1 SMP PREEMPT Sat Nov 13 19:25:38 UTC 2021 x86_64
[ 26.671] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=c0858929-7c23-44e1-83c1-72b3b828ce43 rw quiet udev.log_priority=3
[ 26.671]
[ 26.671] Current version of pixman: 0.40.0
[ 26.671] Before reporting problems, check http://wiki.x.org
[ 26.671] Markers: (--) probed, (**) from config file, (==) default setting,
[ 26.671] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Dec 3 16:54:42 2021
[ 26.671] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 26.671] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 26.671] (==) ServerLayout "layout"
[ 26.671] (**) |-->Screen "Screen0" (0)
[ 26.671] (**) | |-->Monitor "<default monitor>"
[ 26.672] (==) No device specified for screen "Screen0".
Using the first device section listed.
[ 26.672] (**) | |-->Device "Device0"
[ 26.672] (==) No monitor specified for screen "Screen0".
[ 26.672] (==) Automatically adding devices
[ 26.672] (==) Automatically enabling devices
[ 26.672] (==) Automatically adding GPU devices
[ 26.672] (==) Automatically binding GPU devices
[ 26.672] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 26.672] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 26.672] Entry deleted from font path.
[ 26.672] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 26.672] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 26.672] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 26.672] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 26.672] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 26.672] (**) Extension "COMPOSITE" is enabled
[ 26.672] (II) The server relies on udev to provide the list of input devices.
[ 26.672] (II) Module ABI versions:
[ 26.672] X.Org ANSI C Emulation: 0.4
[ 26.672] X.Org Video Driver: 25.2
[ 26.672] X.Org XInput driver : 24.4
[ 26.672] X.Org Server Extension : 10.0
[ 26.673] (++) using VT number 1
[ 26.673] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 26.674] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 26.674] (II) Platform probe for /sys/devices/pci0000:00/0000:00:03.1/0000:1d:00.0/drm/card0
[ 26.677] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 26.677] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 26.680] (--) PCI:*(29@0:0:0) 10de:2206:1458:403f rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[ 26.680] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 26.680] (II) "glx" will be loaded by default.
[ 26.680] (II) LoadModule: "vnc"
[ 26.680] (II) Loading /usr/lib/xorg/modules/extensions/libvnc.so
[ 26.690] (II) Module vnc: vendor="TigerVNC Project"
[ 26.690] compiled for 1.20.9, module version = 1.0.0
[ 26.690] Module class: X.Org Server Extension
[ 26.690] ABI class: X.Org Server Extension, version 10.0
[ 26.690] (II) LoadModule: "glx"
[ 26.690] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 26.692] (II) Module glx: vendor="X.Org Foundation"
[ 26.692] compiled for 1.21.1.1, module version = 1.0.0
[ 26.692] ABI class: X.Org Server Extension, version 10.0
[ 26.692] (II) LoadModule: "nvidia"
[ 26.692] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 26.692] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 26.692] compiled for 1.6.99.901, module version = 1.0.0
[ 26.692] Module class: X.Org Video Driver
[ 26.692] (II) NVIDIA dlloader X Driver 495.44 Fri Oct 22 06:11:21 UTC 2021
[ 26.693] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 26.693] (II) Loading sub module "fb"
[ 26.693] (II) LoadModule: "fb"
[ 26.693] (II) Module "fb" already built-in
[ 26.693] (II) Loading sub module "wfb"
[ 26.693] (II) LoadModule: "wfb"
[ 26.693] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 26.693] (II) Module wfb: vendor="X.Org Foundation"
[ 26.693] compiled for 1.21.1.1, module version = 1.0.0
[ 26.693] ABI class: X.Org ANSI C Emulation, version 0.4
[ 26.693] (II) Loading sub module "ramdac"
[ 26.693] (II) LoadModule: "ramdac"
[ 26.693] (II) Module "ramdac" already built-in
[ 26.694] (II) NVIDIA(0): Creating default Display subsection in Screen section
"Screen0" for depth/fbbpp 24/32
[ 26.694] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 26.694] (==) NVIDIA(0): RGB weight 888
[ 26.694] (==) NVIDIA(0): Default visual is TrueColor
[ 26.694] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 26.694] (**) Option "AllowNVIDIAGpuScreens"
[ 26.694] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 26.694] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 26.694] (**) NVIDIA(0): Enabling 2D acceleration
[ 26.694] (II) Loading sub module "glxserver_nvidia"
[ 26.694] (II) LoadModule: "glxserver_nvidia"
[ 26.694] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 26.703] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 26.703] compiled for 1.6.99.901, module version = 1.0.0
[ 26.703] Module class: X.Org Server Extension
[ 26.703] (II) NVIDIA GLX Module 495.44 Fri Oct 22 06:08:29 UTC 2021
[ 26.703] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 27.304] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:29:0:0
[ 27.304] (--) NVIDIA(0): DFP-0 (boot)
[ 27.304] (--) NVIDIA(0): DFP-1
[ 27.304] (--) NVIDIA(0): DFP-2
[ 27.304] (--) NVIDIA(0): DFP-3
[ 27.304] (--) NVIDIA(0): DFP-4
[ 27.304] (--) NVIDIA(0): DFP-5
[ 27.304] (--) NVIDIA(0): DFP-6
[ 27.304] (--) NVIDIA(0): DFP-7
[ 27.304] (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce RTX 3080 (GA102-A) at PCI:29:0:0
[ 27.304] (II) NVIDIA(0): (GPU-0)
[ 27.304] (--) NVIDIA(0): Memory: 10485760 kBytes
[ 27.304] (--) NVIDIA(0): VideoBIOS: 94.02.26.48.31
[ 27.304] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 27.305] (--) NVIDIA(GPU-0): LG Electronics LG Ultra HD (DFP-0): connected
[ 27.305] (--) NVIDIA(GPU-0): LG Electronics LG Ultra HD (DFP-0): Internal DisplayPort
[ 27.305] (--) NVIDIA(GPU-0): LG Electronics LG Ultra HD (DFP-0): 2670.0 MHz maximum pixel clock
[ 27.307] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 27.307] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 27.307] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 27.307] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 27.307] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 27.307] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 27.307] (--) NVIDIA(GPU-0): DFP-3: disconnected
[ 27.307] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[ 27.307] (--) NVIDIA(GPU-0): DFP-3: 2670.0 MHz maximum pixel clock
[ 27.307] (--) NVIDIA(GPU-0): DFP-4: disconnected
[ 27.307] (--) NVIDIA(GPU-0): DFP-4: Internal TMDS
[ 27.307] (--) NVIDIA(GPU-0): DFP-4: 165.0 MHz maximum pixel clock
[ 27.307] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 27.307] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 27.307] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 27.307] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 27.307] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 27.307] (--) NVIDIA(GPU-0): DFP-6: 2670.0 MHz maximum pixel clock
[ 27.307] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 27.307] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 27.307] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 27.333] (==) NVIDIA(0):
[ 27.333] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 27.333] (==) NVIDIA(0): will be used as the requested mode.
[ 27.334] (II) NVIDIA(0): Validated MetaModes:
[ 27.334] (II) NVIDIA(0): "DFP-0:nvidia-auto-select"
[ 27.334] (II) NVIDIA(0): Virtual screen size determined to be 3840 x 2160
[ 27.374] (--) NVIDIA(0): DPI set to (162, 161); computed from "UseEdidDpi" X config
[ 27.374] (--) NVIDIA(0): option
[ 27.375] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 27.375] (II) NVIDIA: access.
[ 27.378] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 27.378] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 27.378] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 27.378] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 27.378] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 27.378] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 27.378] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 27.378] (II) NVIDIA(0): Config Options in the README.
[ 27.398] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select"
[ 27.514] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 27.514] (==) NVIDIA(0): Backing store enabled
[ 27.514] (==) NVIDIA(0): Silken mouse enabled
[ 27.514] (==) NVIDIA(0): DPMS enabled
[ 27.514] (WW) NVIDIA(0): Option "NoLogo" is not used
[ 27.514] (WW) NVIDIA(0): Option "UserPasswdVerifier" is not used
[ 27.514] (WW) NVIDIA(0): Option "PasswordFile" is not used
[ 27.514] (II) Loading sub module "dri2"
[ 27.514] (II) LoadModule: "dri2"
[ 27.514] (II) Module "dri2" already built-in
[ 27.514] (II) NVIDIA(0): [DRI2] Setup complete
[ 27.514] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 27.514] (II) Initializing extension Generic Event Extension
[ 27.514] (II) Initializing extension SHAPE
[ 27.514] (II) Initializing extension MIT-SHM
[ 27.515] (II) Initializing extension XInputExtension
[ 27.515] (II) Initializing extension XTEST
[ 27.515] (II) Initializing extension BIG-REQUESTS
[ 27.515] (II) Initializing extension SYNC
[ 27.515] (II) Initializing extension XKEYBOARD
[ 27.515] (II) Initializing extension XC-MISC
[ 27.515] (II) Initializing extension SECURITY
[ 27.515] (II) Initializing extension XFIXES
[ 27.515] (II) Initializing extension RENDER
[ 27.515] (II) Initializing extension RANDR
[ 27.515] (II) Initializing extension COMPOSITE
[ 27.515] (II) Initializing extension DAMAGE
[ 27.515] (II) Initializing extension MIT-SCREEN-SAVER
[ 27.516] (II) Initializing extension DOUBLE-BUFFER
[ 27.516] (II) Initializing extension RECORD
[ 27.516] (II) Initializing extension DPMS
[ 27.516] (II) Initializing extension Present
[ 27.516] (II) Initializing extension DRI3
[ 27.516] (II) Initializing extension X-Resource
[ 27.516] (II) Initializing extension XVideo
[ 27.516] (II) Initializing extension XVideo-MotionCompensation
[ 27.516] (II) Initializing extension GLX
[ 27.516] (II) Indirect GLX disabled.
[ 27.516] (II) GLX: Another vendor is already registered for screen 0
[ 27.516] (II) Initializing extension XFree86-VidModeExtension
[ 27.516] (II) Initializing extension XFree86-DGA
[ 27.516] (II) Initializing extension XFree86-DRI
[ 27.516] (II) Initializing extension DRI2
[ 27.516] (II) Initializing extension VNC
[ 27.516] (EE)
[ 27.516] (EE) Backtrace:
[ 27.516] (EE) 0: /usr/lib/Xorg (xorg_backtrace+0x89) [0x563d90725059]
[ 27.516] (EE) 1: /usr/lib/Xorg (0x563d905d5000+0x15ae79) [0x563d9072fe79]
[ 27.516] (EE) 2: /usr/lib/libpthread.so.0 (0x7fbc0bf17000+0x13870) [0x7fbc0bf2a870]
[ 27.516] (EE) 3: /usr/lib/Xorg (xf86OptionValue+0xb) [0x563d9073c3db]
[ 27.516] (EE) 4: /usr/lib/xorg/modules/extensions/libvnc.so (0x7fbc0b39a000+0x34c11) [0x7fbc0b3cec11]
[ 27.516] (EE) 5: /usr/lib/Xorg (InitExtensions+0x89) [0x563d9061dd29]
[ 27.517] (EE) 6: /usr/lib/Xorg (0x563d905d5000+0x3c35b) [0x563d9061135b]
[ 27.517] (EE) 7: /usr/lib/libc.so.6 (__libc_start_main+0xd5) [0x7fbc0bd6db25]
[ 27.517] (EE) 8: /usr/lib/Xorg (_start+0x2e) [0x563d9061275e]
[ 27.517] (EE)
[ 27.517] (EE) Segmentation fault at address 0x100000011
[ 27.517] (EE)
Fatal server error:
[ 27.517] (EE) Caught signal 11 (Segmentation fault). Server aborting
[ 27.517] (EE)
[ 27.517] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 27.517] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 27.517] (EE)
[ 27.617] (EE) Server terminated with error (1). Closing log file.
