I have a cursor but no KDE and cannot start anything. Also for some reason the date on the SDM is in spanish.
What device and what image did you flash?
I have a Raspbery Pi 4B+ with 4GB and flashed Manjaro-ARM-kde-plasma-rpi4-21.02.img.xz.
I don’t know of a 4B+ device. Only 4B and 400.
Sorry, just a 4B
Well, the date in SDDM, should only be in spanish, if you chose spanish locale through the Setup.
Can you try reflashing, maybe try another SD card too?
I just noticed also nano is in spanish, but my locale is set to en_US-UTF-8.
This would be the third reflash today.
Then I don’t know why it’s setting to spanish locale.
It should only do that if you choose it in the Setup. Please verify that you choose en_US in the local selection.
Yes, that is what I selected. I am flashing a different card with the same image and going to try again. If that works, the only differnce will be the current card is a Samsung 128GB and the new card is a Samsung EVO 64GB.
Success! It has to be the card as it was like 10 times faster on the EVO card. It may have been trying to setup the desktop or something.
EDIT: Well, I guess not. After manually having to switch to tty2 to restart as Dr. Konqi kept telling me the KSM-Greeter crashed. I now have a blank black screen again.
The problem is that I am running on a 50" 4K TV that worked fine previously. Now that I did a fresh install and upgrade any window that opens I cannot resize too big as it blanks out to black and subsequent re-openings of the program just crash. This is what happened with System Settings, and now every other boot KDE just displays a blank black screen. My assumption is that it cannot recognize my TVs true resolution and freaks out.
Here is my Xorg.0.log:
[ 8.298] (--) Log file renamed from "/var/log/Xorg.pid-483.log" to "/var/log/Xorg.0.log"
[ 8.308]
X.Org X Server 1.20.10
[ 8.308] Build Operating System: Linux Arch Linux
[ 8.308] Current Operating System: Linux PERSIOPE 5.10.17-1-MANJARO-ARM #1 SMP PREEMPT Mon Feb 22 11:29:03 CST 2021 aarch64
[ 8.308] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:3840x2160M@30 smsc95xx.macaddr=DC:A6:32:8F:44:03 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 root=PARTUUID=2a586bd1-02 rw rootwait console=ttyS0,115200 console=tty3 selinux=0 quiet splash plymouth.ignore-serial-consoles smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 kgdboc=ttyS0,115200 elevator=noop usbhid.mousepoll=8 snd-bcm2835.enable_compat_alsa=0 audit=0
[ 8.308] Build Date: 16 December 2020 11:52:03PM
[ 8.308]
[ 8.308] Current version of pixman: 0.40.0
[ 8.308] Before reporting problems, check http://wiki.x.org
[ 8.308] Markers: (--) probed, (**) from config file, (==) default setting,
[ 8.309] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Mar 13 15:38:32 2021
[ 8.318] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 8.319] (==) No Layout section. Using the first Screen section.
[ 8.319] (==) No screen section available. Using defaults.
[ 8.319] (**) |-->Screen "Default Screen Section" (0)
[ 8.319] (**) | |-->Monitor "<default monitor>"
[ 8.319] (==) No monitor specified for screen "Default Screen Section".
[ 8.319] (==) Automatically adding devices
[ 8.319] (==) Automatically enabling devices
[ 8.319] (==) Automatically adding GPU devices
[ 8.319] (==) Automatically binding GPU devices
[ 8.319] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 8.320] (WW) The directory "/usr/share/fonts/misc" does not exist.
[ 8.320] Entry deleted from font path.
[ 8.321] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 8.321] Entry deleted from font path.
[ 8.321] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[ 8.321] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 8.321] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 8.321] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 8.321] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 8.321] (==) FontPath set to:
[ 8.321] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 8.321] (II) The server relies on udev to provide the list of input devices.
[ 8.324] (II) Module ABI versions:
[ 8.324] X.Org ANSI C Emulation: 0.4
[ 8.324] X.Org Video Driver: 24.1
[ 8.324] X.Org XInput driver : 24.1
[ 8.324] X.Org Server Extension : 10.0
[ 8.325] (++) using VT number 1
[ 8.325] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 8.327] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 8.332] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 8.334] (II) no primary bus or device found
[ 8.334] falling back to /sys/devices/platform/gpu/drm/card0
[ 8.334] (II) LoadModule: "glx"
[ 8.337] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 8.401] (II) Module glx: vendor="X.Org Foundation"
[ 8.401] compiled for 1.20.10, module version = 1.0.0
[ 8.401] ABI class: X.Org Server Extension, version 10.0
[ 8.401] (==) Matched modesetting as autoconfigured driver 0
[ 8.401] (==) Matched fbdev as autoconfigured driver 1
[ 8.402] (==) Assigned the driver to the xf86ConfigLayout
[ 8.402] (II) LoadModule: "modesetting"
[ 8.402] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 8.416] (II) Module modesetting: vendor="X.Org Foundation"
[ 8.416] compiled for 1.20.10, module version = 1.20.10
[ 8.416] Module class: X.Org Video Driver
[ 8.416] ABI class: X.Org Video Driver, version 24.1
[ 8.416] (II) LoadModule: "fbdev"
[ 8.417] (WW) Warning, couldn't open module fbdev
[ 8.418] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 8.418] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 8.432] (II) modeset(0): using drv /dev/dri/card0
[ 8.451] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 8.452] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 8.452] (==) modeset(0): RGB weight 888
[ 8.452] (==) modeset(0): Default visual is TrueColor
[ 8.452] (II) Loading sub module "glamoregl"
[ 8.452] (II) LoadModule: "glamoregl"
[ 8.453] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 8.498] (II) Module glamoregl: vendor="X.Org Foundation"
[ 8.498] compiled for 1.20.10, module version = 1.0.1
[ 8.498] ABI class: X.Org ANSI C Emulation, version 0.4
[ 9.886] (II) modeset(0): glamor X acceleration enabled on V3D 4.2
[ 9.886] (II) modeset(0): glamor initialized
[ 9.917] (II) modeset(0): Output HDMI-1 has no monitor section
[ 9.951] (II) modeset(0): EDID for output HDMI-1
[ 9.951] (II) modeset(0): Manufacturer: TCL Model: 0 Serial#: 0
[ 9.951] (II) modeset(0): Year: 2020 Week: 18
[ 9.951] (II) modeset(0): EDID Version: 1.3
[ 9.951] (II) modeset(0): Digital Display Input
[ 9.952] (II) modeset(0): Max Image Size [cm]: horiz.: 111 vert.: 62
[ 9.952] (II) modeset(0): Gamma: 2.20
[ 9.952] (II) modeset(0): No DPMS capabilities specified
[ 9.952] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 9.952] (II) modeset(0): First detailed timing is preferred mode
[ 9.952] (II) modeset(0): redX: 0.643 redY: 0.332 greenX: 0.322 greenY: 0.623
[ 9.952] (II) modeset(0): blueX: 0.146 blueY: 0.056 whiteX: 0.280 whiteY: 0.290
[ 9.952] (II) modeset(0): Supported established timings:
[ 9.952] (II) modeset(0): 720x400@70Hz
[ 9.952] (II) modeset(0): 640x480@60Hz
[ 9.952] (II) modeset(0): 640x480@72Hz
[ 9.952] (II) modeset(0): 640x480@75Hz
[ 9.952] (II) modeset(0): 800x600@60Hz
[ 9.952] (II) modeset(0): 800x600@72Hz
[ 9.952] (II) modeset(0): 800x600@75Hz
[ 9.952] (II) modeset(0): 1024x768@60Hz
[ 9.952] (II) modeset(0): 1024x768@70Hz
[ 9.952] (II) modeset(0): 1024x768@75Hz
[ 9.952] (II) modeset(0): 1280x1024@75Hz
[ 9.952] (II) modeset(0): Manufacturer's mask: 0
[ 9.952] (II) modeset(0): Supported standard timings:
[ 9.952] (II) modeset(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 9.952] (II) modeset(0): #1: hsize: 1280 vsize 960 refresh: 60 vid: 16513
[ 9.952] (II) modeset(0): #2: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 9.953] (II) modeset(0): #3: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 9.953] (II) modeset(0): #4: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 9.953] (II) modeset(0): #5: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 9.953] (II) modeset(0): #6: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 9.953] (II) modeset(0): #7: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 9.953] (II) modeset(0): Supported detailed timing:
[ 9.953] (II) modeset(0): clock: 297.0 MHz Image Size: 800 x 450 mm
[ 9.953] (II) modeset(0): h_active: 3840 h_sync: 4016 h_sync_end 4104 h_blank_end 4400 h_border: 0
[ 9.953] (II) modeset(0): v_active: 2160 v_sync: 2168 v_sync_end 2178 v_blanking: 2250 v_border: 0
[ 9.953] (II) modeset(0): clock: 148.5 MHz Image Size: 800 x 450 mm
[ 9.953] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 9.953] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 9.953] (II) modeset(0): Monitor name: 50S421
[ 9.953] (II) modeset(0): Ranges: V min: 23 V max: 76 Hz, H min: 15 H max: 81 kHz, PixClock max 345 MHz
[ 9.954] (II) modeset(0): h_active: 3840 h_sync: 4016 h_sync_end 4104 h_blank_end 4400 h_border: 0
[ 9.954] (II) modeset(0): v_active: 2160 v_sync: 2168 v_sync_end 2178 v_blanking: 2250 v_border: 0
[ 9.954] (II) modeset(0): Supported detailed timing:
[ 9.954] (II) modeset(0): clock: 148.5 MHz Image Size: 800 x 450 mm
[ 9.954] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 9.954] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 9.954] (II) modeset(0): clock: 74.2 MHz Image Size: 800 x 450 mm
[ 9.954] (II) modeset(0): h_active: 1280 h_sync: 1390 h_sync_end 1430 h_blank_end 1650 h_border: 0
[ 9.954] (II) modeset(0): v_active: 720 v_sync: 725 v_sync_end 730 v_blanking: 750 v_border: 0
[ 9.954] (II) modeset(0): Number of EDID sections to follow: 1
[ 9.954] (II) modeset(0): EDID (in hex):
[ 9.954] (II) modeset(0): 00ffffffffffff00506c000000000000
[ 9.954] (II) modeset(0): 121e0103806f3e780a8a5da455529f25
[ 9.954] (II) modeset(0): 0e474aadcf00714f8140818081009500
[ 9.954] (II) modeset(0): b300d1c081c004740030f2705a80b058
[ 9.955] (II) modeset(0): 8a0020c23100001e023a801871382d40
[ 9.955] (II) modeset(0): 582c450020c23100001e000000fc0035
[ 9.955] (II) modeset(0): 30533432310a202020202020000000fd
[ 9.955] (II) modeset(0): 00174c0f5122000a20202020202001ec
[ 9.955] (II) modeset(0): 02033f714e5f5d646210222005043e3c
[ 9.955] (II) modeset(0): 0201062f090707150750570700670403
[ 9.955] (II) modeset(0): 3d07c06d030c002300b83c2000600103
[ 9.955] (II) modeset(0): 04e200cfe30e6166e61146d000708004
[ 9.955] (II) modeset(0): 740030f2705a80b0588a0020c2310000
[ 9.955] (II) modeset(0): 1e023a801871382d40582c450020c231
[ 9.955] (II) modeset(0): 00001e011d007251d01e206e28550020
[ 9.955] (II) modeset(0): c23100001e0000000000000000000004
[ 9.956] (--) modeset(0): HDMI max TMDS frequency 300000KHz
[ 9.956] (II) modeset(0): Printing probed modes for output HDMI-1
[ 9.956] (II) modeset(0): Modeline "3840x2160"x30.0 297.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.5 kHz eP)
[ 9.956] (II) modeset(0): Modeline "4096x2160"x30.0 297.00 4096 4184 4272 4400 2160 2168 2178 2250 +hsync +vsync (67.5 kHz e)
[ 9.956] (II) modeset(0): Modeline "4096x2160"x24.0 297.00 4096 5116 5204 5500 2160 2168 2178 2250 +hsync +vsync (54.0 kHz e)
[ 9.956] (II) modeset(0): Modeline "4096x2160"x30.0 296.70 4096 4184 4272 4400 2160 2168 2178 2250 +hsync +vsync (67.4 kHz e)
[ 9.956] (II) modeset(0): Modeline "4096x2160"x24.0 296.70 4096 5116 5204 5500 2160 2168 2178 2250 +hsync +vsync (53.9 kHz e)
[ 9.956] (II) modeset(0): Modeline "3840x2160"x24.0 297.00 3840 5116 5204 5500 2160 2168 2178 2250 +hsync +vsync (54.0 kHz e)
[ 9.956] (II) modeset(0): Modeline "3840x2160"x30.0 296.70 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.4 kHz e)
[ 9.956] (II) modeset(0): Modeline "3840x2160"x24.0 296.70 3840 5116 5204 5500 2160 2168 2178 2250 +hsync +vsync (53.9 kHz e)
[ 9.956] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 9.956] (II) modeset(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 9.956] (II) modeset(0): Modeline "1920x1080i"x60.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 9.956] (II) modeset(0): Modeline "1920x1080"x30.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[ 9.956] (II) modeset(0): Modeline "1920x1080"x24.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 9.957] (II) modeset(0): Modeline "1920x1080i"x59.9 74.18 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[ 9.957] (II) modeset(0): Modeline "1920x1080"x30.0 74.18 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.7 kHz e)
[ 9.957] (II) modeset(0): Modeline "1920x1080"x24.0 74.18 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 9.957] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 9.957] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 9.957] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 9.957] (II) modeset(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 9.957] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 9.957] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[ 9.957] (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 9.957] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 9.957] (II) modeset(0): Modeline "1280x720"x30.0 74.25 1280 3040 3080 3300 720 725 730 750 +hsync +vsync (22.5 kHz e)
[ 9.957] (II) modeset(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 9.957] (II) modeset(0): Modeline "1280x720"x30.0 74.18 1280 3040 3080 3300 720 725 730 750 +hsync +vsync (22.5 kHz e)
[ 9.957] (II) modeset(0): Modeline "1280x720"x24.0 59.40 1280 3040 3080 3300 720 725 730 750 +hsync +vsync (18.0 kHz e)
[ 9.957] (II) modeset(0): Modeline "1280x720"x24.0 59.34 1280 3040 3080 3300 720 725 730 750 +hsync +vsync (18.0 kHz e)
[ 9.958] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 9.958] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 9.958] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 9.958] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 9.958] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 9.958] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 9.958] (II) modeset(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 9.958] (II) modeset(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 9.958] (II) modeset(0): Modeline "720x480i"x60.0 13.51 720 739 801 858 480 488 494 525 interlace -hsync -vsync (15.8 kHz e)
[ 9.958] (II) modeset(0): Modeline "720x480i"x59.9 13.50 720 739 801 858 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[ 9.958] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 9.958] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 9.958] (II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 9.958] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 9.958] (II) modeset(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 9.958] (II) modeset(0): Output HDMI-1 connected
[ 9.958] (II) modeset(0): Using exact sizes for initial modes
[ 9.959] (II) modeset(0): Output HDMI-1 using initial mode 3840x2160 +0+0
[ 9.959] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 9.959] (==) modeset(0): DPI set to (96, 96)
[ 9.959] (II) Loading sub module "fb"
[ 9.959] (II) LoadModule: "fb"
[ 9.959] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 9.964] (II) Module fb: vendor="X.Org Foundation"
[ 9.964] compiled for 1.20.10, module version = 1.0.0
[ 9.964] ABI class: X.Org ANSI C Emulation, version 0.4
[ 10.199] (==) modeset(0): Backing store enabled
[ 10.199] (==) modeset(0): Silken mouse disabled
[ 10.399] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 10.399] (==) modeset(0): DPMS enabled
[ 10.399] (II) modeset(0): [DRI2] Setup complete
[ 10.399] (II) modeset(0): [DRI2] DRI driver: vc4
[ 10.400] (II) modeset(0): [DRI2] VDPAU driver: vc4
[ 10.400] (II) Initializing extension Generic Event Extension
[ 10.401] (II) Initializing extension SHAPE
[ 10.401] (II) Initializing extension MIT-SHM
[ 10.402] (II) Initializing extension XInputExtension
[ 10.406] (II) Initializing extension XTEST
[ 10.406] (II) Initializing extension BIG-REQUESTS
[ 10.407] (II) Initializing extension SYNC
[ 10.408] (II) Initializing extension XKEYBOARD
[ 10.409] (II) Initializing extension XC-MISC
[ 10.409] (II) Initializing extension SECURITY
[ 10.410] (II) Initializing extension XFIXES
[ 10.411] (II) Initializing extension RENDER
[ 10.412] (II) Initializing extension RANDR
[ 10.414] (II) Initializing extension COMPOSITE
[ 10.415] (II) Initializing extension DAMAGE
[ 10.415] (II) Initializing extension MIT-SCREEN-SAVER
[ 10.416] (II) Initializing extension DOUBLE-BUFFER
[ 10.417] (II) Initializing extension RECORD
[ 10.418] (II) Initializing extension DPMS
[ 10.418] (II) Initializing extension Present
[ 10.419] (II) Initializing extension DRI3
[ 10.420] (II) Initializing extension X-Resource
[ 10.421] (II) Initializing extension XVideo
[ 10.422] (II) Initializing extension XVideo-MotionCompensation
[ 10.422] (II) Initializing extension GLX
[ 10.451] (II) AIGLX: Loaded and initialized vc4
[ 10.451] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 10.451] (II) Initializing extension XFree86-VidModeExtension
[ 10.451] (II) Initializing extension XFree86-DGA
[ 10.452] (II) Initializing extension XFree86-DRI
[ 10.452] (II) Initializing extension DRI2
[ 10.459] (II) modeset(0): Damage tracking initialized
[ 10.459] (II) modeset(0): Setting screen physical size to 1016 x 571
[ 10.688] (II) config/udev: Adding input device Logitech Gamepad F710 (/dev/input/event2)
[ 10.688] (II) No input driver specified, ignoring this device.
[ 10.688] (II) This device may have been added with another device file.
[ 10.693] (II) config/udev: Adding input device Logitech Gamepad F710 (/dev/input/js0)
[ 10.693] (II) No input driver specified, ignoring this device.
[ 10.693] (II) This device may have been added with another device file.
[ 10.698] (II) config/udev: Adding input device Logitech Wireless Keyboard PID:4023 (/dev/input/event0)
[ 10.698] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "libinput keyboard catchall"
[ 10.698] (II) LoadModule: "libinput"
[ 10.699] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 10.732] (II) Module libinput: vendor="X.Org Foundation"
[ 10.732] compiled for 1.20.8, module version = 0.30.0
[ 10.732] Module class: X.Org XInput Driver
[ 10.732] ABI class: X.Org XInput driver, version 24.1
[ 10.732] (II) Using input driver 'libinput' for 'Logitech Wireless Keyboard PID:4023'
[ 10.732] (**) Logitech Wireless Keyboard PID:4023: always reports core events
[ 10.732] (**) Option "Device" "/dev/input/event0"
[ 10.733] (**) Option "_source" "server/udev"
[ 10.784] (II) event0 - Logitech Wireless Keyboard PID:4023: is tagged by udev as: Keyboard
[ 10.785] (II) event0 - Logitech Wireless Keyboard PID:4023: device is a keyboard
[ 10.786] (II) event0 - Logitech Wireless Keyboard PID:4023: device removed
[ 10.808] (II) libinput: Logitech Wireless Keyboard PID:4023: needs a virtual subdevice
[ 10.808] (**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:046D:C534.0004/0003:046D:4023.0005/input/input17/event0"
[ 10.808] (II) XINPUT: Adding extended input device "Logitech Wireless Keyboard PID:4023" (type: MOUSE, id 6)
[ 10.809] (**) Option "AccelerationScheme" "none"
[ 10.809] (**) Logitech Wireless Keyboard PID:4023: (accel) selected scheme none/0
[ 10.809] (**) Logitech Wireless Keyboard PID:4023: (accel) acceleration factor: 2.000
[ 10.809] (**) Logitech Wireless Keyboard PID:4023: (accel) acceleration threshold: 4
[ 10.818] (II) event0 - Logitech Wireless Keyboard PID:4023: is tagged by udev as: Keyboard
[ 10.819] (II) event0 - Logitech Wireless Keyboard PID:4023: device is a keyboard
[ 10.825] (II) config/udev: Adding input device Logitech Wireless Mouse (/dev/input/event1)
[ 10.825] (**) Logitech Wireless Mouse: Applying InputClass "libinput pointer catchall"
[ 10.825] (II) Using input driver 'libinput' for 'Logitech Wireless Mouse'
[ 10.825] (**) Logitech Wireless Mouse: always reports core events
[ 10.826] (**) Option "Device" "/dev/input/event1"
[ 10.826] (**) Option "_source" "server/udev"
[ 10.835] (II) event1 - Logitech Wireless Mouse: is tagged by udev as: Mouse
[ 10.835] (II) event1 - Logitech Wireless Mouse: device is a pointer
[ 10.836] (II) event1 - Logitech Wireless Mouse: device removed
[ 10.872] (**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:046D:C534.0004/0003:046D:4054.0006/input/input18/event1"
[ 10.872] (II) XINPUT: Adding extended input device "Logitech Wireless Mouse" (type: MOUSE, id 7)
[ 10.872] (**) Option "AccelerationScheme" "none"
[ 10.873] (**) Logitech Wireless Mouse: (accel) selected scheme none/0
[ 10.873] (**) Logitech Wireless Mouse: (accel) acceleration factor: 2.000
[ 10.873] (**) Logitech Wireless Mouse: (accel) acceleration threshold: 4
[ 10.885] (II) event1 - Logitech Wireless Mouse: is tagged by udev as: Mouse
[ 10.886] (II) event1 - Logitech Wireless Mouse: device is a pointer
[ 10.893] (II) config/udev: Adding input device Logitech Wireless Mouse (/dev/input/mouse0)
[ 10.893] (II) No input driver specified, ignoring this device.
[ 10.893] (II) This device may have been added with another device file.
[ 10.932] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "libinput keyboard catchall"
[ 10.932] (II) Using input driver 'libinput' for 'Logitech Wireless Keyboard PID:4023'
[ 10.932] (**) Logitech Wireless Keyboard PID:4023: always reports core events
[ 10.932] (**) Option "Device" "/dev/input/event0"
[ 10.932] (**) Option "_source" "_driver/libinput"
[ 10.933] (II) libinput: Logitech Wireless Keyboard PID:4023: is a virtual subdevice
[ 10.933] (**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:046D:C534.0004/0003:046D:4023.0005/input/input17/event0"
[ 10.933] (II) XINPUT: Adding extended input device "Logitech Wireless Keyboard PID:4023" (type: KEYBOARD, id 8)
[ 11.012] (II) config/udev: Adding input device Logitech Wireless Mouse (/dev/input/mouse0)
[ 11.012] (II) No input driver specified, ignoring this device.
[ 11.012] (II) This device may have been added with another device file.
[ 11.015] (II) config/udev: removing device Logitech Wireless Keyboard PID:4023
[ 11.016] (II) UnloadModule: "libinput"
[ 11.016] (II) config/udev: removing device Logitech Wireless Keyboard PID:4023
[ 11.017] (II) event0 - Logitech Wireless Keyboard PID:4023: device removed
[ 11.044] (II) UnloadModule: "libinput"
[ 11.050] (II) config/udev: Adding input device Logitech Wireless Keyboard PID:4023 (/dev/input/event0)
[ 11.050] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "libinput keyboard catchall"
[ 11.050] (II) Using input driver 'libinput' for 'Logitech Wireless Keyboard PID:4023'
[ 11.050] (**) Logitech Wireless Keyboard PID:4023: always reports core events
[ 11.051] (**) Option "Device" "/dev/input/event0"
[ 11.051] (**) Option "_source" "server/udev"
[ 11.064] (II) event0 - Logitech Wireless Keyboard PID:4023: is tagged by udev as: Keyboard
[ 11.065] (II) event0 - Logitech Wireless Keyboard PID:4023: device is a keyboard
[ 11.066] (II) event0 - Logitech Wireless Keyboard PID:4023: device removed
[ 11.084] (II) libinput: Logitech Wireless Keyboard PID:4023: needs a virtual subdevice
[ 11.084] (**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:046D:C534.0004/0003:046D:4023.0005/input/input17/event0"
[ 11.084] (II) XINPUT: Adding extended input device "Logitech Wireless Keyboard PID:4023" (type: MOUSE, id 6)
[ 11.084] (**) Option "AccelerationScheme" "none"
[ 11.085] (**) Logitech Wireless Keyboard PID:4023: (accel) selected scheme none/0
[ 11.085] (**) Logitech Wireless Keyboard PID:4023: (accel) acceleration factor: 2.000
[ 11.085] (**) Logitech Wireless Keyboard PID:4023: (accel) acceleration threshold: 4
[ 11.098] (II) event0 - Logitech Wireless Keyboard PID:4023: is tagged by udev as: Keyboard
[ 11.099] (II) event0 - Logitech Wireless Keyboard PID:4023: device is a keyboard
[ 11.100] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "libinput keyboard catchall"
[ 11.100] (II) Using input driver 'libinput' for 'Logitech Wireless Keyboard PID:4023'
[ 11.100] (**) Logitech Wireless Keyboard PID:4023: always reports core events
[ 11.101] (**) Option "Device" "/dev/input/event0"
[ 11.101] (**) Option "_source" "_driver/libinput"
[ 11.101] (II) libinput: Logitech Wireless Keyboard PID:4023: is a virtual subdevice
[ 11.101] (**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:046D:C534.0004/0003:046D:4023.0005/input/input17/event0"
[ 11.101] (II) XINPUT: Adding extended input device "Logitech Wireless Keyboard PID:4023" (type: KEYBOARD, id 8)
[ 11.102] (II) config/udev: removing device Logitech Wireless Mouse
[ 11.103] (II) event1 - Logitech Wireless Mouse: device removed
[ 11.132] (II) UnloadModule: "libinput"
[ 11.138] (II) config/udev: Adding input device Logitech Wireless Mouse (/dev/input/event1)
[ 11.138] (**) Logitech Wireless Mouse: Applying InputClass "libinput pointer catchall"
[ 11.138] (II) Using input driver 'libinput' for 'Logitech Wireless Mouse'
[ 11.138] (**) Logitech Wireless Mouse: always reports core events
[ 11.138] (**) Option "Device" "/dev/input/event1"
[ 11.138] (**) Option "_source" "server/udev"
[ 11.151] (II) event1 - Logitech Wireless Mouse: is tagged by udev as: Mouse
[ 11.152] (II) event1 - Logitech Wireless Mouse: device is a pointer
[ 11.153] (II) event1 - Logitech Wireless Mouse: device removed
[ 11.188] (**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:046D:C534.0004/0003:046D:4054.0006/input/input18/event1"
[ 11.188] (II) XINPUT: Adding extended input device "Logitech Wireless Mouse" (type: MOUSE, id 7)
[ 11.188] (**) Option "AccelerationScheme" "none"
[ 11.189] (**) Logitech Wireless Mouse: (accel) selected scheme none/0
[ 11.189] (**) Logitech Wireless Mouse: (accel) acceleration factor: 2.000
[ 11.189] (**) Logitech Wireless Mouse: (accel) acceleration threshold: 4
[ 11.202] (II) event1 - Logitech Wireless Mouse: is tagged by udev as: Mouse
[ 11.203] (II) event1 - Logitech Wireless Mouse: device is a pointer
[ 11.210] (II) config/udev: Adding input device Logitech Gamepad F710 (/dev/input/js0)
[ 11.210] (II) No input driver specified, ignoring this device.
[ 11.210] (II) This device may have been added with another device file.
[ 11.217] (II) config/udev: Adding input device Logitech Gamepad F710 (/dev/input/event2)
[ 11.217] (II) No input driver specified, ignoring this device.
[ 11.217] (II) This device may have been added with another device file.
[ 12.842] (II) modeset(0): EDID vendor "TCL", prod id 0
[ 12.842] (II) modeset(0): Using EDID range info for horizontal sync
[ 12.842] (II) modeset(0): Using EDID range info for vertical refresh
[ 12.842] (II) modeset(0): Printing DDC gathered Modelines:
[ 12.843] (II) modeset(0): Modeline "3840x2160"x0.0 297.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.5 kHz eP)
[ 12.843] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 12.843] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 12.843] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[ 12.843] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 12.843] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 12.843] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 3040 3080 3300 720 725 730 750 +hsync +vsync (22.5 kHz e)
[ 12.843] (II) modeset(0): Modeline "1280x720"x0.0 59.40 1280 3040 3080 3300 720 725 730 750 +hsync +vsync (18.0 kHz e)
[ 12.843] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 12.843] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 12.843] (II) modeset(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[ 12.843] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 12.843] (II) modeset(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 12.843] (II) modeset(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 12.843] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 12.843] (II) modeset(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 12.843] (II) modeset(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 12.844] (II) modeset(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 12.844] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 12.844] (II) modeset(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 12.844] (II) modeset(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 12.844] (II) modeset(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 12.844] (II) modeset(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 12.844] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 12.844] (II) modeset(0): Modeline "1280x800"x0.0 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[ 12.844] (II) modeset(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 12.844] (II) modeset(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 12.845] (--) modeset(0): HDMI max TMDS frequency 300000KHz
[ 56.034] (II) modeset(0): Disabling kernel dirty updates, not required.
[ 60.787] (II) modeset(0): EDID vendor "TCL", prod id 0
[ 60.787] (II) modeset(0): Using hsync ranges from config file
[ 60.787] (II) modeset(0): Using vrefresh ranges from config file
[ 60.787] (II) modeset(0): Printing DDC gathered Modelines:
[ 60.787] (II) modeset(0): Modeline "3840x2160"x0.0 297.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.5 kHz eP)
[ 60.787] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 60.787] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 60.787] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[ 60.787] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 60.787] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 60.788] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 3040 3080 3300 720 725 730 750 +hsync +vsync (22.5 kHz e)
[ 60.788] (II) modeset(0): Modeline "1280x720"x0.0 59.40 1280 3040 3080 3300 720 725 730 750 +hsync +vsync (18.0 kHz e)
[ 60.788] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 60.788] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 60.788] (II) modeset(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[ 60.788] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 60.788] (II) modeset(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 60.788] (II) modeset(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 60.788] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 60.788] (II) modeset(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 60.788] (II) modeset(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 60.788] (II) modeset(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 60.788] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 60.788] (II) modeset(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 60.788] (II) modeset(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 60.788] (II) modeset(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 60.788] (II) modeset(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 60.788] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 60.788] (II) modeset(0): Modeline "1280x800"x0.0 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[ 60.788] (II) modeset(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 60.788] (II) modeset(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 60.789] (--) modeset(0): HDMI max TMDS frequency 300000KHz
[ 62.451] (II) modeset(0): EDID vendor "TCL", prod id 0
[ 62.452] (II) modeset(0): Using hsync ranges from config file
[ 62.452] (II) modeset(0): Using vrefresh ranges from config file
[ 62.452] (II) modeset(0): Printing DDC gathered Modelines:
[ 62.452] (II) modeset(0): Modeline "3840x2160"x0.0 297.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.5 kHz eP)
[ 62.452] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 62.452] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 62.452] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[ 62.452] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 62.452] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 62.452] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 3040 3080 3300 720 725 730 750 +hsync +vsync (22.5 kHz e)
[ 62.452] (II) modeset(0): Modeline "1280x720"x0.0 59.40 1280 3040 3080 3300 720 725 730 750 +hsync +vsync (18.0 kHz e)
[ 62.452] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 62.452] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 62.452] (II) modeset(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[ 62.452] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 62.452] (II) modeset(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 62.452] (II) modeset(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 62.452] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 62.452] (II) modeset(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 62.452] (II) modeset(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 62.452] (II) modeset(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 62.452] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 62.452] (II) modeset(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 62.452] (II) modeset(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 62.452] (II) modeset(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 62.452] (II) modeset(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 62.452] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 62.452] (II) modeset(0): Modeline "1280x800"x0.0 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[ 62.452] (II) modeset(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 62.452] (II) modeset(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 62.453] (--) modeset(0): HDMI max TMDS frequency 300000KHz
[ 69.044] (EE) modeset(0): Failed to make 3840x2160x32bpp GBM bo
[ 69.045] (EE) modeset(0): Failed to make 3840x2160x32bpp GBM bo
[ 82.499] (EE) event1 - Logitech Wireless Mouse: client bug: event processing lagging behind by 72ms, your system is too slow
[ 83.765] (EE) event1 - Logitech Wireless Mouse: client bug: event processing lagging behind by 34ms, your system is too slow
[ 83.965] (EE) event1 - Logitech Wireless Mouse: client bug: event processing lagging behind by 42ms, your system is too slow
[ 84.899] (EE) event1 - Logitech Wireless Mouse: client bug: event processing lagging behind by 39ms, your system is too slow
[ 85.232] (EE) event1 - Logitech Wireless Mouse: client bug: event processing lagging behind by 37ms, your system is too slow
[ 85.232] (EE) event1 - Logitech Wireless Mouse: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 98.655] (EE) modeset(0): Failed to make 2176x1570x32bpp GBM bo
[ 98.679] (EE) modeset(0): Failed to make 2176x1570x32bpp GBM bo
[ 98.734] (EE) modeset(0): Failed to make 2176x1570x32bpp GBM bo
[ 100.752] (EE) modeset(0): Failed to make 2176x1570x32bpp GBM bo
[ 100.851] (EE) modeset(0): Failed to make 2176x1570x32bpp GBM bo
[ 100.941] (EE) modeset(0): Failed to make 2176x1570x32bpp GBM bo
[ 116.790] (EE) modeset(0): Failed to make 1779x1012x32bpp GBM bo
[ 116.802] (EE) modeset(0): Failed to make 1779x1012x32bpp GBM bo
[ 116.901] (EE) modeset(0): Failed to make 1779x1012x32bpp GBM bo
[ 117.077] (EE) modeset(0): Failed to make 1771x1012x32bpp GBM bo
[ 117.086] (EE) modeset(0): Failed to make 1771x1012x32bpp GBM bo
[ 117.149] (EE) modeset(0): Failed to make 1771x1012x32bpp GBM bo
[ 117.322] (EE) modeset(0): Failed to make 1760x1018x32bpp GBM bo
[ 117.332] (EE) modeset(0): Failed to make 1760x1018x32bpp GBM bo
[ 117.381] (EE) modeset(0): Failed to make 1760x1018x32bpp GBM bo
[ 117.532] (EE) modeset(0): Failed to make 1757x1022x32bpp GBM bo
[ 117.552] (EE) modeset(0): Failed to make 1757x1022x32bpp GBM bo
[ 117.687] (EE) modeset(0): Failed to make 1748x1029x32bpp GBM bo
[ 117.700] (EE) modeset(0): Failed to make 1748x1029x32bpp GBM bo
[ 117.841] (EE) modeset(0): Failed to make 1705x1062x32bpp GBM bo
[ 117.859] (EE) modeset(0): Failed to make 1705x1062x32bpp GBM bo
[ 117.929] (EE) modeset(0): Failed to make 1705x1062x32bpp GBM bo
[ 118.130] (EE) modeset(0): Failed to make 1546x1133x32bpp GBM bo
[ 118.178] (EE) modeset(0): Failed to make 1546x1133x32bpp GBM bo
[ 118.315] (EE) modeset(0): Failed to make 1469x1164x32bpp GBM bo
[ 118.362] (EE) modeset(0): Failed to make 1469x1164x32bpp GBM bo
[ 118.401] (EE) modeset(0): Failed to make 1469x1164x32bpp GBM bo
[ 118.527] (EE) modeset(0): Failed to make 1288x1259x32bpp GBM bo
[ 118.549] (EE) modeset(0): Failed to make 1288x1259x32bpp GBM bo
[ 118.610] (EE) modeset(0): Failed to make 1288x1259x32bpp GBM bo
[ 118.779] (EE) modeset(0): Failed to make 1169x1323x32bpp GBM bo
[ 118.799] (EE) modeset(0): Failed to make 1169x1323x32bpp GBM bo
[ 118.892] (EE) modeset(0): Failed to make 1106x1372x32bpp GBM bo
[ 118.912] (EE) modeset(0): Failed to make 1106x1372x32bpp GBM bo
[ 118.975] (EE) modeset(0): Failed to make 1106x1372x32bpp GBM bo
[ 119.120] (EE) modeset(0): Failed to make 950x1361x32bpp GBM bo
[ 119.146] (EE) modeset(0): Failed to make 950x1361x32bpp GBM bo
[ 119.201] (EE) modeset(0): Failed to make 950x1361x32bpp GBM bo
[ 123.400] (EE) modeset(0): Failed to make 1184x889x32bpp GBM bo
[ 123.411] (EE) modeset(0): Failed to make 1184x889x32bpp GBM bo
[ 123.583] (EE) modeset(0): Failed to make 1217x919x32bpp GBM bo
[ 123.603] (EE) modeset(0): Failed to make 1217x919x32bpp GBM bo
[ 123.671] (EE) modeset(0): Failed to make 1217x919x32bpp GBM bo
[ 123.881] (EE) modeset(0): Failed to make 1247x950x32bpp GBM bo
[ 123.909] (EE) modeset(0): Failed to make 1247x950x32bpp GBM bo
[ 124.092] (EE) modeset(0): Failed to make 1247x950x32bpp GBM bo
[ 124.195] (EE) modeset(0): Failed to make 1260x962x32bpp GBM bo
[ 124.214] (EE) modeset(0): Failed to make 1260x962x32bpp GBM bo
[ 124.294] (EE) modeset(0): Failed to make 1260x962x32bpp GBM bo
[ 124.451] (EE) modeset(0): Failed to make 1236x938x32bpp GBM bo
[ 124.492] (EE) modeset(0): Failed to make 1236x938x32bpp GBM bo
[ 124.532] (EE) modeset(0): Failed to make 1236x938x32bpp GBM bo
[ 124.694] (EE) modeset(0): Failed to make 1219x923x32bpp GBM bo
[ 124.707] (EE) modeset(0): Failed to make 1219x923x32bpp GBM bo
[ 124.801] (EE) modeset(0): Failed to make 1219x923x32bpp GBM bo
[ 124.905] (EE) modeset(0): Failed to make 1218x922x32bpp GBM bo
[ 124.921] (EE) modeset(0): Failed to make 1218x922x32bpp GBM bo
[ 124.973] (EE) modeset(0): Failed to make 1218x922x32bpp GBM bo
[ 125.155] (EE) modeset(0): Failed to make 1196x906x32bpp GBM bo
[ 125.163] (EE) modeset(0): Failed to make 1196x906x32bpp GBM bo
[ 125.244] (EE) modeset(0): Failed to make 1196x906x32bpp GBM bo
[ 125.365] (EE) modeset(0): Failed to make 1187x901x32bpp GBM bo
[ 125.389] (EE) modeset(0): Failed to make 1187x901x32bpp GBM bo
[ 125.460] (EE) modeset(0): Failed to make 1187x901x32bpp GBM bo
[ 125.637] (EE) modeset(0): Failed to make 1181x897x32bpp GBM bo
[ 125.652] (EE) modeset(0): Failed to make 1181x897x32bpp GBM bo
[ 126.064] (EE) modeset(0): Failed to make 1175x893x32bpp GBM bo
[ 126.079] (EE) modeset(0): Failed to make 1175x893x32bpp GBM bo
[ 126.152] (EE) modeset(0): Failed to make 1175x893x32bpp GBM bo
[ 126.306] (EE) modeset(0): Failed to make 1524x1061x32bpp GBM bo
[ 126.342] (EE) modeset(0): Failed to make 1524x1061x32bpp GBM bo
[ 126.504] (EE) modeset(0): Failed to make 1524x1061x32bpp GBM bo
[ 126.707] (EE) modeset(0): Failed to make 1985x1240x32bpp GBM bo
[ 126.721] (EE) modeset(0): Failed to make 1985x1240x32bpp GBM bo
[ 126.995] (EE) modeset(0): Failed to make 1985x1240x32bpp GBM bo
[ 127.069] (EE) modeset(0): Failed to make 1985x1240x32bpp GBM bo
[ 127.221] (EE) modeset(0): Failed to make 2104x1354x32bpp GBM bo
[ 127.302] (EE) modeset(0): Failed to make 2104x1354x32bpp GBM bo
[ 127.401] (EE) modeset(0): Failed to make 2104x1354x32bpp GBM bo
[ 127.609] (EE) modeset(0): Failed to make 2377x1534x32bpp GBM bo
[ 127.627] (EE) modeset(0): Failed to make 2377x1534x32bpp GBM bo
[ 127.701] (EE) modeset(0): Failed to make 2377x1534x32bpp GBM bo
[ 128.042] (EE) modeset(0): Failed to make 2377x1534x32bpp GBM bo
[ 128.149] (EE) modeset(0): Failed to make 2377x1534x32bpp GBM bo
[ 128.201] (EE) modeset(0): Failed to make 2377x1534x32bpp GBM bo
[ 128.492] (EE) modeset(0): Failed to make 2691x1727x32bpp GBM bo
[ 128.521] (EE) modeset(0): Failed to make 2691x1727x32bpp GBM bo
[ 128.713] (EE) modeset(0): Failed to make 2757x1821x32bpp GBM bo
[ 128.746] (EE) modeset(0): Failed to make 2757x1821x32bpp GBM bo
[ 128.837] (EE) modeset(0): Failed to make 2757x1821x32bpp GBM bo
[ 129.219] (EE) modeset(0): Failed to make 2757x1821x32bpp GBM bo
[ 129.456] (EE) modeset(0): Failed to make 2712x1865x32bpp GBM bo
[ 129.471] (EE) modeset(0): Failed to make 2712x1865x32bpp GBM bo
[ 129.533] (EE) modeset(0): Failed to make 2712x1865x32bpp GBM bo
[ 130.132] (EE) modeset(0): Failed to make 2712x1865x32bpp GBM bo
[ 130.502] (EE) modeset(0): Failed to make 2585x1804x32bpp GBM bo
[ 130.551] (EE) modeset(0): Failed to make 2585x1804x32bpp GBM bo
[ 130.990] (EE) modeset(0): Failed to make 2446x1722x32bpp GBM bo
[ 130.998] (EE) modeset(0): Failed to make 2446x1722x32bpp GBM bo
[ 131.403] (EE) modeset(0): Failed to make 2335x1653x32bpp GBM bo
[ 131.421] (EE) modeset(0): Failed to make 2335x1653x32bpp GBM bo
[ 131.671] (EE) modeset(0): Failed to make 2207x1583x32bpp GBM bo
[ 131.704] (EE) modeset(0): Failed to make 2207x1583x32bpp GBM bo
[ 132.170] (EE) modeset(0): Failed to make 2157x1521x32bpp GBM bo
[ 132.185] (EE) modeset(0): Failed to make 2157x1521x32bpp GBM bo
[ 132.353] (EE) modeset(0): Failed to make 2030x1411x32bpp GBM bo
[ 132.366] (EE) modeset(0): Failed to make 2030x1411x32bpp GBM bo
[ 132.566] (EE) modeset(0): Failed to make 1950x1344x32bpp GBM bo
[ 132.597] (EE) modeset(0): Failed to make 1950x1344x32bpp GBM bo
[ 132.709] (EE) modeset(0): Failed to make 1950x1344x32bpp GBM bo
[ 132.882] (EE) modeset(0): Failed to make 1857x1260x32bpp GBM bo
[ 132.905] (EE) modeset(0): Failed to make 1857x1260x32bpp GBM bo
[ 133.016] (EE) modeset(0): Failed to make 1857x1260x32bpp GBM bo
[ 133.290] (EE) modeset(0): Failed to make 1753x1199x32bpp GBM bo
[ 133.324] (EE) modeset(0): Failed to make 1753x1199x32bpp GBM bo
[ 133.558] (EE) modeset(0): Failed to make 1720x1159x32bpp GBM bo
[ 133.581] (EE) modeset(0): Failed to make 1720x1159x32bpp GBM bo
[ 133.735] (EE) modeset(0): Failed to make 1710x1119x32bpp GBM bo
[ 133.780] (EE) modeset(0): Failed to make 1710x1119x32bpp GBM bo
[ 133.834] (EE) modeset(0): Failed to make 1710x1119x32bpp GBM bo
[ 133.945] (EE) modeset(0): Failed to make 1668x1078x32bpp GBM bo
[ 133.957] (EE) modeset(0): Failed to make 1668x1078x32bpp GBM bo
[ 134.236] (EE) modeset(0): Failed to make 1630x1046x32bpp GBM bo
[ 134.252] (EE) modeset(0): Failed to make 1630x1046x32bpp GBM bo
[ 134.348] (EE) modeset(0): Failed to make 1630x1046x32bpp GBM bo
[ 134.537] (EE) modeset(0): Failed to make 1573x1016x32bpp GBM bo
[ 134.560] (EE) modeset(0): Failed to make 1573x1016x32bpp GBM bo
[ 134.641] (EE) modeset(0): Failed to make 1573x1016x32bpp GBM bo
[ 134.827] (EE) modeset(0): Failed to make 1525x986x32bpp GBM bo
[ 134.856] (EE) modeset(0): Failed to make 1525x986x32bpp GBM bo
[ 135.157] (EE) modeset(0): Failed to make 1488x955x32bpp GBM bo
[ 136.339] (II) event1 - Logitech Wireless Mouse: SYN_DROPPED event - some input events have been lost.
[ 136.348] (EE) modeset(0): Failed to make 1488x955x32bpp GBM bo
[ 136.506] (EE) modeset(0): Failed to make 1458x915x32bpp GBM bo
[ 136.510] (EE) modeset(0): Failed to make 1458x915x32bpp GBM bo
[ 137.877] (EE) modeset(0): Failed to make 1458x915x32bpp GBM bo
[ 137.958] (EE) modeset(0): Failed to make 1458x915x32bpp GBM bo
[ 138.031] (EE) modeset(0): Failed to make 1458x915x32bpp GBM bo
[ 138.106] (EE) modeset(0): Failed to make 1458x915x32bpp GBM bo
[ 140.104] (EE) modeset(0): Failed to make 1458x915x32bpp GBM bo
[ 140.170] (EE) modeset(0): Failed to make 1458x915x32bpp GBM bo
[ 298.286] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 298.363] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 298.399] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 298.464] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 298.670] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 298.815] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 299.012] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 299.138] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 299.210] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 299.356] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 300.919] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 301.049] (EE) client bug: timer event1 debounce short: scheduled expiry is in the past (-7ms), your system is too slow
[ 301.051] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 301.126] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 301.274] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 301.352] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 301.527] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 301.602] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 301.715] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 301.773] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 302.043] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 302.089] (EE) client bug: timer event1 debounce: scheduled expiry is in the past (-18ms), your system is too slow
[ 302.100] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 302.163] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 302.214] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 302.401] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 302.464] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 302.538] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 302.603] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 302.665] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 302.697] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 302.731] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 302.765] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 303.072] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 303.137] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 303.201] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 303.267] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 303.344] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 303.410] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 303.643] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 304.570] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 304.618] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 304.704] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 304.907] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 304.969] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 306.540] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 306.602] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 306.635] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 306.668] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 306.701] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 306.734] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 306.768] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 306.801] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 307.471] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 308.493] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 308.571] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 308.801] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 308.877] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 309.031] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 309.106] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 309.267] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 309.334] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 310.347] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 310.434] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 310.566] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 310.732] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 310.810] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 310.944] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 311.031] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 311.230] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 311.816] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 311.943] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 312.012] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 312.121] (EE) modeset(0): Failed to make 3840x2130x32bpp GBM bo
[ 437.000] (EE) event0 - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 32ms, your system is too slow
Try changing the resolution in the /boot/config.txt with HDMI modes. Seems like your screen resolution is not supported by default.
I changed it to 1920x1080 and so far it seems to work and I updated to the newest packages as of today.
I have same issue just flashed image for Pi 4B I see cursor nothing else. 45’ 4K LG TV what should I put in config.txt ? I think it’s trying to go to 4096x2160 many Distros do dunno why… First time I have that issue… So no idea… I want to keep it at 1080p … 4K too small …
hdmi_mode:0=16
hdmi_group:0=1
hdmi_force_mode:0=1
hdmi_ignore_edid:0=0xa5000080
I was able to get to desktop but nothing opens except gtk apps… Settings, Konsole nothing opens… Am updating now to see if this helps. Also resolution was 1080p only on login but once logged in it goes to 4K. With settings not opening I can’t change it xD
EDIT : Now after update/reboot I cannot use my Keyboard and mouse… WTF!!!
